Wyze Cam v4: 8x Digital Zoom & 3-Axis Home Security Camera
Discover the Wyze Cam v4: The Ultimate Digital Zoom Camera with Flexible 3-Axis Design for Home Security
When it comes to securing your home with smart, reliable, and high-quality cameras, the Wyze Cam v4 series stands out as a top choice. Designed with advanced features like digital zoom, flexible mounting options including a 3-axis design, and crystal-clear video quality, these cameras offer unmatched home surveillance capabilities. Whether you want a standalone camera or a complete home security bundle, Wyze has you covered with multiple options tailored to your needs.
Wyze Cam v4: Precision Zoom and Flexible 3-Axis Mounting for Perfect Angles
Advanced Digital Zoom and High-Resolution Video
The Wyze Cam v4 delivers stunning 2.5K Quad High Definition (QHD) video resolution, allowing you to capture every detail with remarkable clarity. Its 8x digital zoom lets you focus in on important areas without losing image quality, making it perfect for monitoring entrances, driveways, or any vulnerable spots around your home.
Flexible 3-Axis Design for Easy Installation
Thanks to its versatile mounting options—including stand, wall mount, ceiling mount, and a magnetic wall mount with adhesive—the Wyze Cam v4 offers a flexible 3-axis design. This means you can easily adjust the camera angle horizontally, vertically, and rotationally to get the perfect view, no matter where you place it.
Enhanced Night Vision and Color Accuracy
Equipped with 4 IR LEDs and 2 white spotlight LEDs, the Wyze Cam v4 features Enhanced Color Night Vision that reveals vibrant colors even in low-light conditions. This is a significant upgrade over traditional black-and-white night vision, helping you identify people and objects clearly at night.
Weather-Resistant and Durable
Rated IP65 for weather resistance, the Wyze Cam v4 is built to withstand rain, snow, and extreme temperatures, making it suitable for both indoor and outdoor use.
Smart Features and Connectivity
  • Wi-Fi 6 support ensures a stronger, more reliable connection.
  • Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
  • Motion and sound detection with customizable detection zones.
  • Two-way talk with noise and echo cancellation.
  • Built-in 99 dB siren and motion-activated spotlight for added security.
Wyze Cam v4 mounted outdoors Wyze Cam v4 providing vigilant outdoor security with night vision and spotlight
Wyze Cam v4 Outdoor Bundle: Complete Protection for Your Home Exterior
All-in-One Outdoor Security Solution
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4 camera, a Wyze Outdoor Power Adapter, and a 128GB MicroSD card for continuous local recording. This bundle is perfect for those who want to secure their home’s exterior with a camera designed to handle the elements and provide 24/7 monitoring.
Key Features
  • Same 2.5K QHD resolution and 8x digital zoom as the standalone camera.
  • IP65 weather resistance for reliable outdoor performance.
  • Motion-activated spotlight and siren to deter intruders.
  • Wi-Fi 6 support and smart assistant compatibility.
  • Continuous local recording with included MicroSD card.
This bundle offers excellent value and convenience, ensuring your outdoor areas are always under watchful eyes.
Whole Home Security Starter Kit: Comprehensive Home Surveillance
More Than Just a Camera
For those looking to secure their entire home, the Whole Home Security Starter Kit combines the Wyze Cam v4 with a Wyze Video Doorbell v2 and a Home Monitoring Starter Kit. This package provides a holistic approach to home security, covering entry points and indoor/outdoor spaces.
Features of the Kit
  • Wyze Cam v4 with all its advanced features including digital zoom and flexible mounting.
  • Video Doorbell v2 for front door monitoring with two-way talk.
  • Home Monitoring Starter Kit for alerts and emergency response integration.
  • Available in multiple colors: White, Grey, and Black to match your home decor.
Why Choose Wyze Cam v4 for Your Home?
"The Wyze Cam v4 is the clearest Wyze Cam ever, combining high-resolution video, flexible installation, and smart features to keep your home safe day and night."
  • Flexible 3-axis design allows you to position the camera exactly where you need it.
  • 8x digital zoom ensures you never miss a detail.
  • Enhanced Color Night Vision provides vivid images even in darkness.
  • Weather-resistant IP65 rating means it works indoors or outdoors.
  • Smart home integration with Alexa, Google Assistant, and IFTTT.
  • Motion-activated spotlight and siren add an extra layer of security.
Wyze Cam v4 lifestyle indoor Wyze Cam v4 seamlessly blends into your home environment with flexible mounting and smart features
Summary of Wyze Cam v4 Products for Home Security
Product NameKey FeaturesPrice Range
Wyze Cam v42.5K QHD, 8x digital zoom, 3-axis mount, IP65$35.98 - $107.94
Wyze Cam v4 Outdoor BundleIncludes outdoor power adapter & 128GB SD card$69.99
Whole Home Security Starter KitCam v4 + Video Doorbell v2 + Monitoring Kit$155.95
Wyze Cam v4 Home Security BundleEnhanced bundle with spotlight, siren, 128GB SD$169.99
Conclusion
For anyone searching for a Wyze Cam v2 digital zoom camera with flexible 3-axis design for home use, the Wyze Cam v4 and its bundles offer the perfect blend of advanced technology, ease of installation, and robust security features. Whether you want a single camera or a full home security system, Wyze provides reliable, high-quality options to keep your home safe and monitored around the clock.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWhole Home Security Starter KitWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price (USD)$35.98$69.99$155.95$169.99$35.98
Color OptionsBlack, Grey, White, Clear (sold out)Black, Grey, WhiteBlack, Grey, WhiteNot specified (likely Black, Grey, White)Black, Grey, White
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
SpotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlight
AudioEnhanced Two-Way Talk, 99 dB sirenEnhanced Two-Way Talk, 99 dB sirenIncluded (Wyze Cam v4) + Doorbell v2Improved 2-way audio, 99 dB sirenEnhanced Two-Way Talk, 99 dB siren
Weather ResistanceIP65IP65IP65 (Wyze Cam v4)IP65IP65
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Local Recording24/7 local recording (microSD card required)24/7 local recording (microSD card included 128GB)24/7 local recording (microSD card required)24/7 local recording (128GB microSD included)24/7 local recording (microSD card included 32GB)
Cloud StorageOptional subscription (Cam Plus)Optional subscription (Cam Plus)Optional subscription (Cam Plus)Optional subscription (Cam Plus)Optional subscription (Cam Plus)
Motion & Sound DetectionYesYesYesYesYes
Smoke & CO AlertsYesYesYesYesYes
Field of View (DFOV x HFOV x VFOV)115.9° x 98.5° x 53.1°115.9° x 98.5° x 53.1°Not specified115.8° x 98.5° x 53.1°115.9° x 98.5° x 53.1°
Mounting OptionsStand, Wall, Ceiling, Magnetic mountStand, Wall, Ceiling, Magnetic mountNot specifiedStand, Wall, Ceiling, Magnetic mountStand, Wall, Ceiling, Magnetic mount
Included AccessoriesUSB Power Adapter, Mounting kitOutdoor Power Adapter, 128GB microSD cardWyze Cam v4, Video Doorbell v2, Home Monitoring Starter KitWyze Cam v4, 128GB microSD cardWyze Cam v4, 32GB microSD card
Warranty1 Year1 YearNot specified1 YearNot specified
Additional FeaturesBluetooth 5.2, AI Auto-Zoom, WDR, IP65, Siren, Alexa/Google/IFTTTSame as Wyze Cam v4 + Outdoor Power AdapterIncludes Video Doorbell v2 and Home Monitoring KitImproved 2-way audio, 8x digital zoom, IP65, SirenSame as Wyze Cam v4 + FREE 32GB microSD card
What is the video resolution of the Wyze Cam v4?The Wyze Cam v4 features a stunning 2.5K Quad High Definition (QHD) video resolution, allowing you to capture every detail with remarkable clarity for superior home security.
How does the Wyze Cam v4's digital zoom work?The Wyze Cam v4 offers 8x digital zoom, enabling you to focus in on important areas without losing image quality. This makes it ideal for monitoring entrances, driveways, or any vulnerable spots around your home.
What is the flexible 3-axis design of the Wyze Cam v4?The Wyze Cam v4 features a flexible 3-axis design, allowing you to adjust the camera angle horizontally, vertically, and rotationally. This ensures you can get the perfect view, whether you mount it on a stand, wall, ceiling, or use the magnetic wall mount with adhesive.
Does the Wyze Cam v4 have color night vision?Yes, the Wyze Cam v4 is equipped with Enhanced Color Night Vision, using 4 IR LEDs and 2 white spotlight LEDs to reveal vibrant colors even in low-light conditions. This helps you clearly identify people and objects at night.
Is the Wyze Cam v4 weather-resistant?Absolutely. The Wyze Cam v4 is rated IP65 for weather resistance, making it durable and suitable for both indoor and outdoor use, even in rain, snow, or extreme temperatures.
What smart features does the Wyze Cam v4 offer?The Wyze Cam v4 supports Wi-Fi 6 for a stronger connection, is compatible with Alexa, Google Assistant, and IFTTT, and includes motion and sound detection with customizable zones, two-way talk with noise and echo cancellation, a built-in 99 dB siren, and a motion-activated spotlight.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4 camera, a Wyze Outdoor Power Adapter, and a 128GB MicroSD card for continuous local recording. It is designed for reliable outdoor performance and 24/7 monitoring.
What does the Whole Home Security Starter Kit include?The Whole Home Security Starter Kit combines the Wyze Cam v4, a Wyze Video Doorbell v2, and a Home Monitoring Starter Kit. This package provides comprehensive home surveillance, covering entry points and both indoor and outdoor spaces.
Can I integrate the Wyze Cam v4 with my smart home system?Yes, the Wyze Cam v4 is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your existing smart home devices.
Does the Wyze Cam v4 support local video recording?Yes, the Wyze Cam v4 supports local video recording via a MicroSD card. The Outdoor Bundle includes a 128GB MicroSD card for continuous recording.
What security features does the Wyze Cam v4 offer?The Wyze Cam v4 includes motion and sound detection, customizable detection zones, a motion-activated spotlight, a built-in 99 dB siren, and two-way talk with noise and echo cancellation for enhanced home security.
What color options are available for the Wyze Cam v4?The Wyze Cam v4 is available in multiple colors, including White, Grey, and Black, so you can choose the one that best matches your home decor.
What is the price range for Wyze Cam v4 products?The Wyze Cam v4 is priced between $35.98 and $107.94. The Outdoor Bundle is $69.99, the Whole Home Security Starter Kit is $155.95, and the Home Security Bundle is $169.99.
What are the key features of the Wyze Cam v4 compared to the Wyze Cam v2?Can you tell me more about the Wyze Cam v4 Outdoor Bundle?Is there a warranty available for the Wyze Cam v4?
