Wyze Telephoto Cam for Seamless Stacking and Dual View Monitoring
Enhance your home or business security with Wyze’s innovative camera solutions designed for seamless stacking and dual view monitoring. Whether you want to expand your field of vision or create a multi-angle surveillance setup, Wyze offers versatile products and accessories that make it easy to customize your monitoring system.
Wyze Cam v4: The Core of Dual View Monitoring
Advanced Video Quality and Features
The Wyze Cam v4 is a powerful plug-in camera that delivers stunning 2.5K QHD (2560x1440) video resolution, ensuring crystal-clear footage day and night. Equipped with a CMOS Starlight Sensor and 4 IR LEDs plus 2 white spotlight LEDs, it offers excellent night vision including color night vision capabilities. This makes it ideal for capturing detailed images in low-light conditions.
Flexible Mounting and Connectivity
With multiple mounting options such as stand, wall mount, ceiling mount, and magnetic adhesive mounts, the Wyze Cam v4 can be positioned anywhere for optimal coverage. It supports both 2.4 GHz Wi-Fi and Wi-Fi 6 for reliable connectivity and integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
Smart Features for Enhanced Security
- 8x digital zoom for close-up views
- Built-in siren and 99dB waterproof speaker for deterrence
- Two-way talk with noise and echo cancellation
- Weather resistance rated IP65 for indoor/outdoor use
- Local microSD storage up to 512 GB and cloud storage options
This camera is perfect for stacking with telephoto lenses or pairing with other Wyze cameras to create a comprehensive dual view monitoring system.
Wyze Window Mount: Perfect Accessory for Telephoto and Dual View Setup
Glare-Free Window Mounting Solution
The Wyze Window Mount is an essential accessory for anyone looking to mount their Wyze Cam v4 or Wyze Cam OG Telephoto directly on glass surfaces. This mount eliminates glare and reflections, providing a crystal-clear view through windows, which is ideal for exterior monitoring without compromising image quality.
Compatibility and Use Cases
- Compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto
- Ideal for smart home security setups requiring exterior views
- Easy installation on glass surfaces for campers, motorhomes, and travel trailers
This accessory enables seamless stacking of telephoto cameras on windows, expanding your monitoring angles without bulky external mounts.
Wyze Battery Cam Pro: Wireless Flexibility for Remote Monitoring
High-Resolution Wire-Free Camera
The Wyze Battery Cam Pro offers 2.5K HDR video resolution with a wide 134° diagonal field of view, perfect for covering large areas wirelessly. Its rechargeable 6200mAh battery lasts up to 6 months on a single charge, making it ideal for locations without easy access to power.
Advanced Detection and Night Vision
- Radar + PIR motion detection for precise alerts
- Integrated spotlight and siren for active deterrence
- Night vision with 2 IR LEDs and 2 powerful white LEDs for color night vision
- Weatherproof IP65 rating for all-season outdoor use
Easy Integration and Mounting
- Supports 2.4 GHz and 5 GHz Wi-Fi for stable connections
- Compatible with Alexa, Google Assistant, and IFTTT
- Standard 1/4” - 20 mounting thread for versatile installation
The Battery Cam Pro complements your dual view monitoring by providing wireless coverage in hard-to-reach or power-limited areas, perfect for stacking views with telephoto cams.
Why Choose Wyze for Telephoto and Dual View Monitoring?
Wyze’s ecosystem of cameras and accessories is designed to work together seamlessly, allowing you to stack telephoto lenses and combine multiple cameras for comprehensive dual view monitoring. Whether you want to monitor your front porch, backyard, or multiple angles of your property, Wyze provides affordable, high-quality solutions with smart features and easy installation.
With the Wyze Cam v4 as your main camera, enhanced by the Wyze Window Mount for glare-free window placement, and the wireless flexibility of the Wyze Battery Cam Pro, you can build a robust, multi-angle security system tailored to your needs.
Summary of Featured Products
Product | Key Features | Price (USD) |
Wyze Cam v4 | 2.5K QHD, color night vision, IP65, smart integrations | $100.00 |
Wyze Window Mount | Glare-free window mounting for Wyze cams | $9.98 |
Wyze Battery Cam Pro | Wire-free, 2.5K HDR, radar motion detection, IP65 | $159.98 (1 pack) |
What is dual view monitoring with Wyze cameras?
Dual view monitoring with Wyze cameras refers to the ability to combine multiple Wyze cameras, such as the Wyze Cam v4 and Wyze Battery Cam Pro, to monitor different angles or areas simultaneously. This setup enhances security coverage by providing comprehensive, multi-angle surveillance for your home or business.How does the Wyze Cam v4 improve home security?
The Wyze Cam v4 enhances home security with its 2.5K QHD video resolution, color night vision, 8x digital zoom, built-in siren, two-way talk, and weather-resistant IP65 rating. It supports flexible mounting options and integrates with Alexa, Google Assistant, and IFTTT for smart home automation.Can I use Wyze cameras for outdoor monitoring?
Yes, both the Wyze Cam v4 and Wyze Battery Cam Pro are rated IP65 weather-resistant, making them suitable for both indoor and outdoor use. They are designed to withstand various weather conditions, ensuring reliable security monitoring year-round.What is the Wyze Window Mount and how does it work?
The Wyze Window Mount is an accessory that allows you to mount compatible Wyze cameras directly on glass surfaces. It eliminates glare and reflections, providing a clear view through windows. This is ideal for exterior monitoring without compromising image quality.Which Wyze cameras are compatible with the Wyze Window Mount?
The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto. This makes it a versatile accessory for various Wyze camera models.What are the benefits of stacking Wyze telephoto cameras?
Stacking Wyze telephoto cameras allows you to expand your field of vision and create a multi-angle surveillance setup. This approach provides more comprehensive coverage and enables you to monitor multiple areas or angles simultaneously for enhanced security.How long does the Wyze Battery Cam Pro last on a single charge?
The Wyze Battery Cam Pro features a rechargeable 6200mAh battery that can last up to 6 months on a single charge, depending on usage and environmental factors. This makes it ideal for locations without easy access to power.Does the Wyze Battery Cam Pro support wireless installation?
Yes, the Wyze Battery Cam Pro is a wire-free camera that supports both 2.4 GHz and 5 GHz Wi-Fi connections. It offers flexible, wireless installation and is easy to mount using its standard 1/4” - 20 mounting thread.Can Wyze cameras be integrated with smart home systems?
Yes, Wyze cameras including the Cam v4 and Battery Cam Pro integrate seamlessly with Alexa, Google Assistant, and IFTTT. This allows for convenient voice control and automation within your smart home ecosystem.What storage options are available for Wyze cameras?
Wyze cameras offer both local and cloud storage options. The Wyze Cam v4 supports local microSD storage up to 512 GB, and cloud storage is also available for added convenience and security.Are Wyze cameras easy to install?
Yes, Wyze cameras are designed for easy installation with multiple mounting options, including stand, wall, ceiling, and magnetic adhesive mounts. The Wyze Window Mount also allows for simple, glare-free window placement.What is the price of the Wyze Cam v4, Wyze Window Mount, and Wyze Battery Cam Pro?
The Wyze Cam v4 is priced at $100.00, the Wyze Window Mount at $9.98, and the Wyze Battery Cam Pro at $159.98 for a 1-pack.
