Reliable Motion Triggered Doorbell Cameras with On-Demand Live View
When it comes to securing your home entrance, having a reliable motion-triggered doorbell camera with on-demand live view is essential. Wyze offers two standout video doorbells that combine advanced technology, clear video quality, and smart features to keep your porch safe and connected. Whether you prefer a wired setup or a battery-powered option with dual cameras, Wyze has you covered.
Wyze Video Doorbell v2: Wired 2K Clarity and Essential Features
Experience crystal-clear wired video doorbell security.
The
Wyze Video Doorbell v2 is Wyze’s clearest and most capable wired video doorbell yet, designed for those who want high-resolution video and dependable wired power.
Key Features:
- 2K Video Resolution: Capture every visitor and delivery in stunning detail with 2K clarity and a wide 135° x 103° field of view.
- Motion-Activated Alerts: Receive instant notifications when motion is detected, so you never miss a visitor.
- Two-Way Audio: Speak directly to visitors from anywhere using the Wyze app.
- Motion-Activated Voice Deterrence: Automatically warn unwanted visitors with a voice prompt when motion is detected (requires Cam Plus subscription).
- Local microSD Storage: Continuous 24/7 local recording with onboard microSD card slot lets you review footage anytime without relying solely on cloud storage.
- Works with Existing Chimes: Includes a chime controller so you can keep your traditional doorbell sound.
- IP65 Weatherproof: Built to withstand rain, snow, and harsh weather conditions.
- Color Night Vision: Award-winning starlight sensor provides vivid color video even in low light.
Why Choose Wyze Video Doorbell v2?
This doorbell is perfect for homeowners who want a wired, always-on solution with crisp video quality and local storage options. The included 30° corner wedge kit helps you mount it perfectly for maximum coverage.
Wyze Duo Cam Battery Doorbell: Dual Cameras for Ultimate Porch Protection
Double the coverage with Wyze Duo Cam’s dual camera system.
For those seeking a wireless, battery-powered doorbell with enhanced coverage, the
Wyze Duo Cam Battery Doorbell is the most advanced option. It features two cameras to monitor both visitors and packages simultaneously.
Key Features:
- Dual Cameras: One camera faces visitors at the door with 2K resolution, while the second camera looks down at packages with 1080p resolution, providing comprehensive porch coverage.
- 2K Video with Color Night Vision: Capture clear, detailed video day or night with the award-winning starlight sensor.
- Real-Time AI Detections: Get smart alerts for people, packages, pets, and vehicles with AI-powered notifications.
- Motion-Activated Voice Deterrence: Automatically warn intruders with a voice prompt.
- Two-Way Audio: Communicate with visitors or delivery personnel from anywhere.
- Wi-Fi Chime Included: Hear doorbell alerts anywhere in your home without wiring.
- Battery or Wired Power: Use the removable battery pack for wire-free installation or hardwire for continuous power and 24/7 local recording.
- IP65 Weather Resistant: Durable for all weather conditions.
- Easy Installation: Mount with adhesive strips or screws in under a minute.
Why Choose Wyze Duo Cam Battery Doorbell?
Ideal for renters or those without existing doorbell wiring, this doorbell offers unmatched porch coverage with dual cameras and flexible power options. The included Wi-Fi chime ensures you never miss a visitor, even indoors.
Enhance Your Home Security with Wyze Doorbell Accessories
To optimize your Wyze Video Doorbell v2 installation, consider the
Wyze Video Doorbell v2 Wedge Kit. This accessory allows you to adjust the doorbell’s angle for better viewing on angled door frames or porches with stairs, eliminating blind spots and improving security coverage.
Summary: Which Wyze Doorbell is Right for You?
Feature | Wyze Video Doorbell v2 | Wyze Duo Cam Battery Doorbell |
Power Source | Wired (AC 16-24V) | Battery-powered or Wired |
Video Resolution | 2K (2560 x 1440) | Dual: 2K (top cam) + 1080p (bottom) |
Field of View | 135° x 103° | Top: 132° x 100°, Bottom: 121° x 60° |
Local Storage | microSD (up to 256GB) | microSD (up to 256GB, 24/7 with wired) |
AI Detection & Alerts | With Cam Plus subscription | Built-in AI detections & alerts |
Two-Way Audio | Yes | Yes |
Voice Deterrence | Motion-activated (Cam Plus) | Motion-activated |
Weather Resistance | IP65 | IP65 |
Installation | Requires wiring | Battery or wired, adhesive or screws |
Included Chime | Chime controller included | Wyze Wi-Fi Chime included |
Both Wyze doorbells provide reliable motion-triggered alerts and on-demand live view through the Wyze app, making them excellent choices for smart home security.
"Wyze Duo Cam Doorbell offers double the porch protection with dual cameras and flexible power options, while Wyze Video Doorbell v2 delivers wired 2K clarity and local storage for continuous monitoring."
Additional Wyze Security Cameras for Comprehensive Coverage
While focusing on doorbell cameras, consider complementing your setup with the
Wyze Cam v4 or
Wyze Cam Pan v3 for indoor/outdoor surveillance with advanced features like 2.5K QHD resolution, color night vision, and 360° pan and tilt capabilities.
Product Highlights
This page provides a detailed overview of Wyze’s reliable motion-triggered doorbell cameras with on-demand live view, helping you choose the perfect smart doorbell for your home security needs.
What are the main differences between Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell?
Wyze Video Doorbell v2 is a wired doorbell offering 2K video resolution, local microSD storage, and compatibility with existing chimes. Wyze Duo Cam Battery Doorbell is a battery-powered or wired option featuring dual cameras (2K for visitors, 1080p for packages), built-in AI detections, and a Wi-Fi chime. Both provide motion-triggered alerts, two-way audio, and IP65 weather resistance.Does Wyze Video Doorbell v2 support local storage?
Yes, Wyze Video Doorbell v2 supports continuous 24/7 local recording with an onboard microSD card slot (up to 256GB), allowing you to review footage anytime without relying solely on cloud storage.Can I use Wyze Duo Cam Battery Doorbell without existing doorbell wiring?
Yes, Wyze Duo Cam Battery Doorbell can be installed wire-free using its removable battery pack, making it ideal for renters or homes without existing doorbell wiring. It can also be hardwired for continuous power and 24/7 local recording.What is the video quality of Wyze doorbell cameras?
Wyze Video Doorbell v2 offers 2K (2560 x 1440) video resolution with a 135° x 103° field of view. Wyze Duo Cam Battery Doorbell features a top camera with 2K resolution and a bottom camera with 1080p resolution, providing comprehensive coverage for both visitors and packages.Do Wyze doorbell cameras have night vision?
Yes, both Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell feature award-winning starlight sensors for vivid color night vision, ensuring clear video even in low-light conditions.Are Wyze doorbell cameras weatherproof?
Yes, both Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell are rated IP65 weatherproof, making them suitable for use in rain, snow, and harsh weather conditions.Can I talk to visitors using Wyze doorbell cameras?
Yes, both Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell offer two-way audio, allowing you to speak directly to visitors or delivery personnel from anywhere using the Wyze app.What smart features do Wyze doorbell cameras offer?
Wyze doorbell cameras provide motion-activated alerts, on-demand live view, two-way audio, and motion-activated voice deterrence. Wyze Duo Cam Battery Doorbell also includes real-time AI detections for people, packages, pets, and vehicles.Is there a chime included with Wyze doorbell cameras?
Wyze Video Doorbell v2 includes a chime controller for use with your existing chime, while Wyze Duo Cam Battery Doorbell comes with a Wi-Fi chime that can be placed anywhere in your home.How easy is it to install Wyze doorbell cameras?
Wyze Video Doorbell v2 requires wired installation and comes with a 30° corner wedge kit for optimal mounting. Wyze Duo Cam Battery Doorbell can be installed wire-free with adhesive strips or screws in under a minute, or hardwired for continuous power.Are there accessories available for Wyze doorbell cameras?
Yes, the Wyze Video Doorbell v2 Wedge Kit is available to help adjust the doorbell’s angle for better viewing on angled door frames or porches with stairs, eliminating blind spots and improving security coverage.Can Wyze doorbell cameras be integrated with other Wyze security cameras?
Yes, you can complement your Wyze doorbell camera setup with other Wyze security cameras like Wyze Cam v4 or Wyze Cam Pan v3 for comprehensive indoor and outdoor surveillance.
