Wired or Wireless Security Cameras with Built-In Siren and Spotlight
When it comes to securing your home or business, having a security camera equipped with both a built-in siren and spotlight can be a game-changer. These features not only provide clear video footage but also actively deter intruders by illuminating dark areas and sounding alarms. Whether you prefer wired or wireless setups, Wyze offers a range of cameras that combine these essential security elements with advanced technology for reliable protection.
Wyze Cam v4 Outdoor Bundle – Wired Security with Advanced Spotlight and Siren
Experience unmatched security with the
Wyze Cam v4 Outdoor Bundle, a wired camera solution designed for continuous power and 24/7 monitoring. This bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card for local recording.
Key Features:
- 2.5K Quad HD Resolution: Capture crystal-clear video with enhanced detail.
- Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to advanced hardware.
- Motion-Activated Spotlight: Automatically lights up when motion is detected, illuminating your property.
- Built-In Siren: Deter unwanted visitors with a loud siren.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
- 24/7 Local Recording: Continuous event capture with microSD card support.
- Smart Detection: Optional AI-powered person, pet, package, and vehicle notifications with subscription.
- Compatibility: Works seamlessly with Alexa and Google Assistant.
This wired camera is perfect for outdoor use when paired with the Wyze Outdoor Power Adapter, ensuring your home stays protected rain or shine.
Wyze Cam v4 – Wired Indoor/Outdoor Camera with Spotlight and Siren
The
Wyze Cam v4 is a versatile wired camera suitable for both indoor and outdoor use (outdoor requires the Wyze Outdoor Power Adapter). It offers the same high-quality 2.5K QHD video and enhanced color night vision as the outdoor bundle but is available as a standalone camera in multiple colors and pack sizes.
Highlights:
- Integrated Spotlight & Siren: Motion-activated spotlight and a 99 dB siren provide active deterrence.
- IP65 Weather Resistance: Durable for outdoor environments.
- Advanced Two-Way Audio: Clear communication with enhanced microphone and speaker.
- Wide Field of View: 115.9° diagonal for broad coverage.
- Continuous Local Recording: Supports microSD cards up to 256GB.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
- Easy Setup: Bluetooth-enabled for hassle-free installation.
- Motion Detection Zones: Customize alerts to focus on important areas.
- Smoke & CO Alerts: Receive notifications if alarms sound near the camera.
This wired camera is ideal for users wanting a reliable, always-on security solution with smart features and excellent night vision.
Wyze Cam OG – Wireless Camera with Built-In Spotlight and Siren
For those seeking a wireless option, the
Wyze Cam OG offers a compelling choice with built-in spotlight and siren features, designed for both indoor and outdoor use.
Features:
- 1080p Full HD Video: Clear and smooth video streaming.
- Built-In 40 Lumen Spotlight: Bright enough to illuminate dark areas.
- 90 dB User-Activated Siren: Loud enough to scare off intruders.
- Upgraded Two-Way Audio: Enhanced microphone and speaker for clear conversations.
- 120° Field of View: Wide coverage area.
- IP65 Weather Resistance: Suitable for outdoor installation.
- Fast Live Streaming: 50% faster than previous Wyze models.
- Custom Detection Zones: Focus on specific areas for motion alerts.
- Smoke and CO Alerts: Added safety notifications.
- Local Storage: Supports up to 256GB microSD card.
The Wyze Cam OG is perfect for users who want a wireless camera with spotlight and siren capabilities, offering flexibility in placement without sacrificing security features.
Wyze Cam Spotlight Bundle – Wired Camera with Powerful Spotlight and Siren
The
Wyze Cam Spotlight Bundle pairs the Wyze Cam v3 with a state-of-the-art, motion-activated spotlight and siren, providing enhanced security lighting and audible alerts.
Bundle Benefits:
- 1080p HD Video: Clear video quality with a 120° diagonal viewing angle.
- 70 Lumen Spotlight: Brighter than many competitors, ideal for outdoor lighting.
- Built-In Siren: Audible alarm to deter intruders.
- Simultaneous Two-Way Talk: Communicate clearly through the camera.
- IP65 Weather Resistance: Durable for outdoor use.
- Easy Installation: Includes wall mount plate and cables.
- Compatible with Android and iOS: Control and monitor from your smartphone.
This bundle is a great wired option for those who want a camera with a powerful spotlight and siren, especially for outdoor areas requiring bright illumination.
Wyze Cam Pan v3 – Wired 360° Pan-Tilt Camera with Spotlight and Siren
The
Wyze Cam Pan v3 offers a unique 360° horizontal and 180° vertical pan and tilt capability, combined with a built-in spotlight and siren for comprehensive coverage.
Features:
- 1080p Full HD Video: Crisp video with wide dynamic range.
- 360° Pan & 180° Tilt: Covers every angle with remote control.
- Built-In Spotlight & Siren: Motion-activated lighting and loud siren for deterrence.
- IP65 Weather Resistant: Suitable for outdoor use with the Wyze Outdoor Power Adapter.
- Two-Way Audio: Clear communication with noise and echo cancellation.
- Supports up to 256GB microSD: Continuous local recording.
- Smart Home Compatible: Works with Alexa, Google Assistant, and IFTTT.
Ideal for users who want full-area coverage with active deterrence features in a wired camera.
Summary
Whether you prefer wired or wireless security cameras, Wyze offers multiple models equipped with built-in sirens and spotlights to enhance your home security:
Product | Wired/Wireless | Resolution | Spotlight | Siren (dB) | Weather Resistant | Special Features |
Wyze Cam v4 Outdoor Bundle | Wired | 2.5K QHD | Yes | Yes | Yes (IP65) | Wi-Fi 6, Color Night Vision, 24/7 recording |
Wyze Cam v4 | Wired | 2.5K QHD | Yes | 99 dB | Yes (IP65) | Bluetooth setup, Smart Detection |
Wyze Cam OG | Wireless | 1080p | Yes (40 lumens) | 90 dB | Yes (IP65) | Faster streaming, Custom zones |
Wyze Cam Spotlight Bundle | Wired | 1080p | Yes (70 lumens) | Yes | Yes (IP65) | Two-way talk, Bright spotlight |
Wyze Cam Pan v3 | Wired | 1080p | Yes | Yes | Yes (IP65) | 360° pan-tilt, Smart home compatible |
Choose the Wyze camera that best fits your security needs and enjoy peace of mind with advanced spotlight and siren protection.
What are the benefits of security cameras with built-in siren and spotlight?
Security cameras with built-in siren and spotlight provide both visual and audible deterrence against intruders. The spotlight illuminates dark areas, making it easier to capture clear video footage, while the siren can scare off unwanted visitors and alert you to suspicious activity.Which Wyze security cameras have both a built-in siren and spotlight?
Wyze offers several security cameras with both a built-in siren and spotlight, including the Wyze Cam v4 Outdoor Bundle, Wyze Cam v4, Wyze Cam OG, Wyze Cam Spotlight Bundle, and Wyze Cam Pan v3.What is the difference between wired and wireless Wyze security cameras with siren and spotlight?
Wired Wyze security cameras, such as the Wyze Cam v4, Wyze Cam v4 Outdoor Bundle, Wyze Cam Spotlight Bundle, and Wyze Cam Pan v3, require a constant power source and are ideal for continuous 24/7 monitoring. The Wyze Cam OG is a wireless option, offering more flexibility in placement and easier installation, while still providing built-in siren and spotlight features.Are Wyze security cameras with siren and spotlight weather resistant?
Yes, most Wyze security cameras with built-in siren and spotlight, including the Wyze Cam v4, Wyze Cam v4 Outdoor Bundle, Wyze Cam OG, Wyze Cam Spotlight Bundle, and Wyze Cam Pan v3, are IP65 weather resistant, making them suitable for outdoor use.Can Wyze security cameras with siren and spotlight record video locally?
Yes, Wyze security cameras such as the Wyze Cam v4, Wyze Cam v4 Outdoor Bundle, Wyze Cam OG, Wyze Cam Spotlight Bundle, and Wyze Cam Pan v3 support local video recording via microSD cards, with some models supporting up to 256GB for continuous 24/7 recording.Do Wyze security cameras with siren and spotlight support smart home integration?
Yes, Wyze security cameras with built-in siren and spotlight are compatible with popular smart home platforms such as Alexa, Google Assistant, and IFTTT, allowing for easy integration and voice control.What is the video resolution of Wyze security cameras with siren and spotlight?
Wyze security cameras with siren and spotlight offer high-definition video quality. The Wyze Cam v4 and Wyze Cam v4 Outdoor Bundle provide 2.5K Quad HD resolution, while the Wyze Cam OG, Wyze Cam Spotlight Bundle, and Wyze Cam Pan v3 offer 1080p Full HD video.How loud are the sirens on Wyze security cameras?
The siren loudness varies by model. For example, the Wyze Cam v4 features a 99 dB siren, while the Wyze Cam OG has a 90 dB user-activated siren. All models are designed to be loud enough to deter intruders effectively.Do Wyze security cameras with siren and spotlight have night vision?
Yes, Wyze security cameras such as the Wyze Cam v4 and Wyze Cam v4 Outdoor Bundle feature enhanced color night vision, allowing you to see vibrant colors even in low-light conditions. Other models also offer night vision capabilities for clear footage at night.Can I receive motion alerts and customize detection zones with Wyze security cameras?
Yes, Wyze security cameras with siren and spotlight offer customizable motion detection zones and smart notifications. Some models also provide AI-powered alerts for people, pets, packages, and vehicles with an optional subscription.Are Wyze security cameras with siren and spotlight easy to install?
Yes, Wyze security cameras are designed for easy installation. Wired models often include wall mount plates and cables, and some, like the Wyze Cam v4, feature Bluetooth-enabled setup for hassle-free installation. Wireless models like the Wyze Cam OG offer flexible placement options.Which Wyze security camera is best for full-area coverage?
The Wyze Cam Pan v3 is ideal for full-area coverage, offering 360° horizontal pan and 180° vertical tilt, combined with a built-in spotlight and siren for comprehensive security.
