Top Home & Outdoor Security Cameras with Spotlight & Edge AI
Best Home and Outdoor Security Cameras with Built-in Spotlight and Edge AI
When it comes to securing your home and outdoor spaces, having a reliable security camera with advanced features like built-in spotlights and edge AI can make all the difference. These cameras not only provide crystal-clear video but also enhance safety with smart lighting and intelligent detection. Below, we explore the top Wyze security cameras designed to keep your property safe day and night, featuring built-in spotlights, AI-powered tracking, and robust weather resistance.
Wyze Cam v4 – Ultimate Clarity and Smart Spotlight Security
Wyze Cam v4 stands out as the clearest Wyze camera ever made, delivering stunning 2.5K Quad High Definition (QHD) video resolution. This camera is perfect for both indoor and outdoor use, thanks to its IP65 weather resistance rating, allowing it to withstand rain, snow, and harsh weather conditions.
Key Features:
  • 2.5K QHD Resolution: Capture every detail with crystal-clear video quality.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions, surpassing traditional black-and-white night vision.
  • Motion-Activated Spotlight & Siren: The built-in spotlight automatically lights up when motion is detected, deterring intruders, while the 99 dB siren adds an extra layer of security.
  • 24/7 Local Recording: Supports continuous recording to a microSD card (up to 256GB) without subscription fees.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Auto-Zoom with AI: Edge AI enables smart focus and tracking of important events, so you never miss a thing.
  • Easy Installation: Screw-free magnetic mount for quick setup without tools.
Wyze Cam v4 is available in multiple colors and pack sizes, making it easy to customize your security setup. Wyze Cam v4 Outdoor Security Wyze Cam v4 installed outdoors providing smart home security with spotlight and AI detection.
Wyze Cam Pan v3 – 360° Pan, Tilt, and AI Motion Tracking
For those who want comprehensive coverage with intelligent tracking, the Wyze Cam Pan v3 is an excellent choice. This camera offers a full 360° pan and 180° tilt, allowing you to monitor every corner of your property with a single device.
Key Features:
  • IP65 Weather Resistance: Designed for outdoor use with the Wyze Outdoor Power Adapter (sold separately).
  • Automatic Motion Tracking: The camera detects motion and quietly follows the subject, ensuring continuous monitoring.
  • 360° Pan & 180° Tilt: Covers wide areas with smooth, quiet motorized movement.
  • Color Night Vision: Equipped with a Starlight Sensor for vivid nighttime images.
  • Two-Way Audio: Communicate through the camera with built-in microphone and speaker.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward when privacy is needed.
  • Custom Detection Zones: Focus alerts on specific areas to reduce false alarms.
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This camera is perfect for users who want dynamic coverage and smart AI features in a weatherproof design. Wyze Cam Pan v3 in Snowy Outdoor Setting Wyze Cam Pan v3 providing 360° outdoor surveillance in all weather conditions.
Wyze Cam Floodlight v2 – Powerful Lighting Meets 2K Security
If you need a security camera that doubles as a powerful floodlight, the Wyze Cam Floodlight v2 is the ideal solution. It combines bright illumination with smart AI-powered light control and 2K video quality.
Key Features:
  • 2800 Lumens LED Floodlights: Two dimmable LED panels provide bright, adjustable lighting to illuminate large outdoor areas.
  • 2K Video Resolution: Crisp 2304 x 1296 video with a 160° wide-angle field of view.
  • Color Night Vision: See clear, colorful images even in the dark.
  • AI-Powered Light Control: Automatically adjusts lighting based on ambient conditions and motion detection.
  • Dusk-to-Dawn Automation: Lights turn on and off automatically based on natural light levels.
  • 105 dB Siren & Two-Way Audio: Built-in speaker and microphone allow communication and deterrence.
  • IP65 Weather Resistance: Built to withstand outdoor elements year-round.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for seamless control.
  • Local Storage: Supports up to 256GB microSD card for continuous recording.
This floodlight camera is perfect for driveways, garages, and front porches where bright lighting and security are essential. Wyze Cam Floodlight v2 Lighting Driveway Wyze Cam Floodlight v2 illuminating a driveway with smart motion detection and AI lighting.
Wyze Cam OG – Compact Spotlight Camera with Fast Streaming
The Wyze Cam OG is the next generation of Wyze’s popular spotlight camera, offering faster live streaming and improved two-way audio. It features a built-in 40-lumen spotlight and a 90-decibel siren for enhanced security.
Key Features:
  • 1080p Full HD Video: Clear video with a 120° field of view.
  • Built-in Spotlight: 40 lumens of light to illuminate dark areas on demand.
  • 90 dB Siren: User-activated siren to deter unwanted visitors.
  • Improved Two-Way Audio: Enhanced microphone and speaker for clear communication.
  • Fast Live Streaming: 50% faster than previous Wyze cameras.
  • IP65 Weather Resistance: Suitable for indoor and outdoor use.
  • Custom Detection Zones: Tailor motion alerts to your needs.
  • Smoke and CO Alerts: Receive notifications if alarms are detected.
  • Local Storage: Supports microSD cards up to 256GB.
This camera is a great choice for users seeking a compact, affordable spotlight camera with reliable performance.
Why Choose Wyze Security Cameras with Built-in Spotlight and Edge AI?
"Smart security cameras with built-in spotlights and edge AI provide proactive protection by illuminating potential threats and intelligently focusing on important events, ensuring your home and outdoor spaces are safe around the clock."
Wyze cameras combine advanced AI features, high-resolution video, and integrated lighting to deliver superior security. Whether you want wide-area coverage with the Pan v3, powerful illumination with the Floodlight v2, or the crystal-clear detail of the Cam v4, Wyze offers versatile options to fit your security needs.
Summary of Top Features
Camera ModelResolutionSpotlightAI FeaturesWeather ResistanceAudioSpecial Features
Wyze Cam v42.5K QHDYesAuto-Zoom, Edge AIIP65Enhanced 2-WayWi-Fi 6, 24/7 local recording
Wyze Cam Pan v31080pNoMotion TrackingIP652-Way Audio360° Pan & 180° Tilt
Wyze Cam Floodlight v22KYesAI Light ControlIP652-Way Audio2800 Lumens Floodlight, Siren
Wyze Cam OG1080pYesBasic AI DetectionIP65Improved 2-WayFast streaming, 90 dB siren
Choose the best Wyze security camera with built-in spotlight and edge AI to protect your home and outdoor spaces with smart, reliable technology.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam Floodlight v2Wyze Cam OGWyze Cam v4 Home Security Bundle
Video Resolution2.5K QHD (2560x1440)Not specified (assumed 1080p+)2K (2304x1296)1080p (1920x1080)2.5K QHD (2560x1440)
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt160° diagonal120° diagonalDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionEnhanced Color Night Vision + IR LEDsColor Night Vision (Starlight Sensor)Color Night Vision4 IR LEDs (850nm)4 IR LEDs + 2 white spotlight LEDs (72 lumens)
AudioEnhanced 2-way talk, 99dB sirenTwo-way audioBuilt-in speaker & mic, 2-way talkBuilt-in speaker & mic, noise & echo cancellationImproved 2-way audio, built-in siren
SpotlightMotion-activated spotlightNo2 dimmable LED light panelsBuilt-in spotlight (40 lumens)Motion-activated spotlight
SirenYes, 99dBNo105dB90dB user-activated sirenYes
Weather ResistanceIP65IP65IP65IP65IP65
Power SourceWired (Indoor USB power adapter included)Wired (Outdoor adapter sold separately)HardwiredWired (Indoor power adapter)Wired (Indoor power adapter)
Wi-Fi Support2.4 GHz & Wi-Fi 62.4 GHz2.4 GHz2.4 GHz2.4 GHz & Wi-Fi 6
Local StoragemicroSD up to 512GB (sold separately)microSD up to 256GB (sold separately)microSD up to 256GBmicroSD up to 256GBmicroSD 128GB included
Cloud StorageSubscription availableSubscription availableNot specifiedNot specifiedNot specified
Motion & Sound DetectionYesYesYesYesYes
Motion Detection ZonesYesYesNot specifiedYesYes
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Dimensions2in x 2in x 2 3/8in (51 x 51 x 60 mm)Not specified9.5in x 7.7in x 7.0in (24.13 x 19.56 x 17.78 cm)1.89in x 1.89in x 1.89in (48 mm)2in x 2in x 2 3/8in (51 x 51 x 60 mm)
Weight0.49 lb (222 g)Not specified2.76 lbs (1.25 kg)4.1 oz (116 g)0.49 lb (222 g)
Additional FeaturesAI Auto-Zoom, Bluetooth 5.2, Wide Dynamic Range (WDR), Smoke & CO alertsAuto motion-tracking, Privacy Mode, Pan Scan™ Patrol, Smoke & CO alertsAmbient Light Mode, AI-Powered Light Control, Dusk-to-Dawn automation3X faster notifications, built-in spotlightBundle includes Wyze Cam v4, Outdoor Power Adapter, 128GB microSD card
Price (Single Unit)$35.98$39.98$89.98$29.98$169.99 (bundle)
What are the best Wyze security cameras with built-in spotlight and edge AI?The best Wyze security cameras with built-in spotlight and edge AI include the Wyze Cam v4, Wyze Cam Floodlight v2, and Wyze Cam OG. These models offer advanced features such as high-resolution video, smart lighting, AI-powered detection, and robust weather resistance for comprehensive home and outdoor security.
What makes the Wyze Cam v4 ideal for home and outdoor security?The Wyze Cam v4 is ideal for home and outdoor security due to its 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight and siren, 24/7 local recording, Wi-Fi 6 support, edge AI for smart tracking, and IP65 weather resistance. Its easy installation and compatibility with smart assistants make it a versatile choice.
Does the Wyze Cam v4 support continuous local recording?Yes, the Wyze Cam v4 supports 24/7 continuous local recording to a microSD card (up to 256GB) without requiring a subscription, ensuring you never miss important events.
What are the key features of the Wyze Cam Pan v3?The Wyze Cam Pan v3 features 360° pan and 180° tilt for full coverage, automatic motion tracking, color night vision, two-way audio, privacy mode, custom detection zones, IP65 weather resistance (with outdoor power adapter), and smart assistant integration for dynamic and intelligent surveillance.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is suitable for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately). It has an IP65 weather resistance rating, making it durable in various weather conditions.
How does the Wyze Cam Floodlight v2 enhance outdoor security?The Wyze Cam Floodlight v2 enhances outdoor security with 2800 lumens of dimmable LED floodlights, 2K video resolution, color night vision, AI-powered light control, dusk-to-dawn automation, a 105 dB siren, two-way audio, IP65 weather resistance, and support for local storage up to 256GB.
Can I use Wyze security cameras with Alexa or Google Assistant?Yes, Wyze security cameras including the Cam v4, Cam Pan v3, Floodlight v2, and Cam OG are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration and voice control.
What is the difference between Wyze Cam v4 and Wyze Cam OG?Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, Wi-Fi 6, edge AI, and a motion-activated spotlight and siren. Wyze Cam OG features 1080p HD video, a 40-lumen built-in spotlight, 90 dB siren, improved two-way audio, fast live streaming, and basic AI detection. Both are IP65 weather resistant and support local storage.
Do Wyze security cameras require a subscription for recording?No, Wyze security cameras such as the Cam v4, Cam Pan v3, Floodlight v2, and Cam OG support local recording to a microSD card (up to 256GB) without requiring a subscription, allowing for continuous video storage.
Are Wyze security cameras weather resistant?Yes, Wyze security cameras including the Cam v4, Cam Pan v3, Floodlight v2, and Cam OG are rated IP65 for weather resistance, making them suitable for both indoor and outdoor use in various weather conditions.
What is edge AI in Wyze security cameras?Edge AI in Wyze security cameras refers to on-device artificial intelligence that enables features like smart motion detection, auto-zoom, and intelligent event tracking. This allows the camera to process and respond to events in real time without relying solely on cloud services.
How does color night vision work in Wyze cameras?Color night vision in Wyze cameras uses advanced sensors and image processing to capture vibrant, full-color video even in low-light conditions, providing clearer and more detailed nighttime footage compared to traditional black-and-white night vision.
Can I customize motion detection zones on Wyze cameras?Yes, Wyze cameras such as the Cam Pan v3 and Cam OG allow you to set custom detection zones, so you can focus motion alerts on specific areas and reduce false alarms.
What are the key features of the Wyze Cam v4?How does the edge AI technology work in Wyze security cameras?Are there any ongoing promotions or discounts for Wyze cameras?
