Top Indoor & Outdoor Security Cameras with Siren & Floodlight
Best Indoor and Outdoor Security Cameras with Siren, Integrated Floodlight, and Adjustable Brightness
When it comes to securing your home or business, having a security camera that combines powerful lighting, clear video, and smart features is essential. Whether you need an indoor/outdoor camera with a siren, integrated floodlight, or adjustable brightness, Wyze offers a range of advanced cameras designed to keep your property safe day and night. Explore the top Wyze security cameras that perfectly match your needs for indoor and outdoor surveillance with integrated floodlights and sirens.
Wyze Cam Floodlight v2: Bright, Smart, and Reliable Outdoor Security
Wyze Cam Floodlight v2 illuminating a driveway at night Alt: Outdoor security camera with floodlight illuminating driveway at night The Wyze Cam Floodlight v2 is a standout choice for outdoor security with its powerful 2800 lumens LED floodlights and crystal-clear 2K video resolution. This camera offers a wide 160° field of view, ensuring you capture more of your property with vibrant color night vision.
Key Features:
  • 2800 Lumens Adjustable LEDs: Motion-activated and dimmable to suit your lighting needs, with Ambient Light Mode providing a constant low-level glow that brightens when motion is detected.
  • 2K HD Video with Color Night Vision: See every detail clearly, even in low light or darkness.
  • Wide 160° Field of View: Covers a broad area to reduce blind spots.
  • 105dB Loud Siren: Deterrent siren to scare off intruders instantly.
  • Two-Way Talk: Communicate with visitors or delivery personnel directly through the Wyze app.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
  • AI-Powered Light Control: Smart automation adjusts lighting based on detected motion and ambient light.
  • Dusk-to-Dawn Automation: Automatically turns lights on at sunset and off at sunrise.
  • IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions.
  • Easy DIY Installation: Optional plug-in mount available for simple setup without electrician help.
This camera integrates seamlessly with Alexa and Google Assistant, allowing voice control and smart home automation.
Wyze Cam Floodlight Pro: The Ultimate Outdoor Security Floodlight Camera
Woman with dog near Wyze Cam Floodlight Pro Alt: Outdoor security camera with floodlight and woman with dog For those who want the best in floodlight security, the Wyze Cam Floodlight Pro offers a professional-grade 180° ultra-wide field of view and stunning 2.5K QHD video quality. It’s designed to be your personal home security guard with advanced AI-powered motion detection and customizable lighting.
Highlights:
  • 3,000 Lumens Adjustable LED Floodlights: Three independently articulating panels let you customize light coverage and brightness.
  • 2.5K QHD Video + Color Night Vision: Ultra-clear video day and night with enhanced detail.
  • AI Computer Vision: Detects motion from people, vehicles, and other objects you select, triggering lights and notifications only when needed.
  • Motion-Activated Voice Deterrence & 105dB Siren: Plays voice prompts and sounds a loud siren to deter unwanted visitors.
  • Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks for faster, more reliable streaming.
  • Dusk-to-Dawn Automation & IP65 Weatherproofing: Ensures your property is lit and protected around the clock, rain or shine.
  • 24/7 Local Recording: Supports up to 256GB microSD card for continuous video capture.
  • Easy DIY Installation: Replace your existing floodlight in under 20 minutes with no electrician needed.
  • Plug-In Mount Option: For renters or those without junction boxes, a plug-in mount bundle is available.
This camera is perfect for large yards or properties needing comprehensive coverage with smart lighting and security.
Wyze Cam Pan v3: Versatile Indoor/Outdoor Security with 360° Coverage
Wyze Cam Pan v3 in snowy outdoor setting Alt: Weather-resistant Wyze Cam Pan v3 mounted outdoors in snow If you want a flexible camera that works both indoors and outdoors, the Wyze Cam Pan v3 is an excellent choice. It offers 360° horizontal and 180° vertical rotation, allowing you to pan and tilt remotely to cover every angle.
Features:
  • 1080p Full HD Video: Clear video with 4 IR LEDs for night vision.
  • 360° Pan & 180° Tilt: Complete coverage with remote control via the app.
  • IP65 Weather Resistance: Suitable for outdoor use with the Wyze Outdoor Power Adapter.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
  • Motion Tracking & Alerts: Automatically follows movement and sends push notifications.
  • Supports up to 256GB microSD: For local continuous recording.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
  • Compact and Lightweight: Easy to mount anywhere indoors or outdoors.
This camera is ideal for monitoring large indoor spaces or outdoor areas where flexible viewing angles are needed.
Wyze Cam v4: Compact Spotlight Camera with Siren and Color Night Vision
The Wyze Cam v4 is a compact, versatile camera that combines a motion-activated spotlight with 2.5K QHD video and a built-in siren, perfect for both indoor and outdoor use.
Key Specs:
  • 2.5K QHD Video & Enhanced Color Night Vision: Crisp, colorful video even in the dark.
  • Motion-Activated Spotlight: Brightens your property instantly when motion is detected.
  • Built-In 99dB Siren: Loud enough to deter intruders.
  • Wi-Fi 6 Support: Faster and more reliable wireless connection.
  • 24/7 Local Recording: Supports microSD cards up to 512GB.
  • IP65 Weatherproof: Durable for outdoor conditions.
  • Two-Way Talk: Communicate through the camera.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts.
Wyze Cam v4 is perfect for users who want a smaller footprint camera with powerful lighting and siren features.
Convenient Plug-In Mount Bundles for Floodlight Cameras
For those who prefer a hassle-free installation without wiring or junction boxes, Wyze offers plug-in mount bundles for both the Floodlight v2 and Floodlight Pro models.
Benefits:
  • Easy Plug-and-Play Setup: Just plug into an outdoor outlet—no electrician needed.
  • Flexible Placement: Ideal for renters or homes without existing floodlight wiring.
  • Includes 20ft Power Cord: Manage cable easily with included velcro straps.
  • Same Powerful Features: All the floodlight and camera capabilities remain intact.
Choose the Wyze Cam Floodlight v2 + Plug-In Mount or Wyze Cam Floodlight Pro + Plug-In Mount bundles for maximum convenience and security.
Illuminate your property with confidence. Whether you want a powerful floodlight camera with AI motion detection, a versatile pan-tilt camera, or a compact spotlight camera with siren, Wyze has the perfect indoor/outdoor security solution with integrated floodlights and adjustable brightness to keep your home safe day and night.
Summary Table of Featured Cameras
ModelVideo ResolutionFloodlight LumensField of ViewSirenWeatherproofSpecial Features
Wyze Cam Floodlight v22K2800160°105dBIP65AI Light Control, Ambient Mode
Wyze Cam Floodlight Pro2.5K QHD3000180°105dBIP65AI Vision, Voice Deterrence
Wyze Cam Pan v31080pNo360° panNoIP65360° Pan/Tilt, Motion Tracking
Wyze Cam v42.5K QHDSpotlight (72 lm)115.8° DFOV99dBIP65Spotlight, Wi-Fi 6, Compact
Floodlight Pro + Plug-In2.5K QHD3000180°105dBIP65Plug-In Mount Convenience
Floodlight v2 + Plug-In2K2800160°105dBIP65Plug-In Mount Convenience
Secure your home with the best indoor/outdoor security cameras featuring integrated floodlights, sirens, and adjustable brightness from Wyze. Choose the model that fits your needs and enjoy peace of mind with smart, powerful home security.
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight ProWyze Cam Pan v3Wyze Cam v4Wyze Cam Floodlight Pro + Plug-In MountWyze Cam Floodlight v2 + Plug-In Mount
Price (USD)$89.98$149.98$39.98 - $114.94 (varies by pack)$35.98 - $107.94 (varies by pack)$169.96$109.96
Video Resolution2K HD (160° FOV)2.5K QHD (180° FOV)1080p (120° FOV)2.5K QHD (115.8° DFOV)2.5K QHD (180° Ultra-Wide)2K HD (160° wide-angle)
Field of View160° wide-angle180° ultra-wide360° horizontal, 180° vertical115.8° DFOV, 98.5° HFOV, 53.1° VFOV180° ultra-wide160° wide-angle
LED Floodlight Brightness2800 lumens3000 lumensN/ASpotlight LEDs (72 lumens)3000 lumens2800 lumens
Night VisionColor Night VisionColor Night Vision4 IR LEDs (850 nm)Enhanced Color Night VisionColor Night VisionVibrant Color Night Vision
Motion DetectionPIR 270° + AI-Powered Light ControlAI Computer Vision (selective)YesYesAI Computer Vision (selective)Advanced Motion Detection
Two-Way TalkYesYesYesYesYesYes
Built-in Siren105 dB105 dBNoYes (99 dB)105 dB105 dB
Local StoragemicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 512 GBmicroSD up to 256 GBmicroSD up to 256 GB
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Wi-Fi Support2.4 GHzDual-band 2.4 & 5 GHz2.4 GHz2.4 GHz & Wi-Fi 62.4 GHz2.4 GHz
Weather ResistanceIP65IP65IP65IP65IP65IP65
Power SourceWiredWiredWired (Outdoor adapter sold separately)WiredWired with Plug-In MountWired with Plug-In Mount
InstallationDIY, no junction box neededDIY, no junction box neededDIY, requires outdoor power adapterDIYPlug-In Mount includedPlug-In Mount included
Ambient Light ModeYesYesNoNoYesYes
Motion-Activated Voice DeterrenceNoYesNoYesYesNo
Siren Loudness105 dB105 dBN/A99 dB105 dB105 dB
DimensionsNot specifiedNot specified124mm x 60mm x 63mm2in x 2in x 2 3/8inNot specifiedNot specified
WeightNot specifiedNot specified11.29 oz (320 g)0.49 lb (222 g)Not specifiedNot specified
Additional FeaturesAI-Powered Light Control, Dusk-to-Dawn Automation, Two-Way TalkAI Computer Vision, 3 Adjustable Floodlight Heads, Motion-Activated Voice Deterrence360° Pan & 180° Tilt, Noise & Echo CancellationWi-Fi 6 Support, 8x Digital Zoom, Built-in SirenIncludes Plug-In Mount for easy outlet powerIncludes Plug-In Mount for easy outlet power
What are the best Wyze security cameras with integrated floodlights and sirens?The best Wyze security cameras with integrated floodlights and sirens are the Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro. Both models offer powerful LED floodlights, loud sirens, and advanced features like AI-powered motion detection, color night vision, and weather resistance for reliable outdoor security.
What features does the Wyze Cam Floodlight v2 offer for outdoor security?The Wyze Cam Floodlight v2 features 2800 lumens adjustable LED floodlights, 2K HD video with color night vision, a wide 160° field of view, a 105dB siren, two-way talk, 24/7 local recording to microSD, AI-powered light control, dusk-to-dawn automation, IP65 weather resistance, and easy DIY installation with an optional plug-in mount.
How does the Wyze Cam Floodlight Pro differ from the Floodlight v2?The Wyze Cam Floodlight Pro offers a higher 2.5K QHD video resolution, a wider 180° field of view, 3,000 lumens adjustable LED floodlights with three articulating panels, AI computer vision for advanced motion detection, motion-activated voice deterrence, dual-band Wi-Fi support, and easy DIY installation. It is ideal for larger properties needing comprehensive coverage.
Can I install Wyze floodlight cameras without an electrician?Yes, Wyze offers plug-in mount bundles for both the Floodlight v2 and Floodlight Pro models. These plug-in mounts allow for easy, tool-free installation by plugging into an outdoor outlet, making them perfect for renters or homes without existing floodlight wiring.
Are Wyze security cameras weatherproof for outdoor use?Yes, Wyze security cameras such as the Floodlight v2, Floodlight Pro, Cam Pan v3, and Cam v4 are all IP65 weather resistant, making them suitable for outdoor use in rain, snow, and harsh conditions.
Which Wyze camera is best for 360° indoor and outdoor coverage?The Wyze Cam Pan v3 is the best option for 360° indoor and outdoor coverage. It features 360° horizontal pan, 180° tilt, 1080p HD video, motion tracking, two-way audio, and is IP65 weather resistant when used with the Wyze Outdoor Power Adapter.
Does Wyze offer security cameras with adjustable brightness?Yes, both the Wyze Cam Floodlight v2 and Floodlight Pro offer adjustable brightness on their LED floodlights. The Floodlight v2 includes dimmable LEDs and Ambient Light Mode, while the Floodlight Pro features three independently adjustable panels for customized lighting.
What is the video resolution of Wyze security cameras with floodlights?The Wyze Cam Floodlight v2 records in 2K HD resolution, while the Wyze Cam Floodlight Pro and Wyze Cam v4 offer 2.5K QHD video for ultra-clear footage day and night.
Do Wyze security cameras support local video recording?Yes, all featured Wyze security cameras support 24/7 local recording to microSD cards. The Floodlight v2 and Pro support up to 256GB, while the Cam v4 supports up to 512GB microSD cards for continuous video capture without subscription fees.
Can I control Wyze security cameras with Alexa or Google Assistant?Yes, Wyze security cameras integrate seamlessly with Alexa and Google Assistant, allowing for voice control and smart home automation. Some models also support IFTTT for additional automation options.
What is the difference between a floodlight camera and a spotlight camera from Wyze?Wyze floodlight cameras, like the Floodlight v2 and Pro, feature high-lumen LED floodlights for wide-area illumination, while the Wyze Cam v4 is a compact camera with a motion-activated spotlight (72 lumens) for focused lighting. Both types include sirens and color night vision.
Are there Wyze security cameras suitable for renters?Yes, Wyze offers plug-in mount bundles for the Floodlight v2 and Pro, which require no wiring or permanent installation. These are ideal for renters or anyone who wants a flexible, non-invasive security solution.
Which Wyze camera is best for small spaces with powerful lighting and siren?The Wyze Cam v4 is the best choice for small spaces. It is compact, features a motion-activated spotlight, 2.5K QHD video, built-in 99dB siren, two-way talk, and multiple mounting options for versatile installation indoors or outdoors.
What are the key features of the Wyze Cam Floodlight v2?Can you tell me more about the Wyze Cam Floodlight Pro and its capabilities?Are there any ongoing sales or discounts for the Wyze security cameras?
