Affordable Indoor Colored LED Light Strip Bundles for Home
Transform your living space with vibrant, customizable LED light strips that bring color, ambiance, and smart control to your home—all without breaking the bank. Whether you want to highlight your favorite corners, create mood lighting, or sync your lights to music, these affordable indoor colored LED light strip bundles offer the perfect solution for every room.
Wyze Light Strip: Brilliant Accent Lighting at a Great Price
The Wyze Light Strip is an excellent choice for those seeking affordable, high-quality LED accent lighting. Available in a 32.8-foot length for just $35.99, this light strip lets you color your world with 16 million colors, perfect for backlighting screens, illuminating headboards, or brightening dark corners.
Key Features:
  • 16 million colors to customize every corner of your home.
  • Music Mode syncs lights to your favorite tracks using a built-in microphone.
  • Sun Match adjusts color temperature to natural light cycles for a healthier ambiance.
  • Voice Control compatible with Alexa and Google Assistant.
  • Vacation Mode simulates occupancy when you're away.
  • Sleep Routines for gradual light changes mimicking sunrise and sunset.
  • Easy peel-and-stick installation for any indoor surface.
Add a splash of color and smart convenience to your home with the Wyze Light Strip, designed to brighten your space affordably and effortlessly.
Wyze Light Strip in cozy living room Alt text: Cozy living room illuminated by colorful Wyze Light Strip under cabinets and shelves
Wyze Light Strip Pro: Multi-Color Segment Control for Custom Vibes
For those who want more advanced lighting customization, the Wyze Light Strip Pro offers multi-color segment control with 16 customizable segments. Although currently unavailable, this 16.4-foot strip is priced at $29.99 and delivers professional-grade lighting effects.
Highlights:
  • 16 million RGB colors plus tunable white for perfect ambiance.
  • Multi-color segment control lets you create multiple colors on one strip.
  • Music Mode syncs lights to the beat of your music.
  • Trimmable design to fit any space.
  • Voice control with Alexa and Google Assistant.
  • Vacation Mode, Sleep Routines, Timers, and Automations for smart living.
Elevate your home lighting with the Wyze Light Strip Pro’s advanced features, perfect for creating dynamic, colorful environments tailored to your mood.
Living room with Wyze Light Strip Pro behind sofa Alt text: Modern living room glowing with multi-color Wyze Light Strip Pro behind sofa
Smart Lighting Kits: Bundles for Complete Home Ambiance
If you want a comprehensive lighting upgrade, consider the Smart Lighting Kits that bundle Wyze Bulb Color BR30 bulbs with the Wyze Light Strip Pro. These kits provide brilliant LED accent lighting with both bulbs and strips, perfect for whole-room color control.
What’s Included:
  • Wyze Bulb Color BR30 bulbs with 30 to 950 lumens and color temperature range from 1800K to 6500K.
  • Wyze Light Strip Pro (16.4 feet) for multi-color accent lighting.
  • High Color Rendering Index (90+) for vivid, natural colors.
  • Compatible with voice assistants and smart home automation.
These kits are ideal for those who want to effortlessly color their entire room with smart, energy-efficient lighting solutions.
Why Choose Wyze LED Light Strips for Your Home?
Affordable, versatile, and smart — Wyze LED light strips are designed to fit seamlessly into your home décor while offering powerful features usually found in premium products.
  • Budget-friendly pricing makes it easy to add colorful lighting anywhere.
  • Smart features like voice control, music sync, and automation enhance convenience.
  • Easy installation with peel-and-stick backing and trimmable design.
  • Multiple lengths and bundles to suit any room size or lighting need.
Bring your home to life with affordable indoor colored LED light strips that combine style, technology, and ease of use.
Summary of Featured Products
Product NameLengthPriceKey Feature
Wyze Light Strip32.8 Feet$35.9916 million colors, Music Mode
Wyze Light Strip Pro16.4 Feet$29.99Multi-color segment control
Smart Lighting Kit (Bulb + Strip Pro)Bulbs + 16.4 Feet$52.98+Complete smart lighting bundle
Enhance your home ambiance today with these affordable, colorful LED light strip bundles designed for indoor use. Whether you want simple accent lighting or a full smart lighting experience, Wyze has you covered.
FeatureWyze Light StripWyze Light Strip ProSmart Lighting Kit - Bulb Color BR30 + Light Strip Pro BundleSmart Lighting Kit - Bulb Color + Light Strip Pro Bundle
TypeConnected HomeSmart LightingSmart LightingSmart Lighting
Size Variants16.4 ft, 32.8 ft16.4 ft, 32.8 ft16.4 ft Light Strip Pro + Bulb Color BR30 (2 or 4 pack)16.4 ft Light Strip Pro + Bulb Color (2 or 4 pack)
Price Range$19.99 - $35.99$29.99 - $44.99$53.98 (2-pack), $77.97 (4-pack)$52.98 (2-pack), $74.97 (4-pack)
Colors16 million colors, one color per strip16 million colors, multicolor segment control (up to 16 colors per strip)16 million colors, multicolor segment control (Light Strip Pro)16 million colors, multicolor segment control (Light Strip Pro)
Lighting EffectsBasic lighting effectsAdvanced lighting effectsAdvanced lighting effects (Light Strip Pro)Advanced lighting effects (Light Strip Pro)
Protective CoatingNo epoxy coatingClear epoxy coatingClear epoxy coating (Light Strip Pro)Clear epoxy coating (Light Strip Pro)
Music ModeYes, syncs to music via built-in micYes, syncs to music via built-in micYes, syncs to music via built-in mic (Light Strip Pro)Yes, syncs to music via built-in mic (Light Strip Pro)
Sun MatchYesYesYesYes
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Vacation ModeYesYesYesYes
Sleep RoutinesYesYesYesYes
Timers & AutomationsYesYesYesYes
Trimmable DesignNot specifiedYesYes (Light Strip Pro)Yes (Light Strip Pro)
Customizable ZonesNo16 customizable zones16 customizable zones (Light Strip Pro)16 customizable zones (Light Strip Pro)
Bulb IncludedNoNoWyze Bulb Color BR30 included (2 or 4 pack)Wyze Bulb Color included (2 or 4 pack)
Bulb Lumens RangeN/AN/A30 - 950 lumens (Bulb Color BR30)30 - 1100 lumens (Bulb Color)
Bulb Color Temperature RangeN/AN/A1800K - 6500K1800K - 6500K
Bulb Power ConsumptionN/AN/A11.5W (Bulb Color BR30)12W (Bulb Color)
Communication ModesWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, Bluetooth
UsageIndoor onlyIndoor onlyIndoor onlyIndoor only
WarrantyNot specifiedNot specified1 Year1 Year
What are the benefits of using Wyze indoor colored LED light strips?Wyze indoor colored LED light strips offer affordable, customizable lighting with 16 million colors, smart features like voice control, music sync, and automation, and easy peel-and-stick installation. They are perfect for creating ambiance, accent lighting, and enhancing your home décor without breaking the bank.
What is the difference between Wyze Light Strip and Wyze Light Strip Pro?The Wyze Light Strip offers 16 million colors, music sync, Sun Match, and voice control in a 32.8-foot length. The Wyze Light Strip Pro, available in a 16.4-foot length, features multi-color segment control with 16 customizable segments, allowing multiple colors on one strip, along with all the smart features of the standard strip.
How much do Wyze LED light strips cost?The Wyze Light Strip is priced at $35.99 for a 32.8-foot strip, while the Wyze Light Strip Pro costs $29.99 for a 16.4-foot strip. Smart Lighting Kits, which bundle Wyze Bulb Color BR30 bulbs with the Light Strip Pro, start at $52.98.
Can Wyze LED light strips be controlled with voice assistants?Yes, both Wyze Light Strip and Wyze Light Strip Pro are compatible with popular voice assistants like Alexa and Google Assistant, allowing you to control your lighting hands-free.
What smart features do Wyze LED light strips offer?Wyze LED light strips include features such as Music Mode (syncs lights to music), Sun Match (adjusts color temperature to natural light cycles), Vacation Mode (simulates occupancy), Sleep Routines (gradual light changes), timers, automations, and voice control.
Are Wyze LED light strips easy to install?Yes, Wyze LED light strips feature a peel-and-stick backing for easy installation on any indoor surface. The strips are also trimmable to fit your desired space.
What is included in the Wyze Smart Lighting Kit?The Wyze Smart Lighting Kit includes Wyze Bulb Color BR30 bulbs (with 30 to 950 lumens and a color temperature range of 1800K to 6500K) and a Wyze Light Strip Pro (16.4 feet). This bundle provides a complete smart lighting solution for your home.
Can I use Wyze LED light strips for whole-room lighting?Yes, Wyze offers bundles and kits that combine LED light strips and smart bulbs, making it easy to color your entire room and create a cohesive lighting experience.
Are Wyze LED light strips energy efficient?Yes, Wyze LED light strips are designed to be energy efficient while providing vivid, customizable lighting for your home.
What lengths are available for Wyze LED light strips?The Wyze Light Strip is available in a 32.8-foot length, while the Wyze Light Strip Pro comes in a 16.4-foot length. Bundles and kits may include different combinations to suit your needs.
What are the key features of the Wyze Light Strip?Can you tell me more about the Smart Lighting Kits available?Do you have any deals, ongoing sales, discounts, or promotions?
