Best Home Security Cameras with Built-In Motion Spotlight
When it comes to protecting your home, having a reliable security camera with a built-in motion spotlight is essential. These cameras not only capture crystal-clear video but also illuminate suspicious activity instantly, deterring intruders and keeping your property safe day and night. Below, we highlight the top Wyze security cameras featuring integrated motion spotlights, advanced night vision, and smart home compatibility to help you choose the perfect fit for your home security needs.
Wyze Cam v4 – The Ultimate Motion Spotlight Camera
Wyze Cam v4 stands out as the clearest and most advanced Wyze camera yet, designed to provide unmatched security with its built-in motion-activated spotlight.
Key Features:
  • 2.5K QHD Resolution: Capture stunningly detailed video with Quad HD clarity, ensuring you never miss a detail.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to upgraded hardware that outperforms traditional night vision.
  • Motion-Activated Spotlight & Siren: Automatically lights up when motion is detected, deterring unwanted visitors. The integrated 99 dB siren adds an extra layer of protection.
  • 24/7 Local Recording: Supports continuous recording to a microSD card (up to 256GB) without any subscription fees.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection for seamless streaming and alerts.
  • Smart Assistant Compatibility: Works effortlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Weather Resistant (IP65): Perfect for indoor or outdoor use, built to withstand rain, snow, and harsh weather.
  • Easy Setup & Mounting: Screw-free magnetic mount and Bluetooth® setup make installation quick and hassle-free.
"Wyze Cam v4 gives your home superhero vision with its enhanced color night vision and motion spotlight."
Ideal For:
Homeowners seeking a versatile, high-resolution camera with powerful night-time illumination and smart home integration. Wyze Cam v4 in action illuminating a driveway at night
Wyze Cam Pan v3 – 360° Pan with Motion Spotlight
For those who want full coverage with a built-in spotlight, the Wyze Cam Pan v3 offers a dynamic security solution with pan, tilt, and motion tracking.
Key Features:
  • 360° Pan & 180° Tilt: Covers every angle of your property with smooth, quiet motorized movement.
  • Automatic Motion Tracking: The camera detects and follows moving objects automatically, ensuring nothing escapes its view.
  • IP65 Weather Resistance: Designed for both indoor and outdoor use when paired with the Wyze Outdoor Power Adapter.
  • Color Night Vision: See clear, colorful images even in the dark with the Starlight Sensor.
  • Motion-Activated Spotlight: Lights up areas when motion is detected to deter intruders and improve video clarity.
  • Two-Way Audio: Communicate directly through the camera using the Wyze app.
  • Custom Detection Zones: Focus alerts on specific areas to reduce false alarms.
  • Privacy Mode: Easily disable the camera’s view when you want privacy by pointing it downward.
"Wyze Cam Pan v3 patrols your property with 360° coverage and lights up suspicious activity instantly."
Ideal For:
Users who want comprehensive coverage with pan and tilt capabilities plus a built-in spotlight for enhanced security. Wyze Cam Pan v3 mounted outdoors in snowy weather
Wyze Cam OG – Reliable Spotlight Security at an Affordable Price
The Wyze Cam OG is a solid choice for those looking for a dependable security camera with a built-in spotlight and quick live streaming.
Key Features:
  • 1080p Full HD Video: Clear and smooth video quality for everyday monitoring.
  • Built-In 40 Lumen Spotlight: Bright enough to illuminate dark areas and alert intruders.
  • 90 dB User-Activated Siren: Scare off unwanted visitors with a loud siren.
  • Color Night Vision: Equipped with 4 IR LEDs and a CMOS Starlight Sensor for vivid night images.
  • Two-Way Audio: Enhanced microphone and speaker for clear communication.
  • IP65 Weather Resistance: Suitable for indoor and outdoor use.
  • Fast Live Streaming: 50% faster than previous Wyze models for real-time monitoring.
  • Custom Detection Zones & Alerts: Tailor your notifications to focus on important areas.
"Wyze Cam OG combines affordability with essential spotlight security features."
Ideal For:
Budget-conscious users who want a reliable camera with spotlight and siren features for both indoor and outdoor use.
Wyze Cam v4 Home Security Bundle – Complete Protection Package
For those looking to secure multiple areas, the Wyze Cam v4 Home Security Bundle offers great value with multiple cameras and accessories.
Bundle Highlights:
  • Includes multiple Wyze Cam v4 units with all the advanced features: 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, and siren.
  • Comes with a 128GB microSD card for extensive local storage.
  • Multiple mounting options including magnetic and wall mounts.
  • Ideal for comprehensive home coverage with consistent performance and smart home integration.
"The Wyze Cam v4 Home Security Bundle is perfect for full-home protection with spotlight security."
Why Choose a Security Camera with Built-In Motion Spotlight?
A built-in motion spotlight is a game-changer for home security cameras. It not only improves video clarity in low light but also acts as a deterrent by illuminating potential threats immediately. This feature enhances your peace of mind by making your home less attractive to intruders and providing clear evidence if an incident occurs.
Conclusion
For the best home security camera with a built-in motion spotlight, Wyze offers several excellent options tailored to different needs:
  • Wyze Cam v4 for the clearest video and advanced spotlight features.
  • Wyze Cam Pan v3 for full 360° coverage with motion tracking and spotlight.
  • Wyze Cam OG for affordable, reliable spotlight security.
  • Wyze Cam v4 Home Security Bundle for multiple-camera setups with all premium features.
Each camera is weather-resistant, supports two-way audio, and integrates seamlessly with smart home systems, making them top choices for protecting your home day and night.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam OGWyze Cam v4 Home Security Bundle
Video Resolution2.5K QHD (2560x1440)Not specified (assumed 1080p)1080p (1920x1080)2.5K QHD (2560x1440)
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt120°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionEnhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs)Color Night Vision with Starlight Sensor4 IR LEDs (850nm), B&W Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
AudioEnhanced 2-way talk, 99dB siren, noise & echo cancellationTwo-way audioBuilt-in speaker & mic; noise & echo cancellationImproved 2-way audio, siren
Weather ResistanceIP65IP65IP65IP65
Power SourceWired (Indoor adapter included; outdoor adapter sold separately)Wired (Outdoor adapter sold separately)WiredWired
Local StoragemicroSD up to 512GB (sold separately)microSD support (up to 256GB)microSD up to 256GBmicroSD 128GB included
Wi-Fi Support2.4 GHz & Wi-Fi 6Not specified2.4 GHz (802.11 b/g/n)2.4 GHz & Wi-Fi 6
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Special FeaturesMotion-activated spotlight, AI auto-zoom & tracking, smoke & CO alerts, motion detection zones360° pan & 180° tilt, motion tracking, privacy mode, custom detection zones, smoke & CO alertsFaster live streaming, 3x faster notifications, built-in spotlightBundle includes 3 cameras, improved 2-way audio, motion-activated spotlight, smoke & CO alerts
Dimensions2in x 2in x 2 3/8inNot specified1.89in x 1.89in x 1.89in2in x 2in x 2 3/8in
Weight0.49 lb (222 g)Not specified4.1 oz (116 g)0.49 lb (222 g)
Price$35.98 (1 pack)$39.98 (1 pack)$29.98 (1 pack)$169.99 (bundle)
What are the benefits of a home security camera with a built-in motion spotlight?A home security camera with a built-in motion spotlight improves video clarity in low-light conditions and acts as a strong deterrent by instantly illuminating suspicious activity. This feature helps scare off intruders, provides clear evidence if an incident occurs, and enhances your overall peace of mind.
Which Wyze security camera offers the clearest video quality with a motion spotlight?The Wyze Cam v4 offers the clearest video quality with its 2.5K QHD resolution and built-in motion-activated spotlight. It also features enhanced color night vision, a 99 dB siren, and seamless smart home integration.
Does the Wyze Cam v4 support continuous local recording without a subscription?Yes, the Wyze Cam v4 supports 24/7 continuous local recording to a microSD card (up to 256GB) without requiring any subscription fees.
Can Wyze security cameras with spotlights be used outdoors?Yes, Wyze security cameras such as the Wyze Cam v4, Wyze Cam Pan v3, and Wyze Cam OG are IP65 weather-resistant, making them suitable for both indoor and outdoor use, even in rain or snow.
What smart home systems are Wyze security cameras compatible with?Wyze security cameras with built-in motion spotlights are compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
Which Wyze camera is best for 360-degree coverage with a motion spotlight?The Wyze Cam Pan v3 is ideal for 360-degree coverage, offering 360° pan and 180° tilt, automatic motion tracking, and a built-in motion-activated spotlight for comprehensive security.
Is there an affordable Wyze security camera with a built-in spotlight?Yes, the Wyze Cam OG is a budget-friendly option that features a built-in 40 lumen spotlight, 1080p Full HD video, color night vision, and a user-activated siren.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 units, a 128GB microSD card for local storage, and various mounting options. It’s designed for comprehensive home coverage with all the advanced features of the Wyze Cam v4.
Do Wyze security cameras offer two-way audio?Yes, all featured Wyze security cameras with built-in motion spotlights, including the Wyze Cam v4, Wyze Cam Pan v3, and Wyze Cam OG, offer two-way audio for direct communication through the Wyze app.
How easy is it to install Wyze security cameras with motion spotlights?Wyze security cameras are designed for easy installation, with features like screw-free magnetic mounts and Bluetooth® setup for quick and hassle-free mounting.
What are the key features of the Wyze Cam v4?How does the motion-activated spotlight work on the Wyze cameras?Are there any ongoing promotions or discounts for Wyze cameras?
