Wireless Security Camera Bundles with Micro USB Power & Splitter
Wireless Security Camera Bundles with Micro USB Power and Splitter
Looking for a reliable wireless security camera bundle that offers flexible power options including micro USB power and splitter compatibility? Discover top-tier Wyze bundles designed to enhance your home security and outdoor monitoring with smart power solutions and versatile camera features.
Bird Feeder Plug-in Cam v4 Bundle: Wireless Birdwatching Meets Security
Overview
The Bird Feeder Plug-in Cam v4 Bundle is perfect for nature lovers and security enthusiasts alike. This bundle includes the Wyze Bird Feeder, Wyze Cam v4, and the Wyze Outdoor Power Adapter, providing a seamless way to monitor your feathered visitors while securing your outdoor space.
Key Features
- Wyze Bird Feeder: Crafted with a vibrant blue body and orange top, this feeder attracts a variety of birds year-round. Its weather-resistant polycarbonate design ensures durability through all seasons.
- Wyze Cam v4: Offers crystal-clear 2.5K QHD resolution and enhanced color night vision, perfect for capturing detailed footage of birds and outdoor activity.
- Wyze Outdoor Power Adapter: Powers your camera reliably with micro USB compatibility, ensuring continuous operation without frequent battery changes.
- Easy Installation: Multiple mounting options including wall, tree, pole, cord, and suction cup make setup flexible and convenient.
- Macro Lens Adapter: Included to provide sharp, close-up views of your bird visitors.
- Live Streaming & Notifications: Use the Wyze app to view live video, record footage, and receive alerts for every visitor.
Enjoy birdwatching on easy mode while securing your outdoor environment with this all-in-one wireless camera bundle.
Alt text: Bird Feeder Plug-in Cam v4 Bundle installed outdoors attracting birds
Cam v4 + Lamp Socket v2 Bundle: Smart Power for Your Wireless Security
Overview
Upgrade your outdoor lighting and security with the Cam v4 + Lamp Socket v2 Bundle. This innovative duo powers your Wyze Cam v4 directly from your existing lamp socket, eliminating the need for additional outlets or complicated wiring.
Key Features
- Convenient Power Source: The Lamp Socket v2 uses your outdoor light fixture’s electricity to power the Wyze Cam v4, compatible with micro USB power setups.
- Motion-Activated Lights: Automatically illuminate your surroundings when motion is detected, enhancing security and visibility.
- Linkability: Connect multiple lamp sockets for expanded coverage and centralized control via the Wyze app.
- Dusk to Dawn Scheduling: Automate your lighting to turn on at sunset and off at sunrise, saving energy and providing consistent security lighting.
- Compact & Durable: Made from polycarbonate and plastic, the socket measures 56.5mm x 56.5mm x 65mm and supports bulbs up to 20W (CFL or LED recommended).
Transform your existing outdoor lighting into a smart security system with this easy-to-install bundle.
Pan v3 + Lamp Socket v2 Bundle: Flexible Wireless Security with Smart Lighting
Overview
The Pan v3 + Lamp Socket v2 Bundle offers a powerful combination of 360° pan-and-tilt camera coverage with smart power integration. Perfect for monitoring large outdoor areas without the hassle of extra wiring.
Key Features
- Wyze Cam Pan v3: Provides 360° horizontal and 180° vertical coverage with automatic motion tracking and color night vision.
- Lamp Socket v2: Powers the Pan v3 camera through your outdoor light fixture, compatible with micro USB power and splitters.
- Smart Lighting Control: Use the Wyze app to control your lights remotely, set motion-triggered illumination, and schedule lighting routines.
- Easy Installation: Screw in the lamp socket like a lightbulb and mount the camera for instant smart security.
- Multiple Socket Linking: Expand your system by linking multiple sockets for comprehensive outdoor coverage.
Achieve seamless wireless security and smart lighting integration with this versatile bundle.
Alt text: Outdoor porch illuminated by smart lighting with security camera installed
Wyze Cam v4 Outdoor Bundle: Advanced Wireless Security with Micro USB Power
Overview
The Wyze Cam v4 Outdoor Bundle is designed for those who demand high-quality security footage and reliable power solutions. This bundle includes the Wyze Cam v4, Wyze Outdoor Power Adapter, and a 128GB microSD card for local storage.
Key Features
- 2.5K QHD Resolution: Crystal-clear video quality with wide dynamic range (WDR) for detailed day and night surveillance.
- Enhanced Color Night Vision: See vivid colors even in low-light conditions.
- Motion-Activated Spotlight: Automatically lights up when motion is detected to deter intruders.
- 24/7 Local Recording: Continuous recording to the included microSD card ensures you never miss a moment.
- Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
- Voice Assistant Compatibility: Works seamlessly with Alexa and Google Assistant.
- Outdoor Ready: Weather-resistant design suitable for all outdoor environments.
- Micro USB Power: Powered via the included outdoor adapter, compatible with micro USB power and splitter setups.
Secure your home with cutting-edge wireless technology and flexible power options.
Alt text: Family relaxing in backyard monitored by outdoor security camera
Why Choose Wyze Wireless Security Camera Bundles?
- Micro USB Power Compatibility: All bundles support micro USB power adapters and splitters, providing flexible and convenient power solutions.
- Smart App Integration: Control, monitor, and receive alerts from anywhere using the Wyze app.
- Weather-Resistant Designs: Ideal for outdoor use, built to withstand various weather conditions.
- Easy Installation: Designed for quick setup with multiple mounting and power options.
- Comprehensive Security: From birdwatching to full home protection, Wyze bundles cover a wide range of needs.
Elevate your home security with wireless camera bundles that combine smart power solutions and advanced monitoring features.
Enhance your home’s safety and enjoy the convenience of wireless security cameras powered by micro USB and splitters. Choose the perfect Wyze bundle tailored to your needs today!
Feature | Bird Feeder Plug-in Cam v4 Bundle | Cam v4 + Lamp Socket v2 Bundle | Pan v3 + Lamp Socket v2 Bundle | Wyze Cam v4 Outdoor Bundle |
Included Items | Wyze Bird Feeder, Wyze Cam v4, Wyze Outdoor Power Adapter | Wyze Cam v4, Lamp Socket v2 | Wyze Cam Pan v3, Lamp Socket v2 | Wyze Cam v4, Wyze Outdoor Power Adapter, Wyze MicroSD Card 128GB |
Price | $89.98 | $49.96 | $53.96 | $69.99 |
Wyze Cam Model | Cam v4 | Cam v4 | Pan v3 | Cam v4 |
Camera Resolution | 2.5K QHD (Cam v4) | 2.5K QHD (Cam v4) | Not specified (Pan v3) | 2.5K QHD |
Night Vision | Color Night Vision (Cam v4) | Color Night Vision (Cam v4) | Color Night Vision (Pan v3) | Enhanced Color Night Vision |
Outdoor Compatibility | Yes (Bird Feeder + Outdoor Power Adapter) | Yes (via Lamp Socket v2) | Not weatherproof (Lamp Socket v2), Pan v3 camera outdoor compatible | Yes |
Power Source | Outdoor Power Adapter included | Powered via Lamp Socket v2 (no outlet needed) | Powered via Lamp Socket v2 (no outlet needed) | Wired with Outdoor Power Adapter |
Mounting Options | Bird Feeder: wall, tree, pole, cord, suction cup | Lamp Socket v2: E26 socket | Lamp Socket v2: E26 socket | Stand, Wall mount, Ceiling mount, Magnetic wall mount |
Weather Resistance | Bird Feeder: Weather-resistant polycarbonate | Lamp Socket v2: Not weatherproof, suitable for damp locations | Lamp Socket v2: Not weatherproof, suitable for damp locations | IP65 |
Camera Features | Live stream, record, notifications via Wyze app | Motion-activated lights, smart lighting control | Motion-activated lights, smart lighting control | Motion-activated spotlight, 24/7 local recording |
Connectivity | Wi-Fi 6, Bluetooth 5.2 (Cam v4) | Wi-Fi 2.4 GHz, Bluetooth | Wi-Fi 2.4 GHz, Bluetooth | Wi-Fi 6, Bluetooth 5.2 |
Dimensions (Lamp Socket) | N/A | 56.5mm x 56.5mm x 65mm | 56.5mm x 56.5mm x 65mm | N/A |
Weight (Lamp Socket) | N/A | 80 g | 80 g | N/A |
Max Lamp Power (Lamp Socket) | N/A | 20W | 20W | N/A |
Compatible Cameras (Lamp Socket) | N/A | Cam v3/v3 Pro, Cam v4, Cam OG, Cam Pan v3 | Cam v3/v3 Pro, Cam v4, Cam OG, Cam Pan v3 | N/A |
Warranty | 30-day hassle-free returns | 1-Year | 1-Year | 1-Year |
What are the benefits of Wyze wireless security camera bundles with micro USB power and splitter compatibility?
Wyze wireless security camera bundles offer flexible power options, including micro USB power and splitter compatibility. This allows for easy installation, continuous operation without frequent battery changes, and the ability to power multiple devices from a single source. These features make Wyze bundles ideal for both home security and outdoor monitoring.Which Wyze security camera bundles support micro USB power and splitters?
All featured Wyze security camera bundles—including the Bird Feeder Plug-in Cam v4 Bundle, Cam v4 + Lamp Socket v2 Bundle, Pan v3 + Lamp Socket v2 Bundle, and Wyze Cam v4 Outdoor Bundle—support micro USB power adapters and splitters for flexible and convenient power solutions.What is included in the Bird Feeder Plug-in Cam v4 Bundle?
The Bird Feeder Plug-in Cam v4 Bundle includes a Wyze Bird Feeder, Wyze Cam v4 with 2.5K QHD resolution and color night vision, a Wyze Outdoor Power Adapter for micro USB power, a macro lens adapter for close-up birdwatching, and multiple mounting options for easy installation.How does the Cam v4 + Lamp Socket v2 Bundle work?
The Cam v4 + Lamp Socket v2 Bundle powers your Wyze Cam v4 directly from your existing outdoor lamp socket using micro USB. The Lamp Socket v2 also provides motion-activated lighting, dusk-to-dawn scheduling, and the ability to link multiple sockets for expanded coverage—all controllable via the Wyze app.What features does the Pan v3 + Lamp Socket v2 Bundle offer for outdoor security?
The Pan v3 + Lamp Socket v2 Bundle provides 360° pan-and-tilt camera coverage with automatic motion tracking, color night vision, and smart lighting control. The Lamp Socket v2 powers the camera via micro USB and allows for remote light control, motion-triggered illumination, and easy installation by screwing into a standard light socket.What makes the Wyze Cam v4 Outdoor Bundle suitable for advanced wireless security?
The Wyze Cam v4 Outdoor Bundle features 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, 24/7 local recording to a 128GB microSD card, Wi-Fi 6 support, voice assistant compatibility, and weather-resistant design. It is powered by a micro USB outdoor adapter, making it reliable for continuous outdoor surveillance.Are Wyze wireless security camera bundles weather-resistant?
Yes, all Wyze wireless security camera bundles are designed with weather-resistant materials, making them suitable for year-round outdoor use in various weather conditions.Can I control Wyze security cameras and lighting remotely?
Yes, all Wyze security camera bundles integrate with the Wyze app, allowing you to control cameras, monitor live feeds, receive notifications, and manage smart lighting remotely from your smartphone.Is installation of Wyze wireless security camera bundles easy?
Wyze wireless security camera bundles are designed for easy installation, offering multiple mounting options such as wall, tree, pole, cord, suction cup, and lamp socket integration. No complicated wiring is required, making setup quick and convenient.Do Wyze security camera bundles support local video recording?
Yes, select Wyze security camera bundles, such as the Wyze Cam v4 Outdoor Bundle, include a microSD card for 24/7 local video recording, ensuring you never miss important footage.
Can you tell me more about the features of the Bird Feeder Plug-in Cam v4 Bundle?How does the Wyze app work with the security camera bundles?Do you have any ongoing sales or discounts for the Wyze camera bundles?
