Wyze Cam Floodlight: Siren Feature for Ultimate Home Security
Wyze Cam Floodlight Siren Feature: Ultimate Home Security Lighting
When it comes to securing your home with smart lighting and powerful deterrents, Wyze Cam Floodlight series stands out with its integrated siren feature. The siren is a critical part of the security system, designed to scare off intruders and alert you instantly. Below, we explore the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro, both equipped with robust siren capabilities and advanced floodlight technology to keep your property safe day and night.
Wyze Cam Floodlight v2: Bright, Smart, and Loud
Powerful Siren and Two-Way Talk
Wyze Cam Floodlight v2 features a loud 105dB siren that you can activate remotely via the Wyze app. This siren works alongside two-way talk, allowing you to communicate directly with visitors or potential intruders. Whether you want to warn off unwanted guests or talk to a delivery person, the combination of voice and siren is a strong deterrent.
Brilliant 2800 Lumens Floodlight
Equipped with two adjustable LED floodlights producing 2800 lumens, this camera lights up your outdoor space brilliantly. The motion-activated lights switch on instantly when movement is detected, illuminating your driveway, porch, or backyard with a wide 160° field of view.
Crisp 2K Video with Color Night Vision
Capture every detail with 2K resolution video and color night vision, ensuring you don’t miss a thing even in low light. The wide-angle lens covers more area, reducing blind spots and enhancing security coverage.
AI-Powered Light Control & Ambient Light Mode
The floodlight intelligently adjusts brightness based on ambient light and motion, providing constant low-level lighting that brightens when needed. This smart feature helps conserve energy while maintaining security.
Weatherproof and Easy Installation
Rated IP65 for weather resistance, the Floodlight v2 withstands rain, snow, and harsh outdoor conditions. Plus, it offers a DIY-friendly installation with a floodlight plug-in mount option, perfect for renters or those with outdoor power outlets.
"Dominate the dark with Wyze Cam Floodlight v2’s siren and floodlight combo — your smart home’s vigilant guardian."
Wyze Cam Floodlight v2 illuminating driveway at night Wyze Cam Floodlight v2 lighting up a driveway with motion detection
Wyze Cam Floodlight Pro: Next-Level Security with Smarter Siren
Enhanced 105dB Siren with Motion-Activated Voice Deterrence
The Floodlight Pro not only includes a powerful 105dB siren but also features motion-activated voice deterrence. When a person is detected, a customizable voice prompt plays to warn off intruders before the siren even sounds, adding an extra layer of security.
Ultra-Wide 180° Field of View with 2.5K QHD Video
See your entire yard with the widest view in the floodlight camera category. The 2.5K Quad HD resolution delivers crystal-clear video, day or night, with color night vision that captures vivid details.
Intelligent AI-Powered Lighting
Unlike traditional PIR sensors, the Floodlight Pro uses onboard AI computer vision to detect specific objects like people and vehicles. This precision triggers the 3000 lumen LED lights only when necessary, reducing false alarms and unnecessary lighting.
Fully Adjustable Floodlight Panels
Three independently articulating LED panels allow you to customize the light coverage to fit your property’s unique layout, ensuring no dark corners remain.
Dual-Band Wi-Fi and Easy Setup
Supports both 2.4 GHz and 5 GHz Wi-Fi for faster, more reliable connections. Setup is simple with BluetoothⓇ, no QR code scanning required.
Rugged Weather Resistance and Automation
IP65 rated for all-weather durability, plus dusk-to-dawn automation means your floodlight turns on and off automatically with the sun.
"Wyze Cam Floodlight Pro’s siren and voice deterrence act like a personal security guard, keeping your home safe with smart, bright vigilance."
Woman with dog near Wyze Cam Floodlight Pro Wyze Cam Floodlight Pro providing security and communication outdoors
Why Choose Wyze Floodlight Cameras with Siren Features?
  • Instant Intruder Deterrence: The 105dB siren is loud enough to startle and scare away intruders immediately.
  • Two-Way Communication: Talk directly through the camera to warn visitors or communicate with family.
  • Smart Lighting: Motion-activated, AI-powered floodlights illuminate only when needed, saving energy.
  • Clear Video Evidence: High-resolution video with color night vision ensures you capture every detail.
  • Weatherproof Durability: IP65 rating means these cameras work reliably in all weather conditions.
  • Easy DIY Installation: No electrician needed, with plug-in mount options available.
Additional Wyze Cameras with Siren Features
While the Wyze Cam Floodlight v2 and Pro are the best choices for floodlight and siren integration, other Wyze cameras also offer siren capabilities for versatile home security:
Wyze Cam v4
  • 2.5K QHD video with enhanced color night vision
  • Built-in 99dB waterproof siren
  • Motion-activated spotlight
  • Wi-Fi 6 support and Alexa/Google Assistant integration
Wyze Battery Cam Pro
  • Wire-free with rechargeable battery packs
  • Integrated spotlight and 100dB siren
  • Radar + PIR motion detection
  • Dual-band Wi-Fi support
These models provide flexible options for indoor/outdoor security with siren features, but for dedicated floodlight and siren combo, Wyze Cam Floodlight v2 and Pro remain the top picks.
Conclusion
The Wyze Cam Floodlight series, especially the Floodlight v2 and Floodlight Pro, offer powerful siren features combined with bright, intelligent floodlighting and high-resolution video. Whether you want to deter intruders with a loud siren, communicate via two-way talk, or enjoy smart lighting automation, these cameras provide comprehensive security solutions for your home. Invest in Wyze Cam Floodlight with siren features to illuminate, monitor, and protect your property with confidence. Wyze Cam Floodlight v2 lifestyle with two-way audio Wyze Cam Floodlight v2 with two-way audio for real-time communication
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight ProWyze Cam v4Wyze Video Doorbell v2
Price$89.98$149.98$35.98 - $107.94 (varies by bundle)$44.98
Video Resolution2K (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2K (2048x1536)
Field of View160° wide-angle180° wide-angleDFOV 115.8°, HFOV 98.5°, VFOV 53.1°166.8° diagonal, 135° horizontal
LED Floodlight Brightness2800 lumens (2 adjustable heads)3000 lumens (3 adjustable heads)Motion-activated spotlight (72 lumens)No floodlight
Night VisionColor Night VisionColor Night VisionEnhanced Color Night VisionIR Night Vision (6 x 940nm IR LEDs)
Local StoragemicroSD up to 256GBmicroSD up to 256GBmicroSD up to 512GBmicroSD up to 256GB
Cloud StorageOptional with Cam Plus subscriptionOptional with Cam Plus subscriptionOptional with subscription planOptional with Wyze Security Plan
AI DetectionPerson, Package, Vehicle (Cam Plus)Person, Package, Vehicle (Onboard AI)Person detectionMotion-activated voice deterrence
Two-Way TalkYesYesYesYes
Siren105 dB loud siren105 dB loud sirenBuilt-in siren (99 dB)No siren
Motion Detection Area270° PIR motion detectionAI computer vision motion detectionYesYes
Ambient Light ModeYesYesMotion-activated spotlightNo
Wi-Fi Support2.4 GHz2.4 & 5 GHz dual-band2.4 GHz & Wi-Fi 62.4 GHz
Weather ResistanceIP65IP65IP65IP65
Power SourceWired (floodlight wiring)Wired (floodlight wiring)Wired (indoor/outdoor with adapter)Wired (16V-24V AC)
InstallationDIY with floodlight plug-in mount optionDIY with floodlight plug-in mount optionMultiple mounting optionsWired doorbell installation
Voice Assistant IntegrationAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
DimensionsNot specifiedNot specified2in x 2in x 2 3/8in4.3in x 1.7in x 0.9in
WeightNot specifiedNot specified0.49 lb (222 g)Not specified
What is the siren feature on Wyze Cam Floodlight cameras?The Wyze Cam Floodlight series, including the v2 and Pro models, features a powerful 105dB siren designed to deter intruders and alert homeowners instantly. The siren can be activated remotely via the Wyze app, providing an effective security measure for your property.
How does the Wyze Cam Floodlight v2 enhance home security?Wyze Cam Floodlight v2 enhances home security with a 105dB siren, two-way talk for direct communication, 2800 lumens of motion-activated LED lighting, 2K video with color night vision, and AI-powered light control. Its IP65 weatherproof rating and easy installation make it ideal for outdoor use.
What are the key features of Wyze Cam Floodlight Pro?Wyze Cam Floodlight Pro offers a 105dB siren, motion-activated voice deterrence, ultra-wide 180° field of view, 2.5K QHD video with color night vision, AI-powered object detection, three adjustable LED panels, dual-band Wi-Fi, and dusk-to-dawn automation. It is IP65 rated for all-weather durability.
Can I communicate with visitors using Wyze Cam Floodlight cameras?Yes, both Wyze Cam Floodlight v2 and Pro support two-way audio, allowing you to speak directly to visitors, delivery personnel, or potential intruders through the Wyze app.
How bright are the Wyze Cam Floodlight v2 and Pro lights?Wyze Cam Floodlight v2 features two adjustable LED floodlights with a combined brightness of 2800 lumens, while the Floodlight Pro offers 3000 lumens with three independently adjustable panels, ensuring wide and customizable coverage.
Do Wyze Cam Floodlight cameras work at night?Yes, both Wyze Cam Floodlight v2 and Pro are equipped with color night vision and high-resolution video (2K for v2, 2.5K QHD for Pro), allowing you to capture clear footage even in low-light conditions.
Are Wyze Cam Floodlight cameras weatherproof?Yes, both the Wyze Cam Floodlight v2 and Pro are rated IP65, making them resistant to rain, snow, and harsh outdoor conditions for reliable year-round performance.
Is installation of Wyze Cam Floodlight cameras easy?Yes, Wyze Cam Floodlight v2 and Pro are designed for easy DIY installation. The v2 model offers a plug-in mount option, making it suitable for renters or homes with outdoor power outlets. The Pro model supports Bluetooth setup for a quick and hassle-free installation.
What smart features do Wyze Cam Floodlight cameras offer?Wyze Cam Floodlight cameras feature AI-powered motion detection, ambient light adjustment, motion-activated lighting, and customizable voice deterrence (Pro model). They also support dusk-to-dawn automation and dual-band Wi-Fi for enhanced connectivity.
Are there other Wyze cameras with siren features?Yes, other Wyze cameras like the Wyze Cam v4 and Wyze Battery Cam Pro also include siren features. The Wyze Cam v4 has a 99dB waterproof siren and motion-activated spotlight, while the Wyze Battery Cam Pro offers a 100dB siren, integrated spotlight, and wire-free installation.
Why should I choose Wyze Cam Floodlight with siren for home security?Wyze Cam Floodlight cameras combine a loud siren, smart floodlighting, high-resolution video, two-way communication, and weatherproof durability. These features work together to deter intruders, provide clear video evidence, and ensure reliable security for your home.
What are the key features of the Wyze Cam Floodlight v2?How does the two-way talk feature work on the Wyze Cam Floodlight v2?Do you have any deals, ongoing sales, discounts, or promotions?
