White USB Extension Cable for Wyze Cam – 20ft Length for Seamless Setup
When it comes to extending the reach of your Wyze Cam while maintaining a clean, discreet look that blends perfectly with your wall molding, the
Wyze Cam USB Extension Cable - 20ft is the ideal accessory. Designed specifically for Wyze cameras, this white USB extension cable offers both functionality and aesthetic harmony, especially for setups where cable visibility matters.
Key Features of the Wyze Cam USB Extension Cable - 20ft
- Length & Flexibility: At 20 feet long, this cable provides ample length to position your Wyze Cam exactly where you need it without worrying about proximity to power outlets.
- Color Matching: The white color of the cable is perfect for blending with white walls, molding, or trim, ensuring your security setup looks neat and unobtrusive.
- Compatibility: Works seamlessly with a wide range of Wyze cameras including Wyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, OG Standard, and OG Telephoto.
- Durability: Rated IP67 for weather resistance, this cable is suitable for both indoor and outdoor use, enduring temperatures from -22°F to 122°F.
- Power Output: Supports 5V 2A output, ensuring your camera receives stable power for uninterrupted operation.
- Connector Type: USB Type A Male to Female, making it easy to extend your existing USB power cable without any adapters.
This extension cable is a must-have for anyone looking to install their Wyze Cam in a location that requires extra cable length while keeping the setup visually clean and professional.
Wyze Cam v4 – The Perfect Camera to Pair with Your Extension Cable
To complement the 20ft USB extension cable, the
Wyze Cam v4 in white is an excellent choice. Its compact design and white finish make it ideal for blending into home interiors, especially when paired with a matching white extension cable.
Wyze Cam v4 Highlights
- Video Quality: Captures stunning 2.5K QHD (2560x1440) video with wide dynamic range and color night vision, ensuring clear footage day and night.
- Sensor & Lens: Equipped with a CMOS Starlight Sensor and a combination of glass and plastic lenses for sharp, vibrant images.
- Field of View: Wide 115.8° diagonal field of view covers more area with fewer blind spots.
- Mounting Options: Versatile mounting including stand, wall mount, ceiling mount, and magnetic adhesive mounts for flexible placement.
- Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6 for reliable streaming.
- Smart Features: Two-way talk, built-in siren, noise and echo cancellation, and integration with Alexa, Google Assistant, and IFTTT.
- Weather Resistance: Rated IP65, suitable for indoor and outdoor use.
- Included Accessories: Comes with a 6-foot flat micro USB to USB-A cable, wall mount plate, screws, and indoor USB power adapter.
Pairing the Wyze Cam v4 with the 20ft white USB extension cable allows you to place your camera in the perfect spot while keeping cables discreet and tidy along your wall molding or baseboards.
Why Choose White Accessories for Your Wyze Cam Setup?
A white USB extension cable is not just about length; it’s about aesthetics and blending technology seamlessly into your home environment.
Using a white extension cable with your white Wyze Cam v4 ensures that cables do not stand out against white walls or molding, maintaining a clean and professional look. This is especially important in living rooms, hallways, or any area where visible cables can detract from your home’s decor.
Summary
For a neat, extended setup of your Wyze Cam, the
Wyze Cam USB Extension Cable - 20ft in white is the perfect accessory. It offers the length you need, durability for indoor/outdoor use, and a color that blends effortlessly with white walls and molding. When combined with the
Wyze Cam v4 White, you get a powerful, visually unobtrusive home security solution.
Alt text: Wyze Cam v4 mounted discreetly on white wall molding with white USB extension cable
What is the length of the Wyze Cam USB Extension Cable?
The Wyze Cam USB Extension Cable is 20 feet long, providing ample reach to position your Wyze Cam exactly where you need it, even if the power outlet is far away.Is the Wyze Cam USB Extension Cable compatible with all Wyze cameras?
Yes, the 20ft white USB extension cable is compatible with a wide range of Wyze cameras, including Wyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, OG Standard, and OG Telephoto.Can the Wyze Cam USB Extension Cable be used outdoors?
Absolutely. The cable is rated IP67 for weather resistance, making it suitable for both indoor and outdoor use. It can withstand temperatures from -22°F to 122°F.What color is the Wyze Cam USB Extension Cable and why is it important?
The extension cable is white, which is ideal for blending with white walls, molding, or trim. This helps maintain a clean and unobtrusive look for your security camera setup.What type of connectors does the Wyze Cam USB Extension Cable use?
The cable features USB Type A Male to Female connectors, allowing you to easily extend your existing USB power cable without the need for additional adapters.Does the Wyze Cam USB Extension Cable provide enough power for my camera?
Yes, the cable supports a 5V 2A output, ensuring your Wyze Cam receives stable power for uninterrupted operation.Why should I choose a white USB extension cable for my Wyze Cam setup?
A white USB extension cable blends seamlessly with white walls and molding, keeping your security camera installation neat and visually unobtrusive, which is especially important in living spaces where aesthetics matter.What are the key features of the Wyze Cam v4 when paired with the extension cable?
The Wyze Cam v4 offers 2.5K QHD video, color night vision, a wide 115.8° field of view, versatile mounting options, Wi-Fi 6 support, smart features like two-way talk and built-in siren, and is rated IP65 for indoor/outdoor use. When paired with the 20ft white extension cable, you can place your camera in the perfect spot while keeping cables discreet.What accessories are included with the Wyze Cam v4?
The Wyze Cam v4 comes with a 6-foot flat micro USB to USB-A cable, a wall mount plate, screws, and an indoor USB power adapter.
