Wyze Cam Pro: Edge AI Security with Two-Way Audio
Wyze Cam Pro with Edge AI and Two-Way Audio Feature
Discover the ultimate smart security solution with Wyze Cam Pro models that combine cutting-edge Edge AI technology and crystal-clear two-way audio. Whether you want advanced AI-powered tracking or seamless communication, Wyze offers cameras designed to keep your home safe and connected.
Wyze Battery Cam Pro: Wire-Free with Edge AI and Two-Way Audio
Experience the freedom of wire-free security with the Wyze Battery Cam Pro, featuring integrated Edge AI and two-way audio for real-time interaction.
Key Features:
  • 2.5K HDR Video Resolution: Capture stunning, high-definition footage with vibrant colors and sharp details.
  • Edge AI Technology: Advanced radar and PIR motion detection intelligently distinguish people, pets, and vehicles, reducing false alerts.
  • Two-Way Audio: Built-in speaker and MEMS digital microphone with noise and echo cancellation allow clear conversations from anywhere.
  • Wire-Free Convenience: Powered by removable, rechargeable 6200mAh battery packs lasting up to 6 months on a single charge.
  • IP65 Weatherproof: Durable for outdoor use in all weather conditions.
  • Integrated Spotlight & Siren: Motion-activated spotlight and 100 dB siren deter intruders effectively.
  • Dual-Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for reliable streaming.
Specs at a Glance:
  • Field of View: 134° diagonal
  • Night Vision: 2 IR LEDs + 2 White LEDs for color night vision
  • Local Storage: Supports up to 256GB microSD cards
  • Dimensions: 2.5 x 1.8 x 3.5 inches
  • Weight: 0.94 lbs
The Wyze Battery Cam Pro is perfect for those seeking a flexible, powerful security camera with smart AI features and crystal-clear two-way communication without the hassle of wires.
Wyze Cam v4: Wired Power with AI Auto-Zoom and Enhanced Two-Way Audio
The Wyze Cam v4 is the clearest Wyze Cam ever made, combining 2.5K Quad HD resolution with Edge AI-powered auto-zoom and enhanced two-way talk.
Standout Features:
  • 2.5K Quad HD Resolution: Capture every detail with vibrant colors and wide dynamic range (WDR).
  • Edge AI Auto-Zoom: Smart Focus tracks moving subjects automatically, keeping what matters in sharp view while maintaining the bigger picture.
  • Enhanced Two-Way Audio: Advanced Audio Coding (AAC), a powerful amplifier, and updated microphone deliver the clearest conversations.
  • Color Night Vision: See in the dark with enhanced hardware that reveals details invisible to the naked eye.
  • IP65 Weather Resistance: Suitable for indoor and outdoor use.
  • Integrated Spotlight & Siren: Motion-activated spotlight and 99 dB siren for added security.
  • Wi-Fi 6 Support: Enjoy stronger, more reliable connections with compatible routers.
  • 24/7 Local Recording: Continuous recording to microSD cards up to 512GB (sold separately), no subscription required.
Technical Highlights:
  • Field of View: 115.9° diagonal
  • Notification Speed: Advanced alerts for motion, sound, smoke, and CO alarms
  • Mounting: Screw-free magnetic mount for easy installation
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT
Wyze Cam v4 is ideal for users who want wired reliability combined with smart AI tracking and superior audio quality for two-way communication.
Wyze Cam v4 in use with two-way audio Enjoy clear two-way conversations with Wyze Cam v4
Wyze Cam Pan v3: 360° Coverage with Two-Way Audio and Weather Resistance
For full panoramic coverage, the Wyze Cam Pan v3 offers 360° horizontal and 180° vertical rotation with two-way audio and Edge AI capabilities.
Features Overview:
  • 1080p Full HD Video: Crisp video quality with 120° field of view.
  • 360° Pan & 180° Tilt: Complete room coverage with up to 110° per second rotation speed.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for seamless communication.
  • IP65 Weather Resistant: Suitable for indoor and outdoor use with the optional outdoor power adapter.
  • AI-Powered Motion Tracking: Automatically follows moving subjects to keep them in frame.
  • Easy Setup: Bluetooth-enabled setup with magnetic base for screw-free mounting.
  • Smart Assistant Compatible: Works with Alexa, Google Assistant, and IFTTT.
Specs Summary:
  • Digital Zoom: 8x
  • Storage: Supports up to 256GB microSD cards
  • Dimensions: 124mm x 60mm x 63mm
  • Weight: 11.29 oz (320 g)
The Wyze Cam Pan v3 is perfect for those who want dynamic, wide-area surveillance with two-way audio and AI tracking in a weatherproof design.
Wyze Cam Pan v3 outdoor lifestyle Wyze Cam Pan v3 delivers 360° coverage in all weather
Why Choose Wyze Cam Pro Models with Edge AI and Two-Way Audio?
Wyze Cam Pro cameras combine advanced Edge AI technology with crystal-clear two-way audio, giving you smarter, more interactive home security. Whether you prefer wire-free flexibility, wired reliability, or panoramic coverage, Wyze has a Pro model tailored to your needs.
  • Edge AI reduces false alerts and enhances tracking accuracy.
  • Two-Way Audio lets you communicate instantly with visitors, family, or intruders.
  • Weather Resistance ensures dependable performance indoors or outdoors.
  • Smart Home Integration offers hands-free control via Alexa, Google Assistant, and IFTTT.
  • Local Storage Options provide privacy and continuous recording without mandatory subscriptions.
Summary Table of Wyze Cam Pro Models
ModelResolutionEdge AI FeaturesTwo-Way AudioPower SourceWeatherproofStorage Support
Wyze Battery Cam Pro2.5K HDRRadar + PIR Motion DetectYesRechargeable BatteryIP65Up to 256GB microSD
Wyze Cam v42.5K QHDAI Auto-Zoom & TrackingEnhancedWired (Continuous)IP65Up to 512GB microSD
Wyze Cam Pan v31080p HDAI Motion TrackingYesWiredIP65Up to 256GB microSD
Choose the Wyze Cam Pro that fits your lifestyle and enjoy smarter, clearer, and more interactive home security with Edge AI and two-way audio.
FeatureWyze Battery Cam ProWyze Cam v4
Video Resolution2.5K HDR2.5K QHD (2560x1440)
Power SourceBattery (Removable, Rechargeable Packs)Wired
Wireless Connectivity2.4 & 5 GHz WiFi2.4 GHz Wi-Fi, Wi-Fi 6
Weatherproof RatingIP65IP65
Motion DetectionRadar + PIR Motion DetectionMotion and Sound Detection
SpotlightIntegrated Spotlight (150 lumens)Motion-activated Spotlight (72 lumens)
SirenIntegrated SirenBuilt-in Siren (99 dB)
Night VisionColor Night VisionEnhanced Color Night Vision
Local StorageMicroSD card support (up to 256GB)MicroSD card support (up to 512GB)
Continuous RecordingNo (event-based, local with microSD)Yes, 24/7 local recording with microSD
AudioTwo-way talk with microphone and speakerEnhanced two-way talk, noise & echo cancellation
SetupBluetoothⓇ setup, no hub requiredBluetoothⓇ setup, no QR code scanning
Mounting OptionsFlexible, includes ceiling mount optionStand, Wall mount, Ceiling mount, Magnetic mount
DimensionsNot specified2in x 2in x 2 3/8in
WeightNot specified0.49 lb (222 g)
Wi-Fi Bands Supported2.4 & 5 GHz2.4 GHz & Wi-Fi 6
Smart Assistant IntegrationNot specifiedAlexa, Google Assistant, IFTTT
Additional FeaturesSolar panel compatible, removable battery packsSmoke & CO alerts, Auto-zoom with AI, Motion detection zones
Price Range (Single Pack)$89.98$35.98
What is Edge AI in Wyze Cam Pro security cameras?Edge AI in Wyze Cam Pro cameras refers to advanced artificial intelligence technology built directly into the camera hardware. This enables real-time processing for features like person, pet, and vehicle detection, smart motion tracking, and auto-zoom, reducing false alerts and enhancing security without relying on cloud processing.
How does two-way audio work on Wyze Cam Pro models?Wyze Cam Pro models feature built-in speakers and microphones with noise and echo cancellation, allowing you to have clear, real-time conversations with visitors, family members, or intruders directly through the Wyze app, no matter where you are.
What are the main differences between Wyze Battery Cam Pro, Wyze Cam v4, and Wyze Cam Pan v3?Wyze Battery Cam Pro is wire-free with a rechargeable battery and 2.5K HDR video, ideal for flexible placement. Wyze Cam v4 offers wired power, 2.5K Quad HD resolution, AI auto-zoom, and enhanced two-way audio for continuous recording. Wyze Cam Pan v3 provides 360° pan and 180° tilt coverage, 1080p HD video, and AI-powered motion tracking for dynamic surveillance.
Are Wyze Cam Pro models weatherproof for outdoor use?Yes, all Wyze Cam Pro models, including the Wyze Battery Cam Pro, Wyze Cam v4, and Wyze Cam Pan v3, are rated IP65 weatherproof or weather resistant, making them suitable for both indoor and outdoor installation.
What storage options are available for Wyze Cam Pro cameras?Wyze Cam Pro cameras support local storage via microSD cards. The Wyze Battery Cam Pro and Wyze Cam Pan v3 support up to 256GB microSD cards, while the Wyze Cam v4 supports up to 512GB microSD cards for continuous 24/7 recording without a subscription.
Do Wyze Cam Pro cameras require a subscription for full functionality?No, Wyze Cam Pro cameras offer key features like local storage, two-way audio, and Edge AI detection without requiring a subscription. However, optional cloud services are available for additional features if desired.
Can Wyze Cam Pro models integrate with smart home systems?Yes, Wyze Cam Pro models are compatible with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT, allowing for hands-free control and automation.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro is powered by removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge, depending on usage and environmental factors.
What is the video resolution of Wyze Cam Pro models?Wyze Battery Cam Pro and Wyze Cam v4 both offer 2.5K high-definition video (HDR and Quad HD, respectively), while Wyze Cam Pan v3 provides 1080p Full HD video for clear and detailed footage.
Do Wyze Cam Pro cameras have night vision capabilities?Yes, all Wyze Cam Pro models feature night vision. Wyze Battery Cam Pro and Wyze Cam v4 offer color night vision with advanced hardware, while Wyze Cam Pan v3 provides crisp infrared night vision for clear footage in low-light conditions.
Can you tell me more about the Wyze Battery Cam Pro's features?How does the Edge AI technology work in the Wyze Cam models?Are there any ongoing promotions or discounts for Wyze cameras?
