Wyze Starter Shield Bundle for Smart Home Security with Accessories
Enhance your smart home security and convenience with the Wyze Starter Shield Bundle, featuring essential accessories designed to complement your Wyze devices. This bundle offers practical add-ons that improve your home’s safety, automation, and everyday ease.
Wyze Universal Wi-Fi Chime: Never Miss a Visitor
Key Features:
- Easy Setup: No complicated wiring needed; simply plug in and connect.
- Wide Compatibility: Works seamlessly with all Wyze Cams and doorbells.
- Customizable Alerts: Choose from 17 different chime tones to suit your preference.
- Smart Automations: Program the chime to ring when your camera detects a person, keeping you informed even when you’re away.
- Compact Design: Measures 81 x 53 x 38 mm, fitting discreetly in any room.
- Reliable Connectivity: Supports IEEE802.11 b/g/n 2.4 GHz Wi-Fi and Bluetooth BLE 5.0.
- Voice Assistant Integration: Compatible with Alexa, Hey Google, and IFTTT for hands-free control.
The Wyze Universal Wi-Fi Chime ensures you never miss a ding-dong, adding an extra layer of awareness to your smart home security setup.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
Why It’s Essential:
- IP65 Weatherproof Rating: Designed to withstand rain, dust, and harsh outdoor conditions.
- Robust Build: Features 4 secure clasps and a gridded cover for enhanced durability.
- Flexible Power Options: Can be powered via hardwire or outdoor outlet, providing installation versatility.
- Perfect Compatibility: Made exclusively for the Wyze Sprinkler Controller, ensuring a perfect fit and protection.
Protect your sprinkler controller from the elements and extend its lifespan with this rugged, weatherproof enclosure.
Alt text: Outdoor sprinkler controller protected by weatherproof box
Wyze Cordless Vacuum S - Battery Pack: Extra Power for Your Cleaning Routine
Highlights:
- Designed for Wyze Cordless Vacuum S: Ensures perfect compatibility and performance.
- Extended Cleaning Time: Provides additional battery life so you can clean longer without interruption.
- Hassle-Free Replacement: Easy to swap in and out, keeping your vacuum ready for action.
- 30-Day Return Policy: Buy with confidence thanks to Wyze’s hassle-free returns.
Keep your Wyze Cordless Vacuum S powered up and ready to tackle every corner of your home with this reliable battery pack.
Why Choose the Wyze Starter Shield Bundle?
This bundle combines smart home security with practical accessories that enhance your Wyze ecosystem. From alerting you instantly when someone’s at your door to protecting your outdoor devices and keeping your home clean, these accessories are designed to work seamlessly together.
Elevate your smart home experience with Wyze’s trusted accessories, engineered for convenience, durability, and smart automation.
Summary of Included Accessories:
Product | Purpose | Price (USD) |
Wyze Universal Wi-Fi Chime | Smart doorbell alerts | 19.98 |
Wyze Weatherproof Sprinkler Box | Outdoor sprinkler protection | 39.99 |
Wyze Cordless Vacuum S Battery | Extra vacuum battery power | 59.99 |
Invest in the Wyze Starter Shield Bundle today and enjoy a smarter, safer, and more efficient home environment.
What is included in the Wyze Starter Shield Bundle?
The Wyze Starter Shield Bundle includes three essential accessories: the Wyze Universal Wi-Fi Chime for smart doorbell alerts, the Wyze Weatherproof Sprinkler Controller Box for outdoor sprinkler protection, and the Wyze Cordless Vacuum S Battery Pack for extra vacuum battery power.How does the Wyze Universal Wi-Fi Chime enhance home security?
The Wyze Universal Wi-Fi Chime ensures you never miss a visitor by providing customizable alerts with 17 different chime tones. It can be programmed to ring when your Wyze camera detects a person, keeping you informed even when you’re away.Is the Wyze Universal Wi-Fi Chime compatible with all Wyze devices?
Yes, the Wyze Universal Wi-Fi Chime works seamlessly with all Wyze Cams and doorbells, and it integrates with Alexa, Hey Google, and IFTTT for hands-free control.What are the installation requirements for the Wyze Universal Wi-Fi Chime?
The Wyze Universal Wi-Fi Chime is easy to set up with no complicated wiring required. Simply plug it in and connect it to your Wi-Fi network (supports IEEE802.11 b/g/n 2.4 GHz) and Bluetooth BLE 5.0.What makes the Wyze Weatherproof Sprinkler Controller Box essential for outdoor use?
The Wyze Weatherproof Sprinkler Controller Box is designed with an IP65 weatherproof rating, making it resistant to rain, dust, and harsh outdoor conditions. Its robust build with 4 secure clasps and a gridded cover ensures your Wyze Sprinkler Controller is protected and lasts longer.Is the Wyze Weatherproof Sprinkler Controller Box compatible with other sprinkler controllers?
No, the Wyze Weatherproof Sprinkler Controller Box is made exclusively for the Wyze Sprinkler Controller, ensuring a perfect fit and optimal protection.How is the Wyze Weatherproof Sprinkler Controller Box powered?
The Wyze Weatherproof Sprinkler Controller Box offers flexible power options and can be powered via hardwire or an outdoor outlet, providing versatile installation choices.What are the benefits of the Wyze Cordless Vacuum S Battery Pack?
The Wyze Cordless Vacuum S Battery Pack is designed specifically for the Wyze Cordless Vacuum S, providing extended cleaning time and easy, hassle-free replacement so you can clean longer without interruption.Does the Wyze Cordless Vacuum S Battery Pack come with a return policy?
Yes, the Wyze Cordless Vacuum S Battery Pack comes with a 30-day return policy, allowing you to buy with confidence and return the product if needed.Why should I choose the Wyze Starter Shield Bundle for my smart home?
The Wyze Starter Shield Bundle is designed to enhance your smart home security, convenience, and automation. It combines practical accessories that work seamlessly with your Wyze devices, helping you stay informed, protect your outdoor equipment, and keep your home clean efficiently.
