Top Plug-In Security Cameras with Smart Voice Assistant Control
Best Plug-In Security Cameras with Smart Assistant Voice Control
Looking for the best plug-in security cameras that seamlessly integrate with your smart assistant for voice control? Whether you want to monitor your home’s exterior or keep an eye on your backyard, these Wyze products offer powerful features, easy installation, and smart home compatibility. From floodlight cameras to smart plugs that enhance your security setup, discover the top options designed for convenience, safety, and smart living.
Smart Plug Solutions for Enhanced Security and Automation
Wyze Plug: Smart Indoor Plug with Voice Control
Transform your everyday devices into smart gadgets with the Wyze Plug. This indoor smart plug supports voice commands through Alexa and Google Assistant, allowing you to control your devices hands-free. Perfect for automating lamps, fans, or any appliance, it offers:
  • 2.4GHz WiFi connectivity for reliable control
  • Compatibility with Android 5.0+ and iOS 9.0+
  • Supports Alexa, Google Assistant, and IFTTT integrations
  • Compact design (2.7" x 2.0" x 1.5") fits easily into any outlet
  • Max output of 15A for a wide range of devices
  • Easy scheduling and remote control via the Wyze app
Ideal for indoor use, this plug helps you create a smarter, safer home environment with simple voice commands or app control.
Wyze Plug Outdoor: Rugged Smart Plug for Outdoor Use
For outdoor security and automation, the Wyze Plug Outdoor is a must-have. Designed to withstand the elements with an IP64 weather rating, it powers your outdoor lights, holiday inflatables, or garden devices with smart control features:
  • Dual outlets with 15A max output and overload protection
  • Works with Alexa voice commands for hands-free control
  • Operates in temperatures from -4°F to 120°F
  • Connectivity via 2.4GHz WiFi and Bluetooth V4.2
  • Monitor energy usage and set schedules through the Wyze app
  • Compact and durable (4.0" x 2.8" x 1.4"), perfect for outdoor installation
This plug makes managing your outdoor security lighting and devices effortless, rain or shine. Outdoor smart plug in garden setting Wyze Plug Outdoor with Alexa voice control for smart garden lighting
Plug-In Floodlight Cameras: Bright, Secure, and Voice-Enabled
The Wyze Cam Floodlight v2 offers a powerful security solution with bright LED lighting and smart camera features, all in a plug-and-play design:
  • 2K HD video resolution with vibrant color night vision
  • Wide 160° field of view to cover large areas
  • 2800-lumen LEDs illuminate your property brightly
  • Advanced motion detection with alerts
  • Built-in 105dB siren for deterrence
  • Easy installation with included plug-in mount (no junction box needed)
  • Compatible with Alexa and Google Assistant for voice control
This camera is perfect for porch, driveway, or backyard security, combining bright lighting with smart monitoring.
For even more advanced security, the Wyze Cam Floodlight Pro bundle includes the camera and plug-in mount for a hassle-free setup:
  • Ultra-high 2.5K QHD resolution for crystal-clear video
  • 180° ultra-wide field of view captures more area
  • Powerful 3000 lumens of light output
  • Color night vision to see details in the dark
  • Supports microSD cards up to 256GB for local storage
  • Weather-resistant with IP65 rating for all-season use
  • Voice assistant compatibility with Alexa, Google Assistant, and IFTTT
  • Operates in extreme temperatures from -22°F to 122°F
This floodlight camera is ideal for those who want premium video quality and bright lighting with smart voice control. Wyze Cam Floodlight Pro installed on home exterior at dusk Wyze Cam Floodlight Pro providing bright, smart security lighting
Why Choose Wyze Plug-In Security Cameras with Voice Control?
"Smart home security should be simple, powerful, and accessible."
Wyze’s plug-in security cameras and smart plugs offer an unbeatable combination of easy installation, smart assistant integration, and reliable performance. Whether you want to control your outdoor lights with Alexa or monitor your property with high-definition floodlight cameras, these products bring convenience and peace of mind to your fingertips.
  • Plug-and-play design means no complicated wiring or junction boxes
  • Voice control compatibility with Alexa and Google Assistant for hands-free operation
  • Robust weather resistance for outdoor durability
  • Energy monitoring and scheduling to optimize power use
  • Affordable pricing without sacrificing quality or features
Upgrade your home security setup today with Wyze’s smart plug and floodlight camera solutions.
Summary of Featured Products
ProductKey FeaturesVoice Assistant Compatibility
Wyze PlugIndoor smart plug, app & voice controlAlexa, Google Assistant, IFTTT
Wyze Plug OutdoorWeather-resistant outdoor plug, dual outletsAlexa
Wyze Cam Floodlight v2 + Mount2K HD video, 2800 lumens, siren, plug-in mountAlexa, Google Assistant
Wyze Cam Floodlight Pro + Mount2.5K QHD, 3000 lumens, color night visionAlexa, Google Assistant, IFTTT
Enhance Your Home Security with Smart Voice Control
Integrate these Wyze plug-in cameras and smart plugs into your smart home ecosystem for effortless security management. Use voice commands to turn on lights, check camera feeds, or activate alarms — all without lifting a finger. Experience the future of home security today.
FeatureWyze PlugWyze Plug OutdoorWyze Cam Floodlight Pro + Plug-In MountWyze Cam Floodlight v2 + Plug-In Mount
TypeConnected HomeConnected HomeCamerasCameras
Price$24.98 (2 Pack), $39.98 (4 Pack)$15.99 (1 Pack), $34.98 (2 Pack)$169.96$109.96
ControlRemote on/off via Wyze appRemote on/off via Wyze appPlug-n-play floodlight with cameraPlug-n-play floodlight with camera
Hub RequiredNoNoNoNo
SchedulingYesYesNot specifiedNot specified
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Weather ResistanceIndoor useIP64 (rain, dust, dirt, snow)IP65Not specified (likely IP65 or similar)
WiFi RangeStandardUp to 300 ft (open space)IEEE802.11 b/g/n, Wi-Fi 2.4G b/g/nNot specified
Outlets1 outlet per plug2 outlets per plug, independently controlledN/AN/A
Energy MonitoringNoYesNoNo
Output PowerStandard15 AMP with overload protectionN/AN/A
LightingN/AN/A3000 lumens floodlight2800 lumens LEDs
Camera ResolutionN/AN/A2.5K QHD (2560x1440)2K HD
Field of ViewN/AN/A180° Ultra-Wide160° wide-angle
Night VisionN/AN/AColor night visionVibrant color night vision
SirenN/AN/ABuilt-in siren105dB siren
InstallationPlug and playPlug and playPlug-in mount, no junction box neededPlug-in mount, no junction box needed
Operating Temperature RangeNot specifiedNot specified-22°F to 122°FNot specified
Included ItemsWyze Plug(s)Wyze Plug Outdoor(s)Wyze Cam Floodlight Pro + Plug-in MountWyze Cam Floodlight v2 + Plug-in Mount
What are the best plug-in security cameras with smart assistant voice control?The best plug-in security cameras with smart assistant voice control include the Wyze Cam Floodlight v2 + Plug-In Mount and the Wyze Cam Floodlight Pro + Plug-In Mount. Both offer high-definition video, bright LED lighting, and compatibility with Alexa and Google Assistant for hands-free operation.
How do Wyze smart plugs enhance home security and automation?Wyze smart plugs, such as the Wyze Plug and Wyze Plug Outdoor, allow you to automate and control indoor and outdoor devices using voice commands or the Wyze app. They support scheduling, remote control, and energy monitoring, making it easy to manage lights, appliances, and security devices for a safer, smarter home.
Are Wyze plug-in security cameras easy to install?Yes, Wyze plug-in security cameras feature a plug-and-play design that requires no complicated wiring or junction boxes. Simply use the included plug-in mount for quick and hassle-free installation.
Which voice assistants are compatible with Wyze plug-in security cameras and smart plugs?Wyze plug-in security cameras and smart plugs are compatible with Alexa and Google Assistant. Some products, like the Wyze Plug and Wyze Cam Floodlight Pro, also support IFTTT for additional smart home integrations.
Can Wyze smart plugs be used outdoors?Yes, the Wyze Plug Outdoor is specifically designed for outdoor use. It features an IP64 weather rating, dual outlets with overload protection, and operates in temperatures from -4°F to 120°F, making it ideal for powering outdoor lights and devices.
What are the key features of the Wyze Cam Floodlight Pro?The Wyze Cam Floodlight Pro offers ultra-high 2.5K QHD video resolution, a 180° ultra-wide field of view, 3000 lumens of bright LED lighting, color night vision, local storage support up to 256GB, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.
How does voice control work with Wyze security products?Voice control with Wyze security products allows you to use Alexa or Google Assistant to turn on lights, check camera feeds, or activate alarms using simple voice commands, providing hands-free convenience and enhanced security.
Do Wyze plug-in security cameras support night vision?Yes, both the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro feature color night vision, enabling you to see clear details even in low-light or nighttime conditions.
What is the difference between Wyze Plug and Wyze Plug Outdoor?The Wyze Plug is designed for indoor use, offering compact size and compatibility with Alexa, Google Assistant, and IFTTT. The Wyze Plug Outdoor is weather-resistant, features dual outlets, energy monitoring, and is built to withstand outdoor conditions, with Alexa voice control support.
Why should I choose Wyze plug-in security cameras and smart plugs?Wyze plug-in security cameras and smart plugs offer easy installation, robust smart assistant integration, reliable performance, weather resistance for outdoor use, energy monitoring, and affordable pricing, making them an excellent choice for enhancing your home security with smart voice control.
What features should I look for in a plug-in security camera?Can the Wyze Plug Outdoor be used for holiday decorations?Do you have any deals, ongoing sales, discounts, or promotions?
