Wyze Battery Cam Pro: Affordable Security with Smart Detection
Budget-Friendly Wyze Battery Cam Pro with Advanced Detection Algorithms
Looking for a reliable, budget-friendly security camera that offers advanced detection algorithms to reduce false alerts? The Wyze Battery Cam Pro is your perfect choice. Designed with cutting-edge Radar + PIR motion detection technology, this camera ensures precise and early detection of real threats while minimizing unnecessary notifications. Whether you want to secure your home, RV, or outdoor space, Wyze Battery Cam Pro delivers pro-grade protection without breaking the bank.
Wyze Battery Cam Pro: Features & Benefits
High-Resolution Video & Smart Detection
  • 2.5K HDR Video Resolution: Capture crystal-clear footage with vibrant colors and balanced lighting, day or night.
  • Radar + PIR Motion Detection: Combines radar and passive infrared sensors for superior motion detection accuracy, drastically reducing false alerts caused by pets, shadows, or weather.
  • Custom Detection Zones: Tailor your camera’s detection areas via the Wyze app to focus on critical spots and avoid irrelevant motion triggers.
  • Cam Plus Compatibility: Upgrade to Cam Plus for enhanced smart detections including person, package, and vehicle notifications.
Wire-Free & Weatherproof Design
  • Wire-Free Setup: No need for power outlets or hubs; install anywhere with ease.
  • IP65 Weatherproof Rating: Built to withstand rain, dust, and extreme temperatures, perfect for outdoor use.
  • Dual-Band Wi-Fi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for faster, more reliable streaming.
Flexible Power Options
  • Removable, Rechargeable Battery Packs: Hot-swap batteries to keep your camera running without downtime.
  • Optional Solar Panel: Extend battery life indefinitely by powering your camera with solar energy.
  • Battery Life: Each 6200mAh battery can last up to 6 months on a single charge, depending on usage.
Additional Features
  • Integrated Spotlight & Siren: Motion-activated 150-lumen LED spotlight and siren deter intruders effectively.
  • Two-Way Audio: Built-in microphone and speaker allow you to communicate through the camera.
  • Local Storage: Supports microSD cards for local recording without subscription fees.
Wyze Battery Cam Pro + Solar Panel Bundle
For those seeking continuous power without the hassle of frequent recharging, the Wyze Battery Cam Pro + Solar Panel bundle is an excellent option. This bundle includes the Wyze Battery Cam Pro and a weather-resistant solar panel that converts sunlight into power, keeping your camera charged and operational for longer periods.
Why Choose the Solar Panel Bundle?
  • Continuous Power Supply: Solar panel provides sustainable energy, reducing the need to manually recharge batteries.
  • Easy Installation: Mount the solar panel anywhere with the included hardware and enjoy hassle-free power.
  • Weather Resistant: IP65 rating ensures durability in all weather conditions.
  • Same Advanced Detection Features: Enjoy all the smart detection benefits of the Battery Cam Pro with added power convenience.
Essential Accessories to Enhance Your Wyze Battery Cam Pro
Wyze Removable Battery Pack
  • 6200mAh Capacity: Long-lasting lithium-ion battery designed specifically for the Battery Cam Pro.
  • USB-C Charging: Convenient and fast charging with a built-in USB-C port.
  • Up to 6 Months Battery Life: Depending on usage, one charge can last half a year.
  • Lightweight & Compact: Easy to swap and carry.
Wyze Battery Charging Dock
  • Charge Two Batteries Simultaneously: Keep multiple batteries ready to go with this dual charging dock.
  • Compact Design: Small footprint fits easily on any desk or shelf.
  • Fast Charging: Fully charges batteries in approximately 8.5 hours.
"Wyze Battery Cam Pro combines affordability with advanced detection technology, making it the ideal choice for anyone wanting smart, reliable home security without the premium price tag."
Summary
The Wyze Battery Cam Pro stands out as a budget-friendly security camera packed with advanced features like Radar + PIR motion detection to reduce false alerts, 2.5K HDR video quality, and flexible power options including removable batteries and solar charging. For extended power autonomy, the Wyze Battery Cam Pro + Solar Panel bundle offers a sustainable solution. Complement your setup with essential accessories like the Wyze Removable Battery Pack and Wyze Battery Charging Dock to maximize uptime and convenience. Protect your home or outdoor space smartly and affordably with Wyze’s innovative battery-powered cameras.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery PackWyze Battery Charging Dock
TypeCameraCamera BundleAccessoryAccessory
Price$89.98 (1 Pack)$109.98$22.99$17.99
Video Resolution2.5K HDR2.5K HDRN/AN/A
Power SourceRemovable, Rechargeable BatteryRemovable, Rechargeable Battery + Solar PanelReplacement 6200mAh Lithium Ion BatteryCharges up to two batteries simultaneously
Battery CapacityIncluded battery packsIncluded battery packs6200 mAhN/A
Battery TypeLithium IonLithium IonLithium IonN/A
Charging MethodUSB-C charging (battery packs removable)USB-C charging (battery packs removable)USB-C charging port built-inUSB-A to USB-C power cable included
Charging TimeApprox. 9 hours (battery pack)Approx. 9 hours (battery pack)Approx. 9 hours at 25°CApprox. 8.5 hours at 25°C
Weatherproof RatingIP65IP65N/AN/A
Wi-Fi Support2.4 & 5 GHz dual-band2.4 & 5 GHz dual-bandN/AN/A
Motion DetectionRadar + PIRRadar + PIRN/AN/A
Integrated Spotlight & SirenYesYesN/AN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/AN/A
Mounting OptionsFlexible, includes ceiling mount optionFlexible, includes ceiling mount optionN/AN/A
Additional FeaturesWire-free, no hub required, Bluetooth setupSolar panel for continuous powerReplacement battery for Battery Cam Pro & Duo Cam DoorbellCharges two batteries simultaneously
WeightNot specifiedNot specified3.9 oz (110 g)2.75 oz (78 g)
DimensionsNot specifiedNot specified2.9 in x 1.6 in x 0.9 in (75 x 40 x 22 mm)Charging Dock: 2.6in x 2in x 1in (58x52x26mm)
CompatibilityWyze Battery Cam ProWyze Battery Cam ProWyze Battery Cam Pro, Wyze Duo Cam DoorbellWyze Battery Cam Pro battery packs
What is the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is a budget-friendly, wire-free security camera featuring advanced Radar + PIR motion detection algorithms, 2.5K HDR video resolution, and flexible power options. It is designed for reliable home, RV, or outdoor security without the high price tag.
How does the Wyze Battery Cam Pro reduce false alerts?The Wyze Battery Cam Pro uses a combination of radar and passive infrared (PIR) sensors to accurately detect real threats while minimizing false alerts caused by pets, shadows, or weather conditions.
What video quality does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro captures footage in 2.5K HDR resolution, providing crystal-clear video with vibrant colors and balanced lighting both day and night.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, making it suitable for outdoor use in rain, dust, and extreme temperatures.
Can I use the Wyze Battery Cam Pro without wires?Absolutely. The Wyze Battery Cam Pro is completely wire-free, allowing you to install it anywhere without the need for power outlets or hubs.
What are the power options for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro uses removable, rechargeable 6200mAh battery packs that can last up to 6 months per charge, depending on usage. You can also use an optional solar panel for continuous, sustainable power.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the Wyze Battery Cam Pro camera and a weather-resistant solar panel, providing continuous power and reducing the need for manual battery recharging.
Does the Wyze Battery Cam Pro support local storage?Yes, the Wyze Battery Cam Pro supports local storage via microSD cards, allowing you to record and store footage without subscription fees.
What smart detection features are available with Wyze Cam Plus?With a Cam Plus subscription, the Wyze Battery Cam Pro offers enhanced smart detections, including person, package, and vehicle notifications.
Can I customize motion detection zones on the Wyze Battery Cam Pro?Yes, you can set custom detection zones through the Wyze app to focus on specific areas and avoid irrelevant motion triggers.
What accessories are available for the Wyze Battery Cam Pro?Essential accessories include the Wyze Removable Battery Pack (6200mAh capacity, USB-C charging) and the Wyze Battery Charging Dock, which can charge two batteries simultaneously for maximum uptime.
Does the Wyze Battery Cam Pro have two-way audio?Yes, the Wyze Battery Cam Pro features built-in two-way audio, allowing you to communicate through the camera using its microphone and speaker.
How long does it take to charge the Wyze Battery Cam Pro batteries?Using the Wyze Battery Charging Dock, you can fully charge two batteries in approximately 8.5 hours.
Does the Wyze Battery Cam Pro have a spotlight and siren?Yes, the camera includes a motion-activated 150-lumen LED spotlight and a built-in siren to help deter intruders.
Is the Wyze Battery Cam Pro compatible with both 2.4 GHz and 5 GHz Wi-Fi networks?Yes, the Wyze Battery Cam Pro supports dual-band Wi-Fi, allowing it to connect to both 2.4 GHz and 5 GHz networks for faster and more reliable streaming.
What are the specific features of the Wyze Battery Cam Pro that help reduce false alerts?Can you explain how the Radar + PIR motion detection technology works in the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
