Wyze Battery Cam Pro: Smart Alerts with Person, Pet, and Vehicle Detection
The
Wyze Battery Cam Pro is a cutting-edge wireless security camera designed to keep your home safe with intelligent alerts that differentiate between people, pets, and vehicles. Featuring 2.5K HDR video resolution, this camera captures crystal-clear footage day and night, ensuring you never miss a detail.
Advanced Motion Detection Technology
Wyze Battery Cam Pro combines radar and PIR (Passive Infrared) sensors to create a motion detection powerhouse. This dual-sensor system enables earlier and more precise detection of movement, reducing false alarms and providing smart notifications tailored to what matters most:
- Person Detection: Receive alerts only when a person is detected, avoiding unnecessary notifications.
- Pet Detection: Know when your furry friends are active without confusing them with intruders.
- Vehicle Detection: Stay informed about cars entering or leaving your property.
Custom detection zones can be set in the Wyze app, allowing you to focus monitoring on specific areas like driveways or doorways.
Wire-Free and Weatherproof Design
Say goodbye to complicated wiring and hubs. The Wyze Battery Cam Pro is completely wire-free and weatherproof with an IP65 rating, making it perfect for indoor or outdoor use in any climate. Its removable, rechargeable battery packs allow for easy hot-swapping, so your security never goes offline.
Integrated Spotlight and Siren
Enhance your home security with a built-in 150-lumen spotlight and siren. The motion-activated light can also be manually controlled via the app, providing extra visibility when walking your dog at night or deterring unwanted visitors.
Flexible Power Options with Solar Panel Bundle
For continuous power without the hassle of frequent charging, the
Wyze Battery Cam Pro + Solar Panel bundle offers an eco-friendly solution. The solar panel converts sunlight into energy, keeping your camera powered longer and reducing downtime.
"Turn your wireless cam into a solar security cam in seconds."
Connectivity and Storage
- Supports both 2.4 GHz and 5 GHz Wi-Fi for faster, more reliable connections.
- Local recording available with a microSD card (sold separately) for subscription-free video storage.
- Optional Cam Plus subscription unlocks unlimited event video cloud storage and enhanced smart detections.
Wyze Battery Cam Pro protecting your home in any weather
Why Choose Wyze Battery Cam Pro?
- 2.5K HDR Video: High dynamic range for balanced, colorful images day and night.
- Radar + PIR Sensors: Double the detection accuracy for fewer false alerts.
- Spotlight & Siren: Active deterrence with bright LED light and loud siren.
- Weatherproof & Wire-Free: IP65 rating and no hub required for easy installation anywhere.
- Removable Batteries: Hot-swap batteries to keep your camera running 24/7.
- Smart Notifications: Person, pet, and vehicle alerts keep you informed about what matters.
Wyze Battery Cam Pro + Solar Panel: Ultimate Wireless Security
The
Wyze Battery Cam Pro + Solar Panel bundle combines all the features of the Battery Cam Pro with the added benefit of solar-powered continuous charging. This bundle is ideal for users who want to maximize uptime without worrying about battery life.
Benefits of the Solar Panel Bundle
- Continuous Power: Solar panel converts sunlight to energy, reducing the need for manual charging.
- Eco-Friendly: Harness renewable energy to keep your home secure sustainably.
- Same Smart Features: Enjoy all smart alerts, 2.5K HDR video, and integrated spotlight & siren.
- Easy Setup: No electrician or power outlet needed; just mount and connect.
Wireless security camera with solar power option for extended protection
Additional Features of Wyze Battery Cam Pro Series
- Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks for faster, more stable streaming.
- Instant Bluetooth Setup: Quick and easy installation without QR code scanning.
- Two-Way Audio: Built-in microphone and speaker allow you to talk or listen remotely.
- IP65 Weather Resistance: Reliable performance in rain, snow, or heat.
- Local and Cloud Storage Options: Choose between microSD card local recording or cloud storage with Cam Plus.
Summary
For those seeking a smart alerts camera that can differentiate between people, pets, and vehicles, the
Wyze Battery Cam Pro and its
Solar Panel bundle offer an unbeatable combination of high-resolution video, advanced motion detection, and flexible power options. Whether you want to monitor your front porch, backyard, or driveway, these cameras provide reliable, wire-free security with smart notifications tailored to your lifestyle.
What is the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro is a wireless security camera that offers advanced motion detection with person, pet, and vehicle alerts. It features 2.5K HDR video resolution, a weatherproof design, and flexible power options, making it ideal for both indoor and outdoor home security.How does the Wyze Battery Cam Pro detect motion?
The Wyze Battery Cam Pro uses a combination of radar and PIR (Passive Infrared) sensors for advanced motion detection. This dual-sensor system provides earlier and more accurate detection, reducing false alarms and enabling smart notifications for people, pets, and vehicles.Can I customize motion detection zones with the Wyze Battery Cam Pro?
Yes, you can set custom detection zones in the Wyze app. This allows you to focus monitoring on specific areas, such as driveways or doorways, for more precise security alerts.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it suitable for use in rain, snow, or heat. Its durable design ensures reliable performance in any climate.Does the Wyze Battery Cam Pro require wiring or a hub?
No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub. It is easy to install anywhere, indoors or outdoors, without complicated wiring.What are the power options for the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro features removable, rechargeable battery packs that can be hot-swapped for continuous operation. For extended power, you can bundle it with a solar panel for eco-friendly, continuous charging.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the camera and a solar panel that converts sunlight into energy, providing continuous power and reducing the need for manual charging.Does the Wyze Battery Cam Pro have a spotlight and siren?
Yes, the Wyze Battery Cam Pro has a built-in 150-lumen spotlight and a siren. The spotlight can be motion-activated or manually controlled via the app, and the siren helps deter unwanted visitors.What Wi-Fi networks does the Wyze Battery Cam Pro support?
The Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz Wi-Fi networks, ensuring faster and more reliable connections for streaming and notifications.How can I store video footage from the Wyze Battery Cam Pro?
You can store video footage locally using a microSD card (sold separately) for subscription-free recording. Alternatively, you can subscribe to Cam Plus for unlimited event video cloud storage and enhanced smart detections.Does the Wyze Battery Cam Pro offer two-way audio?
Yes, the Wyze Battery Cam Pro features built-in two-way audio, allowing you to listen and speak through the camera remotely using the Wyze app.How easy is it to set up the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro offers instant Bluetooth setup, making installation quick and easy without the need for QR code scanning or complex configurations.What are the benefits of using the Wyze Battery Cam Pro with a solar panel?
Using the Wyze Battery Cam Pro with a solar panel provides continuous, eco-friendly power, reduces downtime, and eliminates the need for frequent battery charging, ensuring your camera stays online longer.What makes the Wyze Battery Cam Pro a good choice for home security?
The Wyze Battery Cam Pro offers high-resolution 2.5K HDR video, advanced radar and PIR motion detection, smart alerts for people, pets, and vehicles, weatherproof and wire-free installation, and flexible power options, making it a reliable and versatile choice for home security.
