Affordable Smart Air Purifiers for Google Home & Alexa
Affordable Smart Air Purifiers Compatible with Google Home and Alexa
Looking for an affordable smart air purifier that seamlessly integrates with your Google Home or Alexa devices? Discover the Wyze Air Purifier lineup—designed to deliver premium air quality, smart controls, and whisper-quiet operation without breaking the bank. Whether you want a brand-new unit or a refurbished option, Wyze offers versatile solutions tailored to your home environment and budget.
Wyze Air Purifier: Premium Performance at a Smart Price
Powerful Air Cleaning with Whisper-Quiet Operation
The Wyze Air Purifier boasts an impressive Clean Air Delivery Rate (CADR) of 350 m³/h, cycling through 12,000 cubic feet of air every hour. This means your living space can enjoy fresh, purified air rapidly and efficiently. Despite its power, it operates at an ultra-quiet noise level of just 21 decibels—quieter than a purring kitten—making it perfect for bedrooms, nurseries, or home offices.
Smart Controls and Voice Assistant Compatibility
Control your Wyze Air Purifier effortlessly via the Wyze app or through voice commands with Google Home and Alexa. The purifier features smart automation modes, real-time air quality alerts, and laser particle detection that monitors ultra-fine particles down to 0.3 microns. You can adjust fan speeds, dim the display, and even enable a child lock for safety.
Customizable Filters for Every Need
Choose from three premium HEPA filter variants to match your specific air quality concerns:
  • Allergen Filter (Standard): Ideal for everyday allergens like dust, pollen, and pet dander.
  • Formaldehyde Filter (Premium): Targets harmful gases and chemicals such as formaldehyde from new furniture or construction materials.
  • Wildfire Filter (Special Use): Designed to absorb pollutants from wildfire smoke and other heavy pollution.
Easy Maintenance and Portability
The purifier includes a convenient handle for easy room-to-room movement and simple filter replacement that takes just a few steps. Plus, with a price starting at $169.99, it offers luxury air purification without the luxury price tag. Wyze Air Purifier in Living Room Enjoy clean air effortlessly with Wyze Air Purifier in your home environment.
(Refurbished) Wyze Air Purifier: Smart Savings with Trusted Quality
If you want to save even more, consider the refurbished Wyze Air Purifier. It offers the same powerful 350 CADR, whisper-quiet 21 dB operation, and smart features including AQ alerts and laser particle detection. Certified CARB compliant and suitable for rooms up to 550 sq. ft, this refurbished model is a budget-friendly way to bring smart air purification into your home.
  • Price: $139.99
  • Compatible with Google Home and Alexa
  • Recommended filter replacement every 6 months
  • Power supply: AC 120V / 60 Hz
This option is perfect for those who want premium smart air quality without paying full price.
Wyze Air Filter: Customize Your Air Purifier’s Performance
Tailor Your Air Quality with Specialized Filters
Not all air pollution is the same, so why settle for a one-size-fits-all filter? Wyze Air Filters let you customize your purifier’s performance based on your environment and health needs:
  • Allergen Filter: Combines Pre-Filter, HEPA 13, and granulated carbon to trap common allergens.
  • Formaldehyde Filter: A premium-grade filter that captures and destroys formaldehyde and other VOCs, protecting you from harmful gases.
  • Wildfire Filter: Uses chemically modified granulated carbon to maximize absorption of wildfire smoke and pollution.
Easy Filter Replacement
Replacing your filter is quick and hassle-free—just remove the old filter, insert the new one, and continue enjoying clean air. Filters are available for one-time purchase or subscription, ensuring you always have fresh filters on hand. Replacing Wyze Air Purifier Filter Simple filter changes keep your Wyze Air Purifier running at peak performance.
Why Choose Wyze for Your Smart Air Purification?
"A luxury air purifier without a luxury price tag."
Wyze combines advanced air cleaning technology with smart home integration, making it easy to maintain healthy indoor air quality. With compatibility for both Google Home and Alexa, you can control your air purifier hands-free or remotely via the app. The combination of powerful filtration, quiet operation, and customizable filters makes Wyze Air Purifier the ideal choice for anyone seeking affordable, smart air purification.
Summary of Key Features
FeatureWyze Air Purifier (New & Refurbished)Wyze Air Filter Options
CADR350 m³/hN/A
Noise Level21 decibels (ultra-quiet)N/A
Room CoverageUp to 550 sq. ft (42 m²)N/A
Smart ControlsApp control, Google Home & Alexa compatibleN/A
Particle DetectionLaser particle sensor (0.3 microns)N/A
Filter TypesAllergen, Formaldehyde, WildfireAllergen, Formaldehyde, Wildfire
Filter ReplacementEvery 6 months recommendedEasy 3-step replacement
Price Range$139.99 (refurbished) to $194.99 (premium filter)$37.99 - $63.99 per filter
Invest in a Wyze Air Purifier today and breathe smarter with affordable, voice-controlled air purification tailored to your lifestyle.
FeatureWyze Air Purifier (Refurbished)Wyze Air PurifierWyze Air Filter
TypeRefurbishedConnected HomeConnected Home (Accessory)
Price$139.99$169.99 - $194.99$37.99 - $63.99
Variants (Pre-installed filter)Any FilterAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)
CADR (Clean Air Delivery Rate)350 CADR350 CADR (12,000 cu ft/hr)214 - 186 CFM (varies by filter type)
Noise Level21 decibels (whisper-quiet)21 - 54 decibelsN/A
Filter TypePremium filtersTrue HEPA + Activated Carbon (varies by filter)Pre-filter + True HEPA + Activated Carbon (varies by filter)
Smart Controls & FeaturesYes (smart controls, AQ alerts, laser particle detection)Yes (smart controls, AQ alerts, laser particle detection, Alexa & Google Home compatible)N/A
Air Quality SensorLaser particle detectionLaser particle sensor (0.3 microns, 100x/sec)N/A
Filter Service LifeNot specifiedNot specified4-12 months (varies by filter type)
DimensionsNot specified8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
WeightNot specified1.5 - 1.9 lb (varies by filter)1.5 - 1.9 lb (varies by filter)
Return PolicyFinal Sale, No Returns30-day hassle-free returnsRefund only
AvailabilitySold out / Out of stockLow stock (43 left)Available
What makes Wyze Air Purifiers affordable and smart?Wyze Air Purifiers offer premium air cleaning performance, smart controls, and ultra-quiet operation at a budget-friendly price. Starting at $169.99 for new units and $139.99 for refurbished models, they provide advanced features like app control, Google Home and Alexa compatibility, and customizable filters without the high price tag.
Are Wyze Air Purifiers compatible with Google Home and Alexa?Yes, Wyze Air Purifiers are fully compatible with both Google Home and Alexa. You can control your purifier using voice commands or through the Wyze app for convenient, hands-free operation.
What is the Clean Air Delivery Rate (CADR) of Wyze Air Purifiers?Wyze Air Purifiers have a powerful Clean Air Delivery Rate (CADR) of 350 m³/h, allowing them to cycle through 12,000 cubic feet of air every hour and efficiently purify rooms up to 550 sq. ft.
How quiet is the Wyze Air Purifier during operation?The Wyze Air Purifier operates at an ultra-quiet noise level of just 21 decibels, making it quieter than a purring kitten. This makes it ideal for bedrooms, nurseries, and home offices.
What types of filters are available for Wyze Air Purifiers?Wyze offers three premium HEPA filter options: the Allergen Filter for dust, pollen, and pet dander; the Formaldehyde Filter for harmful gases and chemicals; and the Wildfire Filter for absorbing pollutants from wildfire smoke and heavy pollution.
How often should I replace the filter in my Wyze Air Purifier?It is recommended to replace your Wyze Air Purifier filter every 6 months to maintain optimal air cleaning performance. Filter replacement is quick and easy, requiring just a few simple steps.
What is the difference between new and refurbished Wyze Air Purifiers?Both new and refurbished Wyze Air Purifiers offer the same powerful 350 CADR, ultra-quiet 21 dB operation, and smart features like air quality alerts and laser particle detection. The refurbished model is a more budget-friendly option, priced at $139.99, and is certified CARB compliant.
How do I replace the filter in my Wyze Air Purifier?Replacing the filter is simple: just remove the old filter, insert the new one, and your Wyze Air Purifier is ready to use. Filters are available for one-time purchase or subscription, ensuring you always have a fresh filter on hand.
Can I move my Wyze Air Purifier between rooms easily?Yes, the Wyze Air Purifier features a convenient handle for easy portability, allowing you to move it from room to room as needed.
What smart features are included with Wyze Air Purifiers?Wyze Air Purifiers include smart automation modes, real-time air quality alerts, laser particle detection down to 0.3 microns, adjustable fan speeds, display dimming, and a child lock for safety. All features can be controlled via the Wyze app or voice assistants.
Are Wyze Air Purifiers suitable for large rooms?Yes, Wyze Air Purifiers are suitable for rooms up to 550 sq. ft (42 m²), making them ideal for living rooms, bedrooms, and home offices.
What is the price range for Wyze Air Purifiers and filters?Wyze Air Purifiers range from $139.99 for refurbished models to $194.99 for units with premium filters. Replacement filters are priced between $37.99 and $63.99, depending on the type.
What are the different filter options available for the Wyze Air Purifier?How often do I need to replace the filters in the Wyze Air Purifier?Is there a warranty available for the Wyze Air Purifier?
