Wyze Mesh Router vs Wyze Mesh Router Pro: Key Differences Explained
When choosing a mesh router for your home, understanding the differences between the
Wyze Wi-Fi 6 Mesh Router and the
Wyze Wi-Fi 6E Mesh Router Pro is essential. Both routers are designed to eliminate dead spots and provide seamless internet coverage, but they cater to different needs and home environments. Below, we break down their specifications, features, and performance to help you decide which Wyze mesh router fits your lifestyle best.
Wyze Wi-Fi 6E Mesh Router Pro: The Ultimate in Speed and Coverage
Cutting-Edge Wi-Fi 6E Technology
The Wyze Wi-Fi 6E Mesh Router Pro is a top-tier router featuring the latest
Wi-Fi 6E (802.11ax with 6 GHz support) technology. This means it operates on three frequency bands: 2.4 GHz, 5 GHz, and the new, uncongested 6 GHz band. The addition of the 6 GHz band allows for faster speeds and less interference, ideal for homes with many connected devices.
- Maximum Internet Speed: Up to 2.5 Gbps
- Wi-Fi Bandwidth: AXE5400
- Frequency Bands: 2.4 GHz, 5 GHz, 6 GHz
- Devices Supported: 75+ devices simultaneously
- Coverage: 2000 sq. ft. per router
Powerful Hardware and Features
Equipped with a dual-core ARM Cortex A53 1 GHz CPU, 1 GB DDR3L RAM, and 128 MB SPI NAND Flash, the Pro model ensures smooth performance even under heavy network loads. It also includes:
- 6 antennas per node for robust signal strength
- Wired backhaul support for stable mesh connections
- Dedicated Wi-Fi and routing performance accelerators
- Advanced security with WPA3-PSK and WPA2-PSK encryption
- Parental controls for managing device access
Flexible Operation Modes and Ports
The Pro supports Router Mode, Bridge Mode, and Auto WAN/LAN Port Sensing, making it adaptable to various network setups. It includes:
- 1 x 2.5 Gbps WAN port
- 1 x 1 Gbps LAN port
- 1 x USB 2.0 Type A port
The Wyze Wi-Fi 6E Mesh Router Pro is perfect for large homes or tech-savvy users who demand the fastest speeds and broadest coverage.
Alt text: Lifestyle image of Wyze Wi-Fi 6E Mesh Router Pro providing seamless home Wi-Fi coverage
Wyze Wi-Fi 6 Mesh Router: Reliable Performance for Everyday Use
Advanced Wi-Fi 6 Technology
The Wyze Wi-Fi 6 Mesh Router offers the latest Wi-Fi 6 (802.11ax) technology on dual bands (2.4 GHz and 5 GHz), delivering fast and reliable internet for most modern smart homes.
- Maximum Internet Speed: Up to 1 Gbps
- Wi-Fi Bandwidth: AX3000
- Devices Supported: 50+ devices
- Coverage: 1500 sq. ft. per router
Efficient Hardware for Smooth Connectivity
Powered by the same ARM Cortex A53 dual-core 1 GHz CPU but with 512 MB DDR3L RAM and 128 MB SPI NAND Flash, this router balances performance and affordability. Key features include:
- 4 antennas per node for strong Wi-Fi signals
- Wired backhaul support for mesh stability
- Dedicated Wi-Fi and routing accelerators
- WPA3-PSK and WPA2-PSK wireless security
- Parental controls for family-friendly internet management
Simple Setup and Essential Ports
The Wyze Mesh Router supports Router Mode, Bridge Mode, and Auto WAN/LAN Port Sensing. It comes with:
- 1 x 1 Gbps WAN port
Ideal for small to medium homes, the Wyze Wi-Fi 6 Mesh Router delivers reliable speeds and coverage at a budget-friendly price.
Alt text: Lifestyle image of Wyze Wi-Fi 6 Mesh Router in a home office environment
Side-by-Side Comparison Summary
Feature | Wyze Wi-Fi 6 Mesh Router | Wyze Wi-Fi 6E Mesh Router Pro |
Wi-Fi Technology | Wi-Fi 6 (802.11ax) | Wi-Fi 6E (802.11ax with 6 GHz) |
Maximum Speed | Up to 1 Gbps | Up to 2.5 Gbps |
Frequency Bands | 2.4 GHz, 5 GHz | 2.4 GHz, 5 GHz, 6 GHz |
Coverage per Router | 1500 sq. ft. | 2000 sq. ft. |
Devices Supported | 50+ devices | 75+ devices |
Antennas | 4 | 6 |
RAM | 512 MB DDR3L | 1 GB DDR3L |
WAN Port | 1 x 1 Gbps | 1 x 2.5 Gbps |
LAN Port | 1 x 1 Gbps | 1 x 1 Gbps |
USB Port | None | 1 x USB 2.0 Type A |
Color | White | Black |
Price Range | More affordable (2-pack $99.99) | Premium (1-pack $167.99) |
Which Wyze Mesh Router Should You Choose?
Choose the Wyze Wi-Fi 6 Mesh Router if:
You have a small to medium-sized home, need reliable Wi-Fi for up to 50 devices, and want a cost-effective solution with solid Wi-Fi 6 performance.
Choose the Wyze Wi-Fi 6E Mesh Router Pro if:
You want the fastest speeds available, support for the new 6 GHz band, coverage for larger homes, and the ability to connect 75+ devices without lag.
Both routers offer simple setup, parental controls, and wired backhaul support, making them excellent choices for modern smart homes.
Experience seamless, high-speed internet coverage with Wyze mesh routers designed to keep every corner of your home connected.
Alt text: Lifestyle image showing the easy setup process of Wyze Wi-Fi 6E Mesh Router Pro
# Product Tags Summary
What are the main differences between the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro?
The Wyze Wi-Fi 6 Mesh Router uses dual-band Wi-Fi 6 (2.4 GHz and 5 GHz), supports up to 1 Gbps speeds, covers 1500 sq. ft. per router, and connects 50+ devices. The Wyze Wi-Fi 6E Mesh Router Pro features tri-band Wi-Fi 6E (2.4 GHz, 5 GHz, and 6 GHz), supports up to 2.5 Gbps speeds, covers 2000 sq. ft. per router, and connects 75+ devices. The Pro model also has more antennas, more RAM, a faster WAN port, and a USB port.Which Wyze mesh router is best for large homes?
The Wyze Wi-Fi 6E Mesh Router Pro is best for large homes. It offers greater coverage (2000 sq. ft. per router), supports more devices (75+), and delivers faster speeds with the addition of the 6 GHz band.Does the Wyze Wi-Fi 6 Mesh Router support the 6 GHz band?
No, the Wyze Wi-Fi 6 Mesh Router supports only the 2.4 GHz and 5 GHz bands. For 6 GHz support, choose the Wyze Wi-Fi 6E Mesh Router Pro.How many devices can each Wyze mesh router support?
The Wyze Wi-Fi 6 Mesh Router supports 50+ devices simultaneously, while the Wyze Wi-Fi 6E Mesh Router Pro supports 75+ devices at the same time.What is the maximum internet speed supported by each Wyze mesh router?
The Wyze Wi-Fi 6 Mesh Router supports up to 1 Gbps internet speeds, while the Wyze Wi-Fi 6E Mesh Router Pro supports up to 2.5 Gbps.Do both Wyze mesh routers offer parental controls?
Yes, both the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro include parental controls for managing device access and ensuring family-friendly internet usage.What security features do Wyze mesh routers provide?
Both Wyze mesh routers offer advanced wireless security with WPA3-PSK and WPA2-PSK encryption to help protect your home network.Can I use a wired backhaul with Wyze mesh routers?
Yes, both the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro support wired backhaul for stable and reliable mesh connections.What are the available ports on each Wyze mesh router?
The Wyze Wi-Fi 6 Mesh Router has 1 x 1 Gbps WAN port and 1 x 1 Gbps LAN port. The Wyze Wi-Fi 6E Mesh Router Pro features 1 x 2.5 Gbps WAN port, 1 x 1 Gbps LAN port, and 1 x USB 2.0 Type A port.Which Wyze mesh router is more affordable?
The Wyze Wi-Fi 6 Mesh Router is more affordable, with a 2-pack priced at $99.99. The Wyze Wi-Fi 6E Mesh Router Pro is a premium option, with a 1-pack priced at $167.99.Is the setup process easy for Wyze mesh routers?
Yes, both Wyze mesh routers offer a simple setup process, making it easy to get your home network up and running quickly.What color options are available for Wyze mesh routers?
The Wyze Wi-Fi 6 Mesh Router is available in white, while the Wyze Wi-Fi 6E Mesh Router Pro comes in black.Which Wyze mesh router should I choose for a small or medium-sized home?
For small to medium-sized homes, the Wyze Wi-Fi 6 Mesh Router is recommended. It provides reliable coverage, supports up to 50 devices, and is budget-friendly.Does the Wyze Wi-Fi 6E Mesh Router Pro have a USB port?
Yes, the Wyze Wi-Fi 6E Mesh Router Pro includes a USB 2.0 Type A port, while the Wyze Wi-Fi 6 Mesh Router does not have a USB port.
