Affordable Wyze Smart Security Bundle: Smart Lock, Battery Cam, and Pan Camera
Looking for an affordable, reliable smart security bundle that includes a smart lock, battery-powered camera, and pan camera? Wyze offers a perfect combination of smart home security devices designed to keep your home safe, accessible, and monitored—all without breaking the bank. This guide highlights the key features and benefits of the Wyze Lock Bolt, Wyze Lock, and Wyze battery-powered cameras to help you secure your home smartly and affordably.
Wyze Smart Locks: Secure Your Home with Keyless Convenience
Wyze Lock Bolt: Fingerprint-Enabled Deadbolt Replacement
The
Wyze Lock Bolt is a Bluetooth smart lock that replaces your existing deadbolt with a sleek, secure, and highly convenient solution. It features:
- Ultra-fast fingerprint reader for keyless entry in less than a second.
- Backlit keypad with anti-peep technology, allowing you to enter your code discreetly by adding extra digits.
- Auto-lock timer that locks your door automatically if you forget.
- Weatherproof and pick-proof design with IPX5 rating, built to withstand outdoor elements.
- Up to 12 months battery life on 4 AA batteries, with a USB-C port for emergency charging.
- Local Bluetooth control via the Wyze app to lock/unlock and monitor access history.
- Store up to 50 fingerprints and 20 access codes for family and guests.
- Two stylish finishes: Matte Black and Satin Nickel to complement your door’s exterior.
This lock is perfect for those who want a fast, secure, and keyless entry system without the need for cloud connectivity or complex smart home integrations.
Wyze Lock Bolt installed on a front door, blending security with style.
Wyze Lock: Smart Upgrade for Your Existing Deadbolt
If you prefer to keep your existing deadbolt but want to add smart features, the
Wyze Lock is the ideal choice:
- Keeps your current deadbolt hardware but adds smart control brains.
- Auto-unlocks as you approach and locks automatically when you leave.
- Remote access via Wyze app to lock/unlock from anywhere.
- Integration with Alexa, Google Assistant, and Wyze Switch for voice and physical control.
- Virtual keys can be sent to family and friends with customizable access schedules.
- Compatible with most single-cylinder deadbolts.
- Optional Wyze Lock Keypad available for code-based entry, perfect for guests or short-term rentals.
This lock is designed for smart home enthusiasts who want seamless automation and remote control without changing their door hardware.
Wyze Battery-Powered Security Cameras: Monitor Your Home Anywhere
Wyze Plug-In Cam: Reliable Battery-Powered Security
Wyze’s battery-powered cameras offer flexible placement and dependable home monitoring without the hassle of wiring:
- Wireless and battery-powered for easy installation indoors or outdoors.
- 1080p HD video with night vision and motion detection.
- Two-way audio to communicate through the camera.
- Live streaming and event recording accessible via the Wyze app.
- Smart alerts to notify you of unusual activity.
- Compatible with other Wyze devices for a comprehensive security system.
These cameras are perfect for monitoring entryways, porches, or any area where wiring is inconvenient.
Wyze Plug-In Cam mounted outdoors, providing flexible and reliable home security.
Why Choose Wyze for Your Smart Security Bundle?
Wyze combines affordability, ease of use, and robust features to deliver smart home security solutions that anyone can install and manage.
- Affordable pricing without compromising quality or security.
- Easy installation: Wyze Lock Bolt installs in about 20 minutes; Wyze Lock installs in under 15 minutes.
- Comprehensive app control: Manage locks and cameras from a single app.
- No monthly fees for basic features.
- Strong security protocols including hardware encryption and two-factor authentication.
Summary of the Affordable Wyze Smart Security Bundle
Product | Key Features | Price Range |
Wyze Lock Bolt | Fingerprint unlock, backlit keypad, auto-lock, weatherproof | ~$63 |
Wyze Lock | Keeps existing deadbolt, remote access, auto-lock/unlock, voice control | ~$124 (varies) |
Wyze Plug-In Cam | Battery-powered, 1080p HD, motion alerts, two-way audio | Affordable camera pricing |
This bundle offers a perfect balance of smart lock convenience and versatile video monitoring to keep your home safe and accessible.
Wyze Lock Bolt keypad for secure, keyless entry.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning smoothly, replacement parts are available:
- Wyze Lock Bolt Interior Assembly Battery Cover – $9.99
- Wyze Lock Bolt Screws (set) – $2.99
- Wyze Lock Bolt Interior Assembly Metal Plate – $4.99
These parts ensure your smart lock stays durable and reliable over time.
Secure your home smartly and affordably with the Wyze smart security bundle featuring the Wyze Lock Bolt, Wyze Lock, and Wyze battery-powered cameras. Enjoy keyless convenience, remote monitoring, and peace of mind—all at a great value.
# Product Tags Summary
What is included in the Wyze Smart Security Bundle?
The Wyze Smart Security Bundle typically includes the Wyze Lock Bolt, Wyze Lock, and Wyze battery-powered security cameras. This combination provides keyless entry, remote access, and flexible video monitoring for comprehensive home security.How does the Wyze Lock Bolt work?
The Wyze Lock Bolt is a Bluetooth-enabled smart deadbolt replacement featuring an ultra-fast fingerprint reader, backlit keypad with anti-peep technology, auto-lock timer, and weatherproof design. It allows keyless entry in less than a second and can store up to 50 fingerprints and 20 access codes.Can I keep my existing deadbolt with the Wyze Lock?
Yes, the Wyze Lock is designed to work with your existing single-cylinder deadbolt. It adds smart features like auto-unlock, remote access, and voice control without requiring you to change your current door hardware.Are Wyze security cameras wireless and battery-powered?
Yes, Wyze offers battery-powered security cameras that are wireless and easy to install both indoors and outdoors. They provide 1080p HD video, night vision, motion detection, two-way audio, and smart alerts accessible via the Wyze app.How do I control Wyze locks and cameras?
You can control all Wyze locks and cameras through the Wyze app, which allows you to lock or unlock doors, monitor video feeds, receive alerts, and manage access codes or fingerprints from your smartphone.Does the Wyze Lock Bolt require Wi-Fi or cloud connectivity?
No, the Wyze Lock Bolt operates locally via Bluetooth and does not require Wi-Fi or cloud connectivity for basic functions like locking, unlocking, and managing access codes.Is the Wyze Lock compatible with voice assistants?
Yes, the Wyze Lock integrates with Alexa, Google Assistant, and Wyze Switch, allowing you to control your lock with voice commands or physical switches.What is the battery life of the Wyze Lock Bolt?
The Wyze Lock Bolt offers up to 12 months of battery life on 4 AA batteries. It also features a USB-C port for emergency charging if the batteries run low.Are there replacement parts available for the Wyze Lock Bolt?
Yes, replacement parts for the Wyze Lock Bolt are available, including the interior assembly battery cover, screws set, and interior assembly metal plate, ensuring your lock remains durable and reliable.How easy is it to install Wyze smart locks and cameras?
Wyze smart locks and cameras are designed for easy installation. The Wyze Lock Bolt can be installed in about 20 minutes, while the Wyze Lock installs in under 15 minutes. The battery-powered cameras are wireless, making them simple to set up anywhere.Are there any monthly fees for using Wyze smart security devices?
No, Wyze does not charge monthly fees for basic features on their smart locks and cameras. You can enjoy keyless entry, remote monitoring, and smart alerts without ongoing subscription costs.What security features do Wyze smart locks and cameras offer?
Wyze smart locks and cameras use strong security protocols, including hardware encryption and two-factor authentication, to protect your home and personal data.What finishes are available for the Wyze Lock Bolt?
The Wyze Lock Bolt is available in two stylish finishes: Matte Black and Satin Nickel, allowing you to choose the look that best matches your door.
