Google Nest Audio and Wyze Smart Home Control Bundles
Experience the perfect harmony of premium sound and smart home convenience with the
Google Nest Audio + Wyze Bundles. Designed to fill your space with rich, room-filling sound and seamless smart home control, these bundles combine the power of Google’s voice assistant with Wyze’s innovative smart devices. Whether you want to stream your favorite music or manage your smart home effortlessly, these bundles offer an all-in-one solution.
Google Nest Audio: Superior Sound Meets Smart Control
The Google Nest Audio speaker is engineered to deliver crisp highs and deep bass, adapting dynamically to your room’s acoustics for an optimized listening experience. With built-in Google Assistant, you can control your music, podcasts, and smart home devices using just your voice.
- Sound Quality: 75 mm woofer and 19 mm tweeter deliver rich, balanced audio.
- Smart Features: Voice Match technology personalizes responses; 3 far-field microphones ensure your commands are heard clearly.
- Connectivity: Supports dual-band Wi-Fi (2.4 GHz/5 GHz), Bluetooth 5.0, and Chromecast built-in for versatile streaming.
- Privacy: Hardware mic mute switch and privacy controls keep your data secure.
- Design: Compact dimensions (6.89 in x 4.89 in x 3.07 in) and available in Chalk, Grey, and White to fit any decor.
- Bundles: Choose from Nest Audio alone or combined with Wyze smart bulbs, cameras, or plugs for enhanced home automation.
“Fill the room with gorgeous sound featuring crisp highs and rich bass on the Google Nest Audio speaker.”
Enjoy immersive sound and smart control in your living space
Wyze Smart Home Integration
Paired with Google Nest Audio, Wyze smart devices bring your home to life with easy voice control and automation:
- Wyze Cam Pan v3 & Cam v4: High-resolution cameras with night vision, two-way audio, and Alexa/Google Assistant compatibility.
- Wyze Smart Bulbs & Plugs: Control lighting and appliances hands-free or via app.
- Smart Bundles: Tailored packages combining Nest Audio with Wyze cameras, bulbs, and plugs for a comprehensive smart home setup.
Google Nest Hub (2nd Gen) + Wyze Bundles: Visual Smart Home Control
For those who want a screen to complement their smart home, the
Google Nest Hub (2nd Gen) + Wyze Bundles offer an interactive experience. This bundle pairs the award-winning Wyze Cam v3 or Cam Pan v3 with the Nest Hub’s vibrant display and enhanced speaker.
- Entertainment & Control: Stream music, watch videos, and control Wyze cameras directly from the Nest Hub screen.
- Improved Audio: 50% more bass than the original Nest Hub for richer sound.
- Privacy: Mic switch to turn off the microphone anytime and easy Google Assistant history clearing.
- Sleep Sense: Try Google’s Sleep Sense sleep assistant free until 2023 for better rest.
- Smart Home: Manage Wyze smart devices on-screen or with voice commands.
“Your camera watches the kids. Your kids watch the screen. The screen watches your camera. It’s the circle of life.”
Wyze Noise-Cancelling Headphones: Personal Music Sanctuary
Complement your streaming experience with
Wyze Noise-Cancelling Headphones, designed for immersive sound and comfort whether at home or on the go.
- Hybrid Active Noise Cancellation: Blocks out distractions for focused listening.
- Comfort: Fatigue-free fit with memory foam ear cushions covered in protein leather.
- Battery Life: Up to 20 hours wireless playback, with quick charge providing 4 hours from just 10 minutes.
- Voice Assistant Compatible: Works with Amazon Alexa and other native assistants.
- Connectivity: Bluetooth 5.0 with support for two simultaneous device connections.
- Touch Controls: Easy access to playback and calls with intuitive touch gestures.
Enjoy music anywhere with Wyze Noise-Cancelling Headphones
Why Choose Google Nest Audio + Wyze Smart Home?
- Seamless Integration: Google Assistant and Wyze devices work together for effortless voice control.
- Versatile Bundles: Customize your smart home with combinations of speakers, cameras, bulbs, and plugs.
- Enhanced Audio Experience: Crisp, room-filling sound for music streaming and podcasts.
- Smart Home Security: Wyze cameras provide reliable monitoring with easy access via Google Nest devices.
- Privacy & Control: Hardware mic mute switches and privacy settings keep your data safe.
Transform your home into a smart, connected environment where music and control come together beautifully.
Product Highlights Summary
Crisp sound, voice control, smart home integration, multiple bundle options.
Interactive display, enhanced bass, Wyze camera control, sleep assistant.
Active noise cancellation, long battery life, comfortable fit, voice assistant ready.
What is included in the Google Nest Audio and Wyze Smart Home Control Bundles?
The Google Nest Audio and Wyze Smart Home Control Bundles include the Google Nest Audio smart speaker and a selection of Wyze smart devices such as Wyze smart bulbs, cameras (Cam Pan v3, Cam v4), and smart plugs. These bundles are designed to provide premium sound quality and seamless smart home automation.How does Google Nest Audio enhance my smart home experience?
Google Nest Audio delivers rich, room-filling sound with a 75 mm woofer and 19 mm tweeter, and features built-in Google Assistant for hands-free control of music, podcasts, and compatible smart home devices. Its Voice Match technology personalizes responses, and it supports Wi-Fi, Bluetooth 5.0, and Chromecast for versatile connectivity.Can I control Wyze smart devices with Google Nest Audio?
Yes, you can control Wyze smart devices such as cameras, bulbs, and plugs using Google Nest Audio through voice commands with Google Assistant, making home automation easy and convenient.What privacy features are available on Google Nest Audio and Nest Hub?
Both Google Nest Audio and Nest Hub offer hardware mic mute switches and privacy controls, allowing you to turn off the microphone and manage your Google Assistant history to keep your data secure.What are the benefits of the Google Nest Hub (2nd Gen) + Wyze Bundles?
The Google Nest Hub (2nd Gen) + Wyze Bundles provide an interactive display for streaming music, watching videos, and controlling Wyze cameras directly from the screen. The Nest Hub offers improved audio with 50% more bass, privacy controls, and features like Google’s Sleep Sense sleep assistant.Are Wyze Noise-Cancelling Headphones compatible with voice assistants?
Yes, Wyze Noise-Cancelling Headphones are compatible with Amazon Alexa and other native voice assistants, allowing for hands-free control and easy access to your favorite music and calls.What is the battery life of Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones offer up to 20 hours of wireless playback on a single charge, and a quick 10-minute charge provides up to 4 hours of listening time.How do Wyze smart cameras integrate with Google Nest devices?
Wyze smart cameras, such as the Cam Pan v3 and Cam v4, are compatible with Google Assistant, allowing you to view camera feeds and control camera functions directly from Google Nest Audio or Nest Hub devices using voice commands or the interactive display.What customization options are available with the Google Nest Audio + Wyze Bundles?
You can customize your smart home setup by choosing from various bundle options that combine Google Nest Audio with Wyze smart bulbs, cameras, and plugs, allowing you to tailor your smart home experience to your needs.What makes the Google Nest Audio + Wyze Bundles a good choice for smart home automation?
The Google Nest Audio + Wyze Bundles offer seamless integration between Google Assistant and Wyze devices, providing effortless voice control, enhanced audio quality, versatile bundle options, reliable smart home security, and robust privacy features.
