Buy Genuine Wyze Headphone Replacement Kits & Parts Online
Where to Buy Genuine Replacement Kit for Damaged Wyze Headphones
If you are searching for authentic replacement kits for your damaged Wyze headphones, this guide will help you find the right parts and accessories to restore your audio experience. Wyze offers a range of replacement parts specifically designed for their headphones and other smart devices, ensuring compatibility and quality.
Wyze Noise-Cancelling Headphones Replacement Options
Premium Features of Wyze Noise-Cancelling Headphones
Wyze Noise-Cancelling Headphones are engineered to deliver an immersive audio experience with advanced features such as:
  • Hybrid Active Noise Cancellation that blocks out up to 40 dB of ambient noise.
  • Fatigue-Free Fit with memory foam ear cushions covered in protein leather and a multilayer composite headband for all-day comfort.
  • Voice-Isolating Microphones (6 total) for crystal-clear calls and voice commands.
  • Wireless Connectivity with Bluetooth 5.0, supporting dual device connections and a 33 ft range.
  • Long Battery Life offering up to 20 hours of continuous music or calls, with quick charge providing 4 hours of use from just 10 minutes of charging.
  • Touch Controls and compatibility with Amazon Alexa and other voice assistants for seamless hands-free operation.
These headphones come with a soft carrying pouch, USB Type-C charging cable, audio cable, and a quick start guide.
Experience music like a symphony playing just for you, whether commuting, relaxing, or working.
Wyze Noise-Cancelling Headphones Lifestyle Enjoy music with Wyze Noise-Cancelling Headphones in vibrant urban settings.
Replacement Parts for Wyze Headphones
While Wyze does not currently offer a dedicated full replacement kit specifically for headphones, you can find essential replacement parts to maintain or repair your Wyze audio devices:
Wyze Gaming Headset Boom Mic Cover
  • Price: $1.99 USD
  • Description: Replacement foam cover for the boom microphone, compatible with Wyze Gaming Headset.
  • Benefit: Protects the mic from wear and tear, ensuring clear voice communication.
  • Return Policy: 30-day hassle-free returns.
This small but vital part helps extend the life of your headset’s microphone, keeping your voice crisp during gaming or calls.
Other Wyze Replacement Kits (For Context)
Though not related to headphones, Wyze offers several replacement kits for other devices that showcase their commitment to quality and genuine parts:
  • Wyze Cam v3 Replacement Part Kit ($7.99 USD) – Compatible with Wyze Cam v2 and v3.
  • Wyze Lock Replacement Part Kit ($4.99 - $19.99 USD) – For smart lock components.
  • Wyze Robot Vacuum Replacement Parts Kit ($22.99 USD) – Includes brushes and HEPA filters.
These kits highlight Wyze’s approach to providing genuine, compatible parts for their smart home ecosystem.
Why Choose Genuine Wyze Replacement Parts?
Using genuine Wyze replacement parts ensures your devices maintain their original performance, durability, and warranty coverage. Non-authentic parts may compromise functionality and could void your warranty.
Wyze replacement parts are designed and tested to fit perfectly with your devices, providing peace of mind and long-term reliability.
Summary
If your Wyze Noise-Cancelling Headphones are damaged, the best way to maintain or repair them is by purchasing genuine replacement parts like the Wyze Gaming Headset Boom Mic Cover for microphone protection. While a full headphone replacement kit is not currently available, Wyze’s authentic parts and accessories ensure your devices stay in top condition. For other Wyze devices, explore their dedicated replacement kits to keep your smart home running smoothly. Wyze Headphones Commuting Lifestyle Wyze headphones designed for comfort and durability during daily commutes.
FeatureWyze Noise-Cancelling HeadphonesWyze Gaming Headset Boom Mic CoverWyze Lock Bolt Interior Assembly Metal Plate
TypeHealth & LifestyleReplacement PartsReplacement Parts
DescriptionWireless headphones with 40dB hybrid ANC, Transparency Mode, wear detection, customizable sound via app, voice assistant integration, Bluetooth 5.0Replacement foam cover for gaming headset boom micMetal plate to anchor the interior assembly to the door
Price$80.99 - $99.99 (varies by color and travel case option)$1.99$4.99
Color OptionsBlack, WhiteN/AN/A
Style/Variant OptionsNo Travel Case, With Travel CaseDefaultDefault
Key Features- 40dB Hybrid ANC
- Transparency Mode
- Wear Detection
- Dual 40mm drivers
- Touch controls
- Voice assistant (Alexa, Google Assistant)
- Bluetooth 5.0
- Dual device connection
Replacement foam cover for boom micMetal plate for door assembly anchoring
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
Quantity AvailableUp to 10 unitsUp to 10 units (6 left in stock)Up to 10 units
Where can I buy genuine replacement parts for Wyze headphones?You can purchase authentic replacement parts for Wyze headphones directly from the official Wyze website. Wyze offers a range of genuine parts and accessories designed specifically for their audio devices, ensuring compatibility and quality.
Does Wyze offer a full replacement kit for damaged headphones?Currently, Wyze does not offer a dedicated full replacement kit for their headphones. However, you can find essential replacement parts, such as the Wyze Gaming Headset Boom Mic Cover, to help maintain or repair your Wyze audio devices.
What replacement parts are available for Wyze headphones?The main replacement part available for Wyze headphones is the Wyze Gaming Headset Boom Mic Cover. This foam cover protects the boom microphone from wear and tear, ensuring clear voice communication and extending the life of your headset’s microphone.
How much does the Wyze Gaming Headset Boom Mic Cover cost?The Wyze Gaming Headset Boom Mic Cover is priced at $1.99 USD. It is an affordable way to protect and maintain your headset’s microphone.
What is the return policy for Wyze replacement parts?Wyze offers a 30-day hassle-free return policy on their replacement parts, including the Wyze Gaming Headset Boom Mic Cover. This allows you to shop with confidence and return items if they do not meet your needs.
Why should I use genuine Wyze replacement parts for my headphones?Using genuine Wyze replacement parts ensures your headphones maintain their original performance, durability, and warranty coverage. Non-authentic parts may compromise functionality and could void your warranty.
Are there replacement kits available for other Wyze devices?Yes, Wyze offers several replacement kits for other devices, such as the Wyze Cam v3 Replacement Part Kit, Wyze Lock Replacement Part Kit, and Wyze Robot Vacuum Replacement Parts Kit. These kits are designed to keep your smart home devices running smoothly.
What are the premium features of Wyze Noise-Cancelling Headphones?Wyze Noise-Cancelling Headphones feature hybrid active noise cancellation, fatigue-free fit with memory foam ear cushions, six voice-isolating microphones, Bluetooth 5.0 wireless connectivity, up to 20 hours of battery life, touch controls, and compatibility with Amazon Alexa and other voice assistants.
What are the essential replacement parts available for Wyze headphones?Can you tell me more about the Wyze Gaming Headset Boom Mic Cover?What is the return policy for Wyze products?
