Bluetooth Smart Floor Lamp with AI Brightness Learning | Wyze
Discover the Wyze Bluetooth Smart Floor Lamp with AI Brightness Learning
Elevate your home lighting experience with the Wyze Floor Lamp, a cutting-edge smart floor lamp featuring AI brightness learning functionality. Designed to adapt to your preferences and environment, this lamp offers precise, focused lighting controlled effortlessly via Bluetooth. Complement your smart floor lamp with Wyze’s vibrant smart bulbs and light strips to create a fully customizable and intelligent lighting ecosystem.
Wyze Floor Lamp: Intelligent Lighting with AI Brightness Learning
Key Features and Specifications
- AI Learning for Brightness Preferences: The Wyze Floor Lamp intelligently learns your preferred brightness levels over time, adjusting automatically to provide the perfect illumination for any activity.
- 15 Individual Condenser Lenses: Delivers a super-focused 23° light beam, ideal for reading, working, or highlighting specific areas.
- Bluetooth Remote Control: Adjust brightness across 11 levels from up to 50 feet away with a convenient Bluetooth remote.
- High Color Rendering (RA>90): Ensures colors appear natural and vibrant under the lamp’s 4000K cool white light.
- Flexible Neck: Easily direct light exactly where you need it.
- Brightness: 800 lumens with a dimming range from 2% to 100%.
- Energy Efficient: Rated power of 9 watts with a long life expectancy of 25,000 hours.
- Dimensions & Weight: Stands tall at 73.76 inches with a sturdy base, weighing 7.06 lbs.
- Operating Conditions: Works reliably between -4°F to 104°F.
Shine a focused light on what matters most with the Wyze Floor Lamp’s smart AI brightness learning and precise directional lighting.
Alt text: Modern living room illuminated by Wyze smart floor lamp with warm ambient lighting
Wyze Bulb Color: Vibrant Bluetooth Smart Bulbs for Every Mood
Features That Brighten Your Space
- 16 Million Colors: Choose from an extensive palette to set the perfect ambiance for any occasion.
- Tunable White Light: Adjust color temperature from a warm 1800K to a crisp 6500K to suit your mood or task.
- Extra Bright: Up to 1100 lumens of brightness, dimmable to create cozy or vibrant atmospheres.
- Connectivity: Supports Bluetooth and Wi-Fi (802.11 b/g/n, 2.4GHz) for seamless integration with Alexa, Google Assistant, and IFTTT.
- Long Life: 25,000 hours of reliable use.
- Compact Size: Standard A19 bulb shape with E26 base fits most fixtures.
- Suitable for Damp Locations: Safe for use in kitchens, bathrooms, and covered outdoor areas.
The Wyze Bulb Color pairs perfectly with the Wyze Floor Lamp to add dynamic color and brightness control throughout your home.
Smart Lighting Kits: Bundles for Ultimate Customization
Wyze Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle
- Complete Lighting Solution: Includes Wyze Bulb Color and the Wyze Light Strip Pro for multi-zone, multi-color accent lighting.
- Light Strip Pro Features: 16 customizable segments with 16 million colors, music mode syncing lights to your favorite tunes, and voice control compatibility.
- Indoor Use: Perfect for enhancing living rooms, bedrooms, or entertainment areas.
- Easy Installation: Trimmable design and adhesive clips for flexible placement.
- Communication: Bluetooth and Wi-Fi enabled for smooth smart home integration.
- Warranty: 1-year coverage for peace of mind.
This bundle is ideal for users who want to create immersive lighting environments that respond intelligently to their lifestyle.
Alt text: Stylish home office with colorful smart lighting from Wyze bulbs and light strips
Why Choose Wyze Smart Lighting for Your Home?
- Seamless Bluetooth Connectivity: Control your lighting easily without complicated setups.
- AI-Powered Brightness Learning: The Wyze Floor Lamp adapts to your habits, providing personalized lighting comfort.
- Vibrant Color Options: From subtle whites to vivid colors, Wyze smart bulbs and strips transform your space.
- Energy Efficient and Long-Lasting: Save on energy bills with bulbs and lamps designed to last over 25,000 hours.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice and automation control.
- Flexible and Stylish: Modern designs that fit any room décor and lighting needs.
Summary of Products for Bluetooth Smart Floor Lamp with AI Brightness Learning
Wyze Floor Lamp
AI learning, Bluetooth remote, focused 800 lumens, flexible neck.
Wyze Bulb Color
16 million colors, tunable white, 1100 lumens, Bluetooth & Wi-Fi.
Multi-color segments, music sync, voice control, trimmable design.
Smart Lighting Kits
Bundles combining bulbs and light strips for full smart lighting control.
Experience the future of home lighting with Wyze’s smart floor lamp and complementary smart lighting products that learn, adapt, and brighten your life.
Feature | Wyze Floor Lamp | Wyze Bulb Color | Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle |
Type | Connected Home - Floor Lamp | Smart Lighting - Color Bulb | Smart Lighting - Bulb Color + Light Strip Pro Bundle |
Price | $64.99 | $26.26 (2 Pack), $44.44 (4 Pack), $64.98 (6 Pack) | $52.98 (2 Pack Bulb Color + 16.4 ft Light Strip Pro), $74.97 (4 Pack + 16.4 ft Light Strip Pro) |
Lighting Technology | 15 individual condenser lenses, 23° focused beam | 16 million colors, dimmable | 16 million colors (Bulb), LED accent lighting (Light Strip Pro) |
Brightness (Lumens) | Up to 1400 lx (at 47" distance) | 30 - 1100 lm | Bulb Color: 30 - 1100 lm; Light Strip Pro: multicolor LED |
Color Temperature | 4000K daylight | 1800K - 6500K | 1800K - 6500K (Bulb Color); Light Strip Pro supports 16 million colors |
Color Rendering Index (CRI) | 90+ | 90+ | 90+ |
Control | Bluetooth remote, Wyze app (Bluetooth only) | Wyze app, voice control (Alexa, Google Assistant), grouping | Wyze app, voice control (Alexa, Google Assistant), grouping |
Brightness Levels | 11 levels, AI learns preferences | Adjustable dimming | Adjustable dimming |
Smart Features | Scheduling, timers, sleep mode via app | Custom presets, sleep routines, vacation mode, music mode | Custom presets, sleep routines, vacation mode, music mode |
Lamp Dimensions | 5’ 11” stand, 2’ flexible neck | Standard bulb size (A19) | Bulb Color (A19) + Light Strip Pro (16.4 ft) |
Connectivity | Bluetooth only | Wi-Fi (802.11 b/g/n 2.4GHz), Bluetooth | Wi-Fi (802.11 b/g/n 2.4GHz), Bluetooth |
Power Consumption | Not specified | 12 watts | Bulb Color: 12 watts; Light Strip Pro: 18 watts (16.4 ft) |
Life Expectancy | Not specified | 25,000 hours | 25,000 hours |
Suitable For | Indoor use | Suitable for damp locations | Indoor use only |
Additional Features | Super focused directional lighting, flexible neck, low-profile base | 16 million colors, brilliant notifications, music sync (with Light Strip) | LED accent lighting with customizable zones (16 zones on Light Strip Pro) |
Base Type | Floor lamp stand | E26 base | E26 base (Bulb Color) + adhesive mounting (Light Strip Pro) |
Warranty | Not specified | Not specified | 1-Year warranty |
What is the Wyze Bluetooth Smart Floor Lamp with AI Brightness Learning?
The Wyze Bluetooth Smart Floor Lamp is an advanced floor lamp featuring AI brightness learning technology. It adapts to your preferred brightness levels over time and provides focused, adjustable lighting controlled via Bluetooth remote.How does the AI brightness learning feature work on the Wyze Floor Lamp?
The AI brightness learning feature on the Wyze Floor Lamp intelligently learns your preferred brightness settings and automatically adjusts the illumination to match your activities and environment.What are the key features of the Wyze Floor Lamp?
Key features of the Wyze Floor Lamp include AI brightness learning, 15 individual condenser lenses for a focused 23° light beam, Bluetooth remote control with 11 brightness levels, high color rendering (RA>90), a flexible neck, 800 lumens brightness, energy efficiency (9W), and a long lifespan of 25,000 hours.How do I control the Wyze Floor Lamp?
You can control the Wyze Floor Lamp using a Bluetooth remote, which allows you to adjust brightness across 11 levels from up to 50 feet away.What is the color temperature and brightness of the Wyze Floor Lamp?
The Wyze Floor Lamp emits a 4000K cool white light with a brightness of 800 lumens, and it can be dimmed from 2% to 100%.Is the Wyze Floor Lamp energy efficient?
Yes, the Wyze Floor Lamp is energy efficient with a rated power of 9 watts and a long life expectancy of 25,000 hours.What are the dimensions and weight of the Wyze Floor Lamp?
The Wyze Floor Lamp stands 73.76 inches tall and weighs 7.06 lbs, making it sturdy and suitable for various room settings.What is the Wyze Bulb Color and what features does it offer?
The Wyze Bulb Color is a smart bulb offering 16 million colors, tunable white light from 1800K to 6500K, up to 1100 lumens brightness, Bluetooth and Wi-Fi connectivity, and compatibility with Alexa, Google Assistant, and IFTTT.Can the Wyze Bulb Color be used in damp locations?
Yes, the Wyze Bulb Color is suitable for use in damp locations such as kitchens, bathrooms, and covered outdoor areas.What is included in the Wyze Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle?
The Wyze Smart Lighting Kit includes the Wyze Bulb Color and the Wyze Light Strip Pro, offering multi-zone, multi-color accent lighting, music mode, voice control, and easy installation with trimmable design and adhesive clips.What are the benefits of using Wyze smart lighting products?
Wyze smart lighting products offer seamless Bluetooth connectivity, AI-powered brightness learning, vibrant color options, energy efficiency, long-lasting performance, smart home integration, and modern, flexible designs.Are Wyze smart lighting products compatible with voice assistants?
Yes, Wyze smart lighting products are compatible with Alexa, Google Assistant, and IFTTT for convenient voice and automation control.How long do Wyze smart bulbs and lamps last?
Wyze smart bulbs and lamps are designed to last over 25,000 hours, providing long-term, reliable lighting for your home.Can I create custom lighting environments with Wyze products?
Yes, Wyze offers smart lighting kits and bundles that combine bulbs and light strips, allowing you to create fully customizable and immersive lighting environments tailored to your lifestyle.
Can you tell me more about the AI brightness learning functionality of the Wyze Floor Lamp?How does the Bluetooth remote control work for the Wyze Floor Lamp?Do you have any deals, ongoing sales, discounts, or promotions?
