Wyze Robot Vacuum Replacement Brushes & Filters Kit Online
Wyze Robot Vacuum Replacement Brushes and Filters Kit Online
If you own a Wyze Robot Vacuum, keeping it in peak condition is essential for maintaining a spotless home. Over time, brushes and filters wear out, reducing cleaning efficiency. Fortunately, Wyze offers a comprehensive Replacement Parts Kit designed specifically for your robot vacuum, ensuring it continues to perform like new.
Complete Wyze Robot Vacuum Replacement Parts Kit
All-in-One Maintenance Solution
The Wyze Robot Vacuum - Replacement Parts Kit is the ultimate maintenance bundle for your device. It includes:
  • 4 Edge Brushes: These small but vital brushes sweep dirt and debris from edges and corners.
  • 2 Main Brushes: The primary brushes that pick up dust and larger particles from floors.
  • 4 HEPA Filters: High-efficiency particulate air filters that trap fine dust, allergens, and pet dander, improving air quality.
This kit is perfect for routine upkeep, helping your vacuum maintain optimal suction and cleaning performance.
Keeping your Wyze Robot Vacuum’s brushes and filters fresh ensures thorough cleaning and extends the life of your device.
Wyze Robot Vacuum HEPA Filter Replacement
Fresh Filters for Cleaner Air
If you only need to replace the filter, the Wyze Robot Vacuum - HEPA Filter is available separately. These filters are designed to fit perfectly with your Wyze Robot Vacuum and provide:
  • Superior filtration to capture microscopic dust and allergens.
  • Easy installation and replacement.
  • A cost-effective way to maintain air quality in your home.
Regular filter replacement is recommended to keep your vacuum running efficiently and to maintain a healthy environment.
Additional Replacement Parts for Wyze Robot Vacuum
Charging Station
The Wyze Robot Vacuum - Charging Station is a vital accessory that ensures your vacuum is always ready to clean. If your original charging dock is lost or damaged, this replacement station is fully compatible and easy to set up.
Power Adapter
For uninterrupted power supply, the Wyze Robot Vacuum - Power Adapter is available as a replacement part. It guarantees your vacuum can recharge properly and maintain its cleaning schedule.
Cleaning Pad
The Wyze Robot Vacuum - Pad accessory helps with mopping functions (if your model supports it), ensuring your floors get a thorough clean beyond vacuuming.
Why Choose Wyze Replacement Parts?
  • Perfect Compatibility: All parts are designed specifically for Wyze Robot Vacuum models.
  • Affordable Maintenance: Replacement parts are budget-friendly and help avoid costly repairs.
  • Easy to Replace: Simple installation means you can maintain your vacuum without professional help.
  • Reliable Quality: Genuine Wyze parts ensure your vacuum performs at its best.
Modern Living Room with Smart Vacuum Keep your home spotless with Wyze Robot Vacuum replacement parts.
Summary of Wyze Robot Vacuum Replacement Parts
ProductIncluded Items / FeaturesPrice (USD)
Replacement Parts Kit4 Edge Brushes, 2 Main Brushes, 4 HEPA Filters22.99
HEPA FilterSingle HEPA Filter4.99
Charging StationReplacement charging dock19.99
Power AdapterReplacement power adapter4.99
Cleaning PadReplacement cleaning pad4.99
Investing in genuine Wyze replacement brushes and filters ensures your robot vacuum continues to deliver efficient, thorough cleaning day after day. Keep your smart home spotless and fresh with these essential maintenance parts.
FeatureWyze Robot Vacuum - Replacement Parts KitWyze Robot Vacuum - HEPA FilterWyze Robot Vacuum - Charging Station
Product TypeReplacement Parts KitReplacement PartsReplacement Parts
Price$22.99$4.99$19.99
In the BoxEdge brush4, Main brush2, HEPA filter*4HEPA filter (1)Charging station
CompatibilityWyze Robot VacuumWyze Robot VacuumWyze Robot Vacuum
Quantity Available84 leftIn stockNot specified
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
CollectionsVacuum Accessories, Replacement Parts, Smart Home AccessoriesReplacement Parts, Smart Home AccessoriesReplacement Parts, Smart Home Accessories
What is included in the Wyze Robot Vacuum Replacement Parts Kit?The Wyze Robot Vacuum Replacement Parts Kit includes 4 edge brushes, 2 main brushes, and 4 HEPA filters. This all-in-one maintenance bundle is designed to keep your Wyze Robot Vacuum running efficiently and ensure thorough cleaning.
How often should I replace the brushes and filters on my Wyze Robot Vacuum?It is recommended to replace the brushes and filters on your Wyze Robot Vacuum regularly to maintain optimal cleaning performance and extend the life of your device. The frequency depends on usage, but checking and replacing them every few months is a good practice.
Are Wyze Robot Vacuum replacement parts compatible with all Wyze models?Yes, all Wyze Robot Vacuum replacement parts are designed specifically for Wyze Robot Vacuum models, ensuring perfect compatibility and easy installation.
What are the benefits of using a HEPA filter in my Wyze Robot Vacuum?HEPA filters in the Wyze Robot Vacuum trap fine dust, allergens, and pet dander, improving air quality in your home. Regularly replacing the HEPA filter ensures your vacuum maintains strong suction and provides cleaner air.
Can I purchase a single HEPA filter for my Wyze Robot Vacuum?Yes, you can purchase a single Wyze Robot Vacuum HEPA filter separately. It is designed for easy installation and provides superior filtration to capture microscopic dust and allergens.
What should I do if my Wyze Robot Vacuum charging station is lost or damaged?If your original charging dock is lost or damaged, you can purchase a replacement Wyze Robot Vacuum Charging Station. It is fully compatible and easy to set up, ensuring your vacuum is always ready to clean.
Is there a replacement power adapter available for the Wyze Robot Vacuum?Yes, a replacement power adapter for the Wyze Robot Vacuum is available. It ensures your vacuum can recharge properly and maintain its cleaning schedule.
Does Wyze offer a replacement cleaning pad for the robot vacuum?Yes, Wyze offers a replacement cleaning pad for the robot vacuum. This accessory is especially useful for models with mopping functions, helping to keep your floors extra clean.
Why should I choose genuine Wyze replacement parts for my robot vacuum?Genuine Wyze replacement parts are designed for perfect compatibility, are affordable, easy to install, and ensure reliable quality. Using authentic parts helps your Wyze Robot Vacuum perform at its best and avoids costly repairs.
Where can I buy Wyze Robot Vacuum replacement brushes, filters, and accessories?You can purchase Wyze Robot Vacuum replacement brushes, filters, and accessories online through the official Wyze website. Investing in genuine parts ensures your vacuum continues to deliver efficient and thorough cleaning.
What are the benefits of using the Wyze Robot Vacuum Replacement Parts Kit?How often should I replace the brushes and filters for my Wyze Robot Vacuum?Do you have any deals, ongoing sales, discounts, or promotions for Wyze products?
