Wyze Home Security Cameras: Smart Indoor & Outdoor Protection
Home Security Cameras: Protect Your Home with Advanced Wyze Solutions
When it comes to safeguarding your home, having reliable, smart, and versatile security cameras is essential. Wyze offers a comprehensive lineup of home security cameras designed to meet every need — from indoor monitoring to outdoor protection with powerful lighting and wireless convenience. Explore the features and benefits of the top Wyze cameras that bring peace of mind and smart home integration to your doorstep.
Wyze Cam v4: Crystal-Clear Security Day and Night
Experience unmatched clarity and security with the Wyze Cam v4, perfect for both indoor and outdoor use. This camera delivers stunning 2.5K QHD resolution, ensuring every detail is captured with precision. Its enhanced color night vision lets you see vibrant colors even in low light, while the motion-activated spotlight deters unwanted visitors effectively.
  • Resolution: 2.5K QHD for sharp, detailed video
  • Night Vision: Enhanced color night vision with spotlight
  • Field of View: Wide angles (DFOV 115.8°, HFOV 98.5°, VFOV 53.1°) for broad coverage
  • Connectivity: Supports Wi-Fi 6 for faster, more reliable streaming
  • Smart Home Integration: Compatible with Alexa and Google Assistant
  • Recording: 24/7 local recording keeps your footage safe without subscription fees
  • Design: Durable polycarbonate body with glass + plastic lens, available in multiple colors (Black, Clear, Grey, White)
This camera is ideal for those who want high-resolution video and smart features in a compact, weather-resistant design.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Full Coverage
For complete surveillance with flexible viewing angles, the Wyze Cam Pan v3 is a standout choice. This indoor/outdoor camera offers a full 360° pan and 180° tilt, allowing you to monitor every corner of your property remotely.
  • Movement: 360° horizontal pan and 180° vertical tilt
  • Weather Resistance: IP65 rating for reliable outdoor use (requires Wyze Outdoor Power Adapter)
  • Video Quality: Crisp video with smart motion tracking
  • Colors: Available in Black and White
  • Smart Features: Works seamlessly with your smart home ecosystem
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Wyze Cam Pan v3 providing weather-resistant outdoor security
This camera is perfect for users who want dynamic control over their camera’s view and robust weatherproofing for outdoor environments.
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoors
Illuminate your property while keeping it secure with the Wyze Cam Floodlight v2. Combining a powerful 2800 lumens LED floodlight with a 2K color night vision camera, this device ensures you never miss a thing after dark.
  • Lighting: 2800 lumens with AI-powered light control and ambient light mode
  • Video: 2K resolution with 160° wide-angle view
  • Weatherproof: IP65 rating for all-weather durability
  • Smart Automation: Dusk-to-dawn lighting and integration with Alexa, Google Assistant, and IFTTT
  • Additional Features: Two-way talk, motion detection, and 24/7 local recording
<img src="https://www.wyze.com/cdn/shop/files/WyzeCamFloodlightv2Main-08.jpg?v=1743789457&width=1946" alt="Wyze Cam Floodlight v2 illuminating driveway at night">
Wyze Cam Floodlight v2 lighting up a driveway with smart security
Ideal for driveways, backyards, and entryways, this floodlight camera combines bright illumination with smart security features to deter intruders effectively.
Wyze Bulb Cam: Discreet Security with Smart Lighting
The Wyze Bulb Cam is a unique 2-in-1 device that functions as both a smart LED light bulb and an outdoor security camera. It fits most standard light fixtures, making it an easy and discreet way to add security to your home.
  • Video Quality: Clear 2K HD video with color night vision
  • Installation: Simple screw-in bulb design, no extra wiring needed
  • Smart Alerts: Instant motion notifications via the Wyze app
  • Local Storage: Supports local video storage without subscription fees
  • Certifications: FCC, IC, UL, and IP65 weatherproof rating
<img src="https://www.wyze.com/cdn/shop/files/Wyze_Bulb_Cam_Shopify-07.jpg?v=1746478547&width=1500" alt="Wyze Bulb Cam installed in outdoor light fixture">
Wyze Bulb Cam providing smart security and lighting outdoors
This camera is perfect for those seeking a low-profile security solution that doubles as smart lighting.
Wyze Battery Cam Pro: Wire-Free, Powerful Security Anywhere
For ultimate flexibility, the Wyze Battery Cam Pro offers wire-free installation with powerful features packed into a compact design.
  • Resolution: 2.5K HDR video for crystal-clear footage
  • Power: Removable, rechargeable 6200mAh battery packs for long-lasting use
  • Connectivity: Supports both 2.4 GHz and 5 GHz Wi-Fi networks
  • Features: Integrated spotlight, siren, radar + PIR motion detection
  • Weatherproof: IP65 rating for reliable outdoor use
This camera is ideal for locations where wiring is difficult or impossible, providing flexible placement without sacrificing video quality or smart features.
Ultimate Security Bundle: Comprehensive Protection for Your Home
For those who want an all-in-one solution, the Ultimate Security Bundle (13-piece) offers a complete smart home security system covering every angle. Includes:
  • Wyze Cam Duo Doorbell with dual cameras and two-way audio
  • Wyze Lock Bolt with fingerprint reader and keypad
  • 2× Wyze Cam Pan v3
  • 2× Wyze Cam v4
  • 2× Wyze Battery Cam Pro
  • Wyze Sense Hub, motion sensor, and entry sensors
Features:
  • Smart alerts and motion tracking
  • Color night vision and two-way talk
  • Wire-free and plug-in cameras
  • Central hub for instant notifications
This bundle is perfect for homeowners seeking a robust, integrated security system that protects both indoors and outdoors with smart automation and advanced detection.
Why Choose Wyze Home Security Cameras?
"Wyze cameras combine cutting-edge technology with affordability, making smart home security accessible to everyone."
  • High-resolution video with color night vision for clear monitoring day and night
  • Wide range of cameras for indoor, outdoor, wired, and wireless needs
  • Smart home compatibility with Alexa, Google Assistant, and IFTTT
  • Weather-resistant designs built to withstand harsh conditions
  • Flexible installation options including plug-in, battery-powered, and bulb-style cameras
  • Local storage options with no mandatory subscription fees
Investing in Wyze home security cameras means securing your home with trusted technology that adapts to your lifestyle and environment.
Protect your home with Wyze’s innovative security cameras and enjoy peace of mind knowing your property is monitored with clarity, intelligence, and convenience.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam Floodlight v2Wyze Bulb CamWyze Battery Cam Pro
Video Resolution2.5K QHD (2560x1440)Not specified (assumed 1080p+)2K (2304x1296)2K (2304x1296)2.5K HDR (2560x1440)
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt160° diagonal160° diagonal (166° diagonal)134° (D), 108° (H), 56° (V)
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)Color Night VisionColor Night Vision + IR Night VisionIR LEDs + White LEDs (Color Night Vision)
AudioEnhanced Two-Way Talk, 99dB SirenTwo-Way AudioTwo-Way Audio, 105dB SirenTwo-Way Audio, 95dB SirenTwo-Way Audio, 100dB Siren
Motion DetectionYes, with motion-activated spotlightYes, with automatic motion trackingYes, AI-Powered Light ControlYes, motion alertsRadar + PIR Motion Detection
Power SourceWired (6-ft USB cable)Wired (requires Outdoor Power Adapter for outdoor)Hardwired (110-120V AC)Standard E26 Socket (120V AC)Wire-free, rechargeable battery
Weather ResistanceIP65IP65IP65IP65IP65
Local StoragemicroSD up to 512GB (required)microSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GB
Wireless Connectivity2.4 GHz Wi-Fi, Wi-Fi 6, Bluetooth 5.22.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Bluetooth 4.2/ BLE2.4 & 5 GHz Wi-Fi, BLE 5.1
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Dimensions2in x 2in x 2 3/8in (51x51x60 mm)Not specified9.5in x 7.7in x 7.0in (24.13x19.56x17.78 cm)Not specified2.5 x 1.8 x 3.5 inches
Weight0.49 lb (222 g)Not specified2.76 lbs (1.25 kg)Not specified0.94 lbs
Special FeaturesMotion-activated spotlight, AI Auto-Zoom, 24/7 local recording360° pan & 180° tilt, Privacy Mode, Pan Scan™ Patrol2800 Lumens LED floodlight, Ambient Light Mode, Dusk-to-Dawn automation2-in-1 LED bulb & camera, fits standard fixturesWire-free, removable rechargeable battery, radar + PIR detection
Price (1 Pack)$35.98$39.98$89.98$49.98$159.98
What are the main features of Wyze Cam v4 home security camera?The Wyze Cam v4 offers 2.5K QHD resolution for sharp, detailed video, enhanced color night vision with a motion-activated spotlight, wide field of view, Wi-Fi 6 connectivity, 24/7 local recording without subscription fees, and compatibility with Alexa and Google Assistant. Its weather-resistant design makes it suitable for both indoor and outdoor use.
How does the Wyze Cam Pan v3 provide full coverage for home security?The Wyze Cam Pan v3 features a 360° horizontal pan and 180° vertical tilt, allowing you to remotely monitor every corner of your property. It is IP65 weather-resistant (with the Wyze Outdoor Power Adapter), offers crisp video with smart motion tracking, and integrates seamlessly with smart home systems.
What makes the Wyze Cam Floodlight v2 ideal for outdoor security?Wyze Cam Floodlight v2 combines a powerful 2800 lumens LED floodlight with a 2K color night vision camera, providing bright illumination and clear video footage. It features AI-powered light control, dusk-to-dawn automation, two-way talk, motion detection, 24/7 local recording, and is weatherproof with an IP65 rating.
How does the Wyze Bulb Cam work as both a security camera and smart light?The Wyze Bulb Cam is a 2-in-1 device that functions as a smart LED light bulb and a 2K HD security camera with color night vision. It installs easily by screwing into standard light fixtures, offers instant motion notifications via the Wyze app, supports local video storage without subscription fees, and is IP65 weatherproof.
What are the benefits of the Wyze Battery Cam Pro for wireless home security?Wyze Battery Cam Pro provides wire-free installation with 2.5K HDR video, a removable and rechargeable 6200mAh battery, support for both 2.4 GHz and 5 GHz Wi-Fi, integrated spotlight and siren, radar and PIR motion detection, and an IP65 weatherproof rating. It is ideal for flexible placement where wiring is not possible.
What is included in the Wyze Ultimate Security Bundle?The Wyze Ultimate Security Bundle (13-piece) includes a Wyze Cam Duo Doorbell with dual cameras and two-way audio, Wyze Lock Bolt with fingerprint reader and keypad, 2 Wyze Cam Pan v3, 2 Wyze Cam v4, 2 Wyze Battery Cam Pro, Wyze Sense Hub, motion sensor, and entry sensors. It offers smart alerts, motion tracking, color night vision, two-way talk, and a central hub for instant notifications.
Do Wyze home security cameras require a subscription for video storage?No, Wyze home security cameras support 24/7 local recording and local video storage without mandatory subscription fees, allowing you to keep your footage safe and accessible.
Are Wyze security cameras compatible with smart home systems?Yes, Wyze security cameras are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT, enabling seamless integration and voice control.
Are Wyze cameras weatherproof and suitable for outdoor use?Many Wyze cameras, such as the Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam Floodlight v2, Wyze Bulb Cam, and Wyze Battery Cam Pro, feature IP65 weatherproof ratings, making them durable and reliable for outdoor security in various weather conditions.
Why should I choose Wyze home security cameras for my property?Wyze home security cameras offer high-resolution video with color night vision, a wide range of indoor and outdoor options, smart home compatibility, weather-resistant designs, flexible installation methods, and local storage without mandatory subscription fees, making them an affordable and advanced choice for home protection.
What features does the Wyze Cam v4 offer for night vision?Can you tell me more about the smart home integration capabilities of Wyze cameras?Are there any ongoing promotions or discounts for Wyze security cameras?
