Wyze Refurbished Thermostat: Daily Scheduling & Energy Tips
Wyze Refurbished Thermostat: Smart Heating & Cooling at a Great Price
Looking for an affordable, eco-friendly smart thermostat with daily scheduling and energy-saving tips? The Wyze Refurbished Thermostat offers all the smart features you need at a fraction of the cost of a new unit. Fully tested and guaranteed to work like new, this refurbished model simplifies your home heating and cooling while helping you save energy.
Key Features of the Wyze Refurbished Thermostat
  • Smart Daily Scheduling: Easily program your thermostat to match your daily routine, ensuring your home is comfortable when you need it and saving energy when you don’t.
  • Energy Tips: Receive helpful energy-saving suggestions through the Wyze app to optimize your heating and cooling usage.
  • Connectivity: Supports 2.4GHz WiFi and Bluetooth for seamless integration with your home network.
  • Voice Control: Compatible with Alexa and Google Assistant for hands-free temperature adjustments.
  • Display: Features a crisp IPS display with a wide 180º viewing angle for easy readability.
  • Installation: Comes with a C-wire adapter and all necessary mounting hardware for straightforward setup.
  • Eco-Friendly: Packaged with recyclable materials and free from mercury, arsenic, and PVC.
  • Warranty: Includes a 1-year warranty for peace of mind.
Operating comfortably within indoor environments, the Wyze Refurbished Thermostat supports temperatures from 32°F to 130°F and humidity levels from 5% to 95% RH (non-condensing).
“It’s a like-new Wyze product, fully tested and guaranteed to work — now at an even better price.”
Wyze Thermostat: Brand New Smart Climate Control
If you prefer a brand new unit, the Wyze Thermostat offers the same smart heating and cooling features with a sleek design and reliable performance.
Highlights of the Wyze Thermostat
  • Daily Scheduling & Energy Efficiency: Customize your heating and cooling schedules to fit your lifestyle and reduce energy waste.
  • Smartphone Compatibility: Works with Android 9.0+ and iOS 15.0+ devices for easy control on the go.
  • Voice Assistant Integration: Supports Alexa and Google Assistant for convenient voice commands.
  • Robust Build: Made with durable PC+ABS body and PMMA faceplate materials.
  • Compact Dimensions: Measures 120mm (L) x 65mm (W) x 33mm (D), weighing less than 1 lb.
  • Power Source: Powered by 24VAC through the C terminal, with a low power consumption of under 3.5VA.
  • Included Accessories: Comes with everything needed for installation including a C-wire adapter, mounting plate, wall cover, screws, anchors, wire labels, screwdriver, and quick start guide.
  • Eco-Friendly Packaging: Designed with sustainability in mind.
This thermostat is perfect for indoor use and offers a modern, minimalist look in black or white to complement any home décor. Smart Home Comfort Experience smart comfort and energy savings with Wyze Thermostat.
Why Choose Wyze Thermostats with Daily Scheduling and Energy Tips?
Both the refurbished and new Wyze Thermostats provide:
  • Simplified Smart Home Integration: Easily connect to your existing smart home ecosystem.
  • Energy Savings: Intelligent scheduling and energy tips help reduce your utility bills.
  • User-Friendly Interface: The IPS display and app controls make managing your home climate effortless.
  • Affordable Options: Choose between a budget-friendly refurbished model or a brand new unit without compromising on features.
Whether you want to upgrade your home environment or replace an older thermostat, Wyze offers reliable, smart solutions that put comfort and savings at your fingertips.
Additional Support: Wyze Thermostat Replacement Part Kit
For maintenance or repairs, the Wyze Thermostat Replacement Part Kit is available, including screws, cables, and other essential components to keep your thermostat running smoothly.
  • Price: $19.99
  • Return Policy: 30-day hassle-free returns
  • Perfect for: DIY repairs and replacements to extend the life of your thermostat.
Summary
Invest in a Wyze Thermostat today to enjoy smart daily scheduling, energy-saving tips, and seamless voice control. Choose the refurbished option for unbeatable value or the new thermostat for the latest in smart home climate control technology.
Feature(Refurbished) Wyze ThermostatWyze ThermostatWyze Thermostat Replacement Part Kit
TypeRefurbishedConnected HomeReplacement Parts
Price$29.98 (Regular $79.98)$79.98$19.99
Return PolicyFinal Sale, no returns (Wyze decision)30-day hassle-free returns30-day hassle-free returns
ConditionLike new, fully testedNewNew replacement parts
Smart FeaturesYes, smart heating & coolingYes, smart heating & coolingNo
Voice Assistant CompatibilityAlexa, Google AssistantAlexa, Google AssistantN/A
Room Sensor SupportSupports up to 6 Wyze Room SensorsSupports up to 6 Wyze Room SensorsN/A
SchedulingYes, simple daily schedulingYes, simple daily schedulingN/A
Energy Saving TipsYes, via Wyze appYes, via Wyze appN/A
Installation20-minute DIY with app guidance20-minute DIY with app guidanceN/A
Included ItemsThermostat onlyThermostat only or with Room Sensor 3-pack (sold separately)Screws, cables, and other parts
WarrantyNot specified (refurbished)Standard Wyze warranty30-day hassle-free returns
What is the Wyze Refurbished Thermostat?The Wyze Refurbished Thermostat is a fully tested, like-new smart thermostat that offers daily scheduling, energy-saving tips, and seamless smart home integration at a fraction of the cost of a new unit. It is eco-friendly, comes with a 1-year warranty, and is guaranteed to work like new.
What features does the Wyze Refurbished Thermostat offer?Key features of the Wyze Refurbished Thermostat include smart daily scheduling, energy-saving tips via the Wyze app, 2.4GHz WiFi and Bluetooth connectivity, voice control with Alexa and Google Assistant, a crisp IPS display, easy installation with included hardware, eco-friendly packaging, and a 1-year warranty.
Is the Wyze Refurbished Thermostat easy to install?Yes, the Wyze Refurbished Thermostat comes with a C-wire adapter and all necessary mounting hardware, making installation straightforward for most users.
Does the Wyze Thermostat work with Alexa and Google Assistant?Yes, both the Wyze Refurbished Thermostat and the brand new Wyze Thermostat are compatible with Alexa and Google Assistant for convenient voice control.
What is the operating temperature and humidity range for the Wyze Thermostat?The Wyze Thermostat operates comfortably in indoor environments with temperatures ranging from 32°F to 130°F and humidity levels from 5% to 95% RH (non-condensing).
What is included with the Wyze Thermostat purchase?Each Wyze Thermostat, whether refurbished or new, includes a C-wire adapter, mounting plate, wall cover, screws, anchors, wire labels, screwdriver, and a quick start guide for easy installation.
Is the Wyze Thermostat eco-friendly?Yes, both the refurbished and new Wyze Thermostats are packaged with recyclable materials and are free from mercury, arsenic, and PVC, making them eco-friendly choices.
What warranty is provided with the Wyze Refurbished Thermostat?The Wyze Refurbished Thermostat comes with a 1-year warranty, ensuring peace of mind for your purchase.
Can I control the Wyze Thermostat from my smartphone?Yes, the Wyze Thermostat is compatible with Android 9.0+ and iOS 15.0+ devices, allowing you to control your home climate from anywhere using the Wyze app.
What is the Wyze Thermostat Replacement Part Kit?The Wyze Thermostat Replacement Part Kit includes screws, cables, and other essential components for DIY repairs and replacements, helping you extend the life of your thermostat. It is priced at $19.99 and comes with a 30-day hassle-free return policy.
What are the main differences between the Wyze Refurbished Thermostat and the new Wyze Thermostat?Both models offer smart daily scheduling, energy-saving tips, voice assistant integration, and easy installation. The main difference is that the refurbished model is a fully tested, like-new unit offered at a lower price, while the new model features the latest design and materials.
How does the Wyze Thermostat help save energy?The Wyze Thermostat provides intelligent daily scheduling and personalized energy-saving tips through the Wyze app, helping you optimize your heating and cooling usage and reduce utility bills.
What are the key features of the Wyze Refurbished Thermostat?How does the daily scheduling feature work on the Wyze Thermostat?Is there a warranty included with the Wyze Refurbished Thermostat?
