Wyze L-Shaped Micro USB Adapter & Outdoor Power Kit for Cameras
Wyze L-Shaped Micro USB Adapter and Outdoor Power Adapter for Wyze Cameras
When it comes to powering your Wyze outdoor cameras reliably and safely, the Wyze Outdoor Power Adapter paired with the Wyze L-Shaped Micro USB Adapter is the perfect solution. Designed specifically for outdoor use, these accessories ensure your Wyze Cam Pan v3 and Wyze Cam v3 Pro stay powered through all weather conditions, providing continuous security and peace of mind.
Wyze Outdoor Power Adapter: Durable Power for Any Weather
Weather-Resistant and Reliable
The Wyze Outdoor Power Adapter is built to withstand rain, snow, and shine with an IP67 weather-resistant rating. This means it is fully protected against dust and can handle immersion in water up to 1 meter deep for 30 minutes, making it ideal for outdoor camera setups.
  • Input Power: 100V-240V AC
  • Output Power: 5V 2A DC
  • Cable Length: 12.5 ft (3.8 m) total cable length for flexible installation
  • Operating Temperature: -30°C to 50°C (-22°F to 122°F)
  • Connector to Camera: Micro USB
  • Connector to Wall Plug: 2-pin flat, US style
  • Weight: 235 g
  • Dimensions: 78.7 mm x 62.5 mm x 29.4 mm
  • Certifications: FCC, UL
  • Warranty: 1 Year
Complete Outdoor Power Kit
The adapter kit includes:
  • Wyze Outdoor Power Adapter
  • Weatherproof L-shaped Micro USB Adapter
  • Wire Clips and Screws for secure mounting
Note: The Wyze Cam v3 Pro and Pan v3 require both the Outdoor Power Adapter and the L-shaped Micro USB Adapter for safe outdoor use.
Wyze Cam Pan v3 in snowy outdoor setting Experience reliable outdoor security with Wyze Cam Pan v3 powered by the weatherproof adapter.
Wyze L-Shaped Micro USB Adapter: Perfect Fit for Outdoor Cameras
Designed for Compatibility and Convenience
The Wyze L-Shaped Micro USB Adapter is a compact and essential accessory that works seamlessly with the Wyze Outdoor Power Adapter. It allows the power cable to connect neatly to your Wyze Cam Pan v3 or Cam v3 Pro, reducing cable strain and improving weather resistance.
  • Compatible with:
  • Wyze Cam Pan v3
  • Wyze Cam v3 Pro
  • Wyze Outdoor Power Adapter v1
  • Price: $5.99 (available separately or bundled)
This adapter is especially useful for outdoor installations where a straight cable connection might be exposed or cumbersome. The L-shaped design helps keep the connection tight and protected from the elements.
Wyze Cam Pan v3: The Ideal Camera for Outdoor Monitoring
360° Pan and 180° Tilt with Weather Resistance
The Wyze Cam Pan v3 is a versatile indoor/outdoor security camera that offers full 360° horizontal pan and 180° vertical tilt, giving you comprehensive coverage of your property.
  • Video Resolution: 1080p Full HD
  • Night Vision: 4 IR LEDs (850 nm) for clear night monitoring
  • Weather Rating: IP65 (dust and water resistant)
  • Dimensions: 124 mm (H) x 60 mm (W) x 63 mm (D)
  • Weight: 320 g
  • Connectivity: 2.4 GHz Wi-Fi (802.11 b/g/n)
  • Audio: Built-in speaker and microphone with 2-way audio and noise cancellation
  • Power: Requires Wyze Outdoor Power Adapter for outdoor use
  • Certifications: FCC, UL, IC, TSCA
Smart Features and Easy Integration
  • Compatible with Alexa, Google Assistant, and IFTTT
  • Supports microSD cards up to 256 GB for local storage
  • Push notifications for motion and sound alerts
  • Smooth pan speed up to 110° per second
Wyze Cam Pan v3 outdoor lifestyle Wyze Cam Pan v3 delivers full coverage and weatherproof performance for your outdoor security needs.
Why Choose Wyze Outdoor Power Adapter with L-Shaped Micro USB Adapter?
"Ready for rain, snow, or shine" — the Wyze Outdoor Power Adapter combined with the L-shaped Micro USB Adapter is engineered to keep your Wyze cameras powered safely outdoors without interruption. This pairing is essential for Wyze Cam Pan v3 and Wyze Cam v3 Pro users who want reliable, weatherproof power solutions.
  • Ensures continuous power supply in harsh weather
  • Protects cable connections with weatherproof design
  • Easy to install with included mounting hardware
  • Compatible with multiple Wyze camera models
Summary
For anyone looking to power their Wyze outdoor cameras efficiently and safely, the Wyze Outdoor Power Adapter paired with the Wyze L-Shaped Micro USB Adapter is the best choice. Together, they provide a weatherproof, durable, and convenient power solution that keeps your Wyze Cam Pan v3 and Cam v3 Pro running smoothly in any outdoor environment.
FeatureWyze Outdoor Power AdapterWyze L-Shaped Micro USB AdapterWyze Cam Pan v3
TypeAccessoriesReplacement PartsCamera
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Works with Wyze Outdoor Power Adapter v1 or Micro USB cable for Cam Pan v3 and Cam v3 ProIndoor/outdoor 360° pan and 180° tilt camera
Weather ResistanceIP67Not specifiedIP65
Required for Outdoor UseYesYes (for Cam Pan v3 and Cam v3 Pro with Outdoor Power Adapter)Yes (requires Outdoor Power Adapter for outdoor use)
Power Adapter Output5V/2000mAN/A5V/2000mA
Cable LengthVaries by variant (e.g., 6" micro USB cable included with some bundles)N/A6" (1.8 m) micro USB cable included
Price$5.99 - $19.99 (depending on variant)$5.99$39.98 - $114.94 (depending on pack and variant)
Key FeaturesIP67 weather resistant, safe for outdoor useAllows Micro USB cable to work with Cam Pan v3 and Cam v3 Pro360° horizontal pan, 180° vertical tilt, 1080p HD, 2-way audio, color night vision
DimensionsOutdoor Power Adapter: 78.7 mm x 62.5 mm x 29.4 mm (for Outdoor Adapter in bundles)Not specified124mm (H) x 60mm (W) x 63mm (D)
WeightOutdoor Power Adapter: 235 g (in bundles)Not specified11.29 oz (320 g)
Included ItemsDepends on variant (Outdoor Adapter, L-shaped adapter, USB-C adapter)1x L-Shaped Micro USB AdapterCamera, 6' micro USB cable, power adapter, mounting kit, quick start guide
Warranty30-day hassle-free returns30-day hassle-free returns1-Year
What is the Wyze Outdoor Power Adapter and what cameras is it compatible with?The Wyze Outdoor Power Adapter is a weather-resistant power solution designed specifically for outdoor use with Wyze Cam Pan v3 and Wyze Cam v3 Pro. It ensures your cameras remain powered safely in all weather conditions.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter has an IP67 weather-resistant rating, making it fully protected against dust and capable of withstanding immersion in water up to 1 meter deep for 30 minutes. This makes it ideal for outdoor camera installations.
What is included in the Wyze Outdoor Power Adapter kit?The kit includes the Wyze Outdoor Power Adapter, a weatherproof L-shaped Micro USB Adapter, and wire clips and screws for secure mounting.
Why do I need the L-Shaped Micro USB Adapter for my Wyze outdoor camera?The L-Shaped Micro USB Adapter is essential for outdoor installations as it allows the power cable to connect neatly to your Wyze Cam Pan v3 or Cam v3 Pro, reducing cable strain and improving weather resistance. It helps keep the connection tight and protected from the elements.
Can I use the Wyze Outdoor Power Adapter with other Wyze cameras?The Wyze Outdoor Power Adapter is specifically designed for use with Wyze Cam Pan v3 and Wyze Cam v3 Pro. It is also compatible with the Wyze Outdoor Power Adapter v1.
What are the technical specifications of the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter has an input power of 100V-240V AC, output power of 5V 2A DC, a total cable length of 12.5 ft (3.8 m), and operates in temperatures from -30°C to 50°C (-22°F to 122°F). It features a micro USB connector for the camera and a 2-pin flat US-style wall plug.
Is the Wyze Outdoor Power Adapter certified and does it come with a warranty?Yes, the Wyze Outdoor Power Adapter is FCC and UL certified and comes with a 1-year warranty.
How much does the Wyze L-Shaped Micro USB Adapter cost?The Wyze L-Shaped Micro USB Adapter is priced at $5.99 and is available separately or as part of a bundle with the Wyze Outdoor Power Adapter.
What are the benefits of using the Wyze Outdoor Power Adapter with the L-Shaped Micro USB Adapter?Using both adapters together ensures a continuous power supply for your Wyze cameras in harsh weather, protects cable connections with a weatherproof design, and allows for easy installation with included mounting hardware.
What are the key features of the Wyze Cam Pan v3 for outdoor security?The Wyze Cam Pan v3 offers 360° horizontal pan, 180° vertical tilt, 1080p Full HD video, night vision, IP65 weather resistance, 2-way audio, and compatibility with Alexa, Google Assistant, and IFTTT. It requires the Wyze Outdoor Power Adapter for safe outdoor use.
Can you tell me more about the weather resistance of the Wyze Outdoor Power Adapter?What is the total cable length of the Wyze Outdoor Power Adapter?Are there any ongoing sales or discounts for the Wyze Outdoor Power Adapter or L-Shaped Micro USB Adapter?
