Versatile Wyze Solar Panel Mounts for Any Surface & Battery Cam
Versatile Mounting Solutions for Wyze Solar Panels on Diverse Surfaces
When it comes to extending the battery life of your Wyze Battery Cam Pro or Wyze Cam Outdoor, the Wyze Battery Cam Solar Panel is an essential accessory. Designed with versatility and durability in mind, this solar panel offers multiple mounting options to fit a variety of surfaces, ensuring your camera stays powered longer without frequent recharging.
Wyze Battery Cam Solar Panel: Power Anywhere, Weather Resistant
The Wyze Battery Cam Solar Panel is crafted to be weather resistant, making it ideal for outdoor use in all seasons. Its white frame and black solar cells blend seamlessly with most outdoor environments, while the included mount allows for flexible installation on surfaces such as walls, poles, or even RVs.
  • Compatibility: Works with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro.
  • Mounting Flexibility: Designed to be mountable anywhere, including uneven or challenging surfaces.
  • Weather Resistance: Built to withstand rain, sun, and other outdoor elements.
  • Power Source: Solar energy to extend camera battery life continuously.
This solar panel is perfect for users who want a hassle-free, eco-friendly way to keep their cameras running without the need for frequent battery swaps or wired power. Outdoor security camera mounted with solar panel Alt text: Wyze Battery Cam Pro with solar panel mounted outdoors on a wooden post
Wyze Battery Cam Pro + Solar Panel: Integrated Power and Performance
For those seeking an all-in-one solution, the Wyze Battery Cam Pro + Solar Panel bundle offers a powerful 2.5K HDR video resolution camera paired with the solar panel accessory. This combination ensures your security system is both high-quality and self-sustaining.
  • Video Quality: 2.5K HDR for crystal-clear footage.
  • Wireless Convenience: No hub required, supports 2.4 & 5GHz WiFi.
  • Integrated Features: Spotlight, siren, radar, and PIR motion detection.
  • Weatherproof: IP65 rating for reliable outdoor use.
  • Battery: Removable, rechargeable packs supported by solar charging.
This bundle is ideal for users who want to maximize security coverage with minimal maintenance, leveraging solar power to keep the camera operational day and night.
Mounting Options for Diverse Surfaces
The Wyze Battery Cam Solar Panel’s mount is designed for versatility, allowing installation on a wide range of surfaces:
  • Walls and Fences: Secure the panel on flat or textured walls for optimal sun exposure.
  • Poles and Trees: Use adjustable mounts to attach the panel to poles or tree trunks.
  • RV and Mobile Surfaces: Perfect for mounting on RVs or other mobile setups where power outlets are limited.
  • Windows (with Wyze Window Mount): For cameras mounted on glass surfaces, the Wyze Window Mount accessory allows glare-free installation of Wyze Cam models, complementing solar panel setups by providing flexible camera placement.
“The ability to mount the solar panel almost anywhere means you can tailor your security setup to your environment without compromise.”
Wyze Battery Cam Pro mounted on a window with window mount Alt text: Wyze Battery Cam Pro installed on a window using the Wyze Window Mount accessory
Why Choose Wyze Solar Panel Solutions?
  • Extended Battery Life: Keep your Wyze Battery Cam Pro running longer without manual recharging.
  • Eco-Friendly Power: Harness solar energy to reduce reliance on electrical outlets.
  • Weatherproof and Durable: Designed to withstand outdoor conditions year-round.
  • Easy Installation: Mount on a variety of surfaces with included hardware.
  • Seamless Compatibility: Works with multiple Wyze camera models for flexible security setups.
Family enjoying outdoor security with Wyze cameras Alt text: Family monitoring their home security with Wyze cameras outdoors
Product Highlights
  • Weather resistant and mountable anywhere
  • Compatible with Wyze Cam Outdoor v1/v2 and Battery Cam Pro
  • White frame with black solar cells for aesthetic appeal
  • Price: $24.99
Wyze Battery Cam Pro + Solar Panel Bundle
  • 2.5K HDR video resolution
  • Integrated spotlight, siren, radar, and PIR motion detection
  • IP65 weatherproof rating
  • Supports 2.4 & 5GHz WiFi
  • Price: $109.98
Wyze Window Mount
  • Mount Wyze Cam v3/v3 Pro/v4 and OG series on glass surfaces
  • Reduces glare and reflection for clearer views
  • Price: $9.98
Enhance your Wyze security system with versatile, weatherproof solar panel mounting solutions that keep your cameras powered and your home protected—no matter the surface or environment.
What Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro, providing continuous solar-powered charging for these models.
Is the Wyze Battery Cam Solar Panel weather resistant for outdoor use?Yes, the Wyze Battery Cam Solar Panel is designed to be weather resistant, withstanding rain, sun, and other outdoor elements, making it ideal for year-round outdoor installation.
What surfaces can I mount the Wyze Battery Cam Solar Panel on?The Wyze Battery Cam Solar Panel offers versatile mounting options, allowing installation on walls, fences, poles, trees, RVs, and other mobile surfaces. Its flexible mount ensures secure attachment even on uneven or challenging surfaces.
How does the Wyze Battery Cam Solar Panel help extend camera battery life?The Wyze Battery Cam Solar Panel harnesses solar energy to continuously charge your Wyze camera’s battery, reducing the need for frequent manual recharging and ensuring your camera stays powered longer.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes a 2.5K HDR video resolution camera and a weatherproof solar panel. The camera features integrated spotlight, siren, radar, PIR motion detection, and supports both 2.4GHz and 5GHz WiFi.
Can I use the Wyze Window Mount with my Wyze camera and solar panel setup?Yes, the Wyze Window Mount allows you to install Wyze Cam v3, v3 Pro, v4, and OG series cameras on glass surfaces, reducing glare and reflection. This accessory complements solar panel setups by providing flexible camera placement on windows.
Is the Wyze Battery Cam Pro + Solar Panel bundle weatherproof?Yes, the Wyze Battery Cam Pro + Solar Panel bundle is rated IP65 weatherproof, ensuring reliable performance in various outdoor conditions.
What are the main benefits of using Wyze solar panel solutions for security cameras?Wyze solar panel solutions offer extended battery life, eco-friendly solar power, weatherproof durability, easy installation on diverse surfaces, and seamless compatibility with multiple Wyze camera models.
How much does the Wyze Battery Cam Solar Panel cost?The Wyze Battery Cam Solar Panel is priced at $24.99, offering an affordable and eco-friendly way to keep your Wyze cameras powered.
What is the price of the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle is available for $109.98, providing a high-quality camera and solar charging solution in one package.
How much does the Wyze Window Mount cost?The Wyze Window Mount is priced at $9.98 and is designed to help you mount compatible Wyze cameras on glass surfaces for clearer, glare-free views.
What are the different surfaces I can mount the Wyze Battery Cam Solar Panel on?Can the Wyze Battery Cam Solar Panel be used in all weather conditions?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Solar Panel?
