Weatherproof Security Camera Kits for Small Business Outdoor Protection
Protecting your small business premises requires reliable, weatherproof security cameras that deliver clear video, smart features, and durable construction. Whether you need wide coverage, night vision, or two-way communication, Wyze offers a range of outdoor-ready cameras and kits designed to keep your business safe around the clock.
Below, explore the top Wyze security cameras and bundles ideal for small business outdoor protection, highlighting their key specifications and benefits.
Wyze Cam v4: Crystal-Clear Outdoor Security with Enhanced Night Vision
The Wyze Cam v4 is a standout choice for small businesses seeking high-resolution, weatherproof security cameras. Engineered with a robust polycarbonate body and IP65 weather resistance, it withstands rain, snow, and extreme temperatures from -4ºF to 122ºF (-20ºC to 50ºC).
Key Features:
- 2.5K QHD Resolution (2560x1440): Capture sharp, detailed video footage to identify faces and license plates easily.
- Enhanced Color Night Vision: Unlike traditional IR night vision, the Cam v4 uses 4 IR LEDs plus 2 white spotlight LEDs (72 lumens) to provide vibrant color video even in low light.
- Motion-Activated Spotlight & Built-in Siren: Deter intruders with a bright spotlight and a loud 99dB siren triggered by motion detection.
- Wide Field of View: DFOV 115.8°, HFOV 98.5°, VFOV 53.1° covers broad outdoor areas.
- Connectivity & Storage: Supports Wi-Fi 6 for fast, reliable streaming and local microSD storage up to 512GB, plus optional cloud storage.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Multiple Mounting Options: Stand, wall, ceiling, or magnetic adhesive mounts for flexible installation.
This camera is perfect for monitoring entrances, parking lots, and outdoor storefronts with crystal-clear video day and night.
Wyze Cam v4 providing reliable outdoor security
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Complete Outdoor Coverage
For businesses needing dynamic coverage, the Wyze Cam Pan v3 offers a full 360° horizontal pan and 180° vertical tilt, ensuring no blind spots around your property. This camera is fully IP65 weather resistant, designed to endure harsh outdoor conditions.
Highlights:
- Full Pan & Tilt: Rotate the camera remotely up to 110° per second to track movement or scan large areas.
- 1080p HD Video: Crisp 1920x1080 resolution with 120° field of view.
- Night Vision: Equipped with 4 IR LEDs for clear black-and-white night footage.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for real-time communication.
- Push Notifications: Instant alerts on your phone when motion is detected.
- Storage: Supports up to 256GB microSD cards for local recording.
- Smart Integrations: Works with Alexa, Google Assistant, and IFTTT.
- Power Requirements: Requires Wyze Outdoor Power Adapter (sold separately) for safe outdoor use.
Ideal for monitoring parking areas, loading docks, or outdoor seating spaces, the Pan v3’s versatile movement ensures comprehensive surveillance.
Wyze Cam Pan v3 weatherproof outdoor camera in action
Wyze Cam OG: Affordable Weatherproof Camera with Spotlight and Siren
The Wyze Cam OG is a budget-friendly option that doesn’t compromise on essential outdoor security features. It’s IP65 rated for weather resistance and operates reliably in temperatures from -4ºF to 131ºF (-20ºC to 55ºC).
Features:
- 1080p Full HD Video: Clear video with a 120° field of view.
- Built-in 40 Lumen Spotlight: Illuminates dark areas to enhance night vision.
- 90dB User-Activated Siren: Adds an extra layer of security by scaring off intruders.
- Two-Way Audio: Communicate directly through the camera.
- Fast Live Streaming: 50% faster than previous Wyze models.
- Custom Detection Zones: Focus on specific areas to reduce false alerts.
- Local Storage: Supports up to 256GB microSD cards.
- Smart Home Compatibility: Works with Alexa and Google Assistant.
This camera is perfect for small businesses looking for reliable outdoor protection without a high price tag.
Wyze Cam v4 Home Security Bundle: Complete Outdoor Protection Kit
For small businesses wanting an all-in-one solution, the Wyze Cam v4 Home Security Bundle combines the powerful Wyze Cam v4 with the Wyze Cam Floodlight v2, providing enhanced lighting and security in one package.
Bundle Benefits:
- 2.5K QHD Video & Color Night Vision: Superior image quality for day and night.
- Motion-Activated Spotlight & Floodlight: Brighten dark areas instantly to deter unwanted visitors.
- Person Detection: Smart alerts to reduce false alarms.
- Weatherproof Design: IP65 rating ensures durability outdoors.
- Multiple Mounting Options: Easy installation on walls, ceilings, or magnetic mounts.
- Local and Cloud Storage: Flexible recording options with microSD and subscription plans.
- Smart Assistant Integration: Compatible with Alexa and Google Assistant.
This bundle is ideal for small business owners who want a comprehensive security setup with lighting and camera combined for maximum deterrence.
Why Choose Wyze Weatherproof Security Cameras for Your Small Business?
"Reliable outdoor security cameras with advanced features and weatherproof durability."
Wyze cameras are designed to meet the demanding needs of small business outdoor protection. Their IP65 weather resistance ensures they perform well in rain, snow, and extreme temperatures. With high-resolution video, color night vision, two-way audio, and smart home compatibility, these cameras provide peace of mind and effective surveillance.
Summary of Recommended Weatherproof Security Cameras
Product | Resolution | Weatherproof | Night Vision Type | Special Features | Price Range |
Wyze Cam v4 | 2.5K QHD (2560x1440) | IP65 | Color Night Vision | Motion spotlight, siren, Wi-Fi 6 | $35.98 - $107.94 |
Wyze Cam Pan v3 | 1080p (1920x1080) | IP65 | IR LEDs (Black & White) | 360° pan/180° tilt, 2-way audio | $39.98 - $114.94 |
Wyze Cam OG | 1080p (1920x1080) | IP65 | IR LEDs + Spotlight | Built-in siren, fast live streaming | $29.98 - $89.94 |
Wyze Cam v4 Home Security Bundle | 2.5K QHD | IP65 | Color Night Vision | Floodlight, person detection | $169.99 |
Protect your small business with Wyze’s weatherproof security camera kits that combine advanced technology, durable design, and smart features to keep your outdoor spaces safe and monitored 24/7.
What are the best weatherproof security cameras for small business outdoor protection?
Wyze offers several weatherproof security cameras ideal for small business outdoor protection, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam OG, and the Wyze Cam v4 Home Security Bundle. These cameras feature high-resolution video, night vision, motion-activated spotlights, sirens, and smart home integration, all with IP65 weather resistance for reliable performance in rain, snow, and extreme temperatures.Is the Wyze Cam v4 suitable for outdoor use in extreme weather conditions?
Yes, the Wyze Cam v4 is designed for outdoor use with an IP65 weather resistance rating. It can withstand rain, snow, and temperatures ranging from -4ºF to 122ºF (-20ºC to 50ºC), making it ideal for protecting small business premises in various climates.What features make the Wyze Cam v4 a good choice for small business security?
The Wyze Cam v4 offers 2.5K QHD resolution for clear video, enhanced color night vision, a motion-activated spotlight, a built-in 99dB siren, wide field of view, Wi-Fi 6 connectivity, local and cloud storage options, and compatibility with Alexa, Google Assistant, and IFTTT. Its durable, weatherproof design makes it perfect for monitoring entrances, parking lots, and storefronts.How does the Wyze Cam Pan v3 provide complete outdoor coverage?
The Wyze Cam Pan v3 features a 360° horizontal pan and 180° vertical tilt, allowing you to remotely scan and monitor large outdoor areas without blind spots. It also offers 1080p HD video, night vision, two-way audio, push notifications, and is IP65 weather resistant for reliable outdoor use.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle includes the Wyze Cam v4 and the Wyze Cam Floodlight v2. This combination provides 2.5K QHD video, color night vision, motion-activated spotlight and floodlight, person detection, weatherproof design, multiple mounting options, and both local and cloud storage. It is a comprehensive solution for small business outdoor security.Are Wyze outdoor security cameras compatible with smart home systems?
Yes, Wyze outdoor security cameras are compatible with popular smart home systems, including Amazon Alexa, Google Assistant, and IFTTT. This allows for voice control, automation, and integration with other smart devices in your business.Can Wyze outdoor cameras record video locally without a subscription?
Yes, Wyze outdoor cameras support local video recording via microSD cards. The Wyze Cam v4 supports up to 512GB, while the Wyze Cam Pan v3 and Wyze Cam OG support up to 256GB microSD cards. This allows for continuous or event-based recording without the need for a subscription.What is the difference between color night vision and traditional night vision in Wyze cameras?
Color night vision, available on the Wyze Cam v4 and v4 Home Security Bundle, uses a combination of IR LEDs and white spotlight LEDs to provide vibrant, full-color video even in low-light conditions. Traditional night vision, found on the Wyze Cam Pan v3 and OG, uses IR LEDs to deliver clear black-and-white footage in the dark.Do Wyze outdoor security cameras have two-way audio?
Yes, Wyze outdoor security cameras such as the Cam v4, Cam Pan v3, and Cam OG feature built-in microphones and speakers, allowing for real-time two-way communication. This is useful for greeting visitors or warning potential intruders.What mounting options are available for Wyze outdoor security cameras?
Wyze outdoor security cameras offer multiple mounting options, including stand, wall, ceiling, and magnetic adhesive mounts. This flexibility allows you to install the cameras in the most effective locations for your small business security needs.
