Wyze Integrated Google Nest Audio Speaker for Clear Sound
Experience the perfect harmony of Wyze smart home technology combined with the powerful Google Nest Audio speaker. Designed to deliver crystal-clear sound and seamless voice control, this integration elevates your home audio and smart environment to the next level.
Google Nest Audio + Wyze Bundles: Immersive Sound Meets Smart Control
Room-Filling, Rich Sound Quality
The Google Nest Audio speaker is engineered to fill your room with gorgeous sound, featuring crisp highs and rich bass that bring your music, podcasts, and audiobooks to life. Its 75 mm woofer and 19 mm tweeter work together to deliver balanced, immersive audio that adapts to your environment for the best listening experience.
Built-In Google Assistant for Hands-Free Convenience
With Google Assistant built right in, controlling your smart home has never been easier. Use voice commands to play your favorite songs from streaming services, adjust smart lights, check the weather, or get answers to your questions — all without lifting a finger.
Smart Features and Connectivity
  • Voice Match Technology: Personalized responses for every user.
  • Privacy Controls: Hardware mic mute switch for peace of mind.
  • Connectivity: Supports dual-band Wi-Fi (2.4 GHz/5 GHz), Bluetooth 5.0, and Chromecast built-in for versatile streaming options.
  • Stereo Sound Capability: Pair two Nest Audio speakers for a richer stereo experience.
Available Bundles
Choose from multiple Wyze + Nest Audio bundles including 2-packs, smart bulbs, cameras, and plugs to customize your smart home setup.
"Nest Audio adapts to your environment so whatever you're listening to instantly sounds better."
Google Nest Audio Lifestyle Enjoy clear, rich sound in your living space with Google Nest Audio and Wyze integration.
Why Choose Wyze + Google Nest Audio?
  • Seamless Integration: Control Wyze smart devices effortlessly through Google Assistant on Nest Audio.
  • Compact and Stylish: Measuring 6.89 in x 4.89 in x 3.07 in and weighing just 2.65 lbs, the Nest Audio fits elegantly in any room.
  • Powerful Microphones: Three far-field microphones ensure your voice commands are heard clearly, even from across the room.
  • Easy Setup: Included power adapter and cable make installation quick and hassle-free.
Enhance Your Smart Home with Wyze Ecosystem
While the Google Nest Audio + Wyze Bundles focus on premium sound and voice control, Wyze offers a full range of smart home products to complement your setup:
  • Wyze Cam v4: Crystal-clear 2.5K QHD resolution with color night vision and motion-activated spotlight for home security. Compatible with Google Assistant for voice control.
  • Wyze Air Purifier: Keep your home's air fresh and clean with smart controls and real-time air quality alerts, compatible with Google Home.
  • Wyze Noise-Cancelling Headphones: For personal audio enjoyment, these headphones feature hybrid active noise cancellation and voice assistant compatibility.
Integrate these devices with your Google Nest Audio speaker to create a fully connected, voice-controlled smart home environment.
Product Highlights Summary
ProductKey Features
Google Nest Audio + Wyze BundlesRoom-filling sound, Google Assistant built-in, voice match, stereo sound, privacy controls
Wyze Cam v42.5K QHD video, color night vision, motion spotlight, Alexa & Google Assistant compatible
Wyze Air Purifier350 CADR, whisper-quiet, smart AQ alerts, Google Home compatible
Wyze Noise-Cancelling HeadphonesHybrid ANC, 20-hour battery, voice-isolating mics, Alexa compatible
Conclusion
For those seeking clear, immersive sound combined with smart home convenience, the Wyze integrated Google Nest Audio speaker bundles offer an unbeatable solution. Enjoy rich audio quality, hands-free voice control, and seamless integration with your Wyze smart devices — all designed to make your home smarter and your life easier.
Wyze Noise-Cancelling Headphones Lifestyle Immerse yourself in music with Wyze Noise-Cancelling Headphones, perfect for commuting or relaxing.
Feature / ProductGoogle Nest Audio + Wyze BundlesWyze Cam v4Wyze Air PurifierWyze Noise-Cancelling Headphones
TypeConnected Home BundlesSmart CameraConnected HomeHealth & Lifestyle Audio
Price Range$99.98 - $159.99 (varies by bundle)$35.98 (1-pack) to $107.94 (3-pack)$169.99 - $194.99 (depending on filter)$89.99 - $99.99
Main FunctionSmart speaker with Google Assistant + Wyze device bundleSecurity camera with 2.5K QHD videoAir purification with smart controlsWireless noise-cancelling headphones
Audio FeaturesCrisp highs, rich bass, built-in Google Assistant2-way talk, 99 dB waterproof speakerN/AHybrid Active Noise Cancellation, 40 dB noise cancellation depth
Video ResolutionN/A2.5K QHD (2560x1440)N/AN/A
Night VisionN/AEnhanced Color Night VisionN/AN/A
Smart Assistant CompatibilityGoogle AssistantAlexa, Google AssistantGoogle Home, AlexaAmazon Alexa and other native voice assistants
ConnectivityWi-Fi, Google ecosystemWi-Fi 6, Bluetooth 5.2Wi-FiBluetooth 5.0
Special FeaturesEnvironment adaptive sound, privacy mic switchMotion-activated spotlight, AI auto-zoom, smoke & CO alertsLaser particle detection, AQ alerts, whisper-quiet operationFatigue-free fit, voice-isolating microphones, touch controls
Power SourceWired (speaker) + bundled devicesWired (continuous power)Wired (120V/60Hz)Rechargeable lithium-ion battery
Dimensions / WeightN/A2in x 2in x 2 3/8in; 0.49 lb (222 g)9.5 in x 9.4 in x 18.5 in; ~8.75-9.32 lb (varies by filter)9.9 oz
Battery Life / Operation TimeN/AContinuous wired operationContinuous operationUp to 20 hours music/call time
Additional Included ItemsVaries by bundle (e.g., bulbs, plugs, cameras)Camera, power adapter, mounts, cablesAir purifier with pre-installed filterHeadphones, soft pouch, USB-C cable, audio cable, guide
Warranty / Return PolicyNo Wyze return policy; damaged in transit replaced1 Year warrantyN/AN/A
Use CaseSmart home audio + Wyze device controlHome security indoor/outdoor cameraAir quality improvement for 450-550 sq ftPersonal audio with noise cancellation
What is the Wyze Integrated Google Nest Audio Speaker?The Wyze Integrated Google Nest Audio Speaker is a smart home audio solution that combines Wyze smart home technology with the powerful Google Nest Audio speaker. It delivers crystal-clear, room-filling sound and allows seamless voice control of your smart devices using Google Assistant.
What are the key features of the Google Nest Audio + Wyze Bundles?The Google Nest Audio + Wyze Bundles offer room-filling, rich sound quality, built-in Google Assistant for hands-free control, Voice Match technology for personalized responses, privacy controls with a hardware mic mute switch, dual-band Wi-Fi and Bluetooth 5.0 connectivity, Chromecast built-in, and the ability to pair two speakers for stereo sound.
How does Google Assistant work with Wyze devices?Google Assistant is built into the Nest Audio speaker, allowing you to control Wyze smart devices using simple voice commands. You can play music, adjust smart lights, check the weather, control Wyze cameras, and more, all hands-free.
What smart home products are compatible with Google Nest Audio and Wyze?Wyze offers a range of smart home products compatible with Google Nest Audio, including Wyze Cam v4 (2.5K QHD video, color night vision), Wyze Air Purifier (smart air quality alerts), and Wyze Noise-Cancelling Headphones (hybrid active noise cancellation). All these devices can be integrated and controlled via Google Assistant.
What connectivity options does the Google Nest Audio speaker support?The Google Nest Audio speaker supports dual-band Wi-Fi (2.4 GHz and 5 GHz), Bluetooth 5.0, and has Chromecast built-in for versatile streaming and smart home integration.
How do I ensure my privacy with the Google Nest Audio speaker?The Google Nest Audio speaker features a hardware mic mute switch, allowing you to physically disable the microphones for added privacy and peace of mind.
Can I pair two Google Nest Audio speakers for stereo sound?Yes, you can pair two Google Nest Audio speakers together to create a richer, stereo sound experience in your home.
What are the available Wyze + Nest Audio bundles?Wyze + Nest Audio bundles are available in various configurations, including 2-packs, and bundles with smart bulbs, cameras, and plugs, allowing you to customize your smart home setup.
How easy is it to set up the Google Nest Audio + Wyze Bundles?Setting up the Google Nest Audio + Wyze Bundles is quick and hassle-free. Each bundle includes a power adapter and cable, and the devices are designed for easy installation and integration with your existing smart home ecosystem.
What are the dimensions and weight of the Google Nest Audio speaker?The Google Nest Audio speaker measures 6.89 inches x 4.89 inches x 3.07 inches and weighs 2.65 lbs, making it compact and stylish for any room.
Can you tell me more about the features of the Wyze Noise-Cancelling Headphones?How does the voice match technology work with the Google Nest Audio speaker?Are there any ongoing sales or discounts for the Wyze + Google Nest Audio bundles?
