Affordable Smart Sprinkler Solutions for Water Conservation
Looking for an affordable smart sprinkler system that intelligently skips watering during unfavorable weather to conserve water? Wyze offers a comprehensive solution combining smart hardware and a weather-based subscription service designed to keep your lawn green while saving water and money. Discover how Wyze Sprinkler Controller, Sprinkler Plus service, and the Weatherproof Sprinkler Controller Box work together to deliver efficient, eco-friendly irrigation.
Wyze Sprinkler Controller: Smarter, Simpler, Greener Lawn Care
Wyze Sprinkler Controller is an affordable, Wi-Fi-enabled smart irrigation controller that gives you full control over your lawn watering from anywhere. Designed to replace your existing sprinkler controller in under 20 minutes, it supports up to 8 customizable irrigation zones, allowing you to tailor watering schedules to your yard’s unique needs.
Key Features:
- Remote Control via Wyze App: Start, stop, or adjust watering schedules anytime, anywhere.
- 8 Customizable Zones: Name and personalize each zone with photos for easy management.
- Personalized Weekly Schedules: Create fixed or smart watering routines that fit your lifestyle.
- WaterSense Certified: Recognized by the EPA for water-efficient irrigation.
- Integration with Wyze Cam: Monitor your lawn and get notifications about watering activity for peace of mind.
- Offline Operation: Continues to run saved schedules for up to 14 days without internet.
- Sunrise/Sunset Watering: Automatically adjusts watering times based on local solar cycles.
"Affordably priced smart sprinkler controller" – DigitalTrends
"#1 Affordable Smart Sprinkler Controller" – ZDNet
Control your sprinkler remotely with the Wyze app for smarter watering.
Wyze Sprinkler Plus: Intelligent Weather Skip Service for Water Conservation
Wyze Sprinkler Plus is a subscription service that unlocks advanced weather-based features to optimize your watering schedule and conserve water. Included free for one year with the purchase of the Wyze Sprinkler Controller, Sprinkler Plus uses hyper-local weather data to make your irrigation system smarter and more efficient.
Why Choose Sprinkler Plus?
- Weather Skips: Automatically skip watering when it’s raining, too cold, too windy, or when soil moisture is sufficient, preventing water waste and protecting plants.
- Smart Schedules: Automatically calculates watering needs for each zone based on plant type, growth stage, and weather conditions.
- Advanced Zone Insights: View historical, current, and forecasted moisture levels for each zone directly in the app.
- Cycle/Soak Feature: Breaks watering into multiple cycles to allow soil to absorb water better, reducing runoff.
- 5-Day Weather Forecast: Plan your watering with upcoming weather info at your fingertips.
> "Water when your plants are thirsty, not when it’s raining." – Wyze
Sprinkler Plus uses hyper-local weather data to skip unnecessary watering and save water.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
For outdoor installations, the Wyze Weatherproof Sprinkler Controller Box offers a rugged, IP65-rated enclosure to protect your sprinkler controller from the elements. This accessory ensures your smart irrigation system stays safe and functional year-round.
Features:
- IP65 Weatherproof Rating: Fully protects against dust and water jets.
- Durable Design: Four clasps and a gridded cover provide extra strength and security.
- Flexible Power Options: Supports hardwiring or outdoor outlet power.
- Compatibility: Designed exclusively for the Wyze Sprinkler Controller.
This weatherproof box is ideal for mounting your controller outdoors without worry, extending the lifespan of your smart irrigation system.
Why Choose Wyze for Smart Sprinkler and Water Conservation?
Wyze’s smart sprinkler ecosystem is designed to be affordable, easy to install, and highly effective at conserving water through intelligent automation. By combining the Wyze Sprinkler Controller with the Sprinkler Plus weather skip service, you get a hands-free irrigation system that adapts to your yard’s needs and local weather conditions.
WaterSense Certification: Using Wyze’s weather-based watering can save billions of gallons of water nationwide, reducing water bills and environmental impact.
Installation is DIY-friendly and takes less than 20 minutes, making it accessible for any homeowner looking to upgrade to a smarter, greener lawn care solution.
DIY installation in under 20 minutes gets your smart sprinkler system up and running quickly.
Summary of Wyze Smart Sprinkler Products
Product | Purpose | Price (USD) | Key Benefit |
Wyze Sprinkler Controller | Smart irrigation controller | $59.99 | Remote control, 8 zones, WaterSense certified |
Wyze Sprinkler Plus | Weather skip subscription | $9.99/year | Intelligent weather-based watering |
Wyze Weatherproof Controller Box | Outdoor protection accessory | $39.99 | Durable, weatherproof enclosure |
Conclusion
For affordable, smart sprinkler control with advanced weather skip features to conserve water, Wyze offers a complete solution. The Wyze Sprinkler Controller combined with the Sprinkler Plus subscription service ensures your lawn gets the right amount of water at the right time—never too much, never too little. Protect your investment outdoors with the Weatherproof Sprinkler Controller Box and enjoy a greener, healthier yard with less water waste.
# Product Tags and Highlights
What is the Wyze Sprinkler Controller and how does it work?
The Wyze Sprinkler Controller is an affordable, Wi-Fi-enabled smart irrigation controller that allows you to manage your lawn watering remotely using the Wyze app. It supports up to 8 customizable zones, offers personalized watering schedules, and is WaterSense certified for water efficiency. Installation is DIY-friendly and takes less than 20 minutes.How does Wyze Sprinkler Plus help conserve water?
Wyze Sprinkler Plus is a subscription service that uses hyper-local weather data to automatically skip watering when it’s raining, too cold, too windy, or when soil moisture is sufficient. This intelligent weather skip feature helps prevent water waste and ensures your plants are only watered when needed.What are the main features of the Wyze Sprinkler Controller?
Key features of the Wyze Sprinkler Controller include remote control via the Wyze app, support for 8 customizable zones, personalized weekly schedules, WaterSense certification, integration with Wyze Cam for monitoring, offline operation for up to 14 days, and sunrise/sunset watering adjustments.Is the Wyze Sprinkler Controller easy to install?
Yes, the Wyze Sprinkler Controller is designed for easy DIY installation and can typically be set up in under 20 minutes, making it accessible for most homeowners.What is included with the Wyze Sprinkler Plus subscription?
Wyze Sprinkler Plus includes advanced weather-based features such as automatic weather skips, smart schedules tailored to each zone, advanced zone insights with moisture data, a cycle/soak feature to reduce runoff, and a 5-day weather forecast. The first year is free with the purchase of a Wyze Sprinkler Controller.How does the Wyze Weatherproof Sprinkler Controller Box protect my system?
The Wyze Weatherproof Sprinkler Controller Box is an IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from dust, water, and harsh outdoor conditions. It features a durable design with four clasps and a gridded cover, and supports both hardwiring and outdoor outlet power.Can I control my Wyze Sprinkler system remotely?
Yes, you can control your Wyze Sprinkler system remotely using the Wyze app. This allows you to start, stop, or adjust watering schedules from anywhere, providing convenience and flexibility.What is WaterSense certification and why is it important?
WaterSense certification is an EPA recognition for products that meet water efficiency and performance criteria. The Wyze Sprinkler Controller is WaterSense certified, meaning it helps conserve water and can reduce your water bills while maintaining a healthy lawn.How much does the Wyze smart sprinkler system cost?
The Wyze Sprinkler Controller is priced at $59.99, the Wyze Sprinkler Plus subscription is $9.99 per year (with the first year free), and the Wyze Weatherproof Controller Box is $39.99.Is the Wyze Weatherproof Sprinkler Controller Box compatible with other controllers?
No, the Wyze Weatherproof Sprinkler Controller Box is designed exclusively for use with the Wyze Sprinkler Controller.
