Best Video Doorbells with App-Based Two-Way Audio and Noise Cancellation
If you're searching for a
video doorbell with app-based two-way audio and noise cancellation, Wyze offers some of the most advanced and affordable smart doorbells on the market. Whether you want wired or battery-powered options, crystal-clear video, or intelligent AI detections, Wyze has you covered. This page highlights the top Wyze video doorbells, including the
Wyze Duo Cam Doorbell,
Wyze Video Doorbell v2, and
Wyze Video Doorbell Pro, all designed to keep your home safe and connected.
Wyze Duo Cam Battery Doorbell: Dual Cameras & Advanced Audio
Wyze Duo Cam Doorbell installed on a modern home porch
The
Wyze Duo Cam Battery Doorbell is Wyze’s most advanced battery-powered video doorbell, perfect for those who want comprehensive coverage and superior audio quality with noise cancellation.
Key Features:
- Dual Camera Views: Front camera captures 2K (2048 x 1536) resolution video with a wide 132° horizontal field of view, while the bottom camera covers packages with 1080p resolution and 121° horizontal view.
- Two-Way Audio with Noise Cancellation: Communicate clearly with visitors using the built-in microphone and speaker, enhanced by noise cancellation for crisp conversations.
- Motion-Activated Voice Deterrence: Automatically warns visitors with a voice prompt, "Hi, you’re currently being recorded," to deter unwanted activity.
- Local and Cloud Storage: Supports up to 256GB microSD card for 24/7 local recording and cloud storage options.
- Battery or Hardwired Power: Comes with a removable battery pack and can be hardwired for continuous power.
- Weather Resistant: IP65 rating ensures reliable performance in all weather conditions.
- Smart AI Detections: Real-time alerts for people, packages, and vehicles with AI-powered notifications.
- Integrations: Works seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
This doorbell includes the Wyze Wi-Fi Chime for instant alerts inside your home and a USB-C charging cable for easy battery recharging.
Wyze Video Doorbell v2: Wired 2K Video with Local Storage
Wyze Video Doorbell v2 mounted on a front porch with chime controller
The
Wyze Video Doorbell v2 is a wired doorbell that delivers crystal-clear 2K video and includes local microSD storage, making it a reliable choice for detailed porch monitoring.
Highlights:
- 2K HD Video: Capture every detail with head-to-toe viewing and 2K resolution.
- Two-Way Audio: Talk to visitors instantly through the Wyze app with noise and echo cancellation for clear communication.
- Motion-Activated Voice Deterrence: Scare off suspicious visitors with automated voice alerts.
- Local microSD Storage: Continuous 24/7 recording with onboard microSD card slot (card sold separately).
- Works with Existing Chime: Includes a chime controller so you can keep your traditional doorbell sound.
- Pre-Roll Motion Recording: Captures 3-6 seconds before motion events for full context.
- Weatherproof: IP65 rating for all-weather durability.
- Smart Notifications: With Cam Plus subscription, get person, package, and vehicle detection alerts.
- Smart Home Compatible: Works with Alexa and Google Home for voice commands and live feed viewing.
The package includes a 30° corner mounting wedge to optimize your doorbell’s viewing angle.
Wyze Video Doorbell Pro: Wired or Wireless with Ultra-Wide View
Wyze Video Doorbell Pro installed on a front porch with glowing security light
The
Wyze Video Doorbell Pro offers the flexibility of wired or wireless installation with a battery backup, making it ideal for quick setup and versatile use.
Features:
- HD Video with Ultra-Wide Angle: See your entire porch and beyond with a head-to-toe, ultra-wide viewing angle.
- Two-Way Audio with Noise Cancellation: Communicate clearly with visitors using the Wyze app.
- Motion-Activated Security Light: A blue light around the doorbell button glows when motion is detected, alerting visitors they are on camera.
- Fast Notifications: Includes a dual-band Wi-Fi Extender chime for lightning-fast alerts and battery conservation.
- Preset Quick Responses: Use pre-recorded messages like "Be there shortly" or "Leave the package at the door" for convenience.
- Customizable Chimes: Choose from 20 unique tunes and 8 volume levels, including dog barks to deter intruders.
- Smart AI Alerts: With Cam Plus, get person, package, vehicle, and pet detection notifications.
- Smart Home Integration: Compatible with Alexa and Google Assistant for voice control and live feed display.
- Easy Installation: Screw or adhesive mount, install in 30 seconds.
Why Choose Wyze Video Doorbells?
Wyze video doorbells combine high-resolution video, intelligent AI detections, and crystal-clear two-way audio with noise cancellation to provide a secure and convenient home monitoring experience. Whether you prefer wired or battery-powered options, Wyze offers solutions that fit your lifestyle and budget.
With Wyze, you get:
- Advanced noise cancellation for clear communication.
- Real-time alerts and motion-activated voice deterrence.
- Local and cloud storage options.
- Seamless integration with popular smart home ecosystems.
- Durable, weather-resistant designs built to last.
Enhance Your Setup: Front Porch Security Bundle
For a complete smart home security experience, consider the
Front Porch Security Bundle which pairs the Wyze Video Doorbell with Wyze Lock and Wyze Chime. This bundle lets you view your porch in HD, talk to visitors, and remotely lock or unlock your door — all from the Wyze app.
Summary of Wyze Video Doorbells with Two-Way Audio & Noise Cancellation
Product | Power Type | Video Resolution | Key Features | Price Range |
Wyze Duo Cam Battery Doorbell | Battery / Wired | Front: 2K / Bottom: 1080p | Dual cameras, AI alerts, voice deterrence, local storage | Mid-range |
Wyze Video Doorbell v2 | Wired | 2K | Local microSD storage, motion pre-roll, chime controller | Budget-friendly |
Wyze Video Doorbell Pro | Wired / Battery | HD Ultra-wide | Fast notifications, security light, quick responses | Premium |
Protect your home with Wyze’s smart video doorbells featuring app-based two-way audio and noise cancellation — the perfect combination for clear communication and enhanced security.
What are the best Wyze video doorbells with app-based two-way audio and noise cancellation?
The top Wyze video doorbells featuring app-based two-way audio and noise cancellation are the Wyze Duo Cam Battery Doorbell, Wyze Video Doorbell v2, and Wyze Video Doorbell Pro. Each model offers clear communication, advanced security features, and seamless integration with smart home systems.How does noise cancellation work on Wyze video doorbells?
Wyze video doorbells use built-in microphones and speakers with advanced noise cancellation technology. This feature filters out background noise, ensuring that conversations with visitors are crisp and clear, even in noisy outdoor environments.What is the difference between the Wyze Duo Cam Battery Doorbell, Wyze Video Doorbell v2, and Wyze Video Doorbell Pro?
The Wyze Duo Cam Battery Doorbell features dual cameras (2K front and 1080p bottom), battery or wired power, and advanced AI alerts. The Wyze Video Doorbell v2 is a wired-only model with 2K video, local microSD storage, and motion pre-roll. The Wyze Video Doorbell Pro offers wired or wireless installation, ultra-wide HD video, fast notifications, and customizable chimes.Can Wyze video doorbells be used with Alexa or Google Assistant?
Yes, all featured Wyze video doorbells are compatible with Alexa and Google Assistant. This allows you to use voice commands, view live feeds, and integrate your doorbell with other smart home devices.Do Wyze video doorbells support local and cloud storage?
Yes, Wyze video doorbells support both local and cloud storage options. Models like the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell v2 have microSD card slots for 24/7 local recording, while cloud storage is available for event-based recordings and advanced AI features.Are Wyze video doorbells weather resistant?
All Wyze video doorbells are designed with weather resistance in mind, featuring an IP65 rating. This ensures reliable performance in various weather conditions, including rain and dust.What smart security features do Wyze video doorbells offer?
Wyze video doorbells provide smart AI detections for people, packages, vehicles, and pets (with Cam Plus subscription), motion-activated voice deterrence, and real-time alerts. Some models also include security lights and customizable chimes to enhance your home’s security.How easy is it to install a Wyze video doorbell?
Wyze video doorbells are designed for easy installation. The Wyze Video Doorbell Pro, for example, can be installed in as little as 30 seconds using either screws or adhesive mounts. Other models offer both wired and battery-powered options for flexible setup.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell, Wyze Lock, and Wyze Chime. This bundle allows you to monitor your porch in HD, communicate with visitors, and remotely lock or unlock your door using the Wyze app.Do Wyze video doorbells offer motion-activated voice deterrence?
Yes, Wyze video doorbells feature motion-activated voice deterrence. When motion is detected, the doorbell can automatically play a voice prompt, such as 'Hi, you’re currently being recorded,' to deter unwanted activity.
