20ft Wyze Cam USB Extension Cable for Wide Area Surveillance
Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
If you're looking to position your Wyze Cam for wide area surveillance, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This cable gives you the freedom to place your camera exactly where you need it without worrying about short cable lengths.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length: 20 feet of flexible USB extension for maximum reach.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Ease of Use: Simply plug it in to extend your camera’s power source without any complicated setup.
  • Affordable: Priced at just $7.99, it’s a cost-effective way to enhance your surveillance setup.
This extension cable is ideal for mounting your Wyze Cam in hard-to-reach places such as high corners, wide porches, or detached garages, ensuring you get the best coverage possible.
Enhance Outdoor Surveillance with Wyze Cam v4 Outdoor Bundle
For those who want a complete outdoor security solution, the Wyze Cam v4 Outdoor Bundle offers advanced features that complement the extended placement made possible by the 20ft USB extension cable.
Why Choose Wyze Cam v4 Outdoor Bundle?
  • Crystal-clear 2.5K QHD Resolution: Capture every detail with stunning clarity.
  • Enhanced Color Night Vision: See vibrant colors even in low light conditions.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected to deter intruders.
  • 24/7 Local Recording: Continuous recording with included 128GB microSD card.
  • Wi-Fi 6 Support: Faster and more reliable wireless connection.
  • Smart Home Compatibility: Works with Alexa and Google Assistant for voice control.
  • Weatherproof Design: Built to withstand outdoor elements for year-round security.
This bundle includes the Wyze Cam v4, an outdoor power adapter, and a microSD card, making it a comprehensive package for your home security needs. Outdoor Security Camera in Use Alt text: Wyze Cam v4 mounted outdoors providing wide area surveillance
Power Your Wyze Cam Anywhere with the Lamp Socket v2 Bundle
If you want to power your Wyze Cam without relying on traditional outlets, the Cam v4 + Lamp Socket v2 Bundle is an innovative solution that lets you use your existing outdoor light fixtures.
Benefits of the Lamp Socket v2 Bundle
  • No Outlet Needed: Powers Wyze Cam v4 and other compatible models directly from your lamp socket.
  • Easy Installation: Just screw it in like a lightbulb—no wiring or electrician required.
  • Smart Lighting Integration: Control your outdoor lights and camera together via the Wyze app.
  • Motion-Activated Lighting: Lights turn on automatically when your Wyze Cam detects motion.
  • Expandable Setup: Link multiple lamp sockets for broader coverage and control.
  • Energy Efficient: Compatible with CFL or LED bulbs under 20W (incandescent bulbs not recommended).
This bundle is perfect for those who want a clean, wire-free look while maintaining powerful surveillance capabilities. Smart Outdoor Lighting Setup Alt text: Outdoor porch light with Wyze Cam powered by lamp socket
Summary: Ideal Setup for Wide Area Surveillance
To achieve wide area surveillance with your Wyze Cam, combining the 20ft USB Extension Cable with the Wyze Cam v4 Outdoor Bundle or the Lamp Socket v2 Bundle offers unmatched flexibility and power options. Whether you want to extend your camera’s reach, enhance outdoor security with advanced features, or power your camera through existing light fixtures, these products provide a smart, scalable solution.
"Extend your camera’s reach and power it smartly for comprehensive home security."
Product Highlights
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4 Outdoor BundleCam v4 + Lamp Socket v2 Bundle
Product TypeUSB Extension CableSecurity Camera BundleSecurity Camera Bundle with Lamp Socket
Included Items20ft USB Extension CableWyze Cam v4, Wyze Outdoor Power Adapter, Wyze MicroSD Card 128GBWyze Cam v4, Wyze Lamp Socket v2
Compatible CamerasWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Price$7.99$69.99 (compare at $72.96)$49.96 (compare at $52.96)
ResolutionN/A2.5K QHD2.5K QHD (via Wyze Cam v4)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision (via Wyze Cam v4)
Local RecordingN/A24/7 local recording with MicroSD cardYes (via Wyze Cam v4)
Wi-Fi SupportN/AWi-Fi 6 support802.11 b/g/n 2.4GHz (Lamp Socket connectivity)
Power SourceUSBWired (Wyze Outdoor Power Adapter included)Powered via Lamp Socket (E26 socket, 120V~, 60Hz)
Weather ResistanceN/AIP65 rated (camera)Lamp Socket: Not weatherproof, suitable for damp locations
Spotlight & SirenN/AMotion-activated spotlight and sirenNo (Lamp Socket controls power, no spotlight)
MountingN/AStandard mounting optionsLamp Socket mounts in standard light socket
Additional FeaturesExtends USB cable length to 20ftAlexa & Google Assistant compatibilityMotion-activated lights, dusk to dawn scheduling
WarrantyNot specifiedNot specified1-Year warranty
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to position your camera in hard-to-reach places such as high corners, wide porches, or detached garages. This ensures you get optimal surveillance coverage without being limited by short cable lengths.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models, making it a versatile accessory for various Wyze cameras.
How do I install the Wyze Cam USB Extension Cable?Installation is simple—just plug the extension cable into your Wyze Cam and connect it to your power source. No complicated setup or tools are required.
What are the benefits of the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle offers advanced features such as 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, 24/7 local recording with a 128GB microSD card, Wi-Fi 6 support, smart home compatibility with Alexa and Google Assistant, and a weatherproof design for reliable outdoor security.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card, providing everything you need for comprehensive outdoor surveillance.
How does the Lamp Socket v2 Bundle power my Wyze Cam?The Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 and other compatible models directly from your existing outdoor light fixtures. Simply screw the lamp socket into your light fixture like a bulb—no wiring or electrician needed.
Can I control my outdoor lights and Wyze Cam together with the Lamp Socket v2 Bundle?Yes, the Lamp Socket v2 Bundle enables smart lighting integration, allowing you to control both your outdoor lights and Wyze Cam through the Wyze app. The lights can also be set to turn on automatically when your camera detects motion.
Is the Lamp Socket v2 Bundle energy efficient?Yes, the Lamp Socket v2 Bundle is energy efficient and compatible with CFL or LED bulbs under 20W. Incandescent bulbs are not recommended for use with this bundle.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is affordably priced at just $7.99, making it a cost-effective way to enhance your Wyze Cam setup.
What is the best setup for wide area surveillance with Wyze Cam?For wide area surveillance, it is recommended to combine the 20ft USB Extension Cable with either the Wyze Cam v4 Outdoor Bundle or the Lamp Socket v2 Bundle. This setup provides maximum flexibility in camera placement, advanced security features, and versatile power options for comprehensive home security.
Can you tell me more about the compatibility of the 20ft USB extension cable with different Wyze Cam models?What are the benefits of using the Wyze Cam v4 Outdoor Bundle in conjunction with the 20ft USB extension cable?Do you have any ongoing promotions or discounts for the Wyze Cam accessories?
