Affordable IP65 Telephoto Security Cameras for Home Use
Affordable IP65 Rated Telephoto Security Cameras for Home Surveillance
When it comes to securing your home, having a reliable, weather-resistant security camera with telephoto capabilities is essential. If you're searching for an affordable IP65 rated telephoto security camera that offers excellent home surveillance, Wyze has you covered with its latest lineup. These cameras combine advanced features, robust weather resistance, and smart home compatibility—all at budget-friendly prices.
Wyze Cam OG Telephoto: Precision Telephoto Surveillance
Key Features
  • 3x Telephoto Lens: Capture distant details clearly with a narrow field of view (27° diagonal), perfect for focused monitoring of entryways or driveways.
  • IP65 Weather Resistance: Designed to withstand rain, snow, and dust, making it ideal for outdoor use.
  • 1080p Full HD Video: Crisp video quality day and night with 4 IR LEDs for night vision.
  • 8x Digital Zoom: Zoom in on important details without losing clarity.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for clear communication.
  • Fast Live Streaming & Notifications: 3X faster notifications and quicker live streaming keep you instantly informed.
  • Local Storage Support: Save footage on microSD cards up to 256GB without subscription fees.
  • Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
Why Choose Wyze Cam OG Telephoto?
This camera is perfect for homeowners who want to zoom in on specific areas without sacrificing image quality. Its IP65 rating ensures it performs reliably outdoors in all weather conditions, while the telephoto lens provides detailed surveillance at an affordable price point.
Wyze Cam v4: Versatile Outdoor Security with Enhanced Color Night Vision
Key Features
  • 2.5K QHD Resolution: Higher resolution than standard 1080p for crystal-clear images.
  • Enhanced Color Night Vision: See vibrant colors even in low light, revealing details traditional night vision misses.
  • IP65 Weather Resistance: Durable for outdoor placement in any weather.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and loud siren.
  • Wi-Fi 6 Support: Stronger, more reliable wireless connection.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) with no subscription required.
  • Smart Assistant Compatibility: Works with Alexa and Google Assistant.
  • Easy Setup & Magnetic Mount: Quick installation with Bluetooth setup and screw-free magnetic mounting.
Ideal Use Cases
Wyze Cam v4 is a great all-around outdoor camera for homeowners who want superior image quality and color night vision. Its spotlight and siren add an extra layer of security, making it a proactive choice for home protection. Wyze Cam Pan v3 in Snowy Outdoor Setting
Wyze Cam Pan v3: 360° Pan and Tilt with Weatherproof Design
Key Features
  • 360° Pan & 180° Tilt: Covers every angle with smooth, quiet motion tracking.
  • IP65 Weather Resistance: Suitable for outdoor use with the Wyze Outdoor Power Adapter.
  • Color Night Vision: Starlight sensor technology for vivid nighttime images.
  • Automatic Motion Tracking: Camera follows moving objects automatically.
  • Privacy Mode: Easily disable camera view by pointing it downward.
  • Two-Way Audio: Communicate through the camera with clear sound.
  • Custom Detection Zones: Focus alerts on specific areas of interest.
  • Local Storage & Cam Plus Support: Save footage locally or subscribe for advanced AI detection.
Why It Stands Out
The Wyze Cam Pan v3 is perfect for those who want comprehensive coverage of their property with the flexibility to pan and tilt remotely. Its IP65 rating and quiet motor make it a reliable outdoor camera that won’t disturb your environment.
Summary: Best Affordable IP65 Telephoto Cameras for Home Surveillance
Camera ModelTelephoto LensWeather ResistanceResolutionNight Vision TypePrice Range
Wyze Cam OG Telephoto3x TelephotoIP651080p Full HDIR Night Vision$25.98+
Wyze Cam v4NoIP652.5K QHDEnhanced Color Night$35.98+
Wyze Cam Pan v3NoIP651080p Full HDColor Night Vision$39.98+
Each of these cameras offers IP65 weather resistance, making them durable choices for outdoor home surveillance. The Wyze Cam OG Telephoto stands out for its telephoto zoom capabilities at an unbeatable price, while the Wyze Cam v4 offers superior image quality and color night vision. The Wyze Cam Pan v3 provides dynamic coverage with pan and tilt features, ideal for monitoring large areas.
Enhance Your Home Security Setup
For a discreet and stylish way to integrate your Wyze cameras indoors, consider the Wyze Cam Vase accessory. It combines elegant home decor with practical security, allowing your camera to blend seamlessly into your living space without obstructing its view.
"Protect your home with affordable, weatherproof telephoto cameras that deliver clear, detailed surveillance day and night."
Product Highlights
Wyze Cam v4 Mounted Outdoors Two-Way Audio Feature with Pet
Secure your home confidently with Wyze's affordable, IP65 rated telephoto security cameras designed for reliable outdoor surveillance and smart home integration.
FeatureWyze Cam OG TelephotoWyze Cam v4Wyze Cam Pan v3Wyze Cam Vase
TypeWired Security CameraWired Security CameraWired Pan-Tilt Security CameraCamera Accessory (Decorative Vase)
ResolutionNot specified (HD live video)2.5K QHD (2560x1440)1080p (1920x1080)N/A
Field of View (FOV)27° (3x Telephoto lens)115.8° (DFOV), 98.5° (HFOV), 53.1° (VFOV)120° FOVN/A
Zoom3x Telephoto zoom8x Digital zoom8x Digital zoomN/A
Night VisionColor Night VisionEnhanced Color Night Vision4 IR LEDs (850 nm), Color Night VisionN/A
AudioImproved 2-way audioEnhanced 2-way talk with noise & echo cancelBuilt-in speaker & mic; 2-way audioN/A
Siren90 dB user-activated siren99 dB built-in sirenNot specifiedN/A
SpotlightNoMotion-activated spotlightNoN/A
Weather ResistanceIP65 (Indoor/Outdoor)IP65 (Indoor/Outdoor)IP65 (Indoor/Outdoor)N/A
ConnectivityWiredWired, Wi-Fi 6 support802.11 b/g/n 2.4 GHz Wi-Fi (no 5 GHz)N/A
Local StorageSupports Wyze microSD cards up to 256GBSupports microSD cards up to 512GBSupports microSD cards up to 256GBN/A
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionN/A
Motion Detection3x faster motion notificationsMotion & sound detection with zonesPush notificationsN/A
Smart FeaturesCustomized detection zones, Smoke & CO alertsMotion detection zones, Smoke & CO alertsPush notificationsN/A
DimensionsNot specified2in x 2in x 2 3/8in124mm x 60mm x 63mm3.35mm x 3.35mm x 4.13mm
WeightNot specified0.49 lb (222 g)11.29 oz (320 g)1.08 lbs (0.49 kg)
Mounting OptionsWorks with Wyze Cam OG Stack KitStand, Wall mount, Ceiling mount, MagneticScrew 1/4" - 20Tool-free installation
IntegrationWorks with Wyze ecosystemAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTN/A
Power SourceWiredWiredWiredN/A
Price (Single Pack)$25.98$35.98$39.98$19.99
Additional FeaturesQuicker live streaming, 2-way audio upgradeWi-Fi 6, 24/7 local recording, spotlight360° pan, 180° tilt, noise & echo cancellationDiscreet home security, cable management
Indoor/Outdoor UseIndoor/Outdoor (outdoor with IP65 rating)Indoor/Outdoor (IP65)Indoor/Outdoor (IP65)Indoor (Accessory)
What is an IP65 rated telephoto security camera?An IP65 rated telephoto security camera is a surveillance camera designed to withstand dust, rain, and other harsh weather conditions, making it suitable for outdoor use. The telephoto lens allows you to zoom in on distant objects, providing clear and detailed monitoring of specific areas like entryways or driveways.
Which Wyze camera offers telephoto zoom for home surveillance?The Wyze Cam OG Telephoto features a 3x telephoto lens, allowing you to capture distant details with a narrow 27° field of view. This makes it ideal for focused monitoring of specific areas around your home.
Are Wyze security cameras weatherproof for outdoor use?Yes, Wyze security cameras such as the Wyze Cam OG Telephoto, Wyze Cam v4, and Wyze Cam Pan v3 are all IP65 rated, ensuring they are weather-resistant and suitable for outdoor installation in rain, snow, or dusty environments.
What are the main differences between Wyze Cam OG Telephoto, Wyze Cam v4, and Wyze Cam Pan v3?The Wyze Cam OG Telephoto offers a 3x telephoto lens for focused surveillance, the Wyze Cam v4 provides 2.5K QHD resolution and enhanced color night vision, and the Wyze Cam Pan v3 features 360° pan and 180° tilt for comprehensive coverage. All three are IP65 rated for outdoor use.
Do Wyze security cameras support local storage without a subscription?Yes, Wyze cameras support local storage via microSD cards up to 256GB, allowing you to save footage without any subscription fees. This feature is available on models like the Wyze Cam OG Telephoto, Wyze Cam v4, and Wyze Cam Pan v3.
Can Wyze security cameras be integrated with smart home systems?Wyze cameras are compatible with popular smart home platforms such as Alexa, Google Assistant, and IFTTT, enabling seamless integration and voice control within your smart home ecosystem.
What night vision features do Wyze outdoor cameras offer?Wyze outdoor cameras offer advanced night vision capabilities. The Wyze Cam OG Telephoto uses 4 IR LEDs for clear night vision, the Wyze Cam v4 features enhanced color night vision for vibrant images in low light, and the Wyze Cam Pan v3 utilizes a starlight sensor for vivid nighttime images.
How easy is it to install Wyze outdoor security cameras?Wyze cameras are designed for easy installation. The Wyze Cam v4, for example, offers Bluetooth setup and a screw-free magnetic mount for quick and hassle-free placement. Other models also feature user-friendly mounting options.
What is the price range for Wyze IP65 rated security cameras?Wyze IP65 rated security cameras are budget-friendly, with prices starting at $25.98 for the Wyze Cam OG Telephoto, $35.98 for the Wyze Cam v4, and $39.98 for the Wyze Cam Pan v3.
Is there a discreet way to use Wyze cameras indoors?Yes, the Wyze Cam Vase accessory allows you to integrate your Wyze camera into your home decor, providing a stylish and discreet indoor surveillance solution without obstructing the camera's view.
What are the key features of the Wyze Cam v4?Can you tell me more about the weather resistance of the Wyze cameras?Are there any ongoing sales or discounts for Wyze cameras?
