Weatherproof Outdoor Security Cameras: High-Res, Wide Angle, PTZ, IP65
Weatherproof Outdoor Security Cameras with High Resolution, Wide Angle, PTZ, and IP Rating
When it comes to securing your home or business outdoors, having a weatherproof security camera with high resolution, wide-angle views, PTZ (pan-tilt-zoom) capabilities, and a solid IP rating is essential. Wyze offers a range of outdoor security cameras designed to meet these needs, combining advanced features with affordability and ease of use.
Wyze Bulb Cam: Innovative 2-in-1 Outdoor Security and Lighting Solution
Key Features
- 2K HD Video with Color Night Vision: Capture crystal-clear 2K resolution video with vibrant color even at night, ensuring you never miss a detail.
- Wide 160° Field of View: Covers a broad area, reducing blind spots around your property.
- Weatherproof Design: Built to withstand outdoor conditions, making it perfect for porch, garage, or backyard use.
- Integrated Smart LED Bulb: Functions as an 800-lumen dimmable LED light, controllable remotely via the Wyze app.
- Adjustable Camera Angle: Manually pan and tilt the camera to get the perfect view.
- Local Storage & No Subscription Required: Supports microSD cards up to 256GB for continuous 24/7 local recording.
- Two-Way Audio & Siren: Communicate through the camera and deter intruders with a built-in siren and flashing lights.
- Easy Installation: Fits most light fixtures, turning your existing outdoor lighting into a smart security system.
The Wyze Bulb Cam is perfect for those who want a discreet, dual-purpose device that blends security with smart lighting.
Wyze Bulb Cam: Security meets smart lighting
Wyze Cam v4: High-Resolution Outdoor Security with Enhanced Features
Standout Specifications
- 2.5K QHD Resolution: Offers ultra-clear video quality with rich detail and sharpness.
- Enhanced Color Night Vision: See vibrant colors in low-light conditions, surpassing traditional black-and-white night vision.
- IP65 Weather Resistance: Durable against rain, dust, and harsh weather, suitable for year-round outdoor use.
- Motion-Activated Spotlight & Siren: Automatically lights up and alerts you to movement, deterring unwanted visitors.
- Wi-Fi 6 Support: Ensures a stronger, more reliable connection even at greater distances.
- 24/7 Local Recording: Continuous recording to microSD cards up to 256GB without subscription fees.
- Advanced Two-Way Audio: Clearer conversations with improved microphone and speaker.
- Smart Detection & Notifications: Customizable alerts including person, package, and vehicle detection with AI-powered smart focus and auto-zoom.
Wyze Cam v4 is ideal for users seeking a powerful, weatherproof camera with superior image quality and smart home integration.
Wyze Cam v4: Advanced outdoor security with spotlight
Wyze Cam Pan v3: Full PTZ Control with 360° Coverage and IP65 Rating
Highlights
- 360° Horizontal & 180° Vertical Pan-Tilt: Complete coverage with smooth, fast rotation up to 110° per second.
- 1080p Full HD Resolution: Crisp video quality with 120° field of view.
- IP65 Weatherproof: Reliable performance in rain, snow, and extreme temperatures (-4°F to 122°F).
- 8x Digital Zoom: Zoom in on details without losing clarity.
- Two-Way Audio with Noise & Echo Cancellation: Communicate clearly through the built-in speaker and microphone.
- Supports up to 256GB microSD Storage: Local continuous recording without monthly fees.
- Smartphone Alerts: Push notifications for motion detection with customizable zones.
- Easy Installation: Magnetic mount and screw options for versatile placement.
The Wyze Cam Pan v3 is perfect for those who want a versatile PTZ camera with wide coverage and weatherproof durability.
Wyze Cam Pan v3: Weatherproof PTZ camera for full coverage
Wyze Cam v4 Home Security Bundle: Complete Outdoor Protection
Bundle Benefits
- Includes multiple Wyze Cam v4 units with 128GB microSD cards for extensive local storage.
- All features of Wyze Cam v4: 2.5K QHD resolution, enhanced color night vision, IP65 weather resistance, motion-activated spotlight, and siren.
- Multiple mounting options: stand, wall, ceiling, and magnetic mounts.
- Ideal for comprehensive home or business security setups with easy expansion.
This bundle offers a cost-effective way to secure multiple outdoor areas with high-quality cameras and ample storage.
Why Choose Wyze Outdoor Security Cameras?
- High-Resolution Video: From 1080p to 2.5K QHD, Wyze cameras deliver sharp, detailed footage.
- Wide-Angle & PTZ Options: Choose fixed wide-angle views or full pan-tilt-zoom control for maximum coverage.
- Weatherproof IP65 Rating: All outdoor models are built to withstand rain, dust, and temperature extremes.
- Smart Features: Motion detection, AI alerts, two-way audio, sirens, and smart lighting integration.
- Local Storage & No Mandatory Subscription: Save video locally on microSD cards with optional cloud plans.
- Easy Setup & Integration: Compatible with Alexa, Google Assistant, IFTTT, and controlled via the Wyze app.
Conclusion
For anyone searching for a weatherproof outdoor security camera with high resolution, wide-angle views, PTZ capabilities, and a reliable IP rating, Wyze offers versatile solutions tailored to different needs. Whether you want a smart light bulb camera, a high-definition spotlight camera, or a full PTZ system, Wyze has you covered with affordable, feature-rich options.
Product Summary
Product Name | Resolution | Field of View | PTZ | IP Rating | Special Features |
Wyze Bulb Cam | 2K HD | 160° wide-angle | Manual tilt | IP65 | Smart LED bulb, color night vision |
Wyze Cam v4 | 2.5K QHD | 115.9° diagonal | No | IP65 | Color night vision, spotlight, Wi-Fi 6 |
Wyze Cam Pan v3 | 1080p Full HD | 120° FOV | 360° pan/180° tilt | IP65 | PTZ, 8x zoom, two-way audio |
Wyze Cam v4 Home Bundle | 2.5K QHD | 115.8° diagonal | No | IP65 | Multiple cams + 128GB microSD included |
Feature | Wyze Bulb Cam | Wyze Cam v4 | Wyze Cam Pan v3 | Wyze Cam v4 Home Security Bundle |
Type | Outdoor Security Camera + Smart LED Bulb | Wired Security Camera | Indoor/Outdoor Pan & Tilt Camera | Wired Security Camera Bundle |
Video Resolution | 2K HD | 2.5K QHD (2560x1440) | 1080p (1920x1080) | 2.5K QHD (2560x1440) |
Field of View | 160° wide view | 115.8° DFOV, 98.5° HFOV, 53.1° VFOV | 120° FOV | 115.8° DFOV, 98.5° HFOV, 53.1° VFOV |
Night Vision | Color Night Vision | Enhanced Color Night Vision | 4 IR LEDs (850 nm) | 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens) |
Audio | Two-Way Audio | Enhanced Two-Way Talk | Two-Way Audio with Noise & Echo Cancellation | Improved Two-Way Audio |
Siren | Built-in Siren | Built-in Siren (99 dB) | No siren mentioned | Built-in Siren |
Spotlight | No | Motion-activated Spotlight | No | Motion-activated Spotlight |
Pan/Tilt/Zoom | Manual pan and tilt | Fixed angle | 360° pan, 180° tilt, 8x digital zoom | Fixed angle |
Weather Resistance | Outdoor rated (fits most fixtures) | IP65 | IP65 | IP65 |
Local Storage | microSD up to 256 GB (no subscription needed) | microSD up to 512 GB (required) | microSD up to 256 GB | microSD up to 128 GB |
Cloud Storage | Optional Cam Plus subscription | Optional Cam Plus subscription | Optional Cam Plus subscription | Optional Cam Plus subscription |
Connectivity | Wi-Fi (2.4 GHz) | Wi-Fi 6 + Bluetooth 5.2 | Wi-Fi 2.4 GHz only | Wi-Fi 6 + Bluetooth 5.2 |
Smart Home Integration | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT |
Power Source | Powered by light fixture | Wired (requires power adapter) | Wired (requires power adapter) | Wired (includes power adapter) |
Dimensions | Fits most light fixtures | 2in x 2in x 2 3/8in | 124mm x 60mm x 63mm | 2in x 2in x 2 3/8in |
Weight | Not specified | 0.49 lb (222 g) | 11.29 oz (320 g) | 0.49 lb (222 g) |
Additional Features | Dimmable 800 lumen LED, group light control, siren, motion-activated lights | Auto-zoom with AI, smoke & CO alerts, advanced audio coding, magnetic mount | 360° pan, 180° tilt, noise & echo cancellation | Includes mounting options (stand, wall, ceiling, magnetic) |
Price (approximate) | $49.98 | $35.98 (single) | $39.98 (single) | $169.99 (bundle) |
What makes Wyze outdoor security cameras weatherproof?
Wyze outdoor security cameras are designed with an IP65 weather resistance rating, making them durable against rain, dust, snow, and extreme temperatures. This ensures reliable performance year-round for outdoor home or business security.Do Wyze outdoor security cameras offer high-resolution video?
Yes, Wyze outdoor security cameras provide high-resolution video, ranging from 1080p Full HD to 2.5K QHD. This delivers sharp, detailed footage for clear identification and monitoring.Which Wyze camera is best for wide-angle outdoor coverage?
The Wyze Bulb Cam offers a wide 160° field of view, making it ideal for broad outdoor coverage and reducing blind spots around your property.What is PTZ and which Wyze camera supports it?
PTZ stands for Pan-Tilt-Zoom, allowing the camera to rotate and zoom for comprehensive coverage. The Wyze Cam Pan v3 features full PTZ control with 360° horizontal and 180° vertical movement, plus 8x digital zoom.Can Wyze outdoor cameras record video locally without a subscription?
Yes, all Wyze outdoor security cameras support local video storage on microSD cards up to 256GB, enabling continuous 24/7 recording without requiring a monthly subscription.Do Wyze outdoor cameras have night vision?
Yes, Wyze outdoor cameras feature advanced color night vision, allowing you to capture vibrant, detailed footage even in low-light or nighttime conditions.Are Wyze outdoor security cameras easy to install?
Wyze outdoor cameras are designed for easy installation, with options like magnetic mounts, screw mounts, and compatibility with standard light fixtures for the Bulb Cam. Most models can be set up quickly and controlled via the Wyze app.What smart features do Wyze outdoor security cameras offer?
Wyze outdoor cameras include smart features such as motion detection, AI-powered alerts (person, package, and vehicle detection), two-way audio, built-in sirens, and smart lighting integration. They are also compatible with Alexa, Google Assistant, and IFTTT.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 units, each with a 128GB microSD card for extensive local storage. It offers all the features of the Wyze Cam v4, such as 2.5K QHD resolution, color night vision, IP65 weather resistance, and motion-activated spotlight.Can I control Wyze outdoor cameras remotely?
Yes, Wyze outdoor security cameras can be controlled remotely through the Wyze app, allowing you to view live footage, adjust camera angles, receive alerts, and manage smart features from anywhere.
What are the key features of the Wyze Bulb Cam?Can you tell me more about the installation process for the Wyze Bulb Cam?Do you have any ongoing sales or discounts for the Wyze outdoor security cameras?
