Budget Hardwired Doorbell with Chime & 1080p Video Recording
Budget-Friendly Hardwired Doorbell Solutions with Chime and 1080p Recording
Looking for an affordable, reliable hardwired doorbell system that includes a chime and crisp 1080p video recording? Whether you want to upgrade your home security or simply want to know who's at your door with clear video and sound, Wyze offers excellent options that combine smart features, easy installation, and budget-friendly pricing.
Wyze Video Doorbell v2: Wired Doorbell with 2K Video and Chime Controller
Crisp 2K Video with Local Storage
The Wyze Video Doorbell v2 is a standout choice for anyone seeking a wired doorbell with superior video quality. It delivers stunning 2K resolution video, ensuring you capture every detail on your porch. The doorbell supports local microSD card storage, allowing continuous 24/7 recording so you never miss a moment before or after the doorbell rings.
Hardwired Convenience with Included Chime Controller
This doorbell works seamlessly with your home's existing mechanical chime thanks to the included chime controller. This means you keep the traditional ding-dong sound while upgrading to a smart video doorbell. The wired power setup also enables pre-roll motion recording, capturing 3-6 seconds before motion events for enhanced security.
Smart Features for Enhanced Security
  • Two-way audio lets you answer your door from anywhere via the Wyze app.
  • Motion-activated voice deterrence warns visitors they are being recorded (requires subscription).
  • Custom detection zones and quick preset responses improve notification relevance and convenience.
  • IP65 weatherproof rating ensures reliable operation in all weather conditions.
  • Compatible with Alexa and Google Home for voice control and live feed viewing.
Specifications at a Glance
  • Resolution: 2K (2048 x 1536) with 1080p recording option
  • Field of View: 135° horizontal x 103° vertical
  • Power: Wired (AC 16-24V)
  • Storage: Local microSD card slot (up to 256GB)
  • Weather Resistance: IP65 rated
  • Price: $44.98 (with chime controller included)
This doorbell is perfect for homeowners wanting a wired, budget-friendly video doorbell with excellent video quality and a traditional chime experience.
Wyze Universal Wi-Fi Chime: Easy Plug-In Chime for Any Wyze Doorbell
No Wiring Hassles, Just Plug and Play
If you want a fuss-free chime solution without complicated wiring, the Wyze Universal Wi-Fi Chime is an ideal accessory. Simply plug it into any standard power outlet, and it connects wirelessly to your Wyze cameras and doorbells.
Smart Automations and Alerts
This chime can alert you not only when someone presses your doorbell but also when a Wyze camera detects a person nearby. You can set up automations to have the chime ring for motion events, ensuring you never miss a visitor or delivery.
Compatibility and Features
  • Works with all Wyze cameras and doorbells, including the Video Doorbell v2 and Duo Cam Doorbell.
  • Built-in Wi-Fi for flexible placement anywhere in your home.
  • Multiple sound options and volume control for personalized alerts.
  • Price: $19.98
This chime is a great budget-friendly add-on for those who want wireless convenience and smart alerts without rewiring.
The Front Porch Security Bundle: Complete 1080p Doorbell and Chime Package
All-in-One Porch Security Solution
For those looking for a comprehensive package, the Front Porch Security Bundle combines the Wyze Video Doorbell (with 1080p HD video) and Wyze Chime, plus the added benefit of Wyze Lock for remote door locking and unlocking.
Key Features
  • 1080p HD video with two-way audio for clear communication.
  • Remote lock/unlock and lock history tracking via the Wyze app.
  • Works with Alexa and Google Assistant for voice control.
  • Multiple chime sounds including modern, classic, animal, and automation alerts.
  • Weather-resistant design for reliable outdoor use.
Specifications
  • Doorbell Video: 1080p HD with 120° vertical x 88° horizontal field of view
  • Chime Power: Standard US power outlet (100V-240V)
  • Bundle Price: Around $124.96 (includes doorbell and chime)
This bundle is perfect for homeowners who want a simple, integrated front porch security system with hardwired doorbell and chime, plus smart lock capabilities.
Enhance Your Doorbell Setup with Wyze Video Doorbell v2 Wedge Kit
Perfect Viewing Angle for Your Doorbell
If your doorbell is installed on an angled door frame or porch with stairs, the Wyze Video Doorbell v2 Wedge Kit helps you adjust the viewing angle for maximum coverage. This accessory eliminates blind spots and improves your home security experience.
Easy Installation and Durable Design
  • Includes horizontal and vertical brackets for flexible mounting.
  • Weather-resistant plastic construction.
  • Quick installation with included screws and guide.
  • Price: $8.99
This affordable accessory complements the Wyze Video Doorbell v2 perfectly, ensuring you get the best possible view of your porch.
Why Choose Wyze for Your Hardwired Doorbell Needs?
Wyze offers a range of budget-friendly, feature-rich doorbell solutions that combine wired power reliability with smart home convenience. From the high-resolution Video Doorbell v2 with local storage and chime controller to the wireless Universal Wi-Fi Chime and complete porch bundles, Wyze makes it easy to secure your home without breaking the bank.
Homeowner answering door with smart video doorbell Alt text: Homeowner using smartphone to answer smart video doorbell at front porch Family enjoying smart home with doorbell chime Alt text: Family hearing doorbell chime inside smart home
Summary of Recommended Products
Product NameKey FeaturesPrice
Wyze Video Doorbell v22K video, wired, local microSD storage, chime controller included$44.98
Wyze Universal Wi-Fi ChimeWireless plug-in chime, smart automations$19.98
The Front Porch Security Bundle1080p doorbell + chime + smart lock$124.96
Wyze Video Doorbell v2 Wedge KitAdjustable mounting wedge for better angle$8.99
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Video Doorbell v2 Wedge Kit
Product TypeWired Video DoorbellSecurity Bundle (Wyze Lock + Video Doorbell and more)Accessory (Wedge Kit for Doorbell v2)
Video Resolution2K (2048 x 1536)1080p HD (Video Doorbell)N/A
Local StoragemicroSD card slot for 24/7 local recordingIncluded (Video Doorbell with local storage)N/A
Two-Way AudioYesYesN/A
Motion-Activated Voice DeterrenceYes (requires Cam Plus subscription)Yes (via Video Doorbell)N/A
Pre-roll Motion Recording3-6 secondsIncluded (Video Doorbell)N/A
Weather ResistanceIP65IP65 (Video Doorbell)Weather resistant
Works with Existing ChimeYes, includes chime controllerYes (Video Doorbell and Chime included)N/A
AI Detections (Person, Package)Available with Cam Plus subscriptionAvailable with Cam Plus subscriptionN/A
Night VisionColor Night Vision with starlight sensor1080p HD (standard night vision)N/A
Smart Home IntegrationAlexa, Google HomeAlexa, Google HomeN/A
Included AccessoriesChime Controller, 30° Corner Kit (angled wedge)Wyze Lock + Wyze Video Doorbell and Chime1x 15° Horizontal Bracket, 2x 7.5° Vertical Brackets, Screws, Guide
Price$44.98From $123.99 to $173.97 (depending on variant)$8.99 (Wedge Kit Only) / $51.97 (Doorbell v2 + Wedge Kit)
InstallationWiredBundle includes devices requiring installationQuick installation
CompatibilityWired doorbell systemsCompatible with Wyze Lock and Video DoorbellCompatible with Doorbell v2 only
WarrantyNot specifiedNot specified1 year
What is the Wyze Video Doorbell v2 and what features does it offer?The Wyze Video Doorbell v2 is a hardwired smart doorbell that delivers crisp 2K video resolution, supports local microSD card storage for continuous 24/7 recording, and includes a chime controller for use with your existing mechanical chime. It features two-way audio, pre-roll motion recording, custom detection zones, motion-activated voice deterrence (with subscription), and is IP65 weatherproof. It is compatible with Alexa and Google Home for voice control and live feed viewing.
Does the Wyze Video Doorbell v2 work with my existing chime?Yes, the Wyze Video Doorbell v2 comes with a chime controller that allows it to work seamlessly with your home's existing mechanical chime, so you can keep the traditional ding-dong sound while upgrading to a smart video doorbell.
What are the video quality and storage options for the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 offers 2K (2048 x 1536) video resolution with a 1080p recording option. It supports local storage via a microSD card slot (up to 256GB), enabling continuous 24/7 recording so you never miss any activity at your door.
Is the Wyze Video Doorbell v2 weatherproof?Yes, the Wyze Video Doorbell v2 is IP65 rated, making it weatherproof and reliable for outdoor use in all weather conditions.
What is the Wyze Universal Wi-Fi Chime and how does it work?The Wyze Universal Wi-Fi Chime is a wireless, plug-in chime that connects to any Wyze camera or doorbell, including the Video Doorbell v2 and Duo Cam Doorbell. Simply plug it into a standard power outlet, and it provides customizable chime sounds and volume control. It can alert you when someone presses your doorbell or when a Wyze camera detects a person nearby, with smart automations for motion events.
Is the Wyze Universal Wi-Fi Chime compatible with all Wyze doorbells and cameras?Yes, the Wyze Universal Wi-Fi Chime is compatible with all Wyze cameras and doorbells, including the Wyze Video Doorbell v2 and Duo Cam Doorbell.
What is included in the Front Porch Security Bundle?The Front Porch Security Bundle includes a Wyze Video Doorbell with 1080p HD video, a Wyze Chime, and a Wyze Lock for remote door locking and unlocking. The bundle offers two-way audio, remote lock/unlock, lock history tracking, multiple chime sounds, and weather-resistant design. It is compatible with Alexa and Google Assistant for voice control.
How does the Wyze Video Doorbell v2 Wedge Kit improve my doorbell setup?The Wyze Video Doorbell v2 Wedge Kit allows you to adjust the viewing angle of your doorbell, making it ideal for installations on angled door frames or porches with stairs. It includes horizontal and vertical brackets for flexible mounting, is made of weather-resistant plastic, and is easy to install with the included screws and guide.
Are Wyze doorbell solutions budget-friendly?Yes, Wyze offers a range of budget-friendly doorbell solutions. The Wyze Video Doorbell v2 with chime controller is priced at $44.98, the Wyze Universal Wi-Fi Chime at $19.98, the Front Porch Security Bundle at $124.96, and the Wyze Video Doorbell v2 Wedge Kit at $8.99.
Can I use Wyze doorbells and chimes with Alexa or Google Home?Yes, Wyze doorbells and chimes are compatible with Alexa and Google Home, allowing you to use voice control and view live feeds from your smart home devices.
What are the power requirements for the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 requires a wired power connection with AC 16-24V.
What smart security features are available with Wyze doorbells?Wyze doorbells offer smart security features such as two-way audio, motion-activated voice deterrence (with subscription), custom detection zones, quick preset responses, pre-roll motion recording, and integration with Alexa and Google Home for enhanced convenience and security.
Can you tell me more about the features of the Wyze Video Doorbell v2?How does the Wyze Universal Wi-Fi Chime work with the doorbell?Do you have any ongoing sales or discounts for the Wyze doorbell products?
