Wireless Doorbell Cameras with Live Streaming and Event Playback
When it comes to securing your home entrance with smart technology, a wireless doorbell camera that supports both live streaming and event playback is essential. Among the top choices, the
Wyze Video Doorbell v2 stands out as a feature-rich, reliable option designed to keep you connected to your doorstep anytime, anywhere.
Wyze Video Doorbell v2: Your Smart Wireless Doorbell Camera
The
Wyze Video Doorbell v2 offers an impressive combination of high-resolution video, smart alerts, and two-way communication, making it an ideal wireless doorbell camera for modern homes.
Key Features:
- 2K Video Resolution: Crystal-clear 2048 x 1536 video quality ensures you never miss a detail.
- Wide Field of View: A 166.8° diagonal field of view covers your entire doorstep.
- Live Streaming & Event Playback: Watch real-time video or review recorded events stored locally on a microSD card (up to 256GB) or via cloud storage with the Wyze Security Plan.
- Two-Way Audio: Built-in microphone and speaker allow you to communicate with visitors or delivery personnel directly from your smartphone.
- Motion-Activated Voice Deterrence: Automatically plays a warning message to deter unwanted visitors.
- Weather Resistant: Rated IP65 for reliable outdoor performance in various weather conditions.
- Easy Installation: Compatible with existing doorbell wiring (16V-24V AC) and includes a chime controller for seamless integration.
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
Specifications:
- Dimensions: 4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm)
- Sensor: CMOS Starlight Sensor with F2.0 aperture
- Frame Rate: 20 FPS (day), 15 FPS (night)
- IR Night Vision: 6 x 940nm IR LEDs for clear night monitoring
- Connectivity: 2.4 GHz Wi-Fi (b/g/n)
- Operating Temperature: -4°F to 122°F (-20°C to 50°C)
The Wyze Video Doorbell v2 is perfect for homeowners seeking a wireless doorbell camera that delivers both live streaming and event playback with high-quality video and smart features.
Stay connected to your home with Wyze Video Doorbell v2
Enhance Your Doorbell Experience with Wyze Universal Wi-Fi Chime
To complement your wireless doorbell camera, the
Wyze Universal Wi-Fi Chime is an excellent accessory that ensures you never miss a visitor’s ring, even when you’re away from your phone.
Why Choose Wyze Universal Wi-Fi Chime?
- Wireless Convenience: No complicated wiring needed; simply plug it in and connect via Wi-Fi.
- Compatibility: Works seamlessly with all Wyze Cams and doorbells, including the Wyze Video Doorbell v2.
- Customizable Tones: Choose from 17 different chime tones to suit your preference.
- Smart Automations: Set the chime to ring when your Wyze cameras detect people, even in other rooms.
- Multiple Device Support: Connect multiple chimes throughout your home for full coverage.
Specifications:
- Dimensions: 81 x 53 x 38 mm
- Speaker: Ø40mm
- Wi-Fi: IEEE802.11 b/g/n 2.4 GHz
- Power Input: 10-24V AC, 10VA 60Hz
- Certifications: FCC, IC, UL, CP65
The Wyze Universal Wi-Fi Chime is the perfect companion to your wireless doorbell camera, providing audible alerts anywhere in your home.
Why Choose Wyze for Your Wireless Doorbell Camera Needs?
Wyze offers a comprehensive ecosystem of smart home products designed to work together seamlessly. The Wyze Video Doorbell v2 combined with the Universal Wi-Fi Chime provides a robust, easy-to-install solution for home security and convenience.
- Live Streaming & Playback: Monitor your front door live or review past events with local and cloud storage options.
- Two-Way Communication: Speak directly to visitors or delivery personnel from your smartphone.
- Smart Alerts: Receive instant notifications when motion or a doorbell press is detected.
- Weatherproof & Durable: Designed to withstand outdoor conditions with IP65 rating.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice commands and automation.
Summary
For a wireless doorbell camera that supports both live streaming and event playback, the
Wyze Video Doorbell v2 is a top-tier choice. Paired with the
Wyze Universal Wi-Fi Chime, it offers a complete, smart, and convenient doorbell system that keeps you connected and informed at all times.
Product Highlights
2K video, two-way audio, IP65 weatherproof, wide field of view, local & cloud storage.
Easy plug-in setup, 17 tones, smart automations, compatible with all Wyze cameras.
Enhance your home security with Wyze smart devices
Secure your home entrance with Wyze’s smart wireless doorbell camera and chime for peace of mind and convenience.
What are the main features of the Wyze Video Doorbell v2 wireless doorbell camera?
The Wyze Video Doorbell v2 offers 2K video resolution, a 166.8° wide field of view, live streaming, event playback, two-way audio, motion-activated voice deterrence, IP65 weather resistance, easy installation with existing doorbell wiring, and smart home integration with Alexa, Google Assistant, and IFTTT.Does the Wyze Video Doorbell v2 support live streaming and event playback?
Yes, the Wyze Video Doorbell v2 supports both live streaming and event playback. You can watch real-time video or review recorded events stored locally on a microSD card (up to 256GB) or via cloud storage with the Wyze Security Plan.Is the Wyze Video Doorbell v2 weatherproof?
Yes, the Wyze Video Doorbell v2 is rated IP65, making it weather resistant and suitable for reliable outdoor performance in various weather conditions.How does two-way audio work on the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 features built-in two-way audio, allowing you to communicate with visitors or delivery personnel directly from your smartphone using the built-in microphone and speaker.What storage options are available for recorded events on the Wyze Video Doorbell v2?
You can store recorded events locally on a microSD card (up to 256GB) or use cloud storage with the Wyze Security Plan for event playback and review.Is the Wyze Video Doorbell v2 compatible with smart home systems?
Yes, the Wyze Video Doorbell v2 works with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What is the Wyze Universal Wi-Fi Chime and how does it work?
The Wyze Universal Wi-Fi Chime is a wireless accessory that plugs into any outlet and connects via Wi-Fi. It works with all Wyze Cams and doorbells, including the Wyze Video Doorbell v2, providing customizable chime tones and smart automations for audible alerts throughout your home.Can I use multiple Wyze Universal Wi-Fi Chimes in my home?
Yes, you can connect multiple Wyze Universal Wi-Fi Chimes throughout your home to ensure you never miss a visitor’s ring, even in different rooms.What are the installation requirements for the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 is compatible with existing doorbell wiring (16V-24V AC) and includes a chime controller for easy and seamless installation.What makes Wyze a good choice for wireless doorbell cameras?
Wyze offers a comprehensive smart home ecosystem with reliable, feature-rich products like the Wyze Video Doorbell v2 and Universal Wi-Fi Chime. Their solutions provide high-quality video, live streaming, event playback, smart alerts, weatherproof durability, and seamless smart home integration.
