Bluetooth Controlled Floor Lamp with Magnetic Remote for Easy Mounting
Discover the perfect smart lighting solution that combines convenience, style, and advanced technology. If you're searching for a
Bluetooth controlled floor lamp with a magnetic remote for easy mounting, the Wyze Floor Lamp stands out as an exceptional choice. Paired with the Wyze Bulb Color, it creates a versatile and vibrant lighting experience tailored to your lifestyle.
Wyze Floor Lamp: Precision Lighting with Bluetooth Control
Focused and Directional Lighting for Every Task
The Wyze Floor Lamp is designed to shine a focused light exactly where you need it. Featuring 15 individual condenser lenses, it delivers a sharp 23° beam angle that confines light precisely, eliminating common issues like eye strain and uneven illumination. Whether you're reading, crafting, or working, this lamp ensures your space is lit perfectly without disturbing others.
Easy-to-Use Bluetooth Remote with Magnetic Mounting
Control your lighting effortlessly with the included AI-powered Bluetooth remote. It offers 11 levels of brightness and learns your preferred settings over time, turning on to your ideal light intensity automatically. The remote’s magnetic base allows you to mount it conveniently on any metal surface near your sofa, desk, or nightstand, keeping it within easy reach and preventing loss.
Flexible and Tall Design for Versatile Use
Standing at an impressive 5 feet 11 inches with a 2-foot flexible neck, the Wyze Floor Lamp lets you direct light anywhere—from your reading nook to the ceiling for ambient lighting. Its slim 0.5-inch base is low-profile enough to be cleaned over by the Wyze Robot Vacuum, blending seamlessly into your living space.
Professional-Grade Color Accuracy
With a high Color Rendering Index (CRI) of 90+, the lamp reveals truer, more vivid colors, making it ideal for artists, crafters, and anyone who values fine detail. The 4000K daylight color temperature provides bright, natural light perfect for portraits, video calls, or focused work.
Smart App Integration
Connect the Wyze Floor Lamp to the Wyze app via Bluetooth to unlock additional features like scheduling, timers, sleep mode, and smart dimming. The app also allows you to monitor the lamp’s status and update its firmware for new functionalities.
"Shine a focused light on what matters." — Wyze Floor Lamp
Alt text: Cozy living room with floor lamp and colorful smart lighting
Wyze Bulb Color: Vibrant Smart Lighting to Complement Your Floor Lamp
16 Million Colors and Adjustable Brightness
Pair your Wyze Floor Lamp with the Wyze Bulb Color to transform your space with over 16 million colors. Whether you want a bright, energizing light or a soft, warm glow, this smart bulb offers a wide lumen range from 30lm to 1100lm, allowing you to dim or brighten your room to perfection.
Custom Presets and White Light Temperature Control
Create custom lighting presets for different moods or activities—game day, wine night, or focused work. The bulb also features dedicated white light temperature controls, letting you cool down or warm up the light to suit your needs.
Brilliant Notifications and Automation
Use the Wyze app to set time-based color events or automate lighting with other Wyze devices. For example, get visual reminders for important tasks or alerts triggered by motion or entry sensors.
Voice and App Control
Control your lighting hands-free with Alexa or Google Assistant. The Wyze Bulb Color also supports grouping with other Wyze light strips and bulbs, enabling synchronized lighting effects and music mode for parties.
Alt text: Modern living room illuminated with colorful smart lighting
Why Choose Wyze for Your Bluetooth Controlled Floor Lamp Needs?
- Seamless Bluetooth Connectivity: Both the Wyze Floor Lamp and its remote use Bluetooth for reliable, low-latency control without complicated setups.
- Magnetic Remote for Convenience: Never lose your remote again with the easy-to-mount magnetic base.
- Smart App Features: Schedule, automate, and customize your lighting experience with the Wyze app.
- High-Quality Lighting: Enjoy professional-grade brightness and color accuracy for all your activities.
- Energy Efficient and Stylish: The slim design and efficient LED technology make these products eco-friendly and visually appealing.
Summary
For a
Wyze Floor Lamp combined with the
Wyze Bulb Color offers an unbeatable smart lighting solution. Experience focused, customizable lighting with effortless control and vibrant color options that enhance any room.
What is a Bluetooth controlled floor lamp with a magnetic remote?
A Bluetooth controlled floor lamp with a magnetic remote, like the Wyze Floor Lamp, allows you to adjust your lighting wirelessly using a remote that can be easily mounted on any metal surface. This setup offers convenient control and prevents the remote from getting lost.How does the Wyze Floor Lamp provide focused and directional lighting?
The Wyze Floor Lamp features 15 individual condenser lenses that create a sharp 23° beam angle. This design delivers focused, directional lighting exactly where you need it, reducing eye strain and preventing uneven illumination—ideal for reading, crafting, or working.What are the benefits of the Wyze Floor Lamp’s Bluetooth remote with magnetic mounting?
The Wyze Floor Lamp’s Bluetooth remote offers 11 levels of brightness and uses AI to learn your preferred settings. Its magnetic base allows you to mount it on any metal surface, keeping it within easy reach and minimizing the risk of misplacement.Can I control the Wyze Floor Lamp with a smartphone app?
Yes, you can connect the Wyze Floor Lamp to the Wyze app via Bluetooth. The app enables features like scheduling, timers, sleep mode, smart dimming, and firmware updates for enhanced functionality.What makes the Wyze Floor Lamp suitable for artists and crafters?
With a high Color Rendering Index (CRI) of 90+ and a 4000K daylight color temperature, the Wyze Floor Lamp provides bright, natural light that reveals true, vivid colors. This makes it perfect for artists, crafters, and anyone who needs accurate color representation.How flexible is the Wyze Floor Lamp’s design?
The Wyze Floor Lamp stands 5 feet 11 inches tall and features a 2-foot flexible neck, allowing you to direct light wherever you need it. Its slim 0.5-inch base is also designed to be low-profile, so it blends seamlessly into your living space and can be cleaned over by a robot vacuum.What features does the Wyze Bulb Color offer when paired with the Wyze Floor Lamp?
The Wyze Bulb Color offers over 16 million colors, adjustable brightness from 30lm to 1100lm, custom lighting presets, white light temperature control, and automation through the Wyze app. It can also be controlled via voice assistants like Alexa and Google Assistant.Can I automate and schedule lighting with the Wyze Floor Lamp and Bulb Color?
Yes, the Wyze app allows you to schedule lighting, set timers, create custom presets, and automate lighting events based on time or triggers from other Wyze devices, providing a fully customizable smart lighting experience.Is the Wyze Floor Lamp energy efficient and stylish?
Yes, the Wyze Floor Lamp uses efficient LED technology and features a slim, modern design that is both eco-friendly and visually appealing, making it a great addition to any room.How does the Wyze Floor Lamp enhance convenience in daily use?
The Wyze Floor Lamp enhances convenience with its Bluetooth connectivity, easy-to-mount magnetic remote, flexible design, and smart app integration, allowing you to control and customize your lighting effortlessly.
