Wyze Replacement Parts: L-Shaped Micro USB Adapter and Accessories
When it comes to maintaining and enhancing your Wyze smart camera setup, having the right replacement parts and accessories is essential. If you are searching for a
Wyze replacement L-shaped Micro USB adapter accessory, this page highlights the best compatible products designed to keep your Wyze devices powered and connected efficiently.
Wyze L-Shaped Micro USB Adapter
Perfect Compatibility for Wyze Cam Pan v3 and v3 Pro
The
Wyze L-Shaped Micro USB Adapter is a must-have replacement part for users of Wyze Cam Pan v3 or Cam v3 Pro. This adapter allows you to connect your Wyze Outdoor Power Adapter v1 or any other Micro USB cable seamlessly to your camera, ensuring a secure and space-saving connection.
- Price: $5.99
- Use Case: Works with Wyze Outdoor Power Adapter v1 or other Micro USB cables
- Compatibility: Wyze Cam Pan v3, Cam v3 Pro
- Design: L-shaped connector for better cable management and reduced strain on ports
- Return Policy: 30-day hassle-free returns
This adapter is ideal for outdoor or indoor setups where cable routing needs to be neat and protected from accidental disconnections.
Weather-Resistant Power Solution for Outdoor Cameras
To complement the L-shaped Micro USB adapter, the
Wyze Outdoor Power Adapter is designed to keep your Wyze cameras powered reliably in any weather condition. Rated IP67, it is resistant to rain, snow, and dust, making it perfect for outdoor installations.
- Price: Starting at $14.99 (various bundle options available)
- Weather Resistance: IP67 rating for all-weather durability
- Compatibility: Wyze Cam v3, v4, Pan v3, Battery Cam Pro (with appropriate adapters)
- Cable Length: 12.5 ft (3.8 m) main cable, plus additional AC and DC cable lengths
- Power Output: 5V 2A for stable camera operation
- Included Accessories: Wire clips, screws, screw anchors, and the L-shaped Micro USB adapter
- Warranty: 1-Year limited warranty
Note: Wyze Cam v3 Pro and Pan v3 require both the Outdoor Power Adapter and the L-shaped Micro USB Adapter for proper outdoor use.
Experience reliable outdoor security with Wyze’s weatherproof power solutions.
Wyze Cam Pan v3 USB Cable
Reliable Replacement USB Cable for Wyze Cam Pan v3
If you need a simple replacement USB cable for your Wyze Cam Pan v3, this official Wyze USB cable ensures consistent power and data transfer.
- Price: $1.99
- Type: Standard Micro USB cable
This cable is perfect for replacing lost or damaged cables without compromising your camera’s performance.
Why Choose Official Wyze Replacement Parts?
Using genuine Wyze replacement parts like the L-shaped Micro USB adapter and Outdoor Power Adapter guarantees compatibility, durability, and optimal performance. These parts are designed specifically for Wyze cameras, ensuring your devices stay powered and connected without hassle.
Keeping your Wyze cameras powered with the right accessories means uninterrupted security monitoring and peace of mind.
Summary of Wyze Replacement Accessories for L-Shaped Micro USB Adapter Needs
Product | Price | Key Features | Compatibility |
Wyze L-Shaped Micro USB Adapter | $5.99 | L-shaped design, easy connection | Wyze Cam Pan v3, v3 Pro |
Wyze Outdoor Power Adapter | $14.99+ | IP67 weather-resistant, long cable length | Wyze Cam v3, v4, Pan v3 |
Wyze Cam Pan v3 USB Cable | $1.99 | Official replacement USB cable | Wyze Cam Pan v3 |
By choosing these Wyze replacement parts, you ensure your smart home cameras remain functional and protected, whether indoors or outdoors. The L-shaped Micro USB adapter is a small but crucial accessory that enhances cable management and device longevity.
What is the Wyze L-Shaped Micro USB Adapter used for?
The Wyze L-Shaped Micro USB Adapter is a replacement accessory designed to provide a secure and space-saving connection for Wyze Cam Pan v3 and Cam v3 Pro cameras. It allows you to connect your Wyze Outdoor Power Adapter v1 or any other Micro USB cable, improving cable management and reducing strain on the camera’s ports.Which Wyze cameras are compatible with the L-Shaped Micro USB Adapter?
The L-Shaped Micro USB Adapter is compatible with Wyze Cam Pan v3 and Wyze Cam v3 Pro. It ensures a reliable connection for both indoor and outdoor setups.Is the Wyze Outdoor Power Adapter weather-resistant?
Yes, the Wyze Outdoor Power Adapter is rated IP67, making it resistant to rain, snow, and dust. This ensures reliable power for your Wyze cameras in all weather conditions, making it ideal for outdoor installations.What is included with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter comes with a 12.5 ft (3.8 m) main cable, additional AC and DC cable lengths, wire clips, screws, screw anchors, and the L-shaped Micro USB adapter. It also includes a 1-year limited warranty.Which Wyze cameras are compatible with the Outdoor Power Adapter?
The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (with appropriate adapters). For Wyze Cam v3 Pro and Pan v3, both the Outdoor Power Adapter and the L-shaped Micro USB Adapter are required for proper outdoor use.Can I buy a replacement USB cable for my Wyze Cam Pan v3?
Yes, you can purchase an official Wyze Cam Pan v3 USB cable as a replacement. This standard Micro USB cable ensures consistent power and data transfer for your camera.Why should I use official Wyze replacement parts and accessories?
Using genuine Wyze replacement parts like the L-shaped Micro USB adapter and Outdoor Power Adapter guarantees compatibility, durability, and optimal performance. These accessories are specifically designed for Wyze cameras, ensuring your devices remain powered and connected without hassle.What is the return policy for Wyze replacement parts?
Wyze replacement parts such as the L-shaped Micro USB Adapter and USB cables come with a 30-day hassle-free return policy, allowing you to shop with confidence.How much do Wyze replacement accessories cost?
The Wyze L-Shaped Micro USB Adapter is priced at $5.99, the Wyze Outdoor Power Adapter starts at $14.99 (with various bundle options), and the Wyze Cam Pan v3 USB cable is available for $1.99.
