Where to Buy or Replace Wyze Garage Door Controller Cable Splitter
Where to Buy or Replace the Wyze Garage Door Controller Cable Splitter
If you're looking to buy or replace the Wyze garage door controller cable splitter, it's important to understand that Wyze primarily offers smart home security cameras and accessories rather than specific garage door controller parts like cable splitters. However, Wyze products and bundles can complement your home security setup, including monitoring your garage area effectively. Below, we highlight relevant Wyze products that can enhance your garage security and smart home experience, along with options to power and connect your devices seamlessly.
Wyze Cam v4 Outdoor Bundle: Ultimate Garage Surveillance
Crystal-Clear 2.5K QHD Resolution
The Wyze Cam v4 Outdoor Bundle offers unmatched clarity with 2.5K Quad HD video, ensuring every detail in your garage or driveway is captured with precision.
Enhanced Color Night Vision
Unlike traditional night vision, this camera provides vibrant color footage even in low-light conditions, making it easier to identify people or objects around your garage at night.
Continuous Power and Recording
The camera is wired for continuous power, eliminating worries about battery life. It supports 24/7 local recording with a microSD card (sold separately), so you never miss a moment.
Smart Home Compatibility
Works seamlessly with Alexa and Google Assistant, allowing you to integrate garage monitoring into your smart home ecosystem.
The Wyze Outdoor Power Adapter (sold separately) ensures your camera stays powered in all weather conditions, perfect for garage or outdoor use.
Wyze Cam v4 Outdoor Bundle in Use Keep your garage secure day and night with Wyze Cam v4.
Pan v3 + Lamp Socket v2 Bundle: Power Your Garage Camera Without Outlets
Innovative Power Solution
The Lamp Socket v2 allows you to power your Wyze Cam Pan v3 or compatible cameras by using your existing outdoor light fixture. This is ideal for garages where power outlets may be limited.
Easy Installation
Simply screw the lamp socket into your light fixture and attach your camera—no complicated wiring needed.
Motion-Activated Lighting
Set your garage lights to turn on automatically when motion is detected by your Wyze Cam, enhancing security and convenience.
Compatibility
Works with Wyze Cam v3, v3 Pro, v4, Cam OG, and Cam Pan v3, making it a versatile accessory for your garage setup.
Whole Home Security Starter Kit: Comprehensive Garage and Home Protection
All-in-One Security Solution
This starter kit includes a Wyze Cam v4, Wyze Video Doorbell v2, and Wyze Home Monitoring Starter Kit, providing extensive coverage for your garage and entry points.
Multiple Color Options
Available in White, Grey, and Black to match your home’s exterior and garage aesthetics.
Easy Setup and Integration
Control all devices from the Wyze app, enabling you to monitor your garage door and surroundings remotely.
Whole Home Security Enhanced Kit: Advanced Garage Security Features
Includes Wyze Cam v4 and Wyze Cam Floodlight v2
This enhanced kit adds powerful floodlights to your garage security, illuminating the area when motion is detected.
Customizable Color Combinations
Choose from Black, Grey, or White options for both camera and floodlight to suit your garage style.
Smart Lighting and Surveillance
Floodlights combined with Wyze Cam v4 provide a robust deterrent against intruders and improve visibility for safe garage access at night.
Why Wyze Products Are Ideal for Garage Security
While Wyze does not sell a dedicated garage door controller cable splitter, their cameras and accessories offer excellent alternatives to monitor and secure your garage area. Using Wyze smart cameras with power solutions like the Lamp Socket v2 can help you avoid complicated wiring and maintain continuous surveillance.
"Wyze’s smart home ecosystem provides flexible, affordable, and easy-to-install solutions that enhance your garage security without the need for specialized garage door hardware."
Summary
  • Wyze Cam v4 Outdoor Bundle: Best for high-resolution, color night vision monitoring of your garage.
  • Pan v3 + Lamp Socket v2 Bundle: Ideal for powering cameras via existing light fixtures without extra outlets.
  • Whole Home Security Starter Kit: Comprehensive package including cameras and monitoring for garage and home.
  • Whole Home Security Enhanced Kit: Adds floodlight security for enhanced garage illumination and protection.
Consider these Wyze products to upgrade your garage security setup while you source or replace your garage door controller cable splitter from specialized hardware suppliers.
Smart Home Garage Security Integrate Wyze smart cameras for seamless garage monitoring.
Frequently Asked Questions
Q: Can I buy the Wyze garage door controller cable splitter directly from Wyze? A: Wyze does not currently offer a dedicated garage door controller cable splitter. For replacements, check specialized garage door hardware retailers. Q: How can Wyze products help with garage security? A: Wyze cameras provide real-time video monitoring, motion detection, and smart lighting integration to keep your garage safe and secure. Q: Are Wyze cameras easy to install in a garage setting? A: Yes, especially with accessories like the Lamp Socket v2, which allows powering cameras through existing light fixtures without extra wiring.
Enhance your garage security today with Wyze’s smart cameras and accessories for reliable, affordable, and easy-to-use solutions.
Feature / ProductWyze Cam v4 Outdoor BundlePan v3 + Lamp Socket v2 BundleWyze Cam v4 Whole Home Security Starter KitWhole Home Security Enhanced Kit
Included Devices1x Wyze Cam v4, 1x Wyze Outdoor Power Adapter, 1x Wyze MicroSD Card 128GB1x Wyze Cam Pan v3, 1x Lamp Socket v21x Wyze Cam v4, 1x Wyze Video Doorbell v2, 1x Wyze Home Monitoring Starter Kit1x Wyze Cam v4, 1x Wyze Cam Floodlight v2
Camera Resolution2.5K QHD (2560x1440)Pan v3 camera (resolution not specified here)Wyze Cam v4 2.5K QHDWyze Cam v4 2.5K QHD
Night VisionEnhanced Color Night Vision + Motion-activated spotlightNot specifiedColor Night VisionColor Night Vision
Motion-activated SpotlightYesNoYesYes
Power SourceIncludes Outdoor Power AdapterPowered via Lamp Socket (no outlet needed)Not specified (likely standard power adapter)Not specified (likely standard power adapter)
MicroSD Card Included128GB includedNot includedNot includedNot included
Wi-Fi SupportWi-Fi 6Not specifiedWi-Fi 6Wi-Fi 6
Compatibility with Voice AssistantsAlexa, Google AssistantNot specifiedAlexa, Google AssistantAlexa, Google Assistant
Weather ResistanceIP65Lamp Socket not weatherproof, suitable for damp locationsIP65IP65
Additional Features24/7 local recording, Smoke & CO alerts, Motion Detection ZonesMotion-activated lights, Dusk to Dawn scheduling, Link multiple socketsIncludes Video Doorbell and Home Monitoring KitIncludes Floodlight camera
Price$69.99$53.96$155.95$256.91
Color OptionsBlack, Grey, WhiteBlack, WhiteBlack, Grey, WhiteBlack, Grey, White
Can I buy the Wyze garage door controller cable splitter directly from Wyze?No, Wyze does not currently sell a dedicated garage door controller cable splitter. If you need to buy or replace this part, it is recommended to check with specialized garage door hardware retailers.
What Wyze products are best for garage security?Wyze offers several products ideal for garage security, including the Wyze Cam v4 Outdoor Bundle for high-resolution monitoring, the Pan v3 + Lamp Socket v2 Bundle for easy camera installation without extra outlets, and the Whole Home Security Starter and Enhanced Kits for comprehensive protection with cameras, doorbells, and floodlights.
How can I power a Wyze camera in my garage if I don't have an available outlet?You can use the Wyze Lamp Socket v2, which allows you to power compatible Wyze cameras through your existing outdoor light fixture. This solution is perfect for garages where power outlets are limited.
Are Wyze cameras easy to install in a garage?Yes, Wyze cameras are designed for easy installation. With accessories like the Lamp Socket v2, you can quickly set up your camera using your existing light fixture, eliminating the need for complicated wiring.
Do Wyze cameras offer night vision for garage monitoring?Yes, the Wyze Cam v4 Outdoor Bundle features enhanced color night vision, providing clear and vibrant footage even in low-light conditions, making it ideal for monitoring your garage at night.
Can Wyze cameras be integrated with smart home systems for garage security?Absolutely. Wyze cameras are compatible with Alexa and Google Assistant, allowing you to integrate garage monitoring into your smart home ecosystem for added convenience and control.
What is included in the Wyze Whole Home Security Starter Kit for garage protection?The Wyze Whole Home Security Starter Kit includes a Wyze Cam v4, Wyze Video Doorbell v2, and Wyze Home Monitoring Starter Kit, providing comprehensive coverage for your garage and home entry points.
How does the Wyze Cam Floodlight v2 enhance garage security?The Wyze Cam Floodlight v2, included in the Whole Home Security Enhanced Kit, adds powerful floodlights that illuminate your garage area when motion is detected, deterring intruders and improving nighttime visibility.
Can I monitor my garage remotely with Wyze products?Yes, all Wyze cameras and security kits can be controlled and monitored remotely through the Wyze app, allowing you to keep an eye on your garage from anywhere.
Why should I choose Wyze products for garage security if I need a cable splitter?While Wyze does not offer a garage door controller cable splitter, their smart cameras and accessories provide flexible, affordable, and easy-to-install solutions for monitoring and securing your garage, making them an excellent addition to your overall garage security setup.
What are the features of the Wyze Cam v4 Outdoor Bundle?How does the Lamp Socket v2 work with Wyze cameras?Are there any ongoing sales or discounts for Wyze products?
