Wyze Cam Pan v3: 1080p HD, Crisp Low Light Security Camera
Wyze Cam Pan v3: Crisp 1080p HD Security Camera with Low Light Excellence
If you're searching for a camera that records in 1080p HD and offers crisp footage in low light, the Wyze Cam Pan v3 series is your perfect match. Designed as a versatile indoor/outdoor security camera, the Wyze Cam Pan v3 delivers exceptional video quality, advanced motion tracking, and reliable weather resistance, making it ideal for any home or business security setup.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security with Cloud Storage
The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers everything you need to get started with smart home security:
  • 1080p Full HD Video: Capture clear, detailed footage day and night.
  • Color Night Vision with Starlight Sensor: Unlike traditional black and white night vision, this camera provides vibrant color footage even in low light, ensuring you never miss a detail.
  • 360° Pan and 180° Tilt: Complete room coverage with smooth, quiet motorized movement that automatically tracks motion.
  • IP65 Weather Resistance: Use it indoors or outdoors with confidence, protected against rain and dust. (Outdoor use requires the Wyze Outdoor Power Adapter sold separately.)
  • Privacy Mode: Instantly disable the camera’s view by pointing it downward for peace of mind.
  • Two-Way Audio: Communicate through the camera using the Wyze app, perfect for talking to family, pets, or visitors.
  • Cam Plus Subscription: Enjoy unlimited event video cloud storage and smart notifications for people, packages, and vehicles.
This bundle is a great value for those who want both local and cloud storage options with advanced smart features. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 weatherproof for outdoor use
Wyze Cam Pan v3: Standalone Camera with Flexible Options
The Wyze Cam Pan v3 is available as a standalone camera or in multi-packs, offering flexibility for different security needs:
  • Full 1080p HD Resolution with smooth 20 FPS daytime and 15 FPS nighttime video.
  • 360° Horizontal and 180° Vertical View Range: Double the tilt coverage compared to previous models, allowing the camera to look straight up and down.
  • Automatic Motion Tracking: The camera detects and follows movement quietly, so it won’t disturb your household.
  • Color Night Vision: Powered by a Starlight sensor, it captures vivid color footage even in near darkness.
  • IP65 Weatherproof Rating: Perfect for outdoor installation with the optional outdoor power adapter.
  • Custom Detection Zones & Alerts: Set specific areas to monitor and receive instant notifications on your phone.
  • Smoke and Carbon Monoxide Alerts: Receive alerts if your Wyze Cam hears smoke or CO alarms.
This camera is ideal for users who want a reliable, weatherproof security camera with advanced pan and tilt capabilities.
Pan v3 Outdoor Bundle: Complete Outdoor Security Solution
For those focused on outdoor security, the Pan v3 Outdoor Bundle includes the Wyze Cam Pan v3 camera paired with the Wyze Outdoor Power Adapter, designed specifically for all-weather use:
  • IP67 Weather Resistance: Enhanced protection against water and dust, suitable for harsh outdoor environments.
  • 1080p HD Video with H.264 Encoding: Efficient video compression for smooth streaming and storage.
  • 1/2.9" CMOS Image Sensor: Delivers sharp, clear images with a wide 120° field of view.
  • Night Vision with 4 IR LEDs: Provides clear black and white night footage up to 29.6 feet.
  • Power Adapter with L-shaped MicroUSB Cable: Designed for outdoor durability and easy installation.
  • Local Storage Support: Compatible with up to 128GB microSD cards for extensive video recording.
This bundle is perfect for users who want a robust, weatherproof camera system ready to patrol your property in any weather.
Why Choose Wyze Cam Pan v3 for Your 1080p HD Security Needs?
"Wyze Cam Pan v3 combines affordability, advanced features, and weatherproof design to deliver crisp, reliable footage in any lighting condition."
  • Crisp 1080p HD Video ensures you capture every detail clearly.
  • Color Night Vision powered by Starlight sensors means no more grainy black and white footage in the dark.
  • 360° Pan and 180° Tilt provide full coverage with smooth, quiet motion tracking.
  • Weatherproof Design (IP65/IP67 depending on bundle) lets you install it indoors or outdoors without worry.
  • Smart Features like two-way audio, privacy mode, and customizable detection zones enhance your security experience.
  • Flexible Storage Options with local microSD support and optional Cam Plus cloud subscription.
Additional Features Across Wyze Cam Pan v3 Models
  • Two-Way Audio: Speak and listen through the camera using the Wyze app, ideal for interacting with visitors or pets.
Two-way audio with pet interaction Communicate easily with two-way audio
  • Custom Patrol Routes: Set up to 4 waypoints for the camera to automatically scan your room or yard.
  • Smart Notifications: Receive alerts for motion, sound, and even specific events like crying babies or barking dogs with Cam Plus.
  • Smoke and CO Alarm Alerts: Get notified immediately if your camera detects smoke or carbon monoxide alarms.
Conclusion
The Wyze Cam Pan v3 lineup is the ultimate choice for anyone looking for a 1080p HD camera that excels in low light conditions with advanced pan and tilt capabilities. Whether you want a simple indoor camera, a weatherproof outdoor bundle, or a full-featured package with cloud storage, Wyze Cam Pan v3 offers unbeatable value and performance.
FeatureWyze Cam Pan v3 + 30-Day Cam Plus BundleWyze Cam Pan v3Pan v3 Outdoor Bundle
Price$39.98$39.98 (1 Pack) / $77.96 (2 Pack) / $114.94 (3 Pack)$76.96
Color VariantsBlack, WhiteBlack, WhiteBlack, White
Camera TypeIndoor/Outdoor, 360° pan, 180° tiltIndoor/Outdoor, 360° pan, 180° tiltIndoor/Outdoor, 360° pan, 180° tilt
Weather ResistanceIP65IP65IP67
Outdoor Power Adapter RequiredYes (sold separately)Yes (sold separately)Included (Wyze Outdoor Power Adapter + L-shaped MicroUSB)
Video Resolution1920 x 1080 (1080p)1920 x 1080 (1080p)1920 x 1080 (1080p)
Video FPSDaytime 20 fps / Nighttime 15 fpsDaytime 20 fps / Nighttime 15 fpsDaytime 20 fps / Nighttime 15 fps
Field of View120°120°120°
Pan & Tilt Range360° horizontal, 180° vertical360° horizontal, 180° vertical360° horizontal, 180° vertical
Night VisionColor Night Vision with Starlight SensorColor Night Vision with Starlight Sensor4 IR LEDs (850 nm)
Motion TrackingAutomatic motion trackingAutomatic motion trackingAutomatic motion tracking
Two-Way AudioYesYesYes
Cam Plus Subscription30-Day free trial included, then $2.99/month30-Day free trial included, then $2.99/monthNot included
Cloud StorageUnlimited Event Video Cloud Storage (with Cam Plus)Unlimited Event Video Cloud Storage (with Cam Plus)Not specified
Local Storage SupportSupports microSD cards (sold separately)Supports microSD cards (sold separately)Supports microSD cards (sold separately)
Dimensions (H x W x D)Not specifiedNot specified124mm x 60mm x 63mm
WeightNot specifiedNot specified11.29 oz (320 g)
Additional Bundle Items30-Day Cam Plus subscriptionAvailable in multi-packsIncludes Wyze Outdoor Power Adapter + L-shaped MicroUSB
Warranty1 Year1 Year1 Year
What is the video quality of the Wyze Cam Pan v3?The Wyze Cam Pan v3 records in crisp 1080p Full HD resolution, delivering clear and detailed footage both day and night.
Does the Wyze Cam Pan v3 have color night vision?Yes, the Wyze Cam Pan v3 features color night vision powered by a Starlight sensor, allowing it to capture vibrant color footage even in low light conditions.
Can the Wyze Cam Pan v3 be used outdoors?Yes, the Wyze Cam Pan v3 is weatherproof with an IP65 rating for the standalone camera and an IP67 rating in the Outdoor Bundle, making it suitable for both indoor and outdoor use. For outdoor installation, the Wyze Outdoor Power Adapter is required.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera and a 30-day Cam Plus subscription, offering unlimited event video cloud storage, smart notifications for people, packages, and vehicles, and all the advanced features of the Wyze Cam Pan v3.
How does the Wyze Cam Pan v3’s motion tracking work?The Wyze Cam Pan v3 features automatic motion tracking with smooth, quiet motorized movement. It can pan 360° horizontally and tilt 180° vertically to follow movement and provide complete room or area coverage.
What storage options are available for Wyze Cam Pan v3?The Wyze Cam Pan v3 supports flexible storage options, including local storage with a microSD card (up to 128GB) and cloud storage through the optional Cam Plus subscription.
Does the Wyze Cam Pan v3 support two-way audio?Yes, the Wyze Cam Pan v3 has two-way audio, allowing you to speak and listen through the camera using the Wyze app. This feature is ideal for communicating with family, pets, or visitors.
What is Privacy Mode on the Wyze Cam Pan v3?Privacy Mode allows you to instantly disable the camera’s view by pointing it downward, giving you peace of mind when you want privacy.
Can I set custom detection zones with the Wyze Cam Pan v3?Yes, you can set custom detection zones on the Wyze Cam Pan v3 to monitor specific areas and receive instant notifications when motion is detected in those zones.
Does the Wyze Cam Pan v3 provide alerts for smoke or carbon monoxide alarms?Yes, the Wyze Cam Pan v3 can send you alerts if it hears smoke or carbon monoxide alarms, helping you stay informed about potential emergencies.
What is the difference between the Wyze Cam Pan v3 standalone camera and the Outdoor Bundle?The standalone Wyze Cam Pan v3 is suitable for both indoor and outdoor use (with the outdoor power adapter), while the Pan v3 Outdoor Bundle includes the camera and a Wyze Outdoor Power Adapter, offering enhanced IP67 weather resistance for harsh outdoor environments.
How does the Cam Plus subscription enhance the Wyze Cam Pan v3?The Cam Plus subscription provides unlimited event video cloud storage, smart notifications for people, packages, and vehicles, and advanced event detection features for your Wyze Cam Pan v3.
Can I set patrol routes with the Wyze Cam Pan v3?Yes, you can set up to 4 custom patrol waypoints for the Wyze Cam Pan v3 to automatically scan your room or yard.
What are the key features of the Wyze Cam Pan v3?Can you explain the benefits of the 30-Day Cam Plus Bundle?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Pan v3?
