Where to Buy Wyze Robot Vacuum Parts Kit
If you own a Wyze Robot Vacuum, keeping it in top working condition is essential for maintaining a clean home effortlessly. Whether you need replacement parts or accessories, finding the right Wyze Robot Vacuum parts kit is crucial. This guide highlights the essential replacement parts and accessories available for purchase, helping you extend the life and performance of your Wyze Robot Vacuum.
Wyze Robot Vacuum - Replacement Parts Kit
Complete Maintenance Kit for Your Vacuum
The Wyze Robot Vacuum Replacement Parts Kit is a comprehensive solution designed to keep your vacuum running smoothly. This kit includes:
- 4 Edge Brushes: Perfect for cleaning corners and edges effectively.
- 2 Main Brushes: The primary brushes that pick up dirt and debris from floors.
- 4 HEPA Filters: High-efficiency particulate air filters that trap fine dust and allergens, ensuring cleaner air in your home.
Priced at $22.99, this full maintenance kit is compatible exclusively with the Wyze Robot Vacuum, making it a convenient and cost-effective way to replace worn-out parts all at once.
Keep your vacuum performing at its best with this all-in-one replacement kit designed for easy installation and long-lasting use.
Essential Replacement Parts for Wyze Robot Vacuum
Wyze Robot Vacuum - Charging Station
The charging station is the heart of your robot vacuum’s power system. If your original charging dock is lost or damaged, the Wyze Robot Vacuum Charging Station is available for $19.99. It ensures your vacuum returns to charge efficiently after cleaning cycles.
- Compatible with Wyze Robot Vacuum
- Replacement charging station with a 30-day hassle-free return policy
Wyze Robot Vacuum - Dustbin
A clean dustbin is vital for optimal vacuum performance. The Wyze Robot Vacuum Dustbin replacement part is priced at $9.99 and fits perfectly with your device to collect dirt and debris.
- Easy to remove and clean
- 30-day hassle-free returns
Wyze Robot Vacuum - Power Adapter
If your vacuum’s power adapter is malfunctioning or lost, the Wyze Robot Vacuum Power Adapter is available for $4.99. This essential part ensures your vacuum receives the correct power supply for uninterrupted operation.
- Ample stock available for quick replacement
Additional Accessories to Enhance Your Vacuum
Wyze Robot Vacuum - HEPA Filter
For those who want to replace just the filter, the Wyze Robot Vacuum HEPA Filter is available separately at $4.99. This replacement filter helps maintain air quality by trapping dust and allergens during vacuuming.
- Easy to install and replace
Wyze Robot Vacuum - Pad
The vacuum pad is an accessory that helps with mopping or additional cleaning functions. Available for $4.99, this pad is designed to fit the Wyze Robot Vacuum perfectly.
Investing in genuine Wyze Robot Vacuum parts ensures your device continues to operate efficiently, providing thorough cleaning and long-lasting durability. Whether you need a full parts kit or individual components like filters, dustbins, or charging stations, these replacement parts are designed specifically for your Wyze Robot Vacuum.
Summary of Wyze Robot Vacuum Parts Kit Options
Product | Price | Key Features |
Replacement Parts Kit | $22.99 | Edge brushes, main brushes, HEPA filters |
Charging Station | $19.99 | Replacement charging dock |
Dustbin | $9.99 | Easy-to-clean dustbin |
Power Adapter | $4.99 | Reliable power supply |
HEPA Filter | $4.99 | High-efficiency air filter |
Vacuum Pad | $4.99 | Cleaning/mopping pad accessory |
Maintaining your Wyze Robot Vacuum with these genuine parts ensures optimal performance and extends the life of your smart cleaning device.
Alt text: Wyze Robot Vacuum cleaning a modern living room
Alt text: Wyze Robot Vacuum charging on its station in a home environment
Alt text: Wyze Robot Vacuum replacement parts kit laid out for maintenance
Keep your Wyze Robot Vacuum running like new by choosing the right parts kit and accessories tailored for your device. With hassle-free returns and compatibility guaranteed, these replacement parts are your go-to solution for vacuum maintenance.
Where can I buy genuine Wyze Robot Vacuum replacement parts?
You can purchase genuine Wyze Robot Vacuum replacement parts and accessories directly from authorized retailers or the official Wyze website. These parts are designed specifically for the Wyze Robot Vacuum to ensure compatibility and optimal performance.What is included in the Wyze Robot Vacuum Replacement Parts Kit?
The Wyze Robot Vacuum Replacement Parts Kit includes 4 edge brushes, 2 main brushes, and 4 HEPA filters. This comprehensive kit is designed to keep your vacuum running smoothly and is available for $22.99.Are Wyze Robot Vacuum replacement parts compatible with all Wyze Robot Vacuum models?
The replacement parts and accessories listed, including the maintenance kit, charging station, dustbin, power adapter, HEPA filter, and vacuum pad, are compatible exclusively with the Wyze Robot Vacuum. Always check compatibility before purchasing.How much does the Wyze Robot Vacuum Charging Station cost?
The Wyze Robot Vacuum Charging Station is available for $19.99. It serves as a replacement charging dock to ensure your vacuum returns to charge efficiently after cleaning cycles.What is the price of the Wyze Robot Vacuum Dustbin replacement?
The Wyze Robot Vacuum Dustbin replacement part is priced at $9.99. It is easy to remove and clean, ensuring your vacuum maintains optimal performance.How do I replace the HEPA filter in my Wyze Robot Vacuum?
To replace the HEPA filter in your Wyze Robot Vacuum, simply remove the old filter and insert the new one. The HEPA filter is available separately for $4.99 and is designed for easy installation and replacement.What should I do if my Wyze Robot Vacuum power adapter is lost or malfunctioning?
If your Wyze Robot Vacuum power adapter is lost or malfunctioning, you can purchase a replacement for $4.99. The power adapter ensures your vacuum receives the correct power supply for uninterrupted operation.Is there a return policy for Wyze Robot Vacuum replacement parts?
Yes, all Wyze Robot Vacuum replacement parts and accessories come with a 30-day hassle-free return policy, allowing you to shop with confidence.Why should I use genuine Wyze Robot Vacuum parts?
Using genuine Wyze Robot Vacuum parts ensures your device continues to operate efficiently, provides thorough cleaning, and extends the life of your smart cleaning device. Genuine parts are designed for compatibility and durability.What accessories are available to enhance my Wyze Robot Vacuum?
In addition to the replacement parts kit, you can purchase individual accessories such as the HEPA filter ($4.99) and vacuum pad ($4.99) to enhance your Wyze Robot Vacuum’s cleaning performance.
