Enhance Your Home Security with Video Doorbell and Lock Bolt Kit
When it comes to securing your home, combining a reliable video doorbell with a smart lock bolt kit offers unmatched convenience and peace of mind. Whether you want to see who’s at your door in vibrant color even at night or unlock your door effortlessly with a fingerprint, these smart devices bring modern technology right to your doorstep.
Wyze Video Doorbell v2: Crisp 2K Video with Color Night Vision
Stunning Video Quality and Night Vision
The Wyze Video Doorbell v2 delivers crystal-clear 2K resolution (2048 x 1536) video, ensuring you never miss a detail. Equipped with a CMOS Starlight Sensor and 6 infrared LEDs, it provides vibrant color night vision, allowing you to see visitors clearly even in low-light conditions.
Smart Features for Ultimate Convenience
- Two-way audio: Speak directly to visitors or delivery personnel from anywhere using your smartphone.
- Real-time alerts: Receive instant notifications when motion is detected or someone rings the doorbell.
- Local microSD storage: Save video footage locally for quick access without relying solely on cloud storage.
- Wide field of view: With a 135° horizontal and 103° vertical field of view, monitor your porch comprehensively.
- Weather-resistant: Rated IP65, it withstands rain, snow, and extreme temperatures from -4°F to 122°F.
Seamless Integration
Compatible with Alexa, Google Assistant, and IFTTT, the Wyze Video Doorbell v2 fits perfectly into your smart home ecosystem.
Experience clear, color night vision with Wyze Video Doorbell v2.
Wyze Lock Bolt: Keyless Entry with Fingerprint and App Control
Ultra-Fast Fingerprint Reader & Backlit Keypad
Say goodbye to fumbling for keys. The Wyze Lock Bolt replaces your deadbolt with a sleek, solid metal smart lock featuring an ultra-fast fingerprint sensor and a luxurious backlit keypad for easy nighttime use.
Advanced Security Features
- Anti-peep technology: Enter extra digits before or after your code to prevent onlookers from guessing your passcode.
- Auto-lock: Set a timer in the Wyze app to automatically lock your door if you forget.
- Pick-proof and weatherproof: Completely keyless and built with IPX5 weatherproofing to endure outdoor conditions.
- Long battery life: Powered by 4 AA batteries lasting up to 12 months, with a USB-C port for emergency charging.
Convenient App Control
Control your lock remotely via Bluetooth with the Wyze app. Create and manage up to 20 access codes and 50 fingerprints for family and guests. The app also logs lock/unlock history and alerts you to failed attempts.
Easy Installation and Stylish Design
Compatible with most exterior doors, the Wyze Lock Bolt installs in about 20 minutes and comes in Matte Black or Satin Nickel finishes to complement your home’s exterior.
Secure your home with Wyze Lock Bolt’s fingerprint access and sleek design.
The Front Porch Security Bundle: Complete Smart Home Protection
All-in-One Security Solution
For those seeking a comprehensive package, the Front Porch Security Bundle combines the Wyze Video Doorbell and Wyze Lock Bolt for seamless front door security.
- 1080p HD video with two-way audio lets you monitor and communicate with visitors.
- Remote lock/unlock capability keeps your home secure from anywhere.
- Motion event and lock history tracking in the Wyze app enhances awareness.
- Voice assistant compatibility with Alexa and Google Assistant for hands-free control.
This bundle is perfect for homeowners wanting an integrated, easy-to-manage security system.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning smoothly, replacement parts are available:
- Wyze Lock Bolt Screws: Secure your lock firmly with replacement screws.
- Interior Assembly Battery Cover: Protect the battery compartment with a durable cover.
- Interior Assembly Metal Plate: Anchor the interior assembly securely to your door.
These parts ensure your smart lock remains reliable and easy to maintain.
Protect your home day and night with the perfect combination of Wyze Video Doorbell v2’s color night vision and the Wyze Lock Bolt’s advanced keyless security. Experience convenience, safety, and smart home integration all in one.
Product Summary
Product | Key Features |
Wyze Video Doorbell v2 | 2K video, color night vision, two-way audio, IP65 weatherproof |
Wyze Lock Bolt | Fingerprint unlock, backlit keypad, auto-lock, pick-proof, weatherproof |
Front Porch Security Bundle | Combines doorbell and lock, remote control, voice assistant compatible |
What are the main features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 offers 2K resolution video (2048 x 1536), vibrant color night vision with a CMOS Starlight Sensor, two-way audio, real-time motion alerts, local microSD storage, a wide 135° horizontal and 103° vertical field of view, and IP65 weather resistance. It also integrates seamlessly with Alexa, Google Assistant, and IFTTT.How does the Wyze Lock Bolt enhance home security?
The Wyze Lock Bolt provides keyless entry with an ultra-fast fingerprint reader and a backlit keypad. It features anti-peep technology, auto-lock functionality, pick-proof and weatherproof design (IPX5), long battery life (up to 12 months), and Bluetooth app control for managing access codes and fingerprints. It also logs lock/unlock history and alerts you to failed attempts.Can I control the Wyze Lock Bolt remotely?
Yes, you can control the Wyze Lock Bolt remotely via Bluetooth using the Wyze app. The app allows you to create and manage up to 20 access codes and 50 fingerprints, view lock/unlock history, and receive alerts for failed attempts.Is the Wyze Video Doorbell v2 compatible with smart home systems?
Yes, the Wyze Video Doorbell v2 is compatible with popular smart home systems, including Alexa, Google Assistant, and IFTTT, allowing for easy integration and hands-free control.What is included in the Front Porch Security Bundle?
The Front Porch Security Bundle includes the Wyze Video Doorbell and Wyze Lock Bolt, providing 1080p HD video with two-way audio, remote lock/unlock capability, motion event and lock history tracking in the Wyze app, and voice assistant compatibility for a complete smart home security solution.How easy is it to install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy installation and is compatible with most exterior doors. It can typically be installed in about 20 minutes and comes in Matte Black or Satin Nickel finishes to match your home’s exterior.What replacement parts are available for the Wyze Lock Bolt?
Replacement parts for the Wyze Lock Bolt include Wyze Lock Bolt Screws, an Interior Assembly Battery Cover, and an Interior Assembly Metal Plate. These parts help maintain the lock’s reliability and ease of use.Does the Wyze Video Doorbell v2 work in extreme weather conditions?
Yes, the Wyze Video Doorbell v2 is rated IP65 weather-resistant and can operate in temperatures ranging from -4°F to 122°F, making it suitable for various weather conditions including rain and snow.How does the Wyze Lock Bolt’s anti-peep technology work?
The Wyze Lock Bolt’s anti-peep technology allows you to enter extra digits before or after your actual code on the keypad, preventing onlookers from guessing your passcode and enhancing security.What is the battery life of the Wyze Lock Bolt and how is it powered?
The Wyze Lock Bolt is powered by 4 AA batteries, which can last up to 12 months. It also features a USB-C port for emergency charging if the batteries run out.
