Wyze Headphone Replacement Kit Parts for DIY Repair
If you're looking to repair or replace parts of your Wyze headphones or related accessories, this guide highlights the available Wyze replacement parts that can help you get your gear back in perfect working condition. Whether you need a new mic cover for your Wyze Gaming Headset or other replacement components, these kits and parts are designed to fit seamlessly and restore your device’s functionality.
Wyze Gaming Headset Replacement Parts
Wyze Gaming Headset Boom Mic Cover
For gamers and audio enthusiasts, the Wyze Gaming Headset Boom Mic Cover is an essential replacement part. This foam cover protects the microphone from dust and wear, ensuring clear voice communication during your gaming sessions.
- Type: Replacement boom mic foam cover
- Compatibility: Specifically designed for Wyze Gaming Headset
- Price: $1.99
- Return Policy: 30-day hassle-free returns
This small but crucial part helps maintain the quality of your headset’s microphone, making it a cost-effective solution for DIY repairs.
Keep your gaming headset mic clear and protected with this easy-to-install foam cover.
Other Wyze Replacement Kits for Smart Home Devices
While the focus is on headphone-related parts, Wyze also offers a variety of replacement kits for other smart home devices that might interest DIY repair enthusiasts.
Wyze Cam v3 Replacement Part Kit
- Compatible with Wyze Cam v2 and v3
- Price: $7.99
- Ideal for restoring your Wyze Cam’s accessories and parts without buying a new camera
Wyze Lock Replacement Part Kit
- Includes options like Adapter Replacement Kit and Replacement Part Kit
- Prices range from $4.99 to $19.99
- Designed exclusively for Wyze Lock users
Wyze Robot Vacuum Replacement Parts Kit
- Includes edge brushes, main brushes, and HEPA filters
- Price: $22.99
- Perfect for maintaining your Wyze Robot Vacuum’s cleaning efficiency
Wyze Garage Door Controller Part
- Replacement controller part only (not a full kit)
- Price: $6.99
- Compatible with Wyze Cam v3 Garage Door Controller
Wyze Cordless Vacuum S - Charger
- Replacement charger for Wyze Cordless Vacuum S
- Price: $4.99
Why Choose Wyze Replacement Parts for DIY Repairs?
Wyze replacement parts are designed to be affordable, compatible, and easy to install, making them perfect for DIY enthusiasts who want to extend the life of their devices. With hassle-free 30-day return policies, you can confidently purchase the parts you need without worry.
DIY repairs with genuine Wyze parts help you save money and reduce electronic waste by avoiding full device replacements.
Alt text: Person performing DIY repair on headphones at home
Summary of Wyze Replacement Parts for DIY Repairs
Product Name | Compatibility | Price | Key Feature |
Wyze Gaming Headset Boom Mic Cover | Wyze Gaming Headset | $1.99 | Foam mic cover replacement |
Wyze Cam v3 Replacement Part Kit | Wyze Cam v2 and v3 | $7.99 | Camera accessory replacement |
Wyze Lock Replacement Part Kit | Wyze Lock | $4.99+ | Lock adapter and parts kit |
Wyze Robot Vacuum Replacement Kit | Wyze Robot Vacuum | $22.99 | Brushes and HEPA filters |
Wyze Garage Door Controller Part | Wyze Cam v3 Garage Door | $6.99 | Controller replacement part |
Wyze Cordless Vacuum S - Charger | Wyze Cordless Vacuum S | $4.99 | Replacement charger |
By choosing the right Wyze replacement parts, you can easily perform DIY repairs and keep your devices running smoothly without the need for costly replacements.
What Wyze headphone replacement parts are available for DIY repair?
Wyze offers a variety of replacement parts for headphones, including the Wyze Gaming Headset Boom Mic Cover. This foam cover is specifically designed for the Wyze Gaming Headset and helps protect the microphone from dust and wear, ensuring clear voice communication.Is the Wyze Gaming Headset Boom Mic Cover compatible with all Wyze headsets?
No, the Wyze Gaming Headset Boom Mic Cover is specifically designed for the Wyze Gaming Headset. It may not fit other Wyze headphone models.How much does the Wyze Gaming Headset Boom Mic Cover cost?
The Wyze Gaming Headset Boom Mic Cover is priced at $1.99, making it an affordable solution for replacing your headset’s mic cover.What is the return policy for Wyze replacement parts?
Wyze offers a 30-day hassle-free return policy on replacement parts, allowing you to shop with confidence for your DIY repair needs.Are there Wyze replacement kits for devices other than headphones?
Yes, Wyze provides replacement kits for several smart home devices, including the Wyze Cam v3, Wyze Lock, Wyze Robot Vacuum, Wyze Garage Door Controller, and Wyze Cordless Vacuum S.What does the Wyze Cam v3 Replacement Part Kit include and what is its price?
The Wyze Cam v3 Replacement Part Kit is compatible with Wyze Cam v2 and v3 and is priced at $7.99. It is ideal for restoring your Wyze Cam’s accessories and parts without needing to buy a new camera.What replacement parts are available for the Wyze Robot Vacuum?
The Wyze Robot Vacuum Replacement Parts Kit includes edge brushes, main brushes, and HEPA filters. The kit is priced at $22.99 and helps maintain your vacuum’s cleaning efficiency.Can I buy a replacement charger for the Wyze Cordless Vacuum S?
Yes, Wyze offers a replacement charger for the Wyze Cordless Vacuum S at a price of $4.99.Why should I choose Wyze replacement parts for DIY repairs?
Wyze replacement parts are affordable, compatible, and easy to install, making them ideal for DIY enthusiasts. Using genuine Wyze parts helps extend the life of your devices, saves money, and reduces electronic waste.How do Wyze replacement parts help reduce electronic waste?
By allowing you to repair and maintain your existing devices with genuine Wyze replacement parts, you avoid the need for full device replacements, which helps reduce electronic waste and supports a more sustainable lifestyle.
