Best Weather Resistant Cameras for Business in Extreme Conditions
Weather Resistant Cameras for Business Use in Extreme Conditions
When it comes to securing your business premises in extreme weather conditions, choosing the right weather resistant camera is crucial. Businesses require durable, reliable, and high-performance cameras that can withstand harsh environments while delivering crystal-clear video and smart features. Wyze offers a range of IP65-rated cameras designed specifically for outdoor and indoor/outdoor use, ensuring your business stays protected no matter the weather.
Wyze Cam v4 – Advanced Weatherproof Security with Stunning Clarity
The Wyze Cam v4 is a top-tier choice for businesses needing robust outdoor security. Built with a polycarbonate body and glass/plastic lens, this camera offers exceptional durability and weather resistance rated at IP65, making it ideal for extreme conditions ranging from -4ºF to 122ºF (-20ºC to 50ºC).
Key Features:
  • 2.5K QHD Resolution: Crystal-clear video quality (2560x1440) ensures every detail is captured.
  • Enhanced Color Night Vision: See vibrant colors even in low light, thanks to 4 IR LEDs and 2 white spotlight LEDs (72 lumens).
  • Wide Field of View: DFOV 115.8°, HFOV 98.5°, VFOV 53.1° covers large areas.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart business automation.
  • Connectivity: Supports Wi-Fi 6 and 2.4 GHz Wi-Fi for stable, fast connections.
  • Mounting Flexibility: Multiple mounting options including stand, wall, ceiling, and magnetic mounts.
  • Built-in Siren & Two-Way Audio: 99dB waterproof speaker with noise and echo cancellation for clear communication and deterrence.
This camera is perfect for businesses that require high-resolution monitoring with reliable weather resistance and smart home integration. Wyze Cam v4 Outdoor Security Wyze Cam v4 providing reliable outdoor security in all weather conditions
Wyze Cam Pan v3 – 360° Pan and Tilt for Comprehensive Outdoor Coverage
For businesses needing full-area surveillance, the Wyze Cam Pan v3 offers a dynamic 360° horizontal and 180° vertical view with smooth pan and tilt capabilities. This camera is fully IP65 weather resistant, designed to endure snow, rain, and heat, operating between -4ºF and 122ºF (-20ºC to 50ºC).
Highlights:
  • Full 360° Pan & 180° Tilt: Covers every angle with up to 110° per second rotation speed.
  • 1080p HD Video: Crisp 1920x1080 resolution with 8x digital zoom.
  • Night Vision: 4 IR LEDs provide clear black-and-white night vision.
  • Smart Alerts: Push notifications keep you informed of any activity.
  • Two-Way Audio: Built-in microphone and speaker with noise and echo cancellation.
  • Weatherproof Design: Polycarbonate body with IP65 rating ensures durability in extreme weather.
  • Power Requirements: Requires Wyze Outdoor Power Adapter for safe outdoor use.
This camera is ideal for businesses that want to monitor large outdoor spaces such as parking lots, warehouses, or storefronts with flexible viewing angles. Wyze Cam Pan v3 in Snow Wyze Cam Pan v3 weather resistant and perfect for snowy outdoor business environments
Wyze Cam OG and OG Telephoto – Reliable Weatherproof Cameras with Enhanced Features
Wyze Cam OG
The Wyze Cam OG is a compact, weather-resistant camera (IP65) suitable for both indoor and outdoor business use. It operates in extreme temperatures from -4ºF to 131ºF (-20ºC to 55ºC), making it a versatile option for various climates.
  • 1080p Full HD Video: Clear 1920x1080 resolution with 8x digital zoom.
  • Built-in Spotlight & Siren: 40 lumens spotlight and 90-decibel siren for added security.
  • Fast Live Streaming: 50% faster than previous models for real-time monitoring.
  • Two-Way Audio: Enhanced microphone and speaker for clear communication.
  • Custom Detection Zones: Focus on critical areas to reduce false alerts.
Wyze Cam OG Telephoto
For businesses requiring detailed zoom capabilities, the OG Telephoto model features a 3x telephoto lens with a narrower field of view (27° DFOV) for focused surveillance.
  • 3x Telephoto Lens: Perfect for monitoring distant objects or entrances.
  • 1080p HD Video: Same high-quality video with night vision.
  • Weather Resistant: IP65 rating and wide operating temperature range.
  • Two-Way Audio & Siren: Clear communication and deterrence features.
Both models support microSD storage up to 256GB and integrate with Alexa, Google Assistant, and IFTTT.
Wyze Cam v4 Home Security Bundle – Comprehensive Protection for Business Premises
For businesses looking for an all-in-one solution, the Wyze Cam v4 Home Security Bundle offers multiple cameras with the same advanced features of the v4 model, including: 2.5K QHD Video with Color Night Vision Motion-Activated Spotlight and Person Detection IP65 Weather Resistance for Outdoor Use Wide Dynamic Range and 8x Digital Zoom Local and Cloud Storage Options This bundle is perfect for businesses that want to cover multiple entry points or areas with high-quality, weatherproof cameras.
Wyze v3 Bundle – Trusted Weatherproof Cameras for Business Security
The Wyze v3 Bundle includes two IP65-rated cameras designed for easy installation and reliable outdoor monitoring. These cameras feature: 1080p HD Video with Color Night Vision 360° Horizontal and 180° Vertical View Motion Tracking and Two-Way Audio Supports 32GB MicroSD Storage
  • Operating Temperature Range: -5ºF to 113ºF (-20ºC to 45ºC)
Ideal for businesses starting with outdoor security, this bundle offers excellent value and dependable performance.
Why Choose Wyze Weather Resistant Cameras for Your Business?
Wyze cameras combine rugged IP65 weatherproofing with advanced video technology, smart integrations, and flexible mounting options. Whether you need wide-area coverage, detailed zoom, or multi-camera bundles, Wyze provides reliable solutions that perform in extreme temperatures and harsh weather, ensuring your business stays secure 24/7.
Summary Table of Wyze Weather Resistant Cameras for Business
ModelResolutionWeather RatingField of ViewNight VisionSpecial FeaturesOperating Temp Range
Wyze Cam v42.5K QHD (2560x1440)IP65DFOV 115.8°, HFOV 98.5°Color Night Vision + SpotlightWi-Fi 6, 8x Zoom, Siren, Alexa/Google-4ºF to 122ºF (-20ºC to 50ºC)
Wyze Cam Pan v31080p (1920x1080)IP65360° Horizontal, 180° VerticalIR Night Vision360° Pan/Tilt, Push Alerts, Two-Way Audio-4ºF to 122ºF (-20ºC to 50ºC)
Wyze Cam OG1080p (1920x1080)IP65120°IR Night Vision + SpotlightFast Live Streaming, Siren, Custom Zones-4ºF to 131ºF (-20ºC to 55ºC)
Wyze Cam OG Telephoto1080p (1920x1080)IP6527° DFOV (Telephoto)IR Night Vision3x Telephoto Lens, Siren, Two-Way Audio-4ºF to 131ºF (-20ºC to 55ºC)
Wyze Cam v4 Home Security Bundle2.5K QHD (2560x1440)IP65DFOV 115.8°, HFOV 98.5°Color Night Vision + SpotlightPerson Detection, Multi-Camera Bundle-4ºF to 122ºF (-20ºC to 50ºC)
Wyze v3 Bundle1080p (1920x1080)IP65360° Horizontal, 180° VerticalColor Night VisionMotion Tracking, Two-Way Audio-5ºF to 113ºF (-20ºC to 45ºC)
Protect your business with Wyze’s durable, weather resistant cameras designed for extreme conditions. Whether you need wide coverage, zoom capabilities, or bundled solutions, Wyze has the perfect camera to keep your business safe and secure year-round.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam OGWyze Cam OG TelephotoWyze Cam v4 Home Security BundleWyze v3 Bundle
Price (USD)$35.98 (1 Pack)$39.98 (1 Pack)$29.98 (1 Pack)$25.98 (1 Pack)$169.99 (Bundle)$92.94 (Bundle)
Resolution2.5K QHD (2560x1440)1080p (1920x1080)1080p (1920x1080)1080p (1920x1080)2.5K QHD (2560x1440)1080p (1920x1080)
Field of View (Diagonal)115.9°360° pan / 180° tilt120°Telephoto: 27° (DFOV)115.8°121°
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)4 IR LEDs (850 nm)4 IR LEDs (850 nm)4 IR LEDs + 2 white spotlight LEDs (72 lumens)4 IR LEDs (850 nm)
AudioEnhanced 2-way talkTwo-way audioBuilt-in speaker & mic; noise & echo cancellationBuilt-in speaker & mic; noise & echo cancellationImproved 2-way audioTwo-way audio
SpotlightMotion-activated spotlightNoBuilt-in spotlight (40 lumens)NoMotion-activated spotlightNo
Siren99 dB user-activated sirenNo90 dB user-activated sirenNoIncludedNo
Weather ResistanceIP65IP65IP65IP65IP65IP65
Local Storage SupportmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD 128GB included32GB microSD included
Wi-Fi SupportWi-Fi 62.4 GHz (802.11 b/g/n)2.4 GHz (802.11 b/g/n)2.4 GHz (802.11 b/g/n)Wi-Fi 62.4 GHz (802.11 b/g/n)
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTNot specifiedAlexa, Google Assistant, IFTTTAlexa, Google AssistantYes
Motion TrackingAuto-zoom with AI Smart FocusAutomatic motion-trackingNoNoNoYes
Detection ZonesYesYesYesNot specifiedYesYes
Smoke & CO AlertsYesYesYesNot specifiedYesNot specified
Mounting OptionsStand, Wall, Ceiling, MagneticStand, Wall, CeilingStand, Wall, CeilingStand, Wall, CeilingStand, Wall, Ceiling, MagneticIncluded mounting kit
Dimensions (inches)2 x 2 x 2 3/8Not specified1.89 x 1.89 x 1.891.89 x 1.89 x 1.892 x 2 x 2 3/84.88 x 2.36 x 2.48 (124 x 60 x 63 mm)
Weight0.49 lb (222 g)Not specified4.1 oz (116 g)4.1 oz (116 g)0.49 lb (222 g)11.29 oz (320 g)
Power Adapter Output5V/1ANot specified5V/1A5V/1A5V/1AIncluded
Operating TemperatureNot specifiedNot specified-4°F to 131°F (-20°C to 55°C)-4°F to 131°F (-20°C to 55°C)Not specified-5°F to 113°F (-20°C to 45°C)
Warranty1 YearNot specified1 Year1 Year1 YearNot specified
What makes Wyze weather resistant cameras suitable for extreme business environments?Wyze weather resistant cameras are designed with IP65-rated enclosures, allowing them to withstand harsh weather conditions such as rain, snow, and extreme temperatures. Their durable polycarbonate bodies and wide operating temperature ranges ensure reliable performance for business security in any climate.
Which Wyze camera is best for outdoor business security in extreme weather?The Wyze Cam v4 is an excellent choice for outdoor business security in extreme weather. It features an IP65 weather resistance rating, operates between -4ºF and 122ºF (-20ºC to 50ºC), and offers 2.5K QHD resolution, color night vision, and smart integrations for comprehensive protection.
Can Wyze cameras provide clear video footage at night?Yes, Wyze cameras such as the Cam v4 and v3 Bundle offer advanced night vision capabilities. The Cam v4 features enhanced color night vision with IR and spotlight LEDs, while other models provide clear black-and-white or color night vision to ensure detailed footage even in low-light conditions.
Are Wyze cameras compatible with smart home systems?Wyze cameras are compatible with popular smart home systems, including Alexa, Google Assistant, and IFTTT. This allows businesses to integrate their security cameras with existing automation and monitoring setups for seamless operation.
What is the difference between Wyze Cam OG and OG Telephoto for business use?The Wyze Cam OG is a compact, weather-resistant camera with a wide 120° field of view, ideal for general surveillance. The OG Telephoto model features a 3x telephoto lens and a narrower 27° field of view, making it perfect for monitoring distant objects or specific entry points with greater detail.
Do Wyze cameras support local storage for video recordings?Yes, most Wyze cameras support local storage via microSD cards. The Wyze Cam OG and OG Telephoto support up to 256GB microSD cards, while the v3 Bundle supports up to 32GB, allowing businesses to store video footage locally for easy access and review.
What are the power requirements for Wyze outdoor cameras?Wyze outdoor cameras, such as the Cam Pan v3, require the Wyze Outdoor Power Adapter for safe and reliable outdoor operation. This ensures the cameras remain powered in various weather conditions.
Which Wyze camera bundle is recommended for comprehensive business security?The Wyze Cam v4 Home Security Bundle is recommended for businesses seeking comprehensive security. It includes multiple cameras with 2.5K QHD video, color night vision, motion-activated spotlight, person detection, and IP65 weather resistance, making it ideal for covering multiple entry points or large areas.
How do Wyze cameras help reduce false alerts for businesses?Wyze cameras offer custom detection zones, allowing businesses to focus monitoring on critical areas and reduce false alerts from irrelevant motion. This feature is available on models like the Wyze Cam OG, enhancing the accuracy of security notifications.
What is the operating temperature range for Wyze weather resistant cameras?Wyze weather resistant cameras operate in a wide range of temperatures. For example, the Cam v4 and Cam Pan v3 function between -4ºF and 122ºF (-20ºC to 50ºC), while the Cam OG and OG Telephoto can operate from -4ºF to 131ºF (-20ºC to 55ºC), ensuring reliable performance in extreme climates.
What are the specific features of the Wyze Cam v4 that make it suitable for extreme weather conditions?Can you explain the differences between the Wyze Cam v4 and the Wyze Cam Pan v3?Are there any ongoing promotions or discounts available for Wyze cameras?
