Best Memory Card Upgrade for Older Wyze Models Needing More Storage
If you own an older Wyze camera model and are looking to expand your local storage for continuous recording, time lapses, and enhanced video capture, upgrading your memory card is essential. Wyze offers a range of microSD cards specifically designed to unlock the full potential of your Wyze cameras, ensuring you never miss a moment.
Wyze MicroSD Card: The Perfect Storage Upgrade
Unlock Continuous Recording and Time Lapses
The Wyze MicroSD Card is the ideal accessory to upgrade your older Wyze cameras with more storage capacity. Available in 32GB, 128GB, and 256GB sizes, these microSD cards enable continuous local recording, timeline controls, and calendar view features that make reviewing footage easier than ever.
- Sizes Available: 32GB microSDHC, 128GB microSDXC, 256GB microSDXC
Key Features:
- Local recording support for Wyze cameras
- Continuous recording and timelapse capabilities
- Easy timeline and calendar navigation for footage review
This memory card is optimized for Wyze cameras, ensuring smooth performance and reliable storage without the need for cloud subscriptions.
Upgrade your older Wyze models with a Wyze MicroSD Card to enjoy uninterrupted video storage and enhanced control over your recordings.
Compatible Wyze Cameras Supporting MicroSD Storage
Wyze Cam v4: Advanced Security with Local Storage
The Wyze Cam v4 is a powerful security camera that supports microSD cards up to 512GB, making it compatible with the Wyze MicroSD Card upgrade. It features:
- Resolution: Crystal-clear 2.5K QHD (2560x1440)
- Night Vision: Enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs
- Connectivity: Wi-Fi 6 support for faster and more reliable connections
- Local Storage: Supports microSD cards up to 512GB for 24/7 continuous local recording
- Additional Features: Motion-activated spotlight, person detection, smoke & CO alerts, and compatibility with Alexa and Google Assistant
This camera is weather-resistant (IP65), suitable for both indoor and outdoor use, and requires a microSD card for local storage, making the Wyze MicroSD Card an excellent upgrade choice.
Wyze Cam v3 Security System Bundle: Ready-to-Go Storage Solution
For those looking to build a comprehensive DIY security system, the Wyze Cam v3 Security System Bundle includes multiple Wyze Cam v3 cameras paired with Wyze MicroSD Cards in various sizes (32GB, 128GB, 256GB). This bundle offers:
- 1080p Color Night Vision for clear footage day and night
- IP65 Weather Resistance for indoor and outdoor use
- Person, Vehicle, Pet, and Package Detection with Cam Plus subscription
- 24/7 Continuous Recording enabled by included microSD cards
- Multiple Mounting Options: Magnetic kits, screw kits, and adjustable stands
This bundle is perfect for upgrading older Wyze Cam v3 models with reliable local storage and enhanced security features.
Why Choose Wyze MicroSD Cards for Your Older Wyze Cameras?
- Optimized Compatibility: Designed specifically for Wyze cameras to ensure seamless integration and performance.
- Reliable Local Storage: Avoid cloud subscription fees by storing footage locally with high-capacity cards.
- Flexible Storage Options: Choose from 32GB to 256GB sizes to fit your recording needs and camera model.
- Enhanced Video Features: Enable continuous recording, timelapse, and easy timeline navigation for better footage management.
Summary
Upgrading your older Wyze cameras with a Wyze MicroSD Card is the best way to expand your local storage and unlock advanced recording features. Whether you have a Wyze Cam v3 or the newer Wyze Cam v4, these microSD cards provide reliable, high-capacity storage tailored to your security needs.
Invest in a Wyze MicroSD Card today to enjoy uninterrupted, high-quality video recording and peace of mind knowing your home is always protected.
Enhance your home security with Wyze cameras and microSD card upgrades.
Wyze Cam v4 with microSD card for continuous outdoor recording.
Complete security system with Wyze Cam v3 and microSD cards for extended storage.
What is the best memory card upgrade for older Wyze camera models?
The best memory card upgrade for older Wyze camera models is the Wyze MicroSD Card, which is specifically designed for Wyze cameras. It is available in 32GB, 128GB, and 256GB sizes, providing reliable local storage for continuous recording, time lapses, and easy footage review.Which Wyze cameras are compatible with Wyze MicroSD Cards?
Wyze MicroSD Cards are compatible with a range of Wyze cameras, including the Wyze Cam v3 and Wyze Cam v4. The Wyze Cam v4 supports microSD cards up to 512GB, while the Wyze Cam v3 Security System Bundle comes with microSD cards in 32GB, 128GB, and 256GB sizes.What are the benefits of using a Wyze MicroSD Card with my Wyze camera?
Using a Wyze MicroSD Card with your Wyze camera enables continuous local recording, timelapse capabilities, and easy timeline and calendar navigation for reviewing footage. It also allows you to avoid cloud subscription fees by storing your video locally.What sizes do Wyze MicroSD Cards come in?
Wyze MicroSD Cards are available in 32GB (microSDHC), 128GB (microSDXC), and 256GB (microSDXC) sizes, allowing you to choose the storage capacity that best fits your recording needs.Can I use a Wyze MicroSD Card for 24/7 continuous recording?
Yes, Wyze MicroSD Cards are optimized for 24/7 continuous recording on compatible Wyze cameras, ensuring you never miss important footage and can easily review past events.Do I need a cloud subscription to use local storage with Wyze cameras?
No, you do not need a cloud subscription to use local storage with Wyze cameras. By upgrading with a Wyze MicroSD Card, you can store all your footage locally and access it directly from your camera.What features does the Wyze Cam v4 offer with a microSD card upgrade?
With a microSD card upgrade, the Wyze Cam v4 offers crystal-clear 2.5K QHD resolution, enhanced color night vision, Wi-Fi 6 connectivity, motion-activated spotlight, person detection, smoke & CO alerts, and up to 512GB of local storage for 24/7 continuous recording.Is the Wyze Cam v3 Security System Bundle a good option for upgrading storage?
Yes, the Wyze Cam v3 Security System Bundle is an excellent option for upgrading storage. It includes multiple Wyze Cam v3 cameras and Wyze MicroSD Cards in various sizes, enabling 24/7 continuous recording, person and package detection, and flexible mounting options for comprehensive home security.Why should I choose Wyze MicroSD Cards over other brands for my Wyze camera?
Wyze MicroSD Cards are optimized for seamless compatibility and performance with Wyze cameras. They ensure reliable local storage, support advanced video features like continuous recording and timelapse, and eliminate the need for cloud subscription fees.
