Wireless Gaming Headphones with Adjustable EQ & Hi-Fi Sound
Wireless Headphones with Adjustable Equalizer and High Fidelity Sound for Gaming
When it comes to immersive gaming, having the right headphones can make all the difference. Whether you want crystal-clear audio, customizable sound profiles, or ultra-low latency for competitive play, the right wireless headphones elevate your gaming experience. Below, we explore the top Wyze wireless headphones designed to deliver high fidelity sound and adjustable equalizer features tailored for gaming enthusiasts.
Wyze Noise-Cancelling Headphones: Your Personal Symphony with Custom Sound
Experience sound like never before with the
Wyze Noise-Cancelling Headphones, engineered for audiophiles and gamers who demand precision and clarity.
Key Features for Gaming and Audio Excellence
- Adjustable Equalizer via Wyze App: Customize your sound profile with presets optimized for gaming, music, and movies, or create your own. This feature ensures you get the perfect balance of deep bass, stable mids, and crisp highs tailored to your gaming environment.
- Dual 40mm TPU Composite Drivers: Deliver a wide frequency range up to 38kHz, providing rich, immersive audio that brings game soundtracks and effects to life.
- 40dB Hybrid Active Noise Cancellation (ANC): Block out distracting background noise so you can focus on your game or music.
- Transparency Mode & Quick Conversations: Easily switch to hear your surroundings or chat without removing your headphones.
- Wear Detection: Automatically pauses audio when removed, so you never miss a beat.
- Bluetooth 5.0 with Multi-Device Connectivity: Seamlessly switch between your gaming PC and phone calls without reconnecting.
- Voice Assistant Integration: Use Alexa or Google Assistant hands-free to control music or smart home devices during gameplay.
- Comfort Designed for Long Sessions: Memory foam and elongated earpads provide fatigue-free wear, perfect for marathon gaming.
"Like a symphony playing just for you," these headphones combine world-class engineering with premium hardware to deliver a truly personalized audio experience.
Enjoy immersive gaming and music with Wyze Noise-Cancelling Headphones.
Wyze Wireless Gaming Headset: Ultra-Low Latency and Comfort for Gamers
For gamers who prioritize responsiveness and comfort, the
Wyze Wireless Gaming Headset is built specifically to meet those needs.
Why Gamers Choose Wyze Wireless Gaming Headset
- Ultra-Low 20ms Wireless Latency: Using a 2.4 GHz dongle, this headset ensures near-instant audio transmission, critical for competitive gaming where every millisecond counts.
- 50mm Drivers: Large drivers deliver powerful sound with clear highs and deep bass, enhancing in-game audio cues and voice chat clarity.
- Two Microphone Options: Choose between a detachable boom mic for crystal-clear communication or a built-in mic for convenience.
- Up to 20 Hours Battery Life: Long-lasting playtime with quick 10-minute charging for 2 hours of use.
- Comfort-Focused Design: Memory foam ear pads and a lightweight, extra-wide frame provide a comfortable fit for extended gaming sessions.
- Bluetooth 5.2 and Wireless Dongle Connectivity: Compatible with PC, Mac, PlayStation, Nintendo Switch, Steam Deck, Android, and iOS devices (not compatible with Xbox).
- No App Required: Simple plug-and-play setup with no need for additional software or customization apps.
While this headset does not support adjustable equalizer settings or 3D audio, its ultra-low latency and comfort make it a top choice for serious gamers.
Wyze Wireless Gaming Headset designed for marathon gaming comfort and performance.
Why Choose Wyze for Your Gaming Audio Needs?
Wyze offers a range of wireless headphones and headsets that cater to different gaming and audio preferences:
- Adjustable Equalizer & High Fidelity: Only the Wyze Noise-Cancelling Headphones provide customizable sound profiles through the Wyze app, perfect for gamers who want to fine-tune their audio.
- Ultra-Low Latency Wireless Gaming: The Wyze Wireless Gaming Headset excels in delivering lag-free sound with a dedicated dongle, ideal for competitive gaming.
- Comfort & Durability: Both products feature memory foam ear pads and ergonomic designs to ensure comfort during long gaming sessions.
- Smart Features: Noise cancellation, transparency mode, and voice assistant integration enhance the overall user experience beyond gaming.
Summary of Specs
Feature | Wyze Noise-Cancelling Headphones | Wyze Wireless Gaming Headset |
Drivers | Dual 40mm TPU Composite | 50mm |
Wireless Technology | Bluetooth 5.0 | Bluetooth 5.2 + 2.4 GHz Dongle |
Latency | Standard Bluetooth latency | Ultra-low 20ms latency |
Equalizer | Adjustable via Wyze app | No customization |
Noise Cancellation | 40dB Hybrid ANC | No |
Microphone Options | Dual voice-isolating microphones | Detachable boom mic + built-in mic |
Battery Life | Not specified (typical Bluetooth usage) | Up to 20 hours |
Charging Time | Not specified | 3 hours full, 10 min quick charge |
Comfort Features | Memory foam, elongated earpads | Memory foam, lightweight, extra-wide frame |
Voice Assistant Integration | Alexa, Google Assistant | No |
Compatible Devices | Multi-device Bluetooth pairing | PC, Mac, PlayStation, Nintendo Switch, Steam Deck, Android, iOS |
Elevate your gaming audio with Wyze’s wireless headphones and headsets designed for clarity, comfort, and performance. Whether you want customizable sound or ultra-low latency, Wyze has you covered.
Type | Noise-Cancelling Headphones | Wireless Gaming Headset |
Price | $80.99 - $99.99 (varies by color and travel case) | $59.99 |
Noise Cancellation | 40dB Quick On/Off Hybrid Active Noise Cancellation (ANC) | No active noise cancellation |
Microphones | 6 total (4 for noise cancellation, 2 for voice pickup) | 2 microphone options (detachable boom mic & built-in mic) |
Audio Drivers | Dual 40mm TPU Composite Diaphragm Drivers | 50mm audio drivers |
Frequency Response | Bluetooth: 20 - 20,000 Hz; Line-in: 20 - 38,000 Hz | Not specified |
Battery Life | Up to 20 hours | Up to 20 hours |
Charging | USB Type-C, ~2 hours charging, 10 min quick charge for 4 hrs playback | 3 hours full charge, 10 min quick charge for 2 hours |
Bluetooth Version | Bluetooth 5.0 | Bluetooth 5.2 + 2.4 GHz wireless dongle |
Connectivity | Bluetooth 5.0, connect two devices simultaneously | Bluetooth 5.2 and 2.4 GHz dongle, multi-source connection |
Weight | 9.9 oz | Not specified |
Comfort | Memory foam earpads covered in protein leather | Memory foam ear pads, lightweight, extra-wide frame |
Controls | Touch and tap controls on earcups | On-board multi-function button |
Voice Assistant | Amazon Alexa built-in, supports Siri, Google Assistant, Bixby | Supports voice assistants |
Transparency Mode | Yes, with quick touch to amplify outside sounds | No |
Wear Detection | Yes, auto pause/resume audio | No |
Latency | Not specified | Ultra-low 20ms wireless latency |
Compatibility | General Bluetooth devices | PC, Mac, PlayStation, Nintendo Switch, Steam Deck, Android, iOS (not Xbox) |
Included Accessories | Travel case (optional), USB Type-C cable, audio cable, soft pouch | Detachable boom mic, wireless dongle |
Special Features | Dual voice-isolating microphones, customizable sound via Wyze app | Two mic options, ultra-low latency, multi-device switching |
What are the key features of Wyze Noise-Cancelling Headphones for gaming?
Wyze Noise-Cancelling Headphones offer an adjustable equalizer via the Wyze app, dual 40mm TPU composite drivers for high fidelity sound, 40dB hybrid active noise cancellation, transparency mode, wear detection, Bluetooth 5.0 with multi-device connectivity, voice assistant integration, and memory foam earpads for long-lasting comfort—making them ideal for immersive gaming.Do Wyze Noise-Cancelling Headphones have an adjustable equalizer?
Yes, Wyze Noise-Cancelling Headphones feature an adjustable equalizer accessible through the Wyze app. You can customize your sound profile with gaming, music, and movie presets or create your own for a personalized audio experience.Are Wyze Noise-Cancelling Headphones suitable for long gaming sessions?
Absolutely. Wyze Noise-Cancelling Headphones are designed with memory foam and elongated earpads to provide fatigue-free comfort, making them perfect for marathon gaming sessions.What makes the Wyze Wireless Gaming Headset ideal for competitive gaming?
The Wyze Wireless Gaming Headset offers ultra-low 20ms wireless latency using a 2.4 GHz dongle, ensuring near-instant audio transmission. It also features 50mm drivers for powerful sound, two microphone options, up to 20 hours of battery life, and a comfort-focused design for extended play.Does the Wyze Wireless Gaming Headset support adjustable equalizer settings?
No, the Wyze Wireless Gaming Headset does not support adjustable equalizer settings or 3D audio. It is designed for plug-and-play simplicity with a focus on ultra-low latency and comfort.Which devices are compatible with the Wyze Wireless Gaming Headset?
The Wyze Wireless Gaming Headset is compatible with PC, Mac, PlayStation, Nintendo Switch, Steam Deck, Android, and iOS devices. It is not compatible with Xbox.How long does the Wyze Wireless Gaming Headset battery last and how fast does it charge?
The Wyze Wireless Gaming Headset provides up to 20 hours of battery life. A quick 10-minute charge gives you up to 2 hours of use, while a full charge takes about 3 hours.What are the main differences between Wyze Noise-Cancelling Headphones and Wyze Wireless Gaming Headset?
Wyze Noise-Cancelling Headphones feature an adjustable equalizer, active noise cancellation, voice assistant integration, and multi-device Bluetooth pairing, making them versatile for gaming and music. The Wyze Wireless Gaming Headset focuses on ultra-low latency, powerful 50mm drivers, two microphone options, and broad device compatibility, but does not offer an adjustable equalizer or noise cancellation.Do Wyze headphones support voice assistants like Alexa or Google Assistant?
Yes, Wyze Noise-Cancelling Headphones support voice assistant integration, allowing you to use Alexa or Google Assistant hands-free. The Wyze Wireless Gaming Headset does not support voice assistants.Are Wyze headphones comfortable for extended use?
Yes, both Wyze Noise-Cancelling Headphones and Wyze Wireless Gaming Headset are designed with memory foam ear pads and ergonomic features to ensure comfort during long gaming or listening sessions.
What are the key features of the Wyze Noise-Cancelling Headphones?How does the adjustable equalizer work with the Wyze app?Are there any ongoing sales or discounts for Wyze products?
