Enable Two-Way Talk to Check on Kids with Wyze Cam v4
When it comes to keeping an eye on your children while you're away, having a reliable, high-quality camera with two-way talk functionality is essential. The Wyze Cam v4 series offers advanced features that allow you to not only monitor your kids remotely but also communicate with them instantly through your smartphone. Whether you want to check in during playtime or ensure they’re safe at night, Wyze Cam v4 provides peace of mind with crystal-clear video and seamless audio interaction.
Wyze Cam v4: The Ultimate Indoor Monitoring Solution
Crystal-Clear 2.5K QHD Video Quality
Wyze Cam v4 delivers stunning 2.5K QHD (2560x1440) resolution, ensuring you see every detail in your child’s room or play area. The camera’s CMOS Starlight Sensor enhances image clarity even in low light, making it perfect for day or night monitoring.
Simultaneous Two-Way Talk
Stay connected with your kids anytime using the camera’s built-in 99dB waterproof speaker and noise-echo cancellation technology. This feature allows you to talk and listen simultaneously, making it easy to soothe your child or give instructions remotely.
Enhanced Color Night Vision
Unlike traditional black-and-white night vision, Wyze Cam v4 offers color night vision with 4 IR LEDs and 2 white spotlight LEDs, so you can clearly see your kids even in the dark.
Flexible Mounting Options
Install the camera anywhere indoors with multiple mounting options including stand, wall mount, ceiling mount, or magnetic wall mount with adhesive. Its compact size (2in x 2in x 2 3/8in) and lightweight design (0.49 lb) make it unobtrusive and easy to position.
Smart Home Integration
Wyze Cam v4 works seamlessly with Alexa, Google Assistant, and IFTTT, allowing you to integrate it into your smart home ecosystem for voice commands and automation.
“Wyze Cam v4 is perfect for parents who want to check on their kids and talk to them instantly, no matter where they are.”
Child playing monitored by Wyze Cam v4 Monitor your child’s playroom with Wyze Cam v4’s clear video and two-way talk.
Wyze Cam v4 Outdoor Bundle: Monitor Kids Playing Outside Safely
Outdoor-Ready with IP65 Weather Resistance
The Wyze Cam v4 Outdoor Bundle includes the same powerful camera with added outdoor durability. It’s designed to withstand rain, snow, and extreme temperatures, making it ideal for monitoring kids playing in the yard or driveway.
Motion-Activated Spotlight & Enhanced Color Night Vision
Keep your outdoor spaces well-lit and secure with the motion-activated spotlight and enhanced color night vision. This ensures you can see your kids clearly even after dark.
24/7 Local Recording & Wi-Fi 6 Support
Record continuously with the included 128GB microSD card and enjoy faster, more reliable connectivity with Wi-Fi 6 support. This means no missed moments and smooth live streaming.
Smart Alerts & Compatibility
Receive motion and sound detection alerts directly to your phone, so you’re instantly notified if your kids are outside or if unexpected activity occurs. Compatible with Alexa and Google Assistant for hands-free control. Outdoor lifestyle with Wyze Cam v4 Keep an eye on your kids playing outdoors with Wyze Cam v4 Outdoor Bundle.
Wyze Cam v4 Home Security Bundle: Comprehensive Monitoring for Peace of Mind
All-in-One Indoor/Outdoor Security
This bundle offers the full Wyze Cam v4 experience with enhanced two-way audio, motion-activated spotlight, and person detection. Perfect for parents who want to monitor both inside and outside their home.
Improved Two-Way Audio Quality
The Home Security Bundle features upgraded audio for clearer conversations with your kids, making remote check-ins more natural and reassuring.
Extensive Storage & Video Capabilities
Includes a 128GB Class 10 UHS-3 microSD card for local storage, capable of holding up to 192 hours of HD video. The camera supports 8x digital zoom and wide dynamic range (WDR) for vibrant, detailed footage.
Easy Installation & Smart Features
Mount the camera anywhere with versatile mounting options and control it via Alexa or Google Assistant. The built-in siren adds an extra layer of security.
“The Home Security Bundle is ideal for families wanting a complete monitoring solution with crystal-clear video and reliable two-way communication.”
Why Choose Wyze Cam v4 for Monitoring Your Kids?
  • Simultaneous Two-Way Talk: Talk and listen at the same time to check on your kids or calm them remotely.
  • High-Resolution Video: 2.5K QHD resolution with color night vision ensures you never miss a detail.
  • Smart Alerts: Motion and sound detection keep you informed instantly.
  • Flexible Mounting: Easy to install anywhere indoors or outdoors.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for seamless control.
  • Weather Resistant: IP65 rating for outdoor use, perfect for monitoring kids playing outside.
Additional Options: Wyze Cam v4 + FREE 32GB MicroSD Card
For those looking for a budget-friendly option, the Wyze Cam v4 with a free 32GB microSD card offers all the essential features including two-way talk, color night vision, and motion-activated spotlight. This wired camera requires an outdoor power adapter for outdoor use and supports Wi-Fi 6 for reliable connectivity.
Conclusion
The Wyze Cam v4 lineup is the perfect choice for parents who want to enable two-way talk and keep a watchful eye on their kids while away. Whether indoors or outdoors, these cameras provide crystal-clear video, reliable audio communication, and smart features that make remote monitoring effortless and effective.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD Card
Price$100.00$69.99$169.99$35.98
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD
Color Night VisionYesYesYesYes
Night Vision Type4 IR LEDs + 2 white spotlight LEDs4 IR LEDs + 2 white spotlight LEDs4 IR LEDs + 2 white spotlight LEDsYes
Weather ResistanceIP65IP65IP65IP65
Motion-Activated SpotlightYesYesYesYes
AudioEnhanced Two-Way Talk, 99dB SirenEnhanced Two-Way Talk, 99dB SirenImproved 2-way audio, 99dB SirenEnhanced Two-Way Talk
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Local Storage SupportmicroSD card up to 512 GB128GB microSD Card included128GB microSD Card includedRequires microSD card (included 32GB)
Continuous RecordingYesYesYesYes
Motion & Sound DetectionYesYesYesYes
Smart Detection (Subscription)AvailableAvailableAvailableAvailable
Person DetectionYesYesYesYes
Smoke & CO AlertsYesYesYesYes
Field of View (DFOV x HFOV x VFOV)115.8° x 98.5° x 53.1°115.9° x 98.5° x 53.1°115.8° x 98.5° x 53.1°Not specified
Mounting OptionsStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, MagneticNot specified
Power Adapter IncludedIndoor 5V/1AWyze Outdoor Power Adapter includedIncluded (5V/1A adapter)Requires Outdoor Power Adapter
Bluetooth Version5.2Not specifiedNot specifiedNot specified
Video FPS (Day/Night)20 FPS / 15 FPSNot specified20 FPS / 15 FPSNot specified
Digital Zoom8xNot specified8xNot specified
Warranty1 Year1 Year1 YearNot specified
Included ItemsCamera onlyCamera, Outdoor Power Adapter, 128GB microSD CardCamera, 128GB microSD Card, Power AdapterCamera, Free 32GB microSD Card
What is two-way talk on Wyze Cam v4 and how does it help monitor kids?Two-way talk on Wyze Cam v4 allows you to communicate with your children in real time through the camera using your smartphone. This feature lets you both listen and speak simultaneously, making it easy to check in, comfort, or give instructions to your kids remotely.
Does Wyze Cam v4 offer high-resolution video for monitoring children?Yes, Wyze Cam v4 delivers 2.5K QHD (2560x1440) resolution, ensuring you can see every detail in your child’s room or play area. The advanced CMOS Starlight Sensor also enhances image clarity, even in low-light conditions.
Can Wyze Cam v4 be used to monitor kids at night?Absolutely. Wyze Cam v4 features enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs, allowing you to see your kids clearly even in complete darkness.
Is Wyze Cam v4 suitable for outdoor monitoring of children?Yes, the Wyze Cam v4 Outdoor Bundle is designed with IP65 weather resistance, making it ideal for monitoring kids playing outside in the yard or driveway. It withstands rain, snow, and extreme temperatures.
What mounting options are available for Wyze Cam v4?Wyze Cam v4 offers flexible mounting options, including stand, wall mount, ceiling mount, and magnetic wall mount with adhesive. Its compact and lightweight design makes it easy to install anywhere indoors or outdoors.
Does Wyze Cam v4 integrate with smart home systems?Yes, Wyze Cam v4 works seamlessly with Alexa, Google Assistant, and IFTTT, allowing you to control the camera with voice commands and integrate it into your smart home ecosystem.
How does Wyze Cam v4 notify parents of activity?Wyze Cam v4 provides smart alerts for motion and sound detection, sending instant notifications to your phone if your kids are outside or if unexpected activity occurs.
What storage options are available with Wyze Cam v4?Wyze Cam v4 supports local recording with microSD cards. Bundles are available with 32GB or 128GB microSD cards, allowing for continuous 24/7 recording and up to 192 hours of HD video storage.
Is the audio quality on Wyze Cam v4 suitable for clear communication?Yes, Wyze Cam v4 features a built-in 99dB waterproof speaker and noise-echo cancellation technology, ensuring clear and reliable two-way audio communication with your kids.
Does Wyze Cam v4 support Wi-Fi 6 for better connectivity?Yes, Wyze Cam v4 supports Wi-Fi 6, providing faster and more reliable connectivity for smooth live streaming and uninterrupted monitoring.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes an indoor/outdoor camera with enhanced two-way audio, motion-activated spotlight, person detection, a 128GB Class 10 UHS-3 microSD card, 8x digital zoom, wide dynamic range (WDR), and a built-in siren for comprehensive home monitoring.
Is there a budget-friendly Wyze Cam v4 option for parents?Yes, the Wyze Cam v4 with a free 32GB microSD card offers essential features like two-way talk, color night vision, and motion-activated spotlight at an affordable price. It is a wired camera and requires an outdoor power adapter for outdoor use.
How do I set up the Wyze Cam v4 for two-way talk?Can the Wyze Cam v4 be used outdoors as well?What are the mounting options available for the Wyze Cam v4?
