Wyze Battery Security Camera: No Wires, No Hub, Easy Install
Hassle-Free Installation with Wyze Battery Security Cameras
When it comes to home security, convenience and reliability are key. If you're searching for a battery security camera with hassle-free installation, no wires, and no hub required, Wyze offers the perfect solution. The Wyze Battery Cam Pro stands out as a truly wireless, easy-to-install security camera that delivers high-quality video and smart features without the need for complicated setups or additional hubs.
Wyze Battery Cam Pro: Ultimate Wireless Security
Truly Wire-Free & No Hub Required
The Wyze Battery Cam Pro is designed for effortless installation. With removable, rechargeable 6200mAh battery packs, you can place the camera anywhere without worrying about power cords or hubs. The battery life lasts up to 6 months on a single charge, and recharging takes approximately 9 hours.
Crisp 2.5K HDR Video Quality
Capture every detail with 2560 x 1440 (2.5K) HDR video resolution and a CMOS-Starlight sensor. The camera offers a wide 134° diagonal field of view, ensuring broad coverage of your property.
Advanced Motion Detection & Alerts
Equipped with Radar + PIR motion detection, the camera intelligently detects movement and sends instant alerts to your phone. The integrated spotlight and 100 dB siren add an extra layer of security by deterring intruders.
Weatherproof & Durable
Rated IP65 weatherproof, the Battery Cam Pro withstands rain, snow, and extreme temperatures from -20°C to 50°C (-4°F to 122°F), making it ideal for outdoor use year-round.
Smart Home Integration
Seamlessly connect with Alexa, Google Assistant, and IFTTT for voice control and automation.
Experience the freedom of a wire-free security camera that installs in minutes and keeps your home safe without the hassle of wires or hubs.
Wyze Battery Cam Pro Outdoor Lifestyle Wyze Battery Cam Pro providing reliable outdoor security day and night
Wired Cameras vs. Wireless: Why Choose Battery-Powered?
While Wyze offers several wired cameras like the Wyze Cam OG, Wyze Cam Pan v3, and Wyze Cam v4, these models require power cables and sometimes hubs or adapters. For those prioritizing hassle-free installation with no wires, the Wyze Battery Cam Pro is the standout choice.
Wired Camera Highlights (For Comparison)
  • Wyze Cam OG: 1080p resolution, built-in spotlight, 2-way audio, but requires power cable.
  • Wyze Cam Pan v3: 360° pan and 180° tilt, weather resistant, but needs wired power and optional outdoor adapter.
  • Wyze Cam v4: 2.5K QHD resolution, color night vision, Wi-Fi 6 support, but wired only.
If you want no wires and no hub, these wired options are less convenient for quick, flexible placement.
Why Wyze Battery Cam Pro is Perfect for You
  • No wires, no hub: Place it anywhere indoors or outdoors without running cables.
  • Long battery life: Up to 6 months on a single charge.
  • High-resolution video: 2.5K HDR for crystal-clear footage.
  • Smart alerts and siren: Advanced motion detection with instant notifications.
  • Weatherproof: Ready for all seasons and environments.
  • Easy integration: Works with Alexa, Google Assistant, and IFTTT.
This camera is ideal for renters, homeowners, or anyone who wants a quick, wireless security solution without sacrificing quality or features.
Additional Wyze Camera Options for Comprehensive Security
If you want to complement your wireless setup with wired cameras for specific areas, consider:
Wyze Cam OG
  • 1080p HD video with 40-lumen spotlight.
  • 2-way audio with noise and echo cancellation.
  • Wired power with 6 ft cable.
  • IP65 weather resistance for outdoor use.
Wyze Cam Pan v3
  • 360° horizontal and 180° vertical coverage.
  • 1080p video with 4 IR LEDs for night vision.
  • Wired power; outdoor use requires separate power adapter.
  • IP65 weatherproof rating.
Wyze Cam v4
  • 2.5K QHD resolution with enhanced color night vision.
  • Motion-activated spotlight and 99dB siren.
  • Wired power with Wi-Fi 6 support.
  • IP65 weather resistance.
Wyze Cam Pan v3 in Snowy Outdoor Setting Wyze Cam Pan v3 providing 360° coverage in harsh weather
Conclusion: Choose Wyze Battery Cam Pro for Wire-Free Security
For a battery security camera with hassle-free installation, no wires, and no hub required, the Wyze Battery Cam Pro is the best choice. It combines high-resolution video, long battery life, smart detection, and weatherproof durability in a compact, wireless design. Whether you want to secure your front porch, backyard, or any remote area, this camera offers the ultimate convenience and peace of mind.
FeatureWyze Battery Cam ProWyze Cam OGWyze Cam Pan v3Wyze Cam v4Wyze Cam v4 Home Security BundleWyze Cam OG Telephoto
TypeBattery Wireless CameraWired CameraWired Pan & Tilt CameraWired CameraWired Camera BundleWired Telephoto Camera
Video Resolution2.5K HDRHD (not specified, likely 1080p)Not specified2.5K QHD (2560x1440)2.5K QHD (2560x1440)1080p (1920x1080)
Field of ViewNot specified120°360° pan, 180° tiltDFOV 115.8°, HFOV 98.5°, VFOV 53.1°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°DFOV 27°, HFOV 23.6°, VFOV 13.6°
Night VisionColor Night VisionColor Night VisionYes (not detailed)Enhanced Color Night VisionEnhanced Color Night VisionIR LEDs (4x 850 nm)
SpotlightIntegrated Spotlight (150 lumens)Built-in Spotlight (40 lumens)Not specifiedMotion-activated spotlight (72 lumens)Motion-activated spotlight (72 lumens)No spotlight
SirenIntegrated SirenMini-siren (90 dB)Not specifiedBuilt-in sirenBuilt-in sirenNo siren
Motion DetectionRadar + PIR Motion DetectionYesYesYesYesYes
Two-Way AudioYesImproved 2-way audioYesYesImproved 2-way audioYes
Power SourceBattery (Removable, Rechargeable)WiredWiredWiredWiredWired
Weather ResistanceIP65IP65IP65IP65IP65IP65
Wi-Fi Support2.4 & 5 GHz Wi-Fi2.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi
Local StoragemicroSD card (optional)microSD card up to 256GBNot specifiedmicroSD card up to 512GBmicroSD card 128GB includedmicroSD card up to 256GB
Cloud StorageWith subscription (Cam Plus)With subscription (Cam Plus)Not specifiedWith subscriptionWith subscriptionNot specified
DimensionsNot specifiedNot specifiedNot specified2in x 2in x 2 3/8in2in x 2in x 2 3/8in1.89in x 1.89in x 1.89in
WeightNot specifiedNot specifiedNot specified0.49 lb (222 g)0.49 lb (222 g)4.1 oz (116 g)
Mounting OptionsFlexible mounting optionsNot specifiedNot specifiedStand, Wall, Ceiling, Magnetic mountStand, Wall, Ceiling, Magnetic mountStand, Wall, Ceiling
Price (1 Pack)$89.98$29.98$114.94$107.94$169.99$25.98
Indoor/Outdoor UseOutdoor (wire-free)Indoor/OutdoorIndoor/OutdoorIndoor/OutdoorIndoor/OutdoorIndoor/Outdoor
Special FeaturesSolar panel compatible, Radar + PIR motion3x faster notifications, Smoke/CO alerts360° pan & 180° tiltWi-Fi 6, Alexa/Google Assistant, 8x zoomIncludes microSD card, Alexa/Google Assistant3x Telephoto lens
What makes the Wyze Battery Cam Pro a hassle-free security camera?The Wyze Battery Cam Pro offers truly wire-free installation with no wires or hub required. Its removable, rechargeable battery packs allow you to place the camera anywhere, making setup quick and easy without complicated wiring or additional equipment.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro features a 6200mAh rechargeable battery that lasts up to 6 months on a single charge, depending on usage and settings. Recharging the battery takes approximately 9 hours.
What video quality does the Wyze Battery Cam Pro provide?The Wyze Battery Cam Pro delivers crisp 2.5K HDR video resolution (2560 x 1440) with a CMOS-Starlight sensor and a wide 134° diagonal field of view, ensuring clear and detailed footage day and night.
Does the Wyze Battery Cam Pro require a hub or power cables?No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub or power cables. It operates on a rechargeable battery, allowing for flexible placement anywhere indoors or outdoors.
Is the Wyze Battery Cam Pro weatherproof for outdoor use?Yes, the Wyze Battery Cam Pro is rated IP65 weatherproof, making it suitable for outdoor use in rain, snow, and extreme temperatures ranging from -20°C to 50°C (-4°F to 122°F).
What smart features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro includes advanced Radar + PIR motion detection, instant alerts to your phone, an integrated spotlight, a 100 dB siren for intruder deterrence, and seamless integration with Alexa, Google Assistant, and IFTTT for smart home automation.
How does the Wyze Battery Cam Pro compare to Wyze’s wired cameras?Unlike Wyze’s wired cameras such as the Wyze Cam OG, Wyze Cam Pan v3, and Wyze Cam v4, the Wyze Battery Cam Pro requires no power cables or hubs, making it ideal for hassle-free, flexible installation. Wired models may offer features like pan/tilt or Wi-Fi 6, but require a constant power source.
Can I use the Wyze Battery Cam Pro with Alexa or Google Assistant?Yes, the Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
Is the Wyze Battery Cam Pro suitable for renters and homeowners?Absolutely. The Wyze Battery Cam Pro is perfect for renters, homeowners, or anyone seeking a quick, wireless security solution without the need for permanent installation or wiring.
What are the main benefits of choosing a battery-powered security camera over a wired one?Battery-powered security cameras like the Wyze Battery Cam Pro offer hassle-free installation, flexible placement, no need for power outlets or hubs, and are ideal for areas where wiring is difficult or not possible.
How long does the battery last on the Wyze Battery Cam Pro before needing a recharge?Can the Wyze Battery Cam Pro be used indoors as well as outdoors?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
