Water-Saving Smart Sprinkler Controller with Sprinkler Plus
Water Saving Smart Sprinkler Controller with Sprinkler Plus Service
Efficient lawn irrigation is essential for maintaining a lush, green yard while conserving water and reducing utility costs. The Wyze Sprinkler Controller combined with the Sprinkler Plus service offers a smart, connected solution designed to optimize your watering schedule based on real-time weather data. This system not only saves water but also simplifies lawn care with remote control and personalized settings.
Wyze Sprinkler Controller: Smarter, Simpler, Greener Irrigation
The Wyze Sprinkler Controller is an 8-zone WiFi-enabled device that gives you full control over your lawn’s irrigation system from anywhere using the Wyze app. It replaces your traditional sprinkler timer with a smart, connected solution that adapts watering schedules to your lifestyle and local weather conditions.
Key Features:
  • 8 Customizable Irrigation Zones: Tailor watering schedules for up to 8 different zones, each with unique names and photos for easy identification.
  • Remote Control via App: Start, stop, or adjust watering schedules anytime from your smartphone.
  • WeatherSense Certified: Earned EPA’s WaterSense certification for its ability to use weather-based watering schedules, helping save billions of gallons of water nationwide.
  • Easy DIY Installation: Replace your existing controller in under 20 minutes with no professional help needed.
  • Peace of Mind with Wyze Cam Integration: Monitor your lawn watering remotely and receive notifications if your system is running.
“Affordably priced smart sprinkler controller” – DigitalTrends
“Wyze Sprinkler Controller is a good value” – Wirecutter
“#1 Affordable Smart Sprinkler Controller” – ZDNet
Smart Sprinkler Control with App Control your sprinkler system remotely with the Wyze app for smarter watering.
Wyze Sprinkler Plus: Unlock Weather-Based Watering Efficiency
Wyze Sprinkler Plus is a subscription service that enhances the Wyze Sprinkler Controller by adding intelligent weather-based features. It ensures your lawn is watered only when necessary, preventing overwatering and saving water.
Benefits of Sprinkler Plus:
  • Weather-Based Watering: Automatically adjusts watering schedules based on hyper-local weather data, skipping watering during rain or high moisture conditions.
  • Advanced Yard Insights: View historical, current, and forecasted moisture levels for each zone directly in the app.
  • Water Conservation: Helps protect plants and reduces water waste by skipping unnecessary watering cycles.
  • Free 1-Year Subscription: Included with the purchase of the Wyze Sprinkler Controller for a full year of smart watering.
Weather-Based Watering with Sprinkler Plus Sprinkler Plus uses real-time weather data to optimize watering schedules and conserve water.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
For outdoor installations, the Wyze Weatherproof Sprinkler Controller Box offers a robust, weather-resistant enclosure designed specifically for the Wyze Sprinkler Controller.
Features:
  • IP65 Weatherproof Rating: Fully protects the controller from rain, dust, and harsh outdoor conditions.
  • Durable Design: Equipped with 4 clasps and a gridded cover for extra strength and security.
  • Flexible Power Options: Supports both hardwired and outdoor outlet power sources.
  • Seamless Compatibility: Designed exclusively for the Wyze Sprinkler Controller.
This accessory ensures your smart sprinkler system remains safe and operational regardless of weather, extending the life and reliability of your irrigation controller.
(Refurbished) Wyze Sprinkler Controller: Affordable Smart Irrigation
For budget-conscious customers, the refurbished Wyze Sprinkler Controller offers the same smart features at a lower price point. It supports up to 8 zones and includes the free 1-year Sprinkler Plus subscription for weather-based watering.
Highlights:
  • Same Smart Features: Personalized schedules, app control, and weather-based watering with Sprinkler Plus.
  • Quick Setup: Most users install it in about 20 minutes.
  • Compatible with Most Residential Systems: Works with systems that have master valves or pump relays.
  • Eco-Friendly Choice: Refurbished product reduces waste while delivering smart irrigation.
Why Choose Wyze for Your Smart Sprinkler Needs?
Wyze combines affordability, smart technology, and water conservation in one easy-to-use system. Whether you want to remotely control your sprinklers, save water with weather-based schedules, or protect your investment with a weatherproof enclosure, Wyze has you covered.
Save water, save money, and keep your lawn healthy with Wyze’s smart sprinkler solutions.
Summary of Products for Water Saving Smart Sprinkler Control
Wyze Sprinkler Controller Wyze Sprinkler Plus (Service Subscription) Wyze Weatherproof Sprinkler Controller Box (Refurbished) Wyze Sprinkler Controller
Optimize your lawn irrigation with Wyze’s smart sprinkler controller and Sprinkler Plus service — the perfect combination for water savings, convenience, and greener living.
FeatureWyze Sprinkler ControllerWyze Sprinkler PlusWyze Weatherproof Sprinkler Controller Box(Refurbished) Wyze Sprinkler Controller
TypeConnected HomeService SubscriptionAccessoriesRefurbished
Price$59.99 (Sold out)$9.99/year$39.99$24.99
Zones SupportedUp to 8 irrigation zonesN/A (Service for Controller)N/AUp to 8 irrigation zones
Weather-Based WateringYes, with Sprinkler Plus (1 year free included)Yes, unlocks weather-based watering featuresN/AYes, with Sprinkler Plus (1 year free included)
WaterSense CertifiedYesN/AN/ANo
Installation TimeDIY, approx. 20 minutesN/AN/ADIY, approx. 20 minutes
Remote ControlYes, via Wyze appYes, via Wyze appN/AYes, via Wyze app
Customizable SchedulesYesYesN/AYes
Weather SkipsYes, intelligent weather skips with Sprinkler PlusYes, intelligent weather skipsN/AYes, intelligent weather skips with Sprinkler Plus
CompatibilityMost residential irrigation systems in North AmericaRequires Wyze Sprinkler ControllerCompatible only with Wyze Sprinkler ControllerMost residential irrigation systems in North America
Power OptionsRequires power to operate irrigation systemN/AHardwire or outdoor outlet powerRequires power to operate irrigation system
Weatherproof RatingNot specifiedN/AIP65 (fully weatherproof)Not specified
Durability FeaturesN/AN/A4 clasps, gridded coverN/A
Additional Features1 Year Sprinkler Plus subscription includedSubscription service for advanced featuresOutdoor mounting box for controllerWeather-based watering enabled with Sprinkler Plus
AvailabilitySold outAvailableAvailableAvailable
What is the Wyze Sprinkler Controller and how does it work?The Wyze Sprinkler Controller is an 8-zone WiFi-enabled smart irrigation device that allows you to control your lawn’s watering schedule from anywhere using the Wyze app. It replaces traditional sprinkler timers and adapts watering based on your lifestyle and local weather conditions for efficient, eco-friendly lawn care.
How does the Wyze Sprinkler Plus service enhance my irrigation system?Wyze Sprinkler Plus is a subscription service that adds intelligent, weather-based features to your Wyze Sprinkler Controller. It automatically adjusts watering schedules using hyper-local weather data, skips watering during rain or high moisture, and provides advanced yard insights to help conserve water and protect your plants.
What are the main features of the Wyze Sprinkler Controller?Key features include 8 customizable irrigation zones, remote control via the Wyze app, EPA WaterSense certification for water-saving schedules, easy DIY installation in under 20 minutes, and integration with Wyze Cam for monitoring and notifications.
Is the Wyze Sprinkler Controller easy to install?Yes, the Wyze Sprinkler Controller is designed for easy DIY installation. Most users can replace their existing controller and set up the new system in under 20 minutes without professional help.
How does weather-based watering with Sprinkler Plus save water?Sprinkler Plus uses real-time, hyper-local weather data to automatically adjust your watering schedule. It skips watering during rain or when soil moisture is high, preventing overwatering and reducing water waste while keeping your lawn healthy.
What is included with the purchase of a Wyze Sprinkler Controller?Each Wyze Sprinkler Controller purchase includes the device itself and a free 1-year subscription to the Sprinkler Plus service, enabling weather-based smart watering features.
Can I control my Wyze Sprinkler Controller remotely?Yes, you can start, stop, or adjust your watering schedules anytime and from anywhere using the Wyze app on your smartphone.
What is the Wyze Weatherproof Sprinkler Controller Box?The Wyze Weatherproof Sprinkler Controller Box is a durable, IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from rain, dust, and harsh outdoor conditions. It supports both hardwired and outdoor outlet power sources and is exclusively compatible with the Wyze Sprinkler Controller.
Is there an affordable option for smart irrigation with Wyze?Yes, the (Refurbished) Wyze Sprinkler Controller offers the same smart features as the new model at a lower price. It supports up to 8 zones, includes a free 1-year Sprinkler Plus subscription, and is compatible with most residential irrigation systems.
What are the benefits of choosing Wyze for smart sprinkler control?Wyze offers an affordable, easy-to-use smart sprinkler system that helps you save water, reduce utility costs, and maintain a healthy lawn. With features like remote control, weather-based scheduling, and weatherproof protection, Wyze provides a comprehensive solution for efficient lawn irrigation.
Is the Wyze Sprinkler Controller compatible with most residential irrigation systems?Yes, the Wyze Sprinkler Controller works with most residential irrigation systems, including those with master valves or pump relays.
How does Wyze Sprinkler Controller help with water conservation?The Wyze Sprinkler Controller, especially when paired with Sprinkler Plus, uses weather-based schedules to water only when necessary, helping to save water, prevent overwatering, and reduce your utility bills.
Can you explain how the Wyze Sprinkler Plus service enhances the functionality of the sprinkler controller?What are the key features of the Wyze Sprinkler Controller?Do you have any ongoing sales or discounts for the Wyze Sprinkler Controller?
