Bluetooth Smart Floor Lamp with 11 Brightness Levels and Remote Control
Looking for a modern, smart floor lamp that offers precise lighting control with the convenience of Bluetooth and remote operation? The
Wyze Floor Lamp is designed to shine a focused light exactly where you need it, featuring 11 brightness levels adjustable via a Bluetooth remote. Paired with Wyze’s smart lighting ecosystem, it’s the perfect addition to any connected home.
Wyze Floor Lamp: Focused Lighting with Smart Control
The Wyze Floor Lamp stands out with its innovative design and smart features tailored for your lighting needs:
- 11 Brightness Levels with Bluetooth Remote: Easily adjust the light intensity to your preference using the included wireless remote. The lamp learns your favorite brightness settings over time with AI deep learning, turning on to your preferred level automatically.
- Super Focused 23° Beam: Equipped with 15 individual condenser lenses, the lamp delivers a sharp, directional light beam that reduces eye strain and enhances visibility for reading, crafting, or working.
- Flexible Neck & Tall Stand: At nearly 6 feet tall with a 2-foot flexible neck, you can direct light exactly where you want it—whether over your sofa, desk, or ceiling.
- High Color Rendering Index (CRI 90+): Experience truer, more vibrant colors under professional-grade 4000K daylight color temperature lighting, ideal for detailed tasks like drawing or puzzles.
- Smart App Integration: Connect via Bluetooth to the Wyze app for additional features like scheduling, timers, sleep mode, and remote on/off control.
- Compact Base: The lamp’s low-profile 0.5” base is lightweight and won’t interfere with cleaning robots.
“Shine a focused light on what matters.” — Wyze Floor Lamp
Alt text: Cozy living room with smart floor lamp lighting a reading area
Wyze Bulb Color: Enhance Your Smart Lighting Experience
Complement your floor lamp with the
Wyze Bulb Color, a versatile smart bulb that offers:
- 16 Million Colors & Tunable White Light: Customize your ambiance with a full spectrum of colors or adjust white light temperature from warm to cool.
- Wide Brightness Range: From a subtle 30 lumens to a bright 1100 lumens, perfect for any mood or activity.
- Smart Controls: Use the Wyze app or voice assistants like Alexa and Google Assistant to control brightness, color, and schedules.
- Preset Scenes & Routines: Create custom lighting presets for game day, wine night, or sleep routines that simulate sunrise and sunset.
- High CRI 90+ Rating: See colors more vividly and naturally, enhancing your home’s atmosphere.
- Music Mode: Sync your lights to the beat of your favorite songs when grouped with Wyze Light Strip Pro.
This bulb pairs perfectly with the Wyze Floor Lamp to create a fully customizable lighting setup.
Alt text: Modern living room with colorful smart lighting ambiance
Wyze Plug: Smart Power Control for Your Lighting Setup
To maximize convenience, consider the
Wyze Plug to make any lamp or device smart:
- Remote Control via App: Turn your floor lamp or other devices on/off from anywhere using the Wyze app.
- Scheduling & Automation: Set timers or schedules to automate your lighting and save energy.
- Voice Assistant Compatible: Works seamlessly with Alexa, Google Assistant, and IFTTT for hands-free control.
- Compact Design: Fits easily into any outlet without blocking adjacent sockets.
Use the Wyze Plug to add smart control to your existing lamps or appliances, enhancing your smart home ecosystem.
Why Choose Wyze for Your Smart Lighting Needs?
Wyze offers a comprehensive smart lighting solution that combines:
- Precision Lighting: From focused floor lamps to vibrant color bulbs, Wyze products deliver the right light for every moment.
- Smart Connectivity: Bluetooth and WiFi-enabled devices integrate smoothly with your smartphone and voice assistants.
- User-Friendly Controls: Intuitive apps and remotes make adjusting your lighting effortless.
- Energy Efficiency: Long-lasting bulbs and smart scheduling help reduce power consumption.
- Stylish Design: Modern aesthetics that blend seamlessly into any home décor.
Transform your living space with Wyze’s smart floor lamp and lighting accessories for a personalized, convenient, and vibrant lighting experience.
What features does the Wyze Floor Lamp offer?
The Wyze Floor Lamp features 11 adjustable brightness levels, a Bluetooth remote for wireless control, a super focused 23° beam with 15 condenser lenses, a flexible neck, a tall stand, high color rendering (CRI 90+), and smart app integration for scheduling, timers, and remote on/off control.How do I control the Wyze Floor Lamp?
You can control the Wyze Floor Lamp using the included Bluetooth remote or through the Wyze app, which allows for additional features like scheduling, timers, sleep mode, and remote on/off control.Does the Wyze Floor Lamp remember my preferred brightness settings?
Yes, the Wyze Floor Lamp uses AI deep learning to remember your favorite brightness settings and automatically turns on to your preferred level.What is the color temperature and CRI of the Wyze Floor Lamp?
The Wyze Floor Lamp provides a professional-grade 4000K daylight color temperature and a high Color Rendering Index (CRI) of 90+, ensuring vibrant and true-to-life colors.Can I use the Wyze Floor Lamp for reading or crafting?
Absolutely. The lamp’s super focused 23° beam and high CRI make it ideal for tasks that require detailed visibility, such as reading, crafting, drawing, or working.What are the benefits of the Wyze Bulb Color?
The Wyze Bulb Color offers 16 million colors, tunable white light, a wide brightness range (30 to 1100 lumens), smart controls via app or voice assistants, preset scenes and routines, high CRI 90+ rating, and a music mode for syncing lights to music.How can I control the Wyze Bulb Color?
You can control the Wyze Bulb Color using the Wyze app or with voice assistants like Alexa and Google Assistant. The app allows you to adjust brightness, color, and set schedules or routines.What is the Wyze Plug and how does it work?
The Wyze Plug is a smart plug that allows you to control any lamp or device remotely via the Wyze app. It supports scheduling, automation, and works with Alexa, Google Assistant, and IFTTT for hands-free control.Can I automate my lighting with Wyze products?
Yes, Wyze products like the Floor Lamp, Bulb Color, and Plug support scheduling and automation through the Wyze app, allowing you to set timers, routines, and automate your lighting for convenience and energy savings.Are Wyze smart lighting products energy efficient?
Yes, Wyze smart lighting products are designed for energy efficiency, featuring long-lasting bulbs and smart scheduling options to help reduce power consumption.Do Wyze lighting products work with voice assistants?
Yes, Wyze lighting products are compatible with popular voice assistants such as Alexa and Google Assistant, enabling hands-free control of your lights and devices.How does the Wyze Floor Lamp fit into my home décor?
The Wyze Floor Lamp features a modern, stylish design with a compact, low-profile base that blends seamlessly into any home décor while providing focused, customizable lighting.
